commit 4327ba52afd03fc4b5afa0ee1d774c9c5b0e85c5 upstream.
If a EXT4 filesystem utilizes JBD2 journaling and an error occurs, the
journaling will be aborted first and the error number will be recorded
into JBD2 superblock and, finally, the system will enter into the
panic state in "errors=panic" option. But, in the rare case, this
sequence is little twisted like the below figure and it will happen
that the system enters into panic state, which means the system reset
in mobile environment, before completion of recording an error in the
journal superblock. In this case, e2fsck cannot recognize that the
filesystem failure occurred in the previous run and the corruption
wouldn't be fixed.
Task A Task B
ext4_handle_error()
-> jbd2_journal_abort()
-> __journal_abort_soft()
-> __jbd2_journal_abort_hard()
| -> journal->j_flags |= JBD2_ABORT;
| __ext4_abort()
| | -> if (journal->j_flags & JBD2_ABORT)
| | return;
| -> panic()
-> jbd2_journal_update_sb_errno()
Tested-by: Hobin Woo <hobin.woo@samsung.com>
Signed-off-by: Daeho Jeong <daeho.jeong@samsung.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 841df7df196237ea63233f0f9eaa41db53afd70f upstream.
Commit 6f6a6fda2945 "jbd2: fix ocfs2 corrupt when updating journal
superblock fails" changed jbd2_cleanup_journal_tail() to return EIO
when the journal is aborted. That makes logic in
jbd2_log_do_checkpoint() bail out which is fine, except that
jbd2_journal_destroy() expects jbd2_log_do_checkpoint() to always make
a progress in cleaning the journal. Without it jbd2_journal_destroy()
just loops in an infinite loop.
Fix jbd2_journal_destroy() to cleanup journal checkpoint lists of
jbd2_log_do_checkpoint() fails with error.
Reported-by: Eryu Guan <guaneryu@gmail.com>
Tested-by: Eryu Guan <guaneryu@gmail.com>
Fixes: 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a
Signed-off-by: Jan Kara <jack@suse.com>
commit 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a upstream.
If updating journal superblock fails after journal data has been
flushed, the error is omitted and this will mislead the caller as a
normal case. In ocfs2, the checkpoint will be treated successfully
and the other node can get the lock to update. Since the sb_start is
still pointing to the old log block, it will rewrite the journal data
during journal recovery by the other node. Thus the new updates will
be overwritten and ocfs2 corrupts. So in above case we have to return
the error, and ocfs2_commit_cache will take care of the error and
prevent the other node to do update first. And only after recovering
journal it can do the new updates.
The issue discussion mail can be found at:
https://oss.oracle.com/pipermail/ocfs2-devel/2015-June/010856.html
http://comments.gmane.org/gmane.comp.file-systems.ext4/48841
[ Fixed bug in patch which allowed a non-negative error return from
jbd2_cleanup_journal_tail() to leak out of jbd2_fjournal_flush(); this
was causing xfstests ext4/306 to fail. -- Ted ]
Reported-by: Yiwen Jiang <jiangyiwen@huawei.com>
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Tested-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
A quick search shows that there are no users, drop the
macro for both jbd and jbd2.
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Cc: Jan Kara <jack@suse.cz>
__jbd2_journal_clean_checkpoint_list() returns number of buffers it
freed but noone was using the value so just stop doing that. This
also allows for simplifying the calling convention for
journal_clean_once_cp_list().
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
Cc: stable@vger.kernel.org
If jbd2_journal_restart() fails the handle will have been disconnected
from the current transaction. In this situation, the handle must not
be used for for any jbd2 function other than jbd2_journal_stop().
Enforce this with by treating a handle which has a NULL transaction
pointer as an aborted handle, and issue a kernel warning if
jbd2_journal_extent(), jbd2_journal_get_write_access(),
jbd2_journal_dirty_metadata(), etc. is called with an invalid handle.
This commit also fixes a bug where jbd2_journal_stop() would trip over
a kernel jbd2 assertion check when trying to free an invalid handle.
