path: root/include/linux/kvm.h
2012-03-08KVM: Allow host IRQ sharing for assigned PCI 2.3 devicesJan Kiszka
PCI 2.3 allows to generically disable IRQ sources at device level. This enables us to share legacy IRQs of such devices with other host devices when passing them to a guest. The new IRQ sharing feature introduced here is optional, user space has to request it explicitly. Moreover, user space can inform us about its view of PCI_COMMAND_INTX_DISABLE so that we can avoid unmasking the interrupt and signaling it if the guest masked it via the virtualized PCI config space. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: PPC: Add support for explicit HIOR settingAlexander Graf
Until now, we always set HIOR based on the PVR, but this is just wrong. Instead, we should be setting HIOR explicitly, so user space can decide what the initial HIOR value is - just like on real hardware. We keep the old PVR based way around for backwards compatibility, but once user space uses the SET_ONE_REG based method, we drop the PVR logic. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: PPC: Add generic single register ioctlsAlexander Graf
Right now we transfer a static struct every time we want to get or set registers. Unfortunately, over time we realize that there are more of these than we thought of before and the extensibility and flexibility of transferring a full struct every time is limited. So this is a new approach to the problem. With these new ioctls, we can get and set a single register that is identified by an ID. This allows for very precise and limited transmittal of data. When we later realize that it's a better idea to shove over multiple registers at once, we can reuse most of the infrastructure and simply implement a GET_MANY_REGS / SET_MANY_REGS interface. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: PPC: e500: MMU APIScott Wood
This implements a shared-memory API for giving host userspace access to the guest's TLB. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: provide synchronous registers in kvm_runChristian Borntraeger
On some cpus the overhead for virtualization instructions is in the same range as a system call. Having to call multiple ioctls to get set registers will make certain userspace handled exits more expensive than necessary. Lets provide a section in kvm_run that works as a shared save area for guest registers. We also provide two 64bit flags fields (architecture specific), that will specify 1. which parts of these fields are valid. 2. which registers were modified by userspace Each bit for these flag fields will define a group of registers (like general purpose) or a single register. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: announce capability for user controlled vmsCarsten Otte
This patch announces a new capability KVM_CAP_S390_UCONTROL that indicates that kvm can now support virtual machines that are controlled by userspace. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: interface to inject faults on a vcpu page tableCarsten Otte
This patch allows the user to fault in pages on a virtual cpus address space for user controlled virtual machines. Typically this is superfluous because userspace can just create a mapping and let the kernel's page fault logic take are of it. There is one exception: SIE won't start if the lowcore is not present. Normally the kernel takes care of this [handle_validity() in arch/s390/kvm/intercept.c] but since the kernel does not handle intercepts for user controlled virtual machines, userspace needs to be able to handle this condition. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export SIE control block to userCarsten Otte
This patch exports the s390 SIE hardware control block to userspace via the mapping of the vcpu file descriptor. In order to do so, a new arch callback named kvm_arch_vcpu_fault is introduced for all architectures. It allows to map architecture specific pages. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export page faults to userCarsten Otte
This patch introduces a new exit reason in the kvm_run structure named KVM_EXIT_S390_UCONTROL. This exit indicates, that a virtual cpu has regognized a fault on the host page table. The idea is that userspace can handle this fault by mapping memory at the fault location into the cpu's address space and then continue to run the virtual cpu. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: per vcpu address spacesCarsten Otte
This patch introduces two ioctls for virtual cpus, that are only valid for kernel virtual machines that are controlled by userspace. Each virtual cpu has its individual address space in this mode of operation, and each address space is backed by the gmap implementation just like the address space for regular KVM guests. KVM_S390_UCAS_MAP allows to map a part of the user's virtual address space to the vcpu. Starting offset and length in both the user and the vcpu address space need to be aligned to 1M. KVM_S390_UCAS_UNMAP can be used to unmap a range of memory from a virtual cpu in a similar way. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: add parameter for KVM_CREATE_VMCarsten Otte
