path: root/include/linux/jbd2.h
2011-07-10jbd2: remove jbd2_dev_to_name() from jbd2 tracepointsTheodore Ts'o
Using function calls in TP_printk causes perf heartburn, so print the MAJOR/MINOR device numbers instead. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-13jbd2: Fix oops in jbd2_journal_remove_journal_head()Jan Kara
jbd2_journal_remove_journal_head() can oops when trying to access journal_head returned by bh2jh(). This is caused for example by the following race: TASK1 TASK2 jbd2_journal_commit_transaction() ... processing t_forget list __jbd2_journal_refile_buffer(jh); if (!jh->b_transaction) { jbd_unlock_bh_state(bh); jbd2_journal_try_to_free_buffers() jbd2_journal_grab_journal_head(bh) jbd_lock_bh_state(bh) __journal_try_to_free_buffer() jbd2_journal_put_journal_head(jh) jbd2_journal_remove_journal_head(bh); jbd2_journal_put_journal_head() in TASK2 sees that b_jcount == 0 and buffer is not part of any transaction and thus frees journal_head before TASK1 gets to doing so. Note that even buffer_head can be released by try_to_free_buffers() after jbd2_journal_put_journal_head() which adds even larger opportunity for oops (but I didn't see this happen in reality). Fix the problem by making transactions hold their own journal_head reference (in b_jcount). That way we don't have to remove journal_head explicitely via jbd2_journal_remove_journal_head() and instead just remove journal_head when b_jcount drops to zero. The result of this is that [__]jbd2_journal_refile_buffer(), [__]jbd2_journal_unfile_buffer(), and __jdb2_journal_remove_checkpoint() can free journal_head which needs modification of a few callers. Also we have to be careful because once journal_head is removed, buffer_head might be freed as well. So we have to get our own buffer_head reference where it matters. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-24jbd2: Add function jbd2_trans_will_send_data_barrier()Jan Kara
Provide a function which returns whether a transaction with given tid will send a flush to the filesystem device. The function will be used by ext4 to detect whether fsync needs to send a separate flush or not. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-24jbd2: fix sending of data flush on journal commitJan Kara
In data=ordered mode, it's theoretically possible (however rare) that an inode is filed to transaction's t_inode_list and a flusher thread writes all the data and inode is reclaimed before the transaction starts to commit. In such a case, we could erroneously omit sending a flush to file system device when it is different from the journal device (because data can still be in disk cache only). Fix the problem by setting a flag in a transaction when some inode is added to it and then send disk flush in the commit code when the flag is set. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-03-20jbd2: add COW fields to struct jbd2_journal_handleAmir Goldstein
Add fields needed for the copy-on-write ext4 development work. The h_cowing flag is used by ext4 snapshots code to mark the task in COWING state. The h_XXX_credits fields are used to track buffer credits usage (accounted by COW and non-COW operations). The h_cow_XXX fields are used as per task debugging counters. Merging this commit into mainline will allow users to test ext4 snapshots as a standalone module, without the need to patch and install a development kernel. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: dynamically allocate the jbd2_inode in ext4_inode_info as necessaryTheodore Ts'o
Replace the jbd2_inode structure (which is 48 bytes) with a pointer and only allocate the jbd2_inode when it is needed --- that is, when the file system has a journal present and the inode has been opened for writing. This allows us to further slim down the ext4_inode_info structure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27jbd2: Fix I/O hang in jbd2_journal_release_jbd_inodeBrian King
This fixes a hang seen in jbd2_journal_release_jbd_inode on a lot of Power 6 systems running with ext4. When we get in the hung state, all I/O to the disk in question gets blocked where we stay indefinitely. Looking at the task list, I can see we are stuck in jbd2_journal_release_jbd_inode waiting on a wake up. I added some debug code to detect this scenario and dump additional data if we were stuck in jbd2_journal_release_jbd_inode for longer than 30 minutes. When it hit, I was able to see that i_flags was 0, suggesting we missed the wake up. This patch changes i_flags to be an unsigned long, uses bit operators to access it, and adds barriers around the accesses. Prior to applying this patch, we were regularly hitting this hang on numerous systems in our test environment. After applying the patch, the hangs no longer occur. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-08-07Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4Linus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits) ext4: Adding error check after calling ext4_mb_regular_allocator() ext4: Fix dirtying of journalled buffers in data=journal mode ext4: re-inline ext4_rec_len_(to|from)_disk functions jbd2: Remove t_handle_lock from start_this_handle() jbd2: Change j_state_lock to be a rwlock_t jbd2: Use atomic variables to avoid taking t_handle_lock in jbd2_journal_stop ext4: Add mount options in superblock ext4: force block allocation on quota_off ext4: fix freeze deadlock under IO ext4: drop inode from orphan list if ext4_delete_inode() fails ext4: check to make make sure bd_dev is set before dereferencing it jbd2: Make barrier messages less scary ext4: don't print scary messages for allocation failures post-abort ext4: fix EFBIG edge case when writing to large non-extent file ext4: fix ext4_get_blocks references ext4: Always journal quota file modifications ext4: Fix potential memory leak in ext4_fill_super ext4: Don't error out the fs if the user tries to make a file too big ext4: allocate stripe-multiple IOs on stripe boundaries ext4: move aio completion after unwritten extent conversion ... Fix up conflicts in fs/ext4/inode.c as per Ted. Fix up xfs conflicts as per earlier xfs merge.