Also move the responsibility of setting current->journal_info to
start_this_handle(), simplifying the three users of this function.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reported-by: Younger Liu <younger.liu@huawei.com>
Since the jbd_debug() is implemented with two separate printk()
calls, it can lead to corrupted and misleading debug output like
the following (see lines marked with "*"):
[ 290.339362] (fs/jbd2/journal.c, 203): kjournald2: kjournald2 wakes
[ 290.339365] (fs/jbd2/journal.c, 155): kjournald2: commit_sequence=42103, commit_request=42104
[ 290.339369] (fs/jbd2/journal.c, 158): kjournald2: OK, requests differ
[* 290.339376] (fs/jbd2/journal.c, 648): jbd2_log_wait_commit:
[* 290.339379] (fs/jbd2/commit.c, 370): jbd2_journal_commit_transaction: JBD2: want 42104, j_commit_sequence=42103
[* 290.339382] JBD2: starting commit of transaction 42104
[ 290.339410] (fs/jbd2/revoke.c, 566): jbd2_journal_write_revoke_records: Wrote 0 revoke records
[ 290.376555] (fs/jbd2/commit.c, 1088): jbd2_journal_commit_transaction: JBD2: commit 42104 complete, head 42079
i.e. the debug output from log_wait_commit and journal_commit_transaction
have become interleaved. The output should have been:
(fs/jbd2/journal.c, 648): jbd2_log_wait_commit: JBD2: want 42104, j_commit_sequence=42103
(fs/jbd2/commit.c, 370): jbd2_journal_commit_transaction: JBD2: starting commit of transaction 42104
It is expected that this is not easy to replicate -- I was only able
to cause it on preempt-rt kernels, and even then only under heavy
I/O load.
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Suggested-by: "Theodore Ts'o" <tytso@mit.edu>
The bit_spinlock functions are only used for the jbd_lock_bh_state
functions (and friends) in jbd_common.h and are not directly used
by either of jbd.h or jbd2.h content.
The jbd_common file is new as of commit 446066724c36 ("jdb/jbd2: factor
out common functions from the jbd[2] header files") but common
(and isolated) headers were not considered for factoring at that time.
Inode's data or non journaled quota may be written w/o jounral so we
_must_ send a barrier at the end of ext4_sync_fs. But it can be
skipped if journal commit will do it for us.
Also fix data integrity for nojournal mode.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Current implementation of jbd2_journal_force_commit() is suboptimal because
result in empty and useless commits. But callers just want to force and wait
any unfinished commits. We already have jbd2_journal_force_commit_nested()
which does exactly what we want, except we are guaranteed that we do not hold
journal transaction open.
In some cases we cannot start a transaction because of locking
constraints and passing started transaction into those places is not
handy either because we could block transaction commit for too long.
Transaction reservation is designed to solve these issues. It
reserves a handle with given number of credits in the journal and the
handle can be later attached to the running transaction without
blocking on commit or checkpointing. Reserved handles do not block
transaction commit in any way, they only reduce maximum size of the
running transaction (because we have to always be prepared to
accomodate request for attaching reserved handle).
j_wait_logspace and j_wait_checkpoint are unused. Remove them.
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
__jbd2_log_space_left() and jbd_space_needed() were kind of odd.
jbd_space_needed() accounted also credits needed for currently
committing transaction while it didn't account for credits needed for
control blocks. __jbd2_log_space_left() then accounted for control
blocks as a fraction of free space. Since results of these two
functions are always only compared against each other, this works
correct but is somewhat strange. Move the estimates so that
jbd_space_needed() returns number of blocks needed for a transaction
including control blocks and __jbd2_log_space_left() returns free
space in the journal (with the committing transaction already
subtracted). Rename functions to jbd2_log_space_left() and
jbd2_space_needed() while we are changing them.
Currently when we add a buffer to a transaction, we wait until the
buffer is removed from BJ_Shadow list (so that we prevent any changes
to the buffer that is just written to the journal). This can take
unnecessarily long as a lot happens between the time the buffer is
submitted to the journal and the time when we remove the buffer from
BJ_Shadow list. (e.g. We wait for all data buffers in the
transaction, we issue a cache flush, etc.) Also this creates a
dependency of do_get_write_access() on transaction commit (namely
waiting for data IO to complete) which we want to avoid when
implementing transaction reservation.
So we modify commit code to set new BH_Shadow flag when temporary
shadowing buffer is created and we clear that flag once IO on that
buffer is complete. This allows do_get_write_access() to wait only
for BH_Shadow bit and thus removes the dependency on data IO
completion.
Similarly as for metadata buffers, also log descriptor buffers don't
really need the journal head. So strip it and remove BJ_LogCtl list.
