path: root/include/linux/jbd.h
2012-01-09jbd: Remove j_barrier mutexJan Kara
j_barrier mutex is used for serializing different journal lock operations. The problem with it is that e.g. FIFREEZE ioctl results in process leaving kernel with j_barrier mutex held which makes lockdep freak out. Also hibernation code wants to freeze filesystem but it cannot do so because it then cannot hibernate the system because of mutex being locked. So we remove j_barrier mutex and use direct wait on j_barrier_count instead. Since locking journal is a rare operation we don't have to care about fairness or such things. CC: Andrew Morton <akpm@linux-foundation.org> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Jan Kara <jack@suse.cz>
2011-11-22jbd: clear revoked flag on buffers before a new transaction startedYongqiang Yang
Currently, we clear revoked flag only when a block is reused. However, this can tigger a false journal error. Consider a situation when a block is used as a meta block and is deleted(revoked) in ordered mode, then the block is allocated as a data block to a file. At this moment, user changes the file's journal mode from ordered to journaled and truncates the file. The block will be considered re-revoked by journal because it has revoked flag still pending from the last transaction and an assertion triggers. We fix the problem by keeping the revoked status more uptodate - we clear revoked flag when switching revoke tables to reflect there is no revoked buffers in current transaction any more. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-10-27jdb/jbd2: factor out common functions from the jbd[2] header filesThomas Gleixner
The state bits and the lock functions of jbd and jbd2 are identical. Share them. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-27jbd: Fix oops in journal_remove_journal_head()Jan Kara
journal_remove_journal_head() can oops when trying to access journal_head returned by bh2jh(). This is caused for example by the following race: TASK1 TASK2 journal_commit_transaction() ... processing t_forget list __journal_refile_buffer(jh); if (!jh->b_transaction) { jbd_unlock_bh_state(bh); journal_try_to_free_buffers() journal_grab_journal_head(bh) jbd_lock_bh_state(bh) __journal_try_to_free_buffer() journal_put_journal_head(jh) journal_remove_journal_head(bh); journal_put_journal_head() in TASK2 sees that b_jcount == 0 and buffer is not part of any transaction and thus frees journal_head before TASK1 gets to doing so. Note that even buffer_head can be released by try_to_free_buffers() after journal_put_journal_head() which adds even larger opportunity for oops (but I didn't see this happen in reality). Fix the problem by making transactions hold their own journal_head reference (in b_jcount). That way we don't have to remove journal_head explicitely via journal_remove_journal_head() and instead just remove journal_head when b_jcount drops to zero. The result of this is that [__]journal_refile_buffer(), [__]journal_unfile_buffer(), and __journal_remove_checkpoint() can free journal_head which needs modification of a few callers. Also we have to be careful because once journal_head is removed, buffer_head might be freed as well. So we have to get our own buffer_head reference where it matters. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21jbd: Provide function to check whether transaction will issue data barrierJan Kara
Provide a function which returns whether a transaction with given tid will send a barrier to the filesystem device. The function will be used by ext3 to detect whether fsync needs to send a separate barrier or not. Signed-off-by: Jan Kara <jack@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05jbd[2]: remove references to BUFFER_DEBUGChristoph Egger
CONFIG_BUFFER_DEBUG seems to have been removed from the documentation somewhere around 2.4.15 and seemingly hasn't been available even longer. It is, however, still referenced at one place from the jbd code (one is a copy of the other header). Time to clean it up Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-23jbd.h: bitfields should be unsignedH Hartley Sweeten
bitfields should be unsigned. This fixes sparse noise: error: dubious one-bit signed bitfield Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Jan Kara <jack@ucw.cz> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16jbd: Journal block numbers can ever be only 32-bit use unsigned int for themJan Kara
It does not make sense to store block number for journal as unsigned long since they can be only 32-bit (because of on-disk format limitation). So change in-memory structures and variables to use unsigned int instead. Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-14jbd: use SWRITE_SYNC_PLUG when writing synchronous revoke recordsTheodore Ts'o