This patch introduces a new config option for user controlled kernel virtual machines. It introduces a parameter to KVM_CREATE_VM that allows to set bits that alter the capabilities of the newly created virtual machine. The parameter is passed to kvm_arch_init_vm for all architectures. The only valid modifier bit for now is KVM_VM_S390_UCONTROL. This requires CAP_SYS_ADMIN privileges and creates a user controlled virtual machine on s390 architectures. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-26KVM: Don't automatically expose the TSC deadline timer in cpuidJan Kiszka
Unlike all of the other cpuid bits, the TSC deadline timer bit is set unconditionally, regardless of what userspace wants. This is broken in several ways: - if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC deadline timer feature, a guest that uses the feature will break - live migration to older host kernels that don't support the TSC deadline timer will cause the feature to be pulled from under the guest's feet; breaking it - guests that are broken wrt the feature will fail. Fix by not enabling the feature automatically; instead report it to userspace. Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not KVM_GET_SUPPORTED_CPUID. Fixes the Illumos guest kernel, which uses the TSC deadline timer feature. [avi: add the KVM_CAP + documentation] Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-11-17Revert "KVM: PPC: Add support for explicit HIOR setting"Alexander Graf
This reverts commit a15bd354f083f20f257db450488db52ac27df439. It exceeded the padding on the SREGS struct, rendering the ABI backwards-incompatible. Conflicts: arch/powerpc/kvm/powerpc.c include/linux/kvm.h Signed-off-by: Avi Kivity <avi@redhat.com>
2011-10-30KVM: s390: implement sigp external callChristian Ehrhardt
Implement sigp external call, which might be required for guests that issue an external call instead of an emergency signal for IPI. This fixes an issue with "KVM: unknown SIGP: 0x02" when booting such an SMP guest. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-25KVM: PPC: Enable the PAPR CAP for Book3SAlexander Graf
Now that Book3S PV mode can also run PAPR guests, we can add a PAPR cap and enable it for all Book3S targets. Enabling that CAP switches KVM into PAPR mode. Signed-off-by: Alexander Graf <agraf@suse.de>
2011-09-25KVM: PPC: Add support for explicit HIOR settingAlexander Graf
Until now, we always set HIOR based on the PVR, but this is just wrong. Instead, we should be setting HIOR explicitly, so user space can decide what the initial HIOR value is - just like on real hardware. We keep the old PVR based way around for backwards compatibility, but once user space uses the SREGS based method, we drop the PVR logic. Signed-off-by: Alexander Graf <agraf@suse.de>
2011-09-25KVM: x86: Raise the hard VCPU count limitSasha Levin
The patch raises the hard limit of VCPU count to 254. This will allow developers to easily work on scalability and will allow users to test high VCPU setups easily without patching the kernel. To prevent possible issues with current setups, KVM_CAP_NR_VCPUS now returns the recommended VCPU limit (which is still 64) - this should be a safe value for everybody, while a new KVM_CAP_MAX_VCPUS returns the hard limit which is now 254. Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Suggested-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-20[S390] kvm: extension capability for new address space layoutChristian Borntraeger
598841ca9919d008b520114d8a4378c4ce4e40a1 ([S390] use gmap address spaces for kvm guest images) changed kvm on s390 to use a separate address space for kvm guests. We can now put KVM guests anywhere in the user address mode with a size up to 8PB - as long as the memory is 1MB-aligned. This change was done without KVM extension capability bit. The change was added after 3.0, but we still have a chance to add a feature bit before 3.1 (keeping the releases in a sane state). We use number 71 to avoid collisions with other pending kvm patches as requested by Alexander Graf. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@redhat.com> Cc: Alexander Graf <agraf@suse.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-07-12KVM: PPC: Allocate RMAs (Real Mode Areas) at boot for use by guestsPaul Mackerras