2010-08-03jbd2: Remove t_handle_lock from start_this_handle()Theodore Ts'o
This should remove the last exclusive lock from start_this_handle(), so that we should now be able to start multiple transactions at the same time on large SMP systems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-08-03jbd2: Change j_state_lock to be a rwlock_tTheodore Ts'o
Lockstat reports have shown that j_state_lock is a major source of lock contention, especially on systems with more than 4 CPU cores. So change it to be a read/write spinlock. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-08-02jbd2: Use atomic variables to avoid taking t_handle_lock in jbd2_journal_stopTheodore Ts'o
By using an atomic_t for t_updates and t_outstanding credits, this should allow us to not need to take transaction t_handle_lock in jbd2_journal_stop(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-07-27jbd2: Remove __GFP_NOFAIL from jbd2 layerTheodore Ts'o
__GFP_NOFAIL is going away, so add our own retry loop. Also add jbd2__journal_start() and jbd2__journal_restart() which take a gfp mask, so that file systems can optionally (re)start transaction handles using GFP_KERNEL. If they do this, then they need to be prepared to handle receiving an PTR_ERR(-ENOMEM) error, and be ready to reflect that error up to userspace. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-07-15jbd2/ocfs2: Fix block checksumming when a buffer is used in several transactionsJan Kara
OCFS2 uses t_commit trigger to compute and store checksum of the just committed blocks. When a buffer has b_frozen_data, checksum is computed for it instead of b_data but this can result in an old checksum being written to the filesystem in the following scenario: 1) transaction1 is opened 2) handle1 is opened 3) journal_access(handle1, bh) - This sets jh->b_transaction to transaction1 4) modify(bh) 5) journal_dirty(handle1, bh) 6) handle1 is closed 7) start committing transaction1, opening transaction2 8) handle2 is opened 9) journal_access(handle2, bh) - This copies off b_frozen_data to make it safe for transaction1 to commit. jh->b_next_transaction is set to transaction2. 10) jbd2_journal_write_metadata() checksums b_frozen_data 11) the journal correctly writes b_frozen_data to the disk journal 12) handle2 is closed - There was no dirty call for the bh on handle2, so it is never queued for any more journal operation 13) Checkpointing finally happens, and it just spools the bh via normal buffer writeback. This will write b_data, which was never triggered on and thus contains a wrong (old) checksum. This patch fixes the problem by calling the trigger at the moment data is frozen for journal commit - i.e., either when b_frozen_data is created by do_get_write_access or just before we write a buffer to the log if b_frozen_data does not exist. We also rename the trigger to t_frozen as that better describes when it is called. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05jbd[2]: remove references to BUFFER_DEBUGChristoph Egger
CONFIG_BUFFER_DEBUG seems to have been removed from the documentation somewhere around 2.4.15 and seemingly hasn't been available even longer. It is, however, still referenced at one place from the jbd code (one is a copy of the other header). Time to clean it up Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-23ext4, jbd2: Add barriers for file systems with exernal journalsTheodore Ts'o
This is a bit complicated because we are trying to optimize when we send barriers to the fs data disk. We could just throw in an extra barrier to the data disk whenever we send a barrier to the journal disk, but that's not always strictly necessary. We only need to send a barrier during a commit when there are data blocks which are must be written out due to an inode written in ordered mode, or if fsync() depends on the commit to force data blocks to disk. Finally, before we drop transactions from the beginning of the journal during a checkpoint operation, we need to guarantee that any blocks that were flushed out to the data disk are firmly on the rust platter before we drop the transaction from the journal. Thanks to Oleg Drokin for pointing out this flaw in ext3/ext4. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-12-07ext4: Use slab allocator for sub-page sized allocationsTheodore Ts'o