The revoke records must be written using the same way as the rest of the blocks during the commit process; that is, either marked as synchronous writes or as asynchornous writes. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-03-30trivial: jbd header comment typo fix for JBD_PARANOID_IOFAILKazuo Moriwaka
jbd header comment typo fix. Signed-off-by: Kazuo Moriwaka <moriwaka@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-27ext3: Use WRITE_SYNC for commits which are caused by fsync()Theodore Ts'o
If a commit is triggered by fsync(), set a flag indicating the journal blocks associated with the transaction should be flushed out using WRITE_SYNC. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz>
2009-01-15jbd: fix missing kernel-docRandy Dunlap
Fix jbd header file kernel-doc notation: Warning(linux-2.6.28-git13//include/linux/jbd.h:823): No description found for parameter 'j_average_commit_time' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08jbd: improve fsync batchingJosef Bacik
There is a flaw with the way jbd handles fsync batching. If we fsync() a file and we were not the last person to run fsync() on this fs then we automatically sleep for 1 jiffie in order to wait for new writers to join into the transaction before forcing the commit. The problem with this is that with really fast storage (ie a Clariion) the time it takes to commit a transaction to disk is way faster than 1 jiffie in most cases, so sleeping means waiting longer with nothing to do than if we just committed the transaction and kept going. Ric Wheeler noticed this when using fs_mark with more than 1 thread, the throughput would plummet as he added more threads. This patch attempts to fix this problem by recording the average time in nanoseconds that it takes to commit a transaction to disk, and what time we started the transaction. If we run an fsync() and we have been running for less time than it takes to commit the transaction to disk, we sleep for the delta amount of time and then commit to disk. We acheive sub-jiffie sleeping using schedule_hrtimeout. This means that the wait time is auto-tuned to the speed of the underlying disk, instead of having this static timeout. I weighted the average according to somebody's comments (Andreas Dilger I think) in order to help normalize random outliers where we take way longer or way less time to commit than the average. I also have a min() check in there to make sure we don't sleep longer than a jiffie in case our storage is super slow, this was requested by Andrew. I unfortunately do not have access to a Clariion, so I had to use a ramdisk to represent a super fast array. I tested with a SATA drive with barrier=1 to make sure there was no regression with local disks, I tested with a 4 way multipathed Apple Xserve RAID array and of course the ramdisk. I ran the following command fs_mark -d /mnt/ext3-test -s 4096 -n 2000 -D 64 -t $i where $i was 2, 4, 8, 16 and 32. I mkfs'ed the fs each time. Here are my results type threads with patch without patch sata 2 24.6 26.3 sata 4 49.2 48.1 sata 8 70.1 67.0 sata 16 104.0 94.1 sata 32 153.6 142.7 xserve 2 246.4 222.0 xserve 4 480.0 440.8 xserve 8 829.5 730.8 xserve 16 1172.7 1026.9 xserve 32 1816.3 1650.5 ramdisk 2 2538.3 1745.6 ramdisk 4 2942.3 661.9 ramdisk 8 2882.5 999.8 ramdisk 16 2738.7 1801.9 ramdisk 32 2541.9 2394.0 Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ric Wheeler <rwheeler@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: fix error handling for checkpoint ioHidehiro Kawai
When a checkpointing IO fails, current JBD code doesn't check the error and continue journaling. This means latest metadata can be lost from both the journal and filesystem. This patch leaves the failed metadata blocks in the journal space and aborts journaling in the case of log_do_checkpoint(). To achieve this, we need to do: 1. don't remove the failed buffer from the checkpoint list where in the case of __try_to_free_cp_buf() because it may be released or overwritten by a later transaction 2. log_do_checkpoint() is the last chance, remove the failed buffer from the checkpoint list and abort the journal 3. when checkpointing fails, don't update the journal super block to prevent the journaled contents from being cleaned. For safety, don't update j_tail and j_tail_sequence either 4. when checkpointing fails, notify this error to the ext3 layer so that ext3 don't clear the needs_recovery flag, otherwise the journaled contents are ignored and cleaned in the recovery phase 5. if the recovery fails, keep the needs_recovery flag 6. prevent cleanup_journal_tail() from being called between __journal_drop_transaction() and journal_abort() (a race issue between journal_flush() and __log_wait_for_space() Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20ext3: add an option to control error handling on file dataHidehiro Kawai
