path: root/include/linux/math64.h
2013-12-11math64: Add mul_u64_u32_shr()Peter Zijlstra
Introduce mul_u64_u32_shr() as proposed by Andy a while back; it allows using 64x64->128 muls on 64bit archs and recent GCC which defines __SIZEOF_INT128__ and __int128. (This new method will be used by the scheduler.) Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com Cc: Andy Lutomirski <luto@amacapital.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-hxjoeuzmrcaumR0uZwjpe2pv@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-23math64: New separate div64_u64_rem helperMike Snitzer
Commit f792685006274a850e6cc0ea9ade275ccdfc90bc ("math64: New div64_u64_rem helper") implemented div64_u64 in terms of div64_u64_rem. But div64_u64_rem was removed because it slowed down div64_u64 (and there were no other users of div64_u64_rem). Device Mapper's I/O statistics support has a need for div64_u64_rem; reintroduce this helper as a separate method that doesn't slow down div64_u64, especially on 32-bit systems. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-06-12include/linux/math64.h: add div64_ul()Alex Shi
There is div64_long() to handle the s64/long division, but no mocro do u64/ul division. It is necessary in some scenarios, so add this function. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alex Shi <alex.shi@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Revert "math64: New div64_u64_rem helper"Stanislaw Gruszka
This reverts commit f792685006274a850e6cc0ea9ade275ccdfc90bc. The cputime scaling code was changed/fixed and does not need the div64_u64_rem() primitive anymore. It has no other users, so let's remove them. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dave Hansen <dave@sr71.net> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1367314507-9728-4-git-send-email-sgruszka@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-13math64: New div64_u64_rem helperFrederic Weisbecker
Provide an extended version of div64_u64() that also returns the remainder of the division. We are going to need this to refine the cputime scaling code. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2012-03-15math: Introduce div64_longSasha Levin
Add a div64_long macro which is used to devide a 64bit number by a long (which can be 4 bytes on 32bit systems and 8 bytes on 64bit systems). Suggested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Cc: johnstul@us.ibm.com Link: http://lkml.kernel.org/r/1331829374-31543-1-git-send-email-levinsasha928@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-26div64_u64(): improve precision on 32bit platformsBrian Behlendorf
The current implementation of div64_u64 for 32bit systems returns an approximately correct result when the divisor exceeds 32bits. Since doing 64bit division using 32bit hardware is a long since solved problem we just use one of the existing proven methods. Additionally, add a div64_s64 function to correctly handle doing signed 64bit division. Addresses https://bugzilla.redhat.com/show_bug.cgi?id=616105 Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Ben Woodard <bwoodard@llnl.gov> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Mark Grondona <mgrondona@llnl.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12add an inlined version of iter_div_u64_remJeremy Fitzhardinge
iter_div_u64_rem is used in the x86-64 vdso, which cannot call other kernel code. For this case, provide the always_inlined version, __iter_div_u64_rem. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12common implementation of iterative div/modJeremy Fitzhardinge
We have a few instances of the open-coded iterative div/mod loop, used when we don't expcet the dividend to be much bigger than the divisor. Unfortunately modern gcc's have the tendency to strength "reduce" this into a full mod operation, which isn't necessarily any faster, and even if it were, doesn't exist if gcc implements it in libgcc. The workaround is to put a dummy asm statement in the loop to prevent gcc from performing the transformation. This patch creates a single implementation of this loop, and uses it to replace the open-coded versions I know about. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Segher Boessenkool <segher@kernel.crashing.org> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01introduce explicit signed/unsigned 64bit divideRoman Zippel
The current do_div doesn't explicitly say that it's unsigned and the signed counterpart is missing, which is e.g. needed when dealing with time values. This introduces 64bit signed/unsigned divide functions which also attempts to cleanup the somewhat awkward calling API, which often requires the use of temporary variables for the dividend. To avoid the need for temporary variables everywhere for the remainder, each divide variant also provides a version which doesn't return the remainder. Each architecture can now provide optimized versions of these function, otherwise generic fallback implementations will be used. As an example I provided an alternative for the current x86 divide, which avoids the asm casts and using an union allows gcc to generate better code. It also avoids the upper divde in a few more cases, where the result is known (i.e. upper quotient is zero). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