Now that the SLUB seems to be fixed so that it respects the requested alignment, use kmem_cache_alloc() to allocator if the block size of the buffer heads to be allocated is less than the page size. Previously, we were using 16k page on a Power system for each buffer, even when the file system was using 1k or 4k block size. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-30jbd2: Use tracepoints for history fileTheodore Ts'o
The /proc/fs/jbd2/<dev>/history was maintained manually; by using tracepoints, we can get all of the existing functionality of the /proc file plus extra capabilities thanks to the ftrace infrastructure. We save memory as a bonus. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-17jbd2: bitfields should be unsignedH Hartley Sweeten
This fixes sparse noise: error: dubious one-bit signed bitfield Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Jan Kara <jack@ucw.cz>
2009-06-17jbd2: convert instrumentation from markers to tracepointsTheodore Ts'o
2009-04-14jbd2: use SWRITE_SYNC_PLUG when writing synchronous revoke recordsTheodore Ts'o
The revoke records must be written using the same way as the rest of the blocks during the commit process; that is, either marked as synchronous writes or as asynchornous writes. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-25ext4: Use WRITE_SYNC for commits which are caused by fsync()Theodore Ts'o
If a commit is triggered by fsync(), set a flag indicating the journal blocks associated with the transaction should be flushed out using WRITE_SYNC. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-02-10jbd2: Avoid possible NULL dereference in jbd2_journal_begin_ordered_truncate()Jan Kara
If we race with commit code setting i_transaction to NULL, we could possibly dereference it. Proper locking requires the journal pointer (to access journal->j_list_lock), which we don't have. So we have to change the prototype of the function so that filesystem passes us the journal pointer. Also add a more detailed comment about why the function jbd2_journal_begin_ordered_truncate() does what it does and how it should be used. Thanks to Dan Carpenter <error27@gmail.com> for pointing to the suspitious code. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Joel Becker <joel.becker@oracle.com> CC: linux-ext4@vger.kernel.org CC: ocfs2-devel@oss.oracle.com CC: mfasheh@suse.de CC: Dan Carpenter <error27@gmail.com>
2009-01-16jbd2: On a __journal_expect() assertion failure printk "JBD2", not "EXT3-fs"Theodore Ts'o
Otherwise it can be very confusing to find a "EXT3-fs: " failure in the middle of EXT4-fs failures, and it makes it harder to track the source of the failure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (57 commits) jbd2: Fix oops in jbd2_journal_init_inode() on corrupted fs ext4: Remove "extents" mount option block: Add Kconfig help which notes that ext4 needs CONFIG_LBD ext4: Make printk's consistently prefixed with "EXT4-fs: " ext4: Add sanity checks for the superblock before mounting the filesystem ext4: Add mount option to set kjournald's I/O priority jbd2: Submit writes to the journal using WRITE_SYNC jbd2: Add pid and journal device name to the "kjournald2 starting" message ext4: Add markers for better debuggability ext4: Remove code to create the journal inode ext4: provide function to release metadata pages under memory pressure ext3: provide function to release metadata pages under memory pressure add releasepage hooks to block devices which can be used by file systems ext4: Fix s_dirty_blocks_counter if block allocation failed with nodelalloc ext4: Init the complete page while building buddy cache ext4: Don't allow new groups to be added during block allocation ext4: mark the blocks/inode bitmap beyond end of group as used ext4: Use new buffer_head flag to check uninit group bitmaps initialization ext4: Fix the race between read_inode_bitmap() and ext4_new_inode() ext4: code cleanup ...