When writing metadata to the journal, we create temporary buffer heads
for that task. We also attach journal heads to these buffer heads but
the only purpose of the journal heads is to keep buffers linked in
transaction's BJ_IO list. We remove the need for journal heads by
reusing buffer_head's b_assoc_buffers list for that purpose. Also
since BJ_IO list is just a temporary list for transaction commit, we
use a private list in jbd2_journal_commit_transaction() for that thus
removing BJ_IO list from transaction completely.
invalidatepage now accepts range to invalidate and there are two file
system using jbd2 also implementing punch hole feature which can benefit
from this. We need to implement the same thing for jbd2 layer in order to
allow those file system take benefit of this functionality.
This commit adds length argument to the jbd2_journal_invalidatepage()
and updates all instances in ext4 and ocfs2.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
The jbd2_alloc_handle() function is only called by new_handle(). So
this commit uses kmem_cache_zalloc() instead of
kmem_cache_alloc()/memset().
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
The following race is possible:
[kjournald2] other_task
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
In the case where an inode has a very stale transaction id (tid) in
i_datasync_tid or i_sync_tid, it's possible that after a very large
(2**31) number of transactions, that the tid number space might wrap,
causing tid_geq()'s calculations to fail.
Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified
by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily",
attempted to fix this problem, but it only avoided kjournald spinning
forever by fixing the logic in jbd2_log_start_commit().
Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c
that might call jbd2_log_start_commit() with a stale tid, those
functions will subsequently call jbd2_log_wait_commit() with the same
stale tid, and then wait for a very long time. To fix this, we
replace the calls to jbd2_log_start_commit() and
jbd2_log_wait_commit() with a call to a new function,
jbd2_complete_transaction(), which will correctly handle stale tid's.
As a bonus, jbd2_complete_transaction() will avoid locking
j_state_lock for writing unless a commit needs to be started. This
should have a small (but probably not measurable) improvement for
ext4's scalability.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: George Barnett <gbarnett@atlassian.com>
There are multiple reasons to move away from debugfs. First of all,
we are only using it for a single parameter, and it is much more
complicated to set up (some 30 lines of code compared to 3), and one
more thing that might fail while loading the jbd2 module.
Secondly, as a module paramter it can be specified as a boot option if
jbd2 is built into the kernel, or as a parameter when the module is
loaded, and it can also be manipulated dynamically under
/sys/module/jbd2/parameters/jbd2_debug. So it is more flexible.
Ultimately we want to move away from using jbd_debug() towards
tracepoints, but for now this is still a useful simplification of the
code base.
Handles which stay open a long time are problematic when it comes time
to close down a transaction so it can be committed. These tracepoints
will help us determine which ones are the problematic ones, and to
validate whether changes makes things better or worse.
This reverts commit 93737456d68ddcb86232f669b83da673dd12e351.
The cow-snapshots effort is no longer active, so remove these extra
fields to shrink down the handle structure.
Track the delay between when we first request that the commit begin
and when it actually begins, so we can see how much of a gap exists.
In theory, this should just be the remaining scheduling quantuum of
the thread which requested the commit (assuming it was not a
synchronous operation which triggered the commit request) plus
scheduling overhead; however, it's possible that real time processes
might get in the way of letting the kjournald thread from executing.
We cannot wait for transaction commit in journal_unmap_buffer()
because we hold page lock which ranks below transaction start. We
solve the issue by bailing out of journal_unmap_buffer() and
jbd2_journal_invalidatepage() with -EBUSY. Caller is then responsible
for waiting for transaction commit to finish and try invalidation
again. Since the issue can happen only for page stradding i_size, it
is simple enough to manually call jbd2_journal_invalidatepage() for
such page from ext4_setattr(), check the return value and wait if
necessary.
The use of variable length arrays in structs (VLAIS) in the Linux Kernel code
precludes the use of compilers which don't implement VLAIS (for instance the
Clang compiler). Since ctx is always a 32-bit CRC, hard coding a size of 4
bytes accomplishes the same thing without the use of VLAIS. This is the same
technique already employed in fs/ext4/ext4.h
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Signed-off-by: Behan Webster <behanw@converseincode.com>
ext4_handle_release_buffer() was intended to remove journal
write access from a buffer, but it doesn't actually do anything
at all other than add a BUFFER_TRACE point, but it's not reliably
used for that either. Remove all the associated dead code.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
After we transfer set the EXT4_ERROR_FS bit in the file system
superblock, it's not enough to call jbd2_journal_clear_err() to clear
the error indication from journal superblock --- we need to call
jbd2_journal_update_sb_errno() as well. Otherwise, when the root file
system is mounted read-only, the journal is replayed, and the error
indicator is transferred to the superblock --- but the s_errno field
in the jbd2 superblock is left set (since although we cleared it in
memory, we never flushed it out to disk).
