path: root/include/linux/jffs2.h
2010-08-10Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (79 commits) mtd: Remove obsolete <mtd/compatmac.h> include mtd: Update copyright notices jffs2: Update copyright notices mtd-physmap: add support users can assign the probe type in board files mtd: remove redwood map driver mxc_nand: Add v3 (i.MX51) Support mxc_nand: support 8bit ecc mxc_nand: fix correct_data function mxc_nand: add V1_V2 namespace to registers mxc_nand: factor out a check_int function mxc_nand: make some internally used functions overwriteable mxc_nand: rework get_dev_status mxc_nand: remove 0xe00 offset from registers mtd: denali: Add multi connected NAND support mtd: denali: Remove set_ecc_config function mtd: denali: Remove unuseful code in get_xx_nand_para functions mtd: denali: Remove device_info_tag structure mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips ... Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to redwood driver removal.
2010-08-08jffs2: Update copyright noticesDavid Woodhouse
2010-07-11fix comment typos concerning "sequential"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-25JFFS2: avoid using C++ keyword `new' in userspace-visible headerAndrew Morton
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14995 Reported-by: R. Diez <rdiezmail-kernelbugzilla@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-26make MTD headers use strict integer typesArnd Bergmann
The MTD headers traditionally use stdint types rather than the kernel integer types. This converts them to do the same as all the others. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-11[JFFS2] Add LZO compression support.Richard Purdie
Add LZO1X compression/decompression support to jffs2. LZO's interface doesn't entirely match that required by jffs2 so a buffer and memcpy is unavoidable. Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-27[JFFS2][XATTR] using 'delete marker' for xdatum/xref deletionKaiGai Kohei
- When xdatum is removed, a new xdatum with 'delete marker' is written. (version==0xffffffff means 'delete marker') - When xref is removed, a new xref with 'delete marker' is written. (odd-numbered xseqno means 'delete marker') - delete_xattr_(datum/xref)_delay() are new deletion functions are added. We can only use them if we can detect the target obsolete xdatum/xref as a orphan or errir one. (e.g when inode deletion, or detecting crc error) [1/3] jffs2-xattr-v6-01-delete_marker.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-20Merge git://git.infradead.org/jffs2-xattr-2.6David Woodhouse
2006-05-19[JFFS2] Support new device nodesDavid Woodhouse
Device node major/minor numbers are just stored in the payload of a single data node. Just extend that to 4 bytes and use new_encode_dev() for it. We only use the 4-byte format if we _need_ to, if !old_valid_dev(foo). This preserves backwards compatibility with older code as much as possible. If we do make devices with major or minor numbers above 255, and then mount the file system with the old code, it'll just read the first two bytes and get the numbers wrong. If it comes to garbage-collect it, it'll then write back those wrong numbers. But that's about the best we can expect. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-19Merge git://git.infradead.org/mtd-2.6KaiGai Kohei
2006-05-16[JFFS2] Repack some on-medium structures. ARM is weirder than I thought.David Woodhouse
We have to pack at least the jint16_t structure, because otherwise it'll be four bytes in size. Thankfully, we can do that and _not_ pack the actual node structures, and the compiler still doesn't emit stupid code. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-15[JFFS2] Don't pack on-medium structures, because GCC emits crappy codeDavid Woodhouse
If we use __attribute__((packed)), GCC will _also_ assume that the structures aren't sensibly aligned, and it'll emit code to cope with that instead of straight word load/save. This can be _very_ suboptimal on architectures like ARM. Ideally, we want an attribute which just tells GCC not to do any padding, without the alignment side-effects. In the absense of that, we'll just drop the 'packed' attribute and hope that everything stays as it was (which to be fair is fairly much what we expect). And add some paranoia checks in the initialisation code, which should be optimised away completely in the normal case. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[JFFS2][XATTR] XATTR support on JFFS2 (version. 5)KaiGai Kohei
This attached patches provide xattr support including POSIX-ACL and SELinux support on JFFS2 (version.5). There are some significant differences from previous version posted at last December. The biggest change is addition of EBS(Erase Block Summary) support. Currently, both kernel and usermode utility (sumtool) can recognize xattr nodes which have JFFS2_NODETYPE_XATTR/_XREF nodetype. In addition, some bugs are fixed. - A potential race condition was fixed. - Unexpected fail when updating a xattr by same name/value pair was fixed. - A bug when removing xattr name/value pair was fixed. The fundamental structures (such as using two new nodetypes and exclusion mechanism by rwsem) are unchanged. But most of implementation were reviewed and updated if necessary. Espacially, we had to change several internal implementations related to load_xattr_datum() to avoid a potential race condition. [1/2] xattr_on_jffs2.kernel.version-5.patch [2/2] xattr_on_jffs2.utils.version-5.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-07[JFFS2] Clean up trailing white spacesThomas Gleixner
2005-11-06[JFFS2] Rename jffs2_summary_node to jffs2_raw_summaryFerenc Havasi
Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Add erase block summary support (mount time improvement)Ferenc Havasi
The goal of summary is to speed up the mount time. Erase block summary (EBS) stores summary information at the end of every (closed) erase block. It is no longer necessary to scan all nodes separetly (and read all pages of them) just read this "small" summary, where every information is stored which is needed at mount time. This summary information is stored in a JFFS2_FEATURE_RWCOMPAT_DELETE. During the mount process if there is no summary info the orignal scan process will be executed. EBS works with NAND and NOR flashes, too. There is a user space tool called sumtool to generate this summary information for a JFFS2 image. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[jffs2] Remove compressor lzo and lzariFerenc Havasi
Remove unused compressor code Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Namespace clean upArtem B. Bityutskiy
Rename functions to a name matching the functionality. Remove stall debug code Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
