path: root/include/linux/list.h
2013-11-13list: introduce list_last_entry(), use list_{first,last}_entry()Oleg Nesterov
We already have list_first_entry(), it makes sense to also add list_last_entry() for consistency. And we use both helpers in list_for_each_*(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13list: change list_for_each_entry*() to use list_*_entry()Oleg Nesterov
Now that we have list_{next,prev}_entry() we can change list_for_each_entry*() and list_safe_reset_next() to use the new helpers to improve the readability. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13list: introduce list_next_entry() and list_prev_entry()Oleg Nesterov
Add two trivial helpers list_next_entry() and list_prev_entry(), they can have a lot of users including list.h itself. In fact the 1st one is already defined in events/core.c and bnx2x_sp.c, so the patch simply moves the definition to list.h. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-16linked-list: Remove __list_for_eachDave Jones
__list_for_each used to be the non prefetch() aware list walking primitive. When we removed the prefetch macros from the list routines, it became redundant. Given it does exactly the same thing as list_for_each now, we might as well remove it and call list_for_each directly. All users of __list_for_each have been converted to list_for_each calls in the current merge window. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-31list: introduce list_first_entry_or_nullJiri Pirko
non-rcu variant of list_first_or_null_rcu Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-14list: Fix double fetch of pointer in hlist_entry_safe()Paul E. McKenney
The current version of hlist_entry_safe() fetches the pointer twice, once to test for NULL and the other to compute the offset back to the enclosing structure. This is OK for normal lock-based use because in that case, the pointer cannot change. However, when the pointer is protected by RCU (as in "rcu_dereference(p)"), then the pointer can change at any time. This use case can result in the following sequence of events: 1. CPU 0 invokes hlist_entry_safe(), fetches the RCU-protected pointer as sees that it is non-NULL. 2. CPU 1 invokes hlist_del_rcu(), deleting the entry that CPU 0 just fetched a pointer to. Because this is the last entry in the list, the pointer fetched by CPU 0 is now NULL. 3. CPU 0 refetches the pointer, obtains NULL, and then gets a NULL-pointer crash. This commit therefore applies gcc's "({ })" statement expression to create a temporary variable so that the specified pointer is fetched only once, avoiding the above sequence of events. Please note that it is the caller's responsibility to use rcu_dereference() as needed. This allows RCU-protected uses to work correctly without imposing any additional overhead on the non-RCU case. Many thanks to Eric Dumazet for spotting root cause! Reported-by: CAI Qian <caiqian@redhat.com> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Li Zefan <lizefan@huawei.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19list: remove prefetching from regular list iteratorsLinus Torvalds
This is removes the use of software prefetching from the regular list iterators. We don't want it. If you do want to prefetch in some iterator of yours, go right ahead. Just don't expect the iterator to do it, since normally the downsides are bigger than the upsides. It also replaces <linux/prefetch.h> with <linux/const.h>, because the use of LIST_POISON ends up needing it. <linux/poison.h> is sadly not self-contained, and including prefetch.h just happened to hide that. Suggested by David Miller (networking has a lot of regular lists that are often empty or a single entry, and prefetching is not going to do anything but add useless instructions). Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: David S. Miller <davem@davemloft.net> Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19hlist: remove software prefetching in hlist iteratorsLinus Torvalds
They not only increase the code footprint, they actually make things slower rather than faster. On internationally acclaimed benchmarks ("make -j16" on an already fully built kernel source tree) the hlist prefetching slows down the build by up to 1%. (Almost all of it comes from hlist_for_each_entry_rcu() as used by avc_has_perm_noaudit(), which is very hot due to all the pathname lookups to see if there is anything to do). The cause seems to be two-fold: - on at least some Intel cores, prefetch(NULL) ends up with some microarchitectural stall due to the TLB miss that it incurs. The hlist case triggers this very commonly, since the NULL pointer is the last entry in the list. - the prefetch appears to cause more D$ activity, probably because it prefetches hash list entries that are never actually used (because we ended the search early due to a hit). Regardless, the numbers clearly say that the implicit prefetching is simply a bad idea. If some _particular_ user of the hlist iterators wants to prefetch the next list entry, they can do so themselves explicitly, rather than depend on all list iterators doing so implicitly. Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: David S. Miller <davem@davemloft.net> Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-18Expand CONFIG_DEBUG_LIST to several other list operationsLinus Torvalds