If the journal doesn't abort when it gets an IO error in file data blocks, the file data corruption will spread silently. Because most of applications and commands do buffered writes without fsync(), they don't notice the IO error. It's scary for mission critical systems. On the other hand, if the journal aborts whenever it gets an IO error in file data blocks, the system will easily become inoperable. So this patch introduces a filesystem option to determine whether it aborts the journal or just call printk() when it gets an IO error in file data. If you mount a ext3 fs with data_err=abort option, it aborts on file data write error. If you mount it with data_err=ignore, it doesn't abort, just call printk(). data_err=ignore is the default. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16include: replace __FUNCTION__ with __func__Harvey Harrison
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-03-19fs: fix kernel-doc notation warningsRandy Dunlap
Fix kernel-doc notation warnings in fs/. Warning(mmotm-2008-0314-1449//fs/super.c:560): missing initial short description on line: * mark_files_ro Warning(mmotm-2008-0314-1449//fs/locks.c:1277): missing initial short description on line: * lease_get_mtime Warning(mmotm-2008-0314-1449//fs/locks.c:1277): missing initial short description on line: * lease_get_mtime Warning(mmotm-2008-0314-1449//fs/namei.c:1368): missing initial short description on line: * lookup_one_len: filesystem helper to lookup single pathname component Warning(mmotm-2008-0314-1449//fs/buffer.c:3221): missing initial short description on line: * bh_uptodate_or_lock: Test whether the buffer is uptodate Warning(mmotm-2008-0314-1449//fs/buffer.c:3240): missing initial short description on line: * bh_submit_read: Submit a locked buffer for reading Warning(mmotm-2008-0314-1449//fs/fs-writeback.c:30): missing initial short description on line: * writeback_acquire: attempt to get exclusive writeback access to a device Warning(mmotm-2008-0314-1449//fs/fs-writeback.c:47): missing initial short description on line: * writeback_in_progress: determine whether there is writeback in progress Warning(mmotm-2008-0314-1449//fs/fs-writeback.c:58): missing initial short description on line: * writeback_release: relinquish exclusive writeback access against a device. Warning(mmotm-2008-0314-1449//include/linux/jbd.h:351): contents before sections Warning(mmotm-2008-0314-1449//include/linux/jbd.h:561): contents before sections Warning(mmotm-2008-0314-1449//fs/jbd/transaction.c:1935): missing initial short description on line: * void journal_invalidatepage() Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06jbd.h: hide kernel only codeOlaf Hering
Move a few kernel-only things into __KERNEL__. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06make jbd/journal.c:__journal_abort_hard() staticAdrian Bunk
__journal_abort_hard() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05jbd: Fix assertion failure in fs/jbd/checkpoint.cJan Kara
Before we start committing a transaction, we call __journal_clean_checkpoint_list() to cleanup transaction's written-back buffers. If this call happens to remove all of them (and there were already some buffers), __journal_remove_checkpoint() will decide to free the transaction because it isn't (yet) a committing transaction and soon we fail some assertion - the transaction really isn't ready to be freed :). We change the check in __journal_remove_checkpoint() to free only a transaction in T_FINISHED state. The locking there is subtle though (as everywhere in JBD ;(). We use j_list_lock to protect the check and a subsequent call to __journal_drop_transaction() and do the same in the end of journal_commit_transaction() which is the only place where a transaction can get to T_FINISHED state. Probably I'm too paranoid here and such locking is not really necessary - checkpoint lists are processed only from log_do_checkpoint() where a transaction must be already committed to be processed or from __journal_clean_checkpoint_list() where kjournald itself calls it and thus transaction cannot change state either. Better be safe if something changes in future... Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19jbd: config_jbd_debug cannot create /proc entryJose R. Santos
