path: root/include/linux/leds-pca9532.h
2011-05-25drivers/leds/leds-pca9532.c: add gpio capabilityJoachim Eastwood
Allow unused leds on pca9532 to be used as gpio. The board I am working on now has no less than 6 pca9532 chips. One chips is used for only leds, one has 14 leds and 2 gpio and the rest of the chips are gpio only. There is also one board in mainline which could use this capabilty; arch/arm/mach-iop32x/n2100.c 232 { .type = PCA9532_TYPE_NONE }, /* power OFF gpio */ 233 { .type = PCA9532_TYPE_NONE }, /* reset gpio */ This patch defines a new pin type, PCA9532_TYPE_GPIO, and registers a gpiochip if any pin has this type set. The gpio will registers all chip pins but will filter on gpio_request. [randy.dunlap@oracle.com: fix build when GPIOLIB is not enabled] Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jan Weitzel <j.weitzel@phytec.de> Cc: Juergen Kilb <j.kilb@phytec.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17leds: leds-pca9532.h- indent with tabs, not spacesAntonio Ospite
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-01-08leds: leds-pcs9532 - Move i2c work to a workquequeRiku Voipio
Apparently these might be called under atomic context, and i2c operations may sleep. BUG found by Ross Burton <ross@burtonini.com> Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2008-07-23leds: Add pca9532 led driverRiku Voipio
NXP pca9532 is a LED dimmer/controller attached to i2c bus. It allows attaching upto 16 leds which can either be on, off or dimmed and/or blinked with the two PWM modulators available. This driver is a "new-style" i2c driver that adheres to the driver model and implements the led framework api. Since the leds connected to the driver are platform specific, it is only useful when platform data is passed to the driver to define what leds are connected to which pins. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