When list debugging is enabled, we aim to readably show list corruption errors, and the basic list_add/list_del operations end up having extra debugging code in them to do some basic validation of the list entries. However, "list_del_init()" and "list_move[_tail]()" ended up avoiding the debug code due to how they were written. This fixes that. So the _next_ time we have list_move() problems with stale list entries, we'll hopefully have an easier time finding them.. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25list.h: new helper - hlist_add_fake()Al Viro
Make node look as if it was on hlist, with hlist_del() working correctly. Usable without any locking... Convert a couple of places where we want to do that to inode->i_hash. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-07Drop a couple of unnecessary asm/system.h inclusionsDavid Howells
Drop inclusions of asm/system.h from linux/hardirq.h and linux/list.h as they're no longer required and prevent the M68K arch's IRQ flag handling macros from being made into inlined functions due to circular dependencies. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-07-06Merge branch 'master' into for-linusChris Metcalf
2010-07-06Move list types from <linux/list.h> to <linux/types.h>.Chris Metcalf
This allows a list_head (or hlist_head, etc.) to be used from places that used to be impractical, in particular <asm/processor.h>, which used to cause include file recursion: <linux/list.h> includes <linux/prefetch.h>, which always includes <asm/processor.h> for the prefetch macros, as well as <asm/system.h>, which often includes <asm/processor.h> directly or indirectly. This avoids a lot of painful workaround hackery on the tile architecture, where we use a list_head in the thread_struct to chain together tasks that are activated on a particular hardwall. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
2010-06-29fs: fix superblock iteration racenpiggin@suse.de
list_for_each_entry_safe is not suitable to protect against concurrent modification of the list. 6754af6 introduced a race in sb walking. list_for_each_entry can use the trick of pinning the current entry in the list before we drop and retake the lock because it subsequently follows cur->next. However list_for_each_entry_safe saves n=cur->next for following before entering the loop body, so when the lock is dropped, n may be deleted. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: John Stultz <johnstul@us.ibm.com> Cc: Frank Mayhar <fmayhar@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06lib: fix first line of kernel-doc for a few functionsBen Hutchings
The function name must be followed by a space, hypen, space, and a short description. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16list: Introduce list_rotate_left()Frederic Weisbecker
Bring a new list_rotate_left() helper that rotates a list to the left. This is useful for codes that need to round roubin elements which queue priority increases from tail to head. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
2008-09-01debugobjects: fix lockdep warningVegard Nossum
Daniel J. Blueman reported: > ======================================================= > [ INFO: possible circular locking dependency detected ] > 2.6.27-rc4-224c #1 > ------------------------------------------------------- > hald/4680 is trying to acquire lock: > (&n->list_lock){++..}, at: [<ffffffff802bfa26>] add_partial+0x26/0x80 > > but task is already holding lock: > (&obj_hash[i].lock){++..}, at: [<ffffffff8041cfdc>] > debug_object_free+0x5c/0x120 We fix it by moving the actual freeing to outside the lock (the lock now only protects the list). The pool lock is also promoted to irq-safe (suggested by Dan). It's necessary because free_pool is now called outside the irq disabled region. So we need to protect against an interrupt handler which calls debug_object_init(). [tglx@linutronix.de: added hlist_move_list helper to avoid looping through the list twice] Reported-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-08-08list.h: fix fatal kernel-doc errorRandy Dunlap
Fix fatal multi-line kernel-doc error in list.h: function short description must be on one line. Error(linux-2.6.27-rc2-git3//include/linux/list.h:318): duplicate section name 'Description' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07list.h: add list_cut_position()Luis R. Rodriguez
This adds list_cut_position() which lets you cut a list into two lists given a pivot in the list. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-07list.h: Add list_splice_tail() and list_splice_tail_init()Luis R. Rodriguez
If you are using linked lists for queues list_splice() will not do what you would expect even if you use the elements passed reversed. We need to handle these differently. We add list_splice_tail() and list_splice_tail_init(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-25lists: remove a redundant conditional definition of list_add()Robert P. J. Day