The jbd-debug file used to be located in /proc/sys/fs/jbd-debug, but create_proc_entry() does not do lookups on file names that are more that one directory deep. This causes the entry creation to fail and hence, no proc file is created. Instead of fixing this on procfs might as well move the jbd2-debug file to debugfs which would be the preferred location for this kind of tunable. The new location is now /sys/kernel/debug/jbd/jbd-debug. [akpm@linux-foundation.org: zillions of cleanups] Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19jbd: remove printk() from J_ASSERT macrosChris Snook
Remove printk from J_ASSERT to preserve registers during BUG. Signed-off-by: Chris Snook <csnook@redhat.com> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17JBD: replace jbd_kmalloc with kmalloc directlyMingming Cao
This patch cleans up jbd_kmalloc and replace it with kmalloc directly Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-10-17JBD: JBD slab allocation cleanupsMingming Cao
JBD: Replace slab allocations with page allocations JBD allocate memory for committed_data and frozen_data from slab. However JBD should not pass slab pages down to the block layer. Use page allocator pages instead. This will also prepare JBD for the large blocksize patchset. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-10-15docbook: fix filesystems contentRandy Dunlap
Fix filesystems docbook warnings. Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'name' Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'mode' Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'parent' Warning(linux-2.6.23-git8//fs/debugfs/file.c:241): No description found for parameter 'value' Warning(linux-2.6.23-git8//include/linux/jbd.h:404): No description found for parameter 'h_lockdep_map' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11lockdep: annotate journal_start()Peter Zijlstra
On Fri, 2007-07-13 at 02:05 -0700, Andrew Morton wrote: > Except lockdep doesn't know about journal_start(), which has ranking > requirements similar to a semaphore. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-12-07[PATCH] make fs/jbd/transaction.c:__journal_temp_unlink_buffer() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] JBD: Make journal_brelse_array() staticDave Kleikamp
It's always good to make symbols static when we can, and this also eliminates the need to rename the function in jbd2 Suggested by Eric Sandeen. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: More whitespace cleanupsDave Kleikamp
More white space cleanups in preparation of cloning ext4 from ext3. Removing spaces that precede a tab. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] JBD: 16T fixesEric Sandeen
These are a few places I've found in jbd that look like they may not be 16T-safe, or consistent with the use of unsigned longs for block containers. Problems here would be somewhat hard to hit, would require journal blocks past the 8T boundary, which would not be terribly common. Still, should fix. (some of these have come from the ext4 work on jbd as well). I think there's one more possibility that the wrap() function may not be safe IF your last block in the journal butts right up against the 232 block boundary, but that seems like a VERY remote possibility, and I'm not worrying about it at this point. Signed-off-by: Eric Sandeen <esandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] Manage jbd allocations from its own slabsBadari Pulavarty
JBD currently allocates commit and frozen buffers from slabs. With CONFIG_SLAB_DEBUG, its possible for an allocation to cross the page boundary causing IO problems. https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=200127 So, instead of allocating these from regular slabs - manage allocation from its own slabs and disable slab debug for these slabs. [akpm@osdl.org: cleanups] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] JBD: split checkpoint listsJan Kara
Split the checkpoint list of the transaction into two lists. In the first list we keep the buffers that need to be submitted for IO. In the second list are kept buffers that were already submitted and we just have to wait for the IO to complete. This should simplify a handling of checkpoint lists a bit and can eventually be also a performance gain. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: "Stephen C. Tweedie" <sct@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Make address_space_operations->invalidatepage return voidNeilBrown
