path: root/include/linux/kbd_kern.h
2012-03-08vt:tackle kbd_tableAlan Cox
Keyboard struct lifetime is easy, but the locking is not and is completely ignored by the existing code. Tackle this one head on - Make the kbd_table private so we can run down all direct users - Hoick the relevant ioctl handlers into the keyboard layer - Lock them with the keyboard lock so they don't change mid keypress - Add helpers for things like console stop/start so we isolate the poking around properly - Tweak the braille console so it still builds There are a couple of FIXME locking cases left for ioctls that are so hideous they should be addressed in a later patch. After this patch the kbd_table is private and all the keyboard jiggery pokery is in one place. This update fixes speakup and also a memory leak in the original. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-03-22tty: stop using "delayed_work" in the tty layerLinus Torvalds
Using delayed-work for tty flip buffers ends up causing us to wait for the next tick to complete some actions. That's usually not all that noticeable, but for certain latency-critical workloads it ends up being totally unacceptable. As an extreme case of this, passing a token back-and-forth over a pty will take two ticks per iteration, so even just a thousand iterations will take 8 seconds assuming a common 250Hz configuration. Avoiding the whole delayed work issue brings that ping-pong test-case down to 0.009s on my machine. In more practical terms, this latency has been a performance problem for things like dive computer simulators (simulating the serial interface using the ptys) and for other environments (Alan mentions a CP/M emulator). Reported-by: Jef Driesen <jefdriesen@telenet.be> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-17vt: Add virtual console keyboard mode OFFArthur Taylor
virtual console: add keyboard mode OFF Add a new mode for the virtual console keyboard OFF in which all input other than shift keys is ignored. Prevents vt input buffers from overflowing when a program opens but doesn't read from a tty, like X11 using evdev for input. Signed-off-by: Arthur Taylor <art@ified.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-30Input: Mac button emulation - implement as an input filterDmitry Torokhov
Current implementation of Mac mouse button emulation plugs into legacy keyboard driver, converts certain keys into button events on a separate device, and suppresses the real events from reaching tty. This worked well enough until user space started using evdev which was completely unaware of this arrangement and kept sending original key presses to its users. Change the implementation to use newly added input filter framework so that original key presses are not transmitted to any handlers. As a bonus remove SYSCTL dependencies from the code and use Kconfig instead; also do not create the emulated mouse device until user activates emulation. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-08-22m68k/mac: Make mac_hid_mouse_emulate_buttons() declaration visibleGeert Uytterhoeven
m68k/mac: Make mac_hid_mouse_emulate_buttons() declaration visible drivers/char/keyboard.c: In function 'kbd_keycode': drivers/char/keyboard.c:1142: error: implicit declaration of function 'mac_hid_mouse_emulate_buttons' The forward declaration of mac_hid_mouse_emulate_buttons() is not visible on m68k because it's hidden in the middle of a big #ifdef block. Move it to <linux/kbd_kern.h>, correct the type of the second parameter, and include <linux/kbd_kern.h> where needed. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] swsusp: fix suspend when console is in VT_AUTO+KD_GRAPHICS modeAndrew Johnson
When the console is in VT_AUTO+KD_GRAPHICS mode, switching to the SUSPEND_CONSOLE fails, resulting in vt_waitactive() waiting indefinitely or until the task is interrupted. This patch tests if a console switch can occur in set_console() and returns early if a console switch is not possible. [akpm@linux-foundation.org: cleanup] Signed-off-by: Andrew Johnson <ajohnson@intrinsyc.com> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-22WorkStruct: Separate delayable and non-delayable events.David Howells
Separate delayable work items from non-delayable work items be splitting them into a separate structure (delayed_work), which incorporates a work_struct and the timer_list removed from work_struct. The work_struct struct is huge, and this limits it's usefulness. On a 64-bit architecture it's nearly 100 bytes in size. This reduces that by half for the non-delayable type of event. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-06-28[PATCH] remove active field from tty buffer structurePaul Fulghum
Remove 'active' field from tty buffer structure. This was added in 2.6.16 as part of a patch to make the new tty buffering SMP safe. This field is unnecessary with the more intelligently written flush_to_ldisc that adds receive_room handling. Removing this field reverts to simpler logic where the tail buffer is always the 'active' buffer, which should not be freed by flush_to_ldisc. (active == buffer being filled with new data) The result is simpler, smaller, and faster tty buffer code. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02Input: add support for Braille devicesSamuel Thibault
- Add KEY_BRL_* input keys and K_BRL_* keycodes; - Add emulation of how braille keyboards usually combine braille dots to the console keyboard driver; - Add handling of unicode U+28xy diacritics. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-02-10[PATCH] tty buffering stall fixPaul Fulghum
Prevent stalled processing of received data when a driver allocates tty buffer space but does not immediately follow the allocation with more data and a call to schedule receive tty processing. (example: hvc_console) This bug was introduced by the first locking patch for the new tty buffering. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] new tty buffering locking fixPaul Fulghum
Change locking in the new tty buffering facility from using tty->read_lock, which is currently ignored by drivers and thus ineffective. New locking uses a new tty buffering specific lock enforced centrally in the tty buffering code. Two drivers (esp and cyclades) are updated to use the tty buffering functions instead of accessing tty buffering internals directly. This is required for the new locking to work. Minor checks for NULL buffers added to tty_prepare_flip_string/tty_prepare_flip_string_flags Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