This adds infrastructure which will be needed to allow book3s_hv KVM to run on older POWER processors, including PPC970, which don't support the Virtual Real Mode Area (VRMA) facility, but only the Real Mode Offset (RMO) facility. These processors require a physically contiguous, aligned area of memory for each guest. When the guest does an access in real mode (MMU off), the address is compared against a limit value, and if it is lower, the address is ORed with an offset value (from the Real Mode Offset Register (RMOR)) and the result becomes the real address for the access. The size of the RMA has to be one of a set of supported values, which usually includes 64MB, 128MB, 256MB and some larger powers of 2. Since we are unlikely to be able to allocate 64MB or more of physically contiguous memory after the kernel has been running for a while, we allocate a pool of RMAs at boot time using the bootmem allocator. The size and number of the RMAs can be set using the kvm_rma_size=xx and kvm_rma_count=xx kernel command line options. KVM exports a new capability, KVM_CAP_PPC_RMA, to signal the availability of the pool of preallocated RMAs. The capability value is 1 if the processor can use an RMA but doesn't require one (because it supports the VRMA facility), or 2 if the processor requires an RMA for each guest. This adds a new ioctl, KVM_ALLOCATE_RMA, which allocates an RMA from the pool and returns a file descriptor which can be used to map the RMA. It also returns the size of the RMA in the argument structure. Having an RMA means we will get multiple KMV_SET_USER_MEMORY_REGION ioctl calls from userspace. To cope with this, we now preallocate the kvm->arch.ram_pginfo array when the VM is created with a size sufficient for up to 64GB of guest memory. Subsequently we will get rid of this array and use memory associated with each memslot instead. This moves most of the code that translates the user addresses into host pfns (page frame numbers) out of kvmppc_prepare_vrma up one level to kvmppc_core_prepare_memory_region. Also, instead of having to look up the VMA for each page in order to check the page size, we now check that the pages we get are compound pages of 16MB. However, if we are adding memory that is mapped to an RMA, we don't bother with calling get_user_pages_fast and instead just offset from the base pfn for the RMA. Typically the RMA gets added after vcpus are created, which makes it inconvenient to have the LPCR (logical partition control register) value in the vcpu->arch struct, since the LPCR controls whether the processor uses RMA or VRMA for the guest. This moves the LPCR value into the kvm->arch struct and arranges for the MER (mediated external request) bit, which is the only bit that varies between vcpus, to be set in assembly code when going into the guest if there is a pending external interrupt request. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Allow book3s_hv guests to use SMT processor modesPaul Mackerras
This lifts the restriction that book3s_hv guests can only run one hardware thread per core, and allows them to use up to 4 threads per core on POWER7. The host still has to run single-threaded. This capability is advertised to qemu through a new KVM_CAP_PPC_SMT capability. The return value of the ioctl querying this capability is the number of vcpus per virtual CPU core (vcore), currently 4. To use this, the host kernel should be booted with all threads active, and then all the secondary threads should be offlined. This will put the secondary threads into nap mode. KVM will then wake them from nap mode and use them for running guest code (while they are still offline). To wake the secondary threads, we send them an IPI using a new xics_wake_cpu() function, implemented in arch/powerpc/sysdev/xics/icp-native.c. In other words, at this stage we assume that the platform has a XICS interrupt controller and we are using icp-native.c to drive it. Since the woken thread will need to acknowledge and clear the IPI, we also export the base physical address of the XICS registers using kvmppc_set_xics_phys() for use in the low-level KVM book3s code. When a vcpu is created, it is assigned to a virtual CPU core. The vcore number is obtained by dividing the vcpu number by the number of threads per core in the host. This number is exported to userspace via the KVM_CAP_PPC_SMT capability. If qemu wishes to run the guest in single-threaded mode, it should make all vcpu numbers be multiples of the number of threads per core. We distinguish three states of a vcpu: runnable (i.e., ready to execute the guest), blocked (that is, idle), and busy in host. We currently implement a policy that the vcore can run only when all its threads are runnable or blocked. This way, if a vcpu needs to execute elsewhere in the kernel or in qemu, it can do so without being starved of CPU by the other vcpus. When a vcore starts to run, it executes in the context of one of the vcpu threads. The other vcpu threads all go to sleep and stay asleep until something happens requiring the vcpu thread to return to qemu, or to wake up to run the vcore (this can happen when another vcpu thread goes from busy in host state to blocked). It can happen that a vcpu goes from blocked to runnable state (e.g. because of an interrupt), and the vcore it belongs to is already running. In that case it can start to run immediately as long as the none of the vcpus in the vcore have started to exit the guest. We send the next free thread in the vcore an IPI to get it to start to execute the guest. It synchronizes with the other threads via the vcore->entry_exit_count field to make sure that it doesn't go into the guest if the other vcpus are exiting by the time that it is ready to actually enter the guest. Note that there is no fixed relationship between the hardware thread number and the vcpu number. Hardware threads are assigned to vcpus as they become runnable, so we will always use the lower-numbered hardware threads in preference to higher-numbered threads if not all the vcpus in the vcore are runnable, regardless of which vcpus are runnable. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Accelerate H_PUT_TCE by implementing it in real modeDavid Gibson
This improves I/O performance for guests using the PAPR paravirtualization interface by making the H_PUT_TCE hcall faster, by implementing it in real mode. H_PUT_TCE is used for updating virtual IOMMU tables, and is used both for virtual I/O and for real I/O in the PAPR interface. Since this moves the IOMMU tables into the kernel, we define a new KVM_CREATE_SPAPR_TCE ioctl to allow qemu to create the tables. The ioctl returns a file descriptor which can be used to mmap the newly created table. The qemu driver models use them in the same way as userspace managed tables, but they can be updated directly by the guest with a real-mode H_PUT_TCE implementation, reducing the number of host/guest context switches during guest IO. There are certain circumstances where it is useful for userland qemu to write to the TCE table even if the kernel H_PUT_TCE path is used most of the time. Specifically, allowing this will avoid awkwardness when we need to reset the table. More importantly, we will in the future need to write the table in order to restore its state after a checkpoint resume or migration. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: PPC: Add support for Book3S processors in hypervisor modePaul Mackerras
This adds support for KVM running on 64-bit Book 3S processors, specifically POWER7, in hypervisor mode. Using hypervisor mode means that the guest can use the processor's supervisor mode. That means that the guest can execute privileged instructions and access privileged registers itself without trapping to the host. This gives excellent performance, but does mean that KVM cannot emulate a processor architecture other than the one that the hardware implements. This code assumes that the guest is running paravirtualized using the PAPR (Power Architecture Platform Requirements) interface, which is the interface that IBM's PowerVM hypervisor uses. That means that existing Linux distributions that run on IBM pSeries machines will also run under KVM without modification. In order to communicate the PAPR hypercalls to qemu, this adds a new KVM_EXIT_PAPR_HCALL exit code to include/linux/kvm.h. Currently the choice between book3s_hv support and book3s_pr support (i.e. the existing code, which runs the guest in user mode) has to be made at kernel configuration time, so a given kernel binary can only do one or the other. This new book3s_hv code doesn't support MMIO emulation at present. Since we are running paravirtualized guests, this isn't a serious restriction. With the guest running in supervisor mode, most exceptions go straight to the guest. We will never get data or instruction storage or segment interrupts, alignment interrupts, decrementer interrupts, program interrupts, single-step interrupts, etc., coming to the hypervisor from the guest. Therefore this introduces a new KVMTEST_NONHV macro for the exception entry path so that we don't have to do the KVM test on entry to those exception handlers. We do however get hypervisor decrementer, hypervisor data storage, hypervisor instruction storage, and hypervisor emulation assist interrupts, so we have to handle those. In hypervisor mode, real-mode accesses can access all of RAM, not just a limited amount. Therefore we put all the guest state in the vcpu.arch and use the shadow_vcpu in the PACA only for temporary scratch space. We allocate the vcpu with kzalloc rather than vzalloc, and we don't use anything in the kvmppc_vcpu_book3s struct, so we don't allocate it. We don't have a shared page with the guest, but we still need a kvm_vcpu_arch_shared struct to store the values of various registers, so we include one in the vcpu_arch struct. The POWER7 processor has a restriction that all threads in a core have to be in the same partition. MMU-on kernel code counts as a partition (partition 0), so we have to do a partition switch on every entry to and exit from the guest. At present we require the host and guest to run in single-thread mode because of this hardware restriction. This code allocates a hashed page table for the guest and initializes it with HPTEs for the guest's Virtual Real Memory Area (VRMA). We require that the guest memory is allocated using 16MB huge pages, in order to simplify the low-level memory management. This also means that we can get away without tracking paging activity in the host for now, since huge pages can't be paged or swapped. This also adds a few new exports needed by the book3s_hv code. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2011-07-12KVM: Clarify KVM_ASSIGN_PCI_DEVICE documentationJan Kiszka