2009-01-05jbd2: Add buffer triggersJoel Becker
Filesystems often to do compute intensive operation on some metadata. If this operation is repeated many times, it can be very expensive. It would be much nicer if the operation could be performed once before a buffer goes to disk. This adds triggers to jbd2 buffer heads. Just before writing a metadata buffer to the journal, jbd2 will optionally call a commit trigger associated with the buffer. If the journal is aborted, an abort trigger will be called on any dirty buffers as they are dropped from pending transactions. ocfs2 will use this feature. Initially I tried to come up with a more generic trigger that could be used for non-buffer-related events like transaction completion. It doesn't tie nicely, because the information a buffer trigger needs (specific to a journal_head) isn't the same as what a transaction trigger needs (specific to a tranaction_t or perhaps journal_t). So I implemented a buffer set, with the understanding that journal/transaction wide triggers should be implemented separately. There is only one trigger set allowed per buffer. I can't think of any reason to attach more than one set. Contrast this with a journal or transaction in which multiple places may want to watch the entire transaction separately. The trigger sets are considered static allocation from the jbd2 perspective. ocfs2 will just have one trigger set per block type, setting the same set on every bh of the same type. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05jbd2: Add BH_JBDPrivateStartMark Fasheh
Add this so that file systems using JBD2 can safely allocate unused b_state bits. In this case, we add it so that Ocfs2 can define a single bit for tracking the validation state of a buffer. Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-06ext4: Remove code to create the journal inodeTheodore Ts'o
This code has been obsolete in quite some time, since the supported method for adding a journal inode is to use tune2fs (or to creating new filesystem with a journal via mke2fs or mkfs.ext4). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-11-06jbd2: Call journal commit callback without holding j_list_lockAneesh Kumar K.V
Avoid freeing the transaction in __jbd2_journal_drop_transaction() so the journal commit callback can run without holding j_list_lock, to avoid lock contention on this spinlock. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-11-05jbd2: Remove a large array of bh's from the stack of the checkpoint routineTheodore Ts'o
jbd2_log_do_checkpoint()n is one of the kernel's largest stack users. Move the array of buffer head's from the stack of jbd2_log_do_checkpoint() to the in-core journal structure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-03ext4: add fsync batch tuning knobsTheodore Ts'o
Add new mount options, min_batch_time and max_batch_time, which controls how long the jbd2 layer should wait for additional filesystem operations to get batched with a synchronous write transaction. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-11-26jbd2: improve jbd2 fsync batchingJosef Bacik
This patch removes the static sleep time in favor of a more self optimizing approach where we measure the average amount of time it takes to commit a transaction to disk and the ammount of time a transaction has been running. If somebody does a sync write or an fsync() traditionally we would sleep for 1 jiffies, which depending on the value of HZ could be a significant amount of time compared to how long it takes to commit a transaction to the underlying storage. With this patch instead of sleeping for a jiffie, we check to see if the amount of time this transaction has been running is less than the average commit time, and if it is we sleep for the delta using schedule_hrtimeout to give us a higher precision sleep time. This greatly benefits high end storage where you could end up sleeping for longer than it takes to commit the transaction and therefore sitting idle instead of allowing the transaction to be committed by keeping the sleep time to a minimum so you are sure to always be doing something. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-11-25jbd2: Add BH_JBDPrivateStartMark Fasheh
Add this so that file systems using JBD2 can safely allocate unused b_state bits. In this case, we add it so that Ocfs2 can define a single bit for tracking the validation state of a buffer. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-16ext4: Replace hackish ext4_mb_poll_new_transaction with commit callbackTheodore Ts'o
The multiblock allocator needs to be able to release blocks (and issue a blkdev discard request) when the transaction which freed those blocks is committed. Previously this was done via a polling mechanism when blocks are allocated or freed. A much better way of doing things is to create a jbd2 callback function and attaching the list of blocks to be freed directly to the transaction structure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-16include: replace __FUNCTION__ with __func__Harvey Harrison