The return value of this function is never used, so let's be honest and declare it as void. Some places where invalidatepage returned 0, I have inserted comments suggesting a BUG_ON. [akpm@osdl.org: JBD BUG fix] [akpm@osdl.org: rework for git-nfs] [akpm@osdl.org: don't go BUG in block_invalidate_page()] Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] jbd: embed j_commit_timer in journal structAndrew Morton
The kjournald timer is currently on the kernel thread's stack and the journal structure points at it. Save a pointer hop by moving the timer into the journal structure. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: jbd, j_checkpoint_mutexArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] jbd: revert checkpoint list changesMark Fasheh
This patch reverts commit f93ea411b73594f7d144855fd34278bcf34a9afc: [PATCH] jbd: split checkpoint lists This broke journal_flush() for OCFS2, which is its method of being sure that metadata is sent to disk for another node. And two related commits 8d3c7fce2d20ecc3264c8d8c91ae3beacdeaed1b and 43c3e6f5abdf6acac9b90c86bf03f995bf7d3d92 with the subjects: [PATCH] jbd: log_do_checkpoint fix [PATCH] jbd: remove_transaction fix These seem to be incremental bugfixes on the original patch and as such are no longer needed. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-05[PATCH] jbd: fix transaction batchingAndrew Morton
Ben points out that: When writing files out using O_SYNC, jbd's 1 jiffy delay results in a significant drop in throughput as the disk sits idle. The patch below results in a 4-5x performance improvement (from 6.5MB/s to ~24-30MB/s on my IDE test box) when writing out files using O_SYNC. So optimise the batching code by omitting it entirely if the process which is doing a sync write is the same as the one which did the most recent sync write. If that's true, we're unlikely to get any other processes joining the transaction. (Has been in -mm for ages - it took me a long time to get on to performance testing it) Numbers, on write-cache-disabled IDE: /usr/bin/time -p synctest -n 10 -uf -t 1 -p 1 dir-name Unpatched: 40 seconds Patched: 35 seconds Batching disabled: 35 seconds This is the problematic single-process-doing-fsync case. With multiple fsyncing processes the numbers are AFACIT unaltered by the patch. Aside: performance testing and instrumentation shows that the transaction batching almost doesn't help (testing with synctest -n 1 -uf -t 100 -p 10 dir-name on non-writeback-caching IDE). This is because by the time one process is running a synchronous commit, a bunch of other processes already have a transaction handle open, so they're all going to batch into the same transaction anyway. The batching seems to offer maybe 5-10% speedup with this workload, but I'm pretty sure it was more important than that when it was first developed 4-odd years ago... Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] jbd: split checkpoint listsJan Kara
Split the checkpoint list of the transaction into two lists. In the first list we keep the buffers that need to be submitted for IO. In the second list are kept buffers that were already submitted and we just have to wait for the IO to complete. This should simplify a handling of checkpoint lists a bit and can eventually be also a performance gain. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22compat-ioctl.c: fix compile with no CONFIG_JBDLinus Torvalds
The ext3 compat-ioctl translation wants to translate data structures that <linux/jbd.h> only declared when CONFIG_JBD was enabled. So make <linux/jbd.h> play nicely even when we don't actually end up using it. Acked-by: Andrew Morton <akpm@osdl.org> Acked-by: Jeffrey Hundstad <jeffrey.hundstad@mnsu.edu> Acked-by: Zan Lynx <zlynx@acm.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] jbd doc: fix some kernel-doc warningsRandy Dunlap
Add structure fields kernel-doc for 2 fields in struct journal_s. Warning(/var/linsrc/linux-2614-rc4//include/linux/jbd.h:808): No description found for parameter 'j_wbuf' Warning(/var/linsrc/linux-2614-rc4//include/linux/jbd.h:808): No description found for parameter 'j_wbufsize' Convert fs/jbd/recovery.c non-static functions to kernel-doc format. fs/jbd/recovery.c doesn't export any symbols, so it should use !I instead of !E to eliminate this warning message: Warning(/var/linsrc/linux-2614-rc4//fs/jbd/recovery.c): no structured comments found Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fs/jbd/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - journal.c: remove the unused global function __journal_internal_check and move the check to journal_init - remove the following write-only global variable: - journal.c: current_journal - remove the following unneeded EXPORT_SYMBOL: - journal.c: journal_recover Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
