path: root/include/linux/mISDNhw.h
2009-07-25mISDN: Make clearing B-channel a common functionKarsten Keil
Clearing B-channel is needed in every driver, so it makes sense to have it as common function. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-06-11mISDN: cleanup mISDNhw.hKarsten Keil
Remove unused stuff. Signed-off-by: Karsten Keil <keil@b1-systems.de>
2009-05-25mISDN: Echo canceler now gets delay information from hardwareAndreas Eversberg
Added tx-fifo information for calculation of current delay to sync tx and rx streams for echo canceler. Signed-off-by: Andreas Eversberg <andreas@eversberg.eu> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-09mISDN: Add E-Channel logging featuresMartin Bachem
New prim PH_DATA_E_IND. - all E-ch frames are indicated by recv_Echannel(), which pushes E-Channel frames into dch's rqueue - if dchannel is opened with channel nr 0, no E-Channel logging is requested - if dchannel is opened with channel nr 1, E-Channel logging is requested. if layer1 does not support that, -EINVAL in return is appropriate Signed-off-by: Martin Bachem <m.bachem@gmx.de> Signed-off-by: Karsten Keil <kkeil@suse.de>
2009-01-09mISDN: Add feature via MISDN_CTRL_FILL_EMPTY to fill fifo if emptyAndreas Eversberg
This prevents underrun of fifo when filled and in case of an underrun it prevents subsequent underruns due to jitter. Improve dsp, so buffers are kept filled with a certain delay, so moderate jitter will not cause underrun all the time -> the audio quality is highly improved. tones are not interrupted by gaps anymore, except when CPU is stalling or in high load. Signed-off-by: Andreas Eversberg <andreas@eversberg.eu> Signed-off-by: Karsten Keil <kkeil@suse.de>
2008-07-27Add mISDN core filesKarsten Keil
Add mISDN core files Signed-off-by: Karsten Keil <kkeil@suse.de>