2008-10-10ext4: add an option to control error handling on file dataHidehiro Kawai
If the journal doesn't abort when it gets an IO error in file data blocks, the file data corruption will spread silently. Because most of applications and commands do buffered writes without fsync(), they don't notice the IO error. It's scary for mission critical systems. On the other hand, if the journal aborts whenever it gets an IO error in file data blocks, the system will easily become inoperable. So this patch introduces a filesystem option to determine whether it aborts the journal or just call printk() when it gets an IO error in file data. If you mount an ext4 fs with data_err=abort option, it aborts on file data write error. If you mount it with data_err=ignore, it doesn't abort, just call printk(). data_err=ignore is the default. Here is the corresponding patch of the ext3 version: http://kerneltrap.org/mailarchive/linux-kernel/2008/9/9/3239374 Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-10-10jbd2: fix error handling for checkpoint ioHidehiro Kawai
When a checkpointing IO fails, current JBD2 code doesn't check the error and continue journaling. This means latest metadata can be lost from both the journal and filesystem. This patch leaves the failed metadata blocks in the journal space and aborts journaling in the case of jbd2_log_do_checkpoint(). To achieve this, we need to do: 1. don't remove the failed buffer from the checkpoint list where in the case of __try_to_free_cp_buf() because it may be released or overwritten by a later transaction 2. jbd2_log_do_checkpoint() is the last chance, remove the failed buffer from the checkpoint list and abort the journal 3. when checkpointing fails, don't update the journal super block to prevent the journaled contents from being cleaned. For safety, don't update j_tail and j_tail_sequence either 4. when checkpointing fails, notify this error to the ext4 layer so that ext4 don't clear the needs_recovery flag, otherwise the journaled contents are ignored and cleaned in the recovery phase 5. if the recovery fails, keep the needs_recovery flag 6. prevent jbd2_cleanup_journal_tail() from being called between __jbd2_journal_drop_transaction() and jbd2_journal_abort() (a possible race issue between jbd2_log_do_checkpoint()s called by jbd2_journal_flush() and __jbd2_log_wait_for_space()) Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-09-16jbd2: clean up how the journal device name is printedTheodore Ts'o
Calculate the journal device name once and stash it away in the journal_s structure. This avoids needing to call bdevname() everywhere and reduces stack usage by not needing to allocate an on-stack buffer. In addition, we eliminate the '/' that can appear in device names (e.g. "cciss/c0d0p9" --- see kernel bugzilla #11321) that can cause problems when creating proc directory names, and include the inode number to support ocfs2 which creates multiple journals with different inode numbers. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-07-11jbd2: Remove data=ordered mode support using jbd buffer headsJan Kara
2008-07-11jbd2: Implement data=ordered mode handling via inodesJan Kara
This patch adds necessary framework into JBD2 to be able to track inodes with each transaction and write-out their dirty data during transaction commit time. This new ordered mode brings all sorts of advantages such as possibility to get rid of journal heads and buffer heads for data buffers in ordered mode, better ordering of writes on transaction commit, simplification of some JBD code, no more anonymous pages when truncate of data being committed happens. Also with this new ordered mode, delayed allocation on ordered mode is much simpler. Signed-off-by: Jan Kara <jack@suse.cz>
2008-07-11jbd2: Add commit time into the commit blockTheodore Ts'o
Carlo Wood has demonstrated that it's possible to recover deleted files from the journal. Something that will make this easier is if we can put the time of the commit into commit block. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-06-06jbd2: If a journal checksum error is detected, propagate the error to ext4Theodore Ts'o
If a journal checksum error is detected, the ext4 filesystem will call ext4_error(), and the mount will either continue, become a read-only mount, or cause a kernel panic based on the superblock flags indicating the user's preference of what to do in case of filesystem corruption being detected. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-01-28jbd2: add lockdep supportMingming Cao
Ported from similar patch for the jbd layer. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28ext4: Add the journal checksum featureGirish Shilamkar