This can end up confusing e2fsck. We should make e2fsck more robust
in this case, but the kernel shouldn't be leaving things in this
confused state, either.
Cc: stable@kernel.org
Activate the metadata checksumming feature by adding it to ext4 and
jbd2's lists of supported features.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Calculate and verify a checksum covering the journal superblock.
Obtain a reference to the crc32c driver if needed for the v2 checksum.
Define flags and allocate space in on-disk journal structures to support
checksumming of journal metadata.
Normally, we have to issue a cache flush before we can update journal tail in
journal superblock, effectively wiping out old transactions from the journal.
So use the fact that during transaction commit we issue cache flush anyway and
opportunistically push journal tail as far as we can. Since update of journal
superblock is still costly (we have to use WRITE_FUA), we update log tail only
if we can free significant amount of space.
When we reach jbd2_cleanup_journal_tail(), there is no guarantee that
checkpointed buffers are on a stable storage - especially if buffers were
written out by jbd2_log_do_checkpoint(), they are likely to be only in disk's
caches. Thus when we update journal superblock effectively removing old
transaction from journal, this write of superblock can get to stable storage
before those checkpointed buffers which can result in filesystem corruption
after a crash. Thus we must unconditionally issue a cache flush before we
update journal superblock in these cases.
A similar problem can also occur if journal superblock is written only in
disk's caches, other transaction starts reusing space of the transaction
cleaned from the log and power failure happens. Subsequent journal replay would
still try to replay the old transaction but some of it's blocks may be already
overwritten by the new transaction. For this reason we must use WRITE_FUA when
updating log tail and we must first write new log tail to disk and update
in-memory information only after that.
There are three case of updating journal superblock. In the first case, we want
to mark journal as empty (setting s_sequence to 0), in the second case we want
to update log tail, in the third case we want to update s_errno. Split these
cases into separate functions. It makes the code slightly more straightforward
and later patches will make the distinction even more important.
There is normally only a handful of these active at any one time, but
putting them in a separate slab cache makes debugging memory
corruption problems easier. Manish Katiyar also wanted this make it
easier to test memory failure scenarios in the jbd2 layer.
Cc: Manish Katiyar <mkatiyar@gmail.com>
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Currently, we clear revoked flag only when a block is reused. However,
this can tigger a false journal error. Consider a situation when a block
is used as a meta block and is deleted(revoked) in ordered mode, then the
block is allocated as a data block to a file. At this moment, user changes
the file's journal mode from ordered to journaled and truncates the file.
The block will be considered re-revoked by journal because it has revoked
flag still pending from the last transaction and an assertion triggers.
We fix the problem by keeping the revoked status more uptodate - we clear
revoked flag when switching revoke tables to reflect there is no revoked
buffers in current transaction any more.
The state bits and the lock functions of jbd and jbd2 are
identical. Share them.
This silences some Sparse warnings:
fs/jbd2/transaction.c:135:69: warning: incorrect type in argument 2 (different base types)
fs/jbd2/transaction.c:135:69: expected restricted gfp_t [usertype] flags
fs/jbd2/transaction.c:135:69: got int [signed] gfp_mask
Using function calls in TP_printk causes perf heartburn, so print the
MAJOR/MINOR device numbers instead.
jbd2_journal_remove_journal_head() can oops when trying to access
journal_head returned by bh2jh(). This is caused for example by the
following race:
TASK1 TASK2
processing t_forget list
__jbd2_journal_refile_buffer(jh);
if (!jh->b_transaction) {
jbd_unlock_bh_state(bh);
jbd2_journal_try_to_free_buffers()
jbd2_journal_grab_journal_head(bh)
jbd_lock_bh_state(bh)
__journal_try_to_free_buffer()
jbd2_journal_put_journal_head(jh)
jbd2_journal_remove_journal_head(bh);
jbd2_journal_put_journal_head() in TASK2 sees that b_jcount == 0 and
buffer is not part of any transaction and thus frees journal_head
before TASK1 gets to doing so. Note that even buffer_head can be
released by try_to_free_buffers() after
jbd2_journal_put_journal_head() which adds even larger opportunity for
oops (but I didn't see this happen in reality).