Neither host_irq nor the guest_msi struct are used anymore today. Tag the former, drop the latter to avoid confusion. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: PPC: booke: add sregs supportScott Wood
2011-05-11KVM: X86: Implement userspace interface to set virtual_tsc_khzJoerg Roedel
This patch implements two new vm-ioctls to get and set the virtual_tsc_khz if the machine supports tsc-scaling. Setting the tsc-frequency is only possible before userspace creates any vcpu. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: Add PV MSR to enable asynchronous page faults delivery.Gleb Natapov
Guest enables async PF vcpu functionality using this MSR. Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: PPC: Expose level based interrupt capAlexander Graf
Now that we have all the level interrupt magic in place, let's expose the capability to user space, so it can make use of it! Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: PPC: Add get_pvinfo interface to query hypercall instructionsAlexander Graf
We need to tell the guest the opcodes that make up a hypercall through interfaces that are controlled by userspace. So we need to add a call for userspace to allow it to query those opcodes so it can pass them on. This is required because the hypercall opcodes can change based on the hypervisor conditions. If we're running in hardware accelerated hypervisor mode, a hypercall looks different from when we're running without hardware acceleration. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Remove memory alias supportAvi Kivity
As advertised in feature-removal-schedule.txt. Equivalent support is provided by overlapping memory regions. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: x86: XSAVE/XRSTOR live migration supportSheng Yang
This patch enable save/restore of xsave state. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: PPC: Add OSI hypercall interfaceAlexander Graf
MOL uses its own hypercall interface to call back into userspace when the guest wants to do something. So let's implement that as an exit reason, specify it with a CAP and only really use it when userspace wants us to. The only user of it so far is MOL. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: Add support for enabling capabilities per-vcpuAlexander Graf
Some times we don't want all capabilities to be available to all our vcpus. One example for that is the OSI interface, implemented in the next patch. In order to have a generic mechanism in how to enable capabilities individually, this patch introduces a new ioctl that can be used for this purpose. That way features we don't want in all guests or userspace configurations can just not be enabled and we're good. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: PPC: Allow userspace to unset the IRQ lineAlexander Graf
Userspace can tell us that it wants to trigger an interrupt. But so far it can't tell us that it wants to stop triggering one. So let's interpret the parameter to the ioctl that we have anyways to tell us if we want to raise or lower the interrupt line. Signed-off-by: Alexander Graf <agraf@suse.de> v2 -> v3: - Add CAP for unset irq Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: x86: Add support for saving&restoring debug registersJan Kiszka
So far user space was not able to save and restore debug registers for migration or after reset. Plug this hole. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: x86: Save&restore interrupt shadow maskJan Kiszka
The interrupt shadow created by STI or MOV-SS-like operations is part of the VCPU state and must be preserved across migration. Transfer it in the spare padding field of kvm_vcpu_events.interrupt. As a side effect we now have to make vmx_set_interrupt_shadow robust against both shadow types being set. Give MOV SS a higher priority and skip STI in that case to avoid that VMX throws a fault on next entry. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-25KVM: PPC: Add capability for paired singlesAlexander Graf
We need to tell userspace that we can emulate paired single instructions. So let's add a capability export. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: x86: Add KVM_CAP_X86_ROBUST_SINGLESTEPJan Kiszka
This marks the guest single-step API improvement of 94fe45da and 91586a3b with a capability flag to allow reliable detection by user space. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: stable@kernel.org (2.6.33) Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: enable PCI multiple-segments for pass-through deviceZhai, Edwin