The journal checksum feature adds two new flags i.e JBD2_FEATURE_INCOMPAT_ASYNC_COMMIT and JBD2_FEATURE_COMPAT_CHECKSUM. JBD2_FEATURE_CHECKSUM flag indicates that the commit block contains the checksum for the blocks described by the descriptor blocks. Due to checksums, writing of the commit record no longer needs to be synchronous. Now commit record can be sent to disk without waiting for descriptor blocks to be written to disk. This behavior is controlled using JBD2_FEATURE_ASYNC_COMMIT flag. Older kernels/e2fsck should not be able to recover the journal with _ASYNC_COMMIT hence it is made incompat. The commit header has been extended to hold the checksum along with the type of the checksum. For recovery in pass scan checksums are verified to ensure the sanity and completeness(in case of _ASYNC_COMMIT) of every transaction. Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Girish Shilamkar <girish@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-01-28jbd2: jbd2 stats through procfsJohann Lombardi
The patch below updates the jbd stats patch to 2.6.20/jbd2. The initial patch was posted by Alex Tomas in December 2005 (http://marc.info/?l=linux-ext4&m=113538565128617&w=2). It provides statistics via procfs such as transaction lifetime and size. Sometimes, investigating performance problems, i find useful to have stats from jbd about transaction's lifetime, size, etc. here is a patch for review and inclusion probably. for example, stats after creation of 3M files in htree directory: [root@bob ~]# cat /proc/fs/jbd/sda/history R/C tid wait run lock flush log hndls block inlog ctime write drop close R 261 8260 2720 0 0 750 9892 8170 8187 C 259 750 0 4885 1 R 262 20 2200 10 0 770 9836 8170 8187 R 263 30 2200 10 0 3070 9812 8170 8187 R 264 0 5000 10 0 1340 0 0 0 C 261 8240 3212 4957 0 R 265 8260 1470 0 0 4640 9854 8170 8187 R 266 0 5000 10 0 1460 0 0 0 C 262 8210 2989 4868 0 R 267 8230 1490 10 0 4440 9875 8171 8188 R 268 0 5000 10 0 1260 0 0 0 C 263 7710 2937 4908 0 R 269 7730 1470 10 0 3330 9841 8170 8187 R 270 0 5000 10 0 830 0 0 0 C 265 8140 3234 4898 0 C 267 720 0 4849 1 R 271 8630 2740 20 0 740 9819 8170 8187 C 269 800 0 4214 1 R 272 40 2170 10 0 830 9716 8170 8187 R 273 40 2280 0 0 3530 9799 8170 8187 R 274 0 5000 10 0 990 0 0 0 where, R - line for transaction's life from T_RUNNING to T_FINISHED C - line for transaction's checkpointing tid - transaction's id wait - for how long we were waiting for new transaction to start (the longest period journal_start() took in this transaction) run - real transaction's lifetime (from T_RUNNING to T_LOCKED lock - how long we were waiting for all handles to close (time the transaction was in T_LOCKED) flush - how long it took to flush all data (data=ordered) log - how long it took to write the transaction to the log hndls - how many handles got to the transaction block - how many blocks got to the transaction inlog - how many blocks are written to the log (block + descriptors) ctime - how long it took to checkpoint the transaction write - how many blocks have been written during checkpointing drop - how many blocks have been dropped during checkpointing close - how many running transactions have been closed to checkpoint this one all times are in msec. [root@bob ~]# cat /proc/fs/jbd/sda/info 280 transaction, each upto 8192 blocks average: 1633ms waiting for transaction 3616ms running transaction 5ms transaction was being locked 1ms flushing data (in ordered mode) 1799ms logging transaction 11781 handles per transaction 5629 blocks per transaction 5641 logged blocks per transaction Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2008-01-28jbd2: Fix assertion failure in fs/jbd2/checkpoint.cJan Kara
Before we start committing a transaction, we call __journal_clean_checkpoint_list() to cleanup transaction's written-back buffers. If this call happens to remove all of them (and there were already some buffers), __journal_remove_checkpoint() will decide to free the transaction because it isn't (yet) a committing transaction and soon we fail some assertion - the transaction really isn't ready to be freed :). We change the check in __journal_remove_checkpoint() to free only a transaction in T_FINISHED state. The locking there is subtle though (as everywhere in JBD ;(). We use j_list_lock to protect the check and a subsequent call to __journal_drop_transaction() and do the same in the end of journal_commit_transaction() which is the only place where a transaction can get to T_FINISHED state. Probably I'm too paranoid here and such locking is not really necessary - checkpoint lists are processed only from log_do_checkpoint() where a transaction must be already committed to be processed or from __journal_clean_checkpoint_list() where kjournald itself calls it and thus transaction cannot change state either. Better be safe if something changes in future... Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-01-28jbd2: Remove printk from J_ASSERT to preserve registers during BUGChris Snook
Signed-off-by: Chris Snook <csnook@redhat.com> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-10-17jbd2: JBD_XXX to JBD2_XXX naming cleanupMingming Cao
change JBD_XXX macros to JBD2_XXX in JBD2/Ext4 Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
