path: root/include/linux/kdev_t.h
2007-04-04[PATCH] remove protection of LANANA-reserved majorsAndrew Morton
Revert all this. It can cause device-mapper to receive a different major from earlier kernels and it turns out that the Amanda backup program (via GNU tar, apparently) checks major numbers on files when performing incremental backups. Which is a bit broken of Amanda (or tar), but this feature isn't important enough to justify the churn. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] rework reserved major handlingAndrew Morton
Several people have reported failures in dynamic major device number handling due to the recent changes in there to avoid handing out the local/experimental majors. Rolf reports that this is due to a gcc-4.1.0 bug. The patch refactors that code a lot in an attempt to provoke the compiler into behaving. Cc: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