Fix the problem by making transactions hold their own journal_head
reference (in b_jcount). That way we don't have to remove journal_head
explicitely via jbd2_journal_remove_journal_head() and instead just
remove journal_head when b_jcount drops to zero. The result of this is
that [__]jbd2_journal_refile_buffer(),
[__]jbd2_journal_unfile_buffer(), and
__jdb2_journal_remove_checkpoint() can free journal_head which needs
modification of a few callers. Also we have to be careful because once
journal_head is removed, buffer_head might be freed as well. So we
have to get our own buffer_head reference where it matters.
Provide a function which returns whether a transaction with given tid
will send a flush to the filesystem device. The function will be used
by ext4 to detect whether fsync needs to send a separate flush or not.
In data=ordered mode, it's theoretically possible (however rare) that
an inode is filed to transaction's t_inode_list and a flusher thread
writes all the data and inode is reclaimed before the transaction
starts to commit. In such a case, we could erroneously omit sending a
flush to file system device when it is different from the journal
device (because data can still be in disk cache only).
Fix the problem by setting a flag in a transaction when some inode is added
to it and then send disk flush in the commit code when the flag is set.
Add fields needed for the copy-on-write ext4 development work.
The h_cowing flag is used by ext4 snapshots code to mark the task in
COWING state.
The h_XXX_credits fields are used to track buffer credits usage
(accounted by COW and non-COW operations).
The h_cow_XXX fields are used as per task debugging counters.
Merging this commit into mainline will allow users to test ext4
snapshots as a standalone module, without the need to patch and
install a development kernel.
Signed-off-by: Amir Goldstein <amir73il@users.sf.net>
Replace the jbd2_inode structure (which is 48 bytes) with a pointer
and only allocate the jbd2_inode when it is needed --- that is, when
the file system has a journal present and the inode has been opened
for writing. This allows us to further slim down the ext4_inode_info
structure.
This fixes a hang seen in jbd2_journal_release_jbd_inode
on a lot of Power 6 systems running with ext4. When we get
in the hung state, all I/O to the disk in question gets blocked
where we stay indefinitely. Looking at the task list, I can see
we are stuck in jbd2_journal_release_jbd_inode waiting on a
wake up. I added some debug code to detect this scenario and
dump additional data if we were stuck in jbd2_journal_release_jbd_inode
for longer than 30 minutes. When it hit, I was able to see that
i_flags was 0, suggesting we missed the wake up.
This patch changes i_flags to be an unsigned long, uses bit operators
to access it, and adds barriers around the accesses. Prior to applying
this patch, we were regularly hitting this hang on numerous systems
in our test environment. After applying the patch, the hangs no longer
occur.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits)
ext4: Adding error check after calling ext4_mb_regular_allocator()
ext4: Fix dirtying of journalled buffers in data=journal mode
ext4: re-inline ext4_rec_len_(to|from)_disk functions
jbd2: Remove t_handle_lock from start_this_handle()
jbd2: Change j_state_lock to be a rwlock_t
jbd2: Use atomic variables to avoid taking t_handle_lock in jbd2_journal_stop
ext4: Add mount options in superblock
ext4: force block allocation on quota_off
ext4: fix freeze deadlock under IO
ext4: drop inode from orphan list if ext4_delete_inode() fails
ext4: check to make make sure bd_dev is set before dereferencing it
jbd2: Make barrier messages less scary
ext4: don't print scary messages for allocation failures post-abort
ext4: fix EFBIG edge case when writing to large non-extent file
ext4: fix ext4_get_blocks references
ext4: Always journal quota file modifications
ext4: Fix potential memory leak in ext4_fill_super
ext4: Don't error out the fs if the user tries to make a file too big
ext4: allocate stripe-multiple IOs on stripe boundaries
ext4: move aio completion after unwritten extent conversion
Fix up conflicts in fs/ext4/inode.c as per Ted.
Fix up xfs conflicts as per earlier xfs merge.
This should remove the last exclusive lock from start_this_handle(),
so that we should now be able to start multiple transactions at the
same time on large SMP systems.
Lockstat reports have shown that j_state_lock is a major source of
lock contention, especially on systems with more than 4 CPU cores. So
change it to be a read/write spinlock.