Remove the conditional surrounding the definition of list_add() from list.h since, if you define CONFIG_DEBUG_LIST, the definition you will subsequently pick up from lib/list_debug.c will be absolutely identical, at which point you can remove that redundant definition from list_debug.c as well. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19rcu: split list.h and move rcu-protected lists into rculist.hFranck Bui-Huu
Move rcu-protected lists from list.h into a new header file rculist.h. This is done because list are a very used primitive structure all over the kernel and it's currently impossible to include other header files in this list.h without creating some circular dependencies. For example, list.h implements rcu-protected list and uses rcu_dereference() without including rcupdate.h. It actually compiles because users of rcu_dereference() are macros. Others RCU functions could be used too but aren't probably because of this. Therefore this patch creates rculist.h which includes rcupdates without to many changes/troubles. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29lists: add "const" qualifier to first arg of list_splice() operationsRobert P. J. Day
Since neither the list_splice() nor __list_splice() routines modify their first argument, might as well declare them "const". [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28list.h: add list_is_singular()Masami Hiramatsu
Add list_is_singular() to check a list has just one entry. list_is_singular() is useful to check whether a list_head which have been temporarily allocated for listing objects can be released or not. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21Fix RCU list iterator use of 'rcu_dereference()'Linus Torvalds
The RCU iterators used 'rcu_dereference()' on an already-fetched RCU pointer value, which defeats the whole point of the exercise. When we dereference a pointer protected by RCU, we need to make sure that we only fetch the value _once_, because if the compiler ends up re-loading it due to register pressure, the newly reloaded value could be different from the previously fetched one, and you get inconsistent results. Cleaned-up, fixed, and the pointless list_for_each_safe_rcu #define deleted by Paul Kenney. Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19kernel-api docbook: fix content problemsRandy Dunlap
Fix kernel-api docbook contents problems. docproc: linux-2.6.23-git13/include/asm-x86/unaligned_32.h: No such file or directory Warning(linux-2.6.23-git13//include/linux/list.h:482): bad line: of list entry Warning(linux-2.6.23-git13//mm/filemap.c:864): No description found for parameter 'ra' Warning(linux-2.6.23-git13//block/ll_rw_blk.c:3760): No description found for parameter 'req' Warning(linux-2.6.23-git13//include/linux/input.h:1077): No description found for parameter 'private' Warning(linux-2.6.23-git13//include/linux/input.h:1077): No description found for parameter 'cdev' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17shrink_dcache_sb speedupDenis V. Lunev
This patch makes shrink_dcache_sb consistent with dentry pruning policy. On the first pass we iterate over dentry unused list and prepare some dentries for removal. However, since the existing code moves evicted dentries to the beginning of the LRU it can happen that fresh dentries from other superblocks will be inserted *before* our dentries. This can result in significant slowdown of shrink_dcache_sb(). Moreover, for virtual filesystems like unionfs which can call dput() during dentries kill existing code results in O(n^2) complexity. We observed 2 minutes shrink_dcache_sb() with only 35000 dentries. To avoid this effects we propose to isolate sb dentries at the end of LRU list. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrey Mirkin <amirkin@openvz.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NETNS]: Cleanup list walking in setup_net and cleanup_netPavel Emelyanov
I proposed introducing a list_for_each_entry_continue_reverse macro to be used in setup_net() when unrolling the failed ->init callback. Here is the macro and some more cleanup in the setup_net() itself to remove one variable from the stack :) The same thing is for the cleanup_net() - the existing list_for_each_entry_reverse() is used. Minor, but the code looks nicer. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-12include/linux: trivial repair whitespace damageDaniel Walker
Adding tabs where spaces currently are. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Introduce a handy list_first_entry macroPavel Emelianov
There are many places in the kernel where the construction like foo = list_entry(head->next, struct foo_struct, list); are used. The code might look more descriptive and neat if using the macro list_first_entry(head, type, member) \ list_entry((head)->next, type, member) Here is the macro itself and the examples of its usage in the generic code. If it will turn out to be useful, I can prepare the set of patches to inject in into arch-specific code, drivers, networking, etc. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] add an RCU version of list splicingCorey Minyard
