path: root/include/linux/kthread.h
2011-03-22kthread: NUMA aware kthread_create_on_node()Eric Dumazet
All kthreads being created from a single helper task, they all use memory from a single node for their kernel stack and task struct. This patch suite creates kthread_create_on_node(), adding a 'cpu' parameter to parameters already used by kthread_create(). This parameter serves in allocating memory for the new kthread on its memory node if possible. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-27kthread: Replace deprecated spinlock initializationThomas Gleixner
SPIN_LOCK_UNLOCK is deprecated. Use the lockdep capable variant instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-12-22kthread_work: make lockdep happyYong Zhang
spinlock in kthread_worker and wait_queue_head in kthread_work both should be lockdep sensible, so change the interface to make it suiltable for CONFIG_LOCKDEP. tj: comment update Reported-by: Nicolas <nicolas.mailhot@laposte.net> Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Andy Walls <awalls@md.metrocast.net> Tested-by: Andy Walls <awalls@md.metrocast.net> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-06-29kthread: implement kthread_data()Tejun Heo
Implement kthread_data() which takes @task pointing to a kthread and returns @data specified when creating the kthread. The caller is responsible for ensuring the validity of @task when calling this function. Signed-off-by: Tejun Heo <tj@kernel.org>
2010-06-29kthread: implement kthread_workerTejun Heo
Implement simple work processor for kthread. This is to ease using kthread. Single thread workqueue used to be used for things like this but workqueue won't guarantee fixed kthread association anymore to enable worker sharing. This can be used in cases where specific kthread association is necessary, for example, when it should have RT priority or be assigned to certain cgroup. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2008-07-24Label kthread_create() with printf attribute tag.Rusty Russell
Obvious misc patch been in my queue (& linux-next) for over a cycle. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09kthread: don't depend on work queuesEric W. Biederman
Currently there is a circular reference between work queue initialization and kthread initialization. This prevents the kthread infrastructure from initializing until after work queues have been initialized. We want the properties of tasks created with kthread_create to be as close as possible to the init_task and to not be contaminated by user processes. The later we start our kthreadd that creates these tasks the harder it is to avoid contamination from user processes and the more of a mess we have to clean up because the defaults have changed on us. So this patch modifies the kthread support to not use work queues but to instead use a simple list of structures, and to have kthreadd start from init_task immediately after our kernel thread that execs /sbin/init. By being a true child of init_task we only have to change those process settings that we want to have different from init_task, such as our process name, the cpus that are allowed, blocking all signals and setting SIGCHLD to SIG_IGN so that all of our children are reaped automatically. By being a true child of init_task we also naturally get our ppid set to 0 and do not wind up as a child of PID == 1. Ensuring that tasks generated by kthread_create will not slow down the functioning of the wait family of functions. [akpm@linux-foundation.org: use interruptible sleeps] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-14[PATCH] remove kernel/kthread.c:kthread_stop_sem()Adrian Bunk
Remove the now-unneeded kthread_stop_sem(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] kthread: move kernel-doc and put it into DocBookRandy Dunlap
Move kthread API kernel-doc from kthread.h to kthread.c & fix it. Add kthread API to kernel-api DocBook. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Add kthread_stop_sem()Alan Stern
Enhance the kthread API by adding kthread_stop_sem, for use in stopping threads that spend their idle time waiting on a semaphore. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