Enable optional parameter (default 0) - PCI segment (or domain) besides BDF, when assigning PCI device to guest. Signed-off-by: Zhai Edwin <edwin.zhai@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: Implement NotifyLongSpinWait HYPER-V hypercallGleb Natapov
Windows issues this hypercall after guest was spinning on a spinlock for too many iterations. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Vadim Rozenfeld <vrozenfe@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Add HYPER-V apic access MSRsGleb Natapov
Implement HYPER-V apic MSRs. Spec defines three MSRs that speed-up access to EOI/TPR/ICR apic registers for PV guests. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Vadim Rozenfeld <vrozenfe@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Implement bare minimum of HYPER-V MSRsGleb Natapov
Minimum HYPER-V implementation should have GUEST_OS_ID, HYPERCALL and VP_INDEX MSRs. [avi: fix build on i386] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Vadim Rozenfeld <vrozenfe@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: introduce kvm->srcu and convert kvm_set_memory_region to SRCU updateMarcelo Tosatti
Use two steps for memslot deletion: mark the slot invalid (which stops instantiation of new shadow pages for that slot, but allows destruction), then instantiate the new empty slot. Also simplifies kvm_handle_hva locking. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-09Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Conflicts: include/linux/kvm.h
2009-12-08powerpc/kvm: Sync guest visible MMU stateAlexander Graf
Currently userspace has no chance to find out which virtual address space we're in and resolve addresses. While that is a big problem for migration, it's also unpleasent when debugging, as gdb and the monitor don't work on virtual addresses. This patch exports enough of the MMU segment state to userspace to make debugging work and thus also includes the groundwork for migration. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-03KVM: s390: Make psw available on all exits, not just a subsetCarsten Otte
This patch moves s390 processor status word into the base kvm_run struct and keeps it up-to date on all userspace exits. The userspace ABI is broken by this, however there are no applications in the wild using this. A capability check is provided so users can verify the updated API exists. Cc: stable@kernel.org Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: x86: Add KVM_GET/SET_VCPU_EVENTSJan Kiszka
This new IOCTL exports all yet user-invisible states related to exceptions, interrupts, and NMIs. Together with appropriate user space changes, this fixes sporadic problems of vmsave/restore, live migration and system reset. [avi: future-proof abi by adding a flags field] Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: VMX: Report unexpected simultaneous exceptions as internal errorsAvi Kivity
These happen when we trap an exception when another exception is being delivered; we only expect these with MCEs and page faults. If something unexpected happens, things probably went south and we're better off reporting an internal error and freezing. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Allow internal errors reported to userspace to carry extra dataAvi Kivity
Usually userspace will freeze the guest so we can inspect it, but some internal state is not available. Add extra data to internal error reporting so we can expose it to the debugger. Extra data is specific to the suberror. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Reorder IOCTLs in main kvm.hJan Kiszka
Obviously, people tend to extend this header at the bottom - more or less blindly. Ensure that deprecated stuff gets its own corner again by moving things to the top. Also add some comments and reindent IOCTLs to make them more readable and reduce the risk of number collisions. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: allow userspace to adjust kvmclock offsetGlauber Costa
When we migrate a kvm guest that uses pvclock between two hosts, we may suffer a large skew. This is because there can be significant differences between the monotonic clock of the hosts involved. When a new host with a much larger monotonic time starts running the guest, the view of time will be significantly impacted. Situation is much worse when we do the opposite, and migrate to a host with a smaller monotonic clock. This proposed ioctl will allow userspace to inform us what is the monotonic clock value in the source host, so we can keep the time skew short, and more importantly, never goes backwards. Userspace may also need to trigger the current data, since from the first migration onwards, it won't be reflected by a simple call to clock_gettime() anymore. [marcelo: future-proof abi with a flags field] [jan: fix KVM_GET_CLOCK by clearing flags field instead of checking it] Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
