path: root/include/linux/journal-head.h
2013-05-13jbd,jbd2: fix oops in jbd2_journal_put_journal_head()Jan Kara
Commit ae4647fb (jbd2: reduce journal_head size) introduced a regression where we occasionally hit panic in jbd2_journal_put_journal_head() because of wrong b_jcount. The bug is caused by gcc making 64-bit access to 32-bit bitfield and thus clobbering b_jcount. At least for now, those 8 bytes saved in struct journal_head are not worth the trouble with gcc bitfield handling so revert that part of the patch. Reported-by: EUNBONG SONG <eunb.song@samsung.com> Reported-by: Tony Luck <tony.luck@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-04-12jbd2: reduce journal_head sizeJan Kara
Remove unused t_cow_tid field (ext4 copy-on-write support doesn't seem to be happening) and change b_modified and b_jlist to bitfields thus saving 8 bytes in the structure. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
2012-03-13jbd2: remove bh_state lock from checkpointing codeJan Kara
All accesses to checkpointing entries in journal_head are protected by j_list_lock. Thus __jbd2_journal_remove_checkpoint() doesn't really need bh_state lock. Also the only part of journal head that the rest of checkpointing code needs to check is jh->b_transaction which is safe to read under j_list_lock. So we can safely remove bh_state lock from all of checkpointing code which makes it considerably prettier. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-25jbd: change the field "b_cow_tid" of struct journal_head from type unsigned ↵Wang Sheng-Hui
to tid_t In the definition of struct journal_head, the comment for the field "unsigned b_cow_tid" says the field tracks the last transaction id in which this buffer has been cowed. In the header part of file journal-head.h, it defines typedef unsigned int tid_t; We should use type tid_t to define transaction id fields. Change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Acked-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-20jbd2: add the b_cow_tid field to journal_head structAmir Goldstein
The b_cow_tid field will be used by the ext4 snapshots code to store the transaction id when the buffer was last cowed. Merging this patch to mainline will allow users to test ext4 snapshots as a standalone module, without the need to patch and install a development kernel. On 64bit machines this field uses fills in a padding "hole" and does not increase the size of the struct. On a 32bit machine this patch increases the size of the struct from 60 to 64 bytes. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05jbd2: Add buffer triggersJoel Becker
Filesystems often to do compute intensive operation on some metadata. If this operation is repeated many times, it can be very expensive. It would be much nicer if the operation could be performed once before a buffer goes to disk. This adds triggers to jbd2 buffer heads. Just before writing a metadata buffer to the journal, jbd2 will optionally call a commit trigger associated with the buffer. If the journal is aborted, an abort trigger will be called on any dirty buffers as they are dropped from pending transactions. ocfs2 will use this feature. Initially I tried to come up with a more generic trigger that could be used for non-buffer-related events like transaction completion. It doesn't tie nicely, because the information a buffer trigger needs (specific to a journal_head) isn't the same as what a transaction trigger needs (specific to a tranaction_t or perhaps journal_t). So I implemented a buffer set, with the understanding that journal/transaction wide triggers should be implemented separately. There is only one trigger set allowed per buffer. I can't think of any reason to attach more than one set. Contrast this with a journal or transaction in which multiple places may want to watch the entire transaction separately. The trigger sets are considered static allocation from the jbd2 perspective. ocfs2 will just have one trigger set per block type, setting the same set on every bh of the same type. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