This patch is in support of the IPMI driver. I have tested this with the IPMI driver changes coming in the next patch. Add a list_splice_init_rcu() function to splice an RCU-protected list into another list. This takes the sync function as an argument, so one would do something like: INIT_LIST_HEAD(&list); list_splice_init_rcu(&source, &dest, synchronize_rcu); The idea being to keep the RCU API proliferation down to a dull roar. [akpm@osdl.org: build fix] Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] fix various kernel-doc in header filesRobert P. J. Day
Fix a number of kernel-doc entries for header files in include/linux by making sure they begin with the appropriate '/**' notation and use @var notation. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Debug variants of linked list macrosDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] list_is_last utilityShailabh Nagar
Add another list utility function to check for last element in a list. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] add poison.h and patch primary usersRandy Dunlap
Localize poison values into one header file for better documentation and easier/quicker debugging and so that the same values won't be used for multiple purposes. Use these constants in core arch., mm, driver, and fs code. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Matt Mackall <mpm@selenic.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] list.h doc: change "counter" to "cursor"Randy Dunlap
Use loop "cursor" instead of loop "counter" for list iterator descriptions. They are not counters, they are pointers or positions. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fix list.h kernel-docRandy Dunlap
kernel-doc: Put all short function descriptions on one line or if they are too long, omit the short description & add a Description: section for them. Change some list iterator descriptions to use "current" point instead of "existing" point. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] list: introduce list_replace() helperOleg Nesterov
list_replace() is similar to list_replace_rcu(), but unlike list_replace_rcu() it could be used when list_empty(old) == 1 doesn't use barriers Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-29[NET]: use hlist_unhashed()Akinobu Mita
Use hlist_unhashed() rather than accessing inside data structure. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[LIST]: Introduce list_for_each_entry_fromArnaldo Carvalho de Melo
For iterating over list of given type continuing from existing point. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[LIST]: Introduce list_for_each_entry_safe_fromArnaldo Carvalho de Melo
For iterate over list of given type from existing point safe against removal of list entry. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-03[PATCH] list.h: don't evaluate macro args multiple timesZach Brown
I noticed that list.h init functions were evaluating macro arguments multiple times and thought it might be nice to protect the unsuspecting caller. Converting the macros to inline functions seems to reduce code size, too. A i386 defconfig build with gcc 3.3.3 from fc4: text data bss dec hex filename 3573148 565664 188828 4327640 4208d8 vmlinux.before 3572177 565664 188828 4326669 42050d vmlinux add/remove: 0/0 grow/shrink: 11/144 up/down: 88/-1016 (-928) There was no difference in checkstack output. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Add list_for_each_entry_safe_reverse()David Howells
Add list_for_each_entry_safe_reverse() to linux/list.h This is needed by unmerged cachefs and be an as-yet-unreviewed device_shutdown() fix. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Patrick Mochel <mochel@digitalimplant.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] add hlist_replace_rcu()Ingo Molnar
Add list_replace_rcu: replace old entry by new one. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Remove hlist_for_each_rcu() API, convert existing use to ↵Paul E. McKenney
hlist_for_each_entry_rcu Remove the hlist_for_each_rcu() API, which is used only in one place, and is trivially converted to hlist_for_each_entry_rcu(), making the code shorter and more readable. Any out-of-tree uses may be similarly converted. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-17[PATCH] list: add missing rcu_dereference on first elementHerbert Xu
It seems that all the list_*_rcu primitives are missing a memory barrier on the very first dereference. For example, #define list_for_each_rcu(pos, head) \ for (pos = (head)->next; prefetch(pos->next), pos != (head); \ pos = rcu_dereference(pos->next)) It will go something like: pos = (head)->next prefetch(pos->next) pos != (head) do stuff We're missing a barrier here. pos = rcu_dereference(pos->next) fetch pos->next barrier given by rcu_dereference(pos->next) store pos Without the missing barrier, the pos->next value may turn out to be stale. In fact, if "do stuff" were also dereferencing pos and relying on list_for_each_rcu to provide the barrier then it may also break. So here is a patch to make sure that we have a barrier for the first element in the list. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[LIST]: Add docbook header comments for hlist_add_{before,after}_rcu()Paul E. McKenney
