commit ab936cbcd02072a34b60d268f94440fd5cf1970b upstream.
Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a
function replace_page_cache_page(). This function replaces a page in the
radix-tree with a new page. WHen doing this, memory cgroup needs to fix
up the accounting information. memcg need to check PCG_USED bit etc.
In some(many?) cases, 'newpage' is on LRU before calling
replace_page_cache(). So, memcg's LRU accounting information should be
fixed, too.
This patch adds mem_cgroup_replace_page_cache() and removes the old hooks.
In that function, old pages will be unaccounted without touching
res_counter and new page will be accounted to the memcg (of old page).
WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid
races with LRU handling.
Background:
replace_page_cache_page() is called by FUSE code in its splice() handling.
Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated
page and may be on LRU. LRU mis-accounting will be critical for memory cgroup
because rmdir() checks the whole LRU is empty and there is no account leak.
If a page is on the other LRU than it should be, rmdir() will fail.
This bug was added in March 2011, but no bug report yet. I guess there
are not many people who use memcg and FUSE at the same time with upstream
kernels.
The result of this bug is that admin cannot destroy a memcg because of
account leak. So, no panic, no deadlock. And, even if an active cgroup
exist, umount can succseed. So no problem at shutdown.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Revert the post-3.0 commit 82f9d486e59f5 ("memcg: add
memory.vmscan_stat").
The implementation of per-memcg reclaim statistics violates how memcg
hierarchies usually behave: hierarchically.
The reclaim statistics are accounted to child memcgs and the parent
hitting the limit, but not to hierarchy levels in between. Usually,
hierarchical statistics are perfectly recursive, with each level
representing the sum of itself and all its children.
Since this exports statistics to userspace, this may lead to confusion
and problems with changing things after the release, so revert it now,
we can try again later.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Remove mem_cgroup_shmem_charge_fallback(): it was only required when we
had to move swappage to filecache with GFP_NOWAIT.
Remove the GFP_NOWAIT special case from mem_cgroup_cache_charge(), by
moving its call out from shmem_add_to_page_cache() to two of thats three
callers. But leave it doing mem_cgroup_uncharge_cache_page() on error:
although asymmetrical, it's easier for all 3 callers to handle.
These two changes would also be appropriate if anyone were to start
using shmem_read_mapping_page_gfp() with GFP_NOWAIT.
Remove mem_cgroup_get_shmem_target(): mc_handle_file_pte() can test
radix_tree_exceptional_entry() to get what it needs for itself.
The commit log of 0ae5e89c60c9 ("memcg: count the soft_limit reclaim
in...") says it adds scanning stats to memory.stat file. But it doesn't
because we considered we needed to make a concensus for such new APIs.
This patch is a trial to add memory.scan_stat. This shows
- the number of scanned pages(total, anon, file)
- the number of rotated pages(total, anon, file)
- the number of freed pages(total, anon, file)
- the number of elaplsed time (including sleep/pause time)
for both of direct/soft reclaim.
The biggest difference with oringinal Ying's one is that this file
can be reset by some write, as
# echo 0 ...../memory.scan_stat
Example of output is here. This is a result after make -j 6 kernel
under 300M limit.
[kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.scan_stat
[kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.vmscan_stat
scanned_pages_by_limit 9471864
scanned_anon_pages_by_limit 6640629
scanned_file_pages_by_limit 2831235
rotated_pages_by_limit 4243974
rotated_anon_pages_by_limit 3971968
rotated_file_pages_by_limit 272006
freed_pages_by_limit 2318492
freed_anon_pages_by_limit 962052
freed_file_pages_by_limit 1356440
elapsed_ns_by_limit 351386416101
scanned_pages_by_system 0
scanned_anon_pages_by_system 0
scanned_file_pages_by_system 0
rotated_pages_by_system 0
rotated_anon_pages_by_system 0
rotated_file_pages_by_system 0
freed_pages_by_system 0
freed_anon_pages_by_system 0
freed_file_pages_by_system 0
elapsed_ns_by_system 0
scanned_pages_by_limit_under_hierarchy 9471864
scanned_anon_pages_by_limit_under_hierarchy 6640629
scanned_file_pages_by_limit_under_hierarchy 2831235
rotated_pages_by_limit_under_hierarchy 4243974
rotated_anon_pages_by_limit_under_hierarchy 3971968
rotated_file_pages_by_limit_under_hierarchy 272006
freed_pages_by_limit_under_hierarchy 2318492
freed_anon_pages_by_limit_under_hierarchy 962052
freed_file_pages_by_limit_under_hierarchy 1356440
elapsed_ns_by_limit_under_hierarchy 351386416101
scanned_pages_by_system_under_hierarchy 0
scanned_anon_pages_by_system_under_hierarchy 0
scanned_file_pages_by_system_under_hierarchy 0
rotated_pages_by_system_under_hierarchy 0
rotated_anon_pages_by_system_under_hierarchy 0
rotated_file_pages_by_system_under_hierarchy 0
freed_pages_by_system_under_hierarchy 0
freed_anon_pages_by_system_under_hierarchy 0
freed_file_pages_by_system_under_hierarchy 0
elapsed_ns_by_system_under_hierarchy 0
total_xxxx is for hierarchy management.
This will be useful for further memcg developments and need to be
developped before we do some complicated rework on LRU/softlimit
management.
This patch adds a new struct memcg_scanrecord into scan_control struct.
sc->nr_scanned at el is not designed for exporting information. For
example, nr_scanned is reset frequentrly and incremented +2 at scanning
mapped pages.
To avoid complexity, I added a new param in scan_control which is for
exporting scanning score.
Cc: Andrew Bresticker <abrestic@google.com>
In mm/memcontrol.c, there are many lru stat functions as..
mem_cgroup_zone_nr_lru_pages
mem_cgroup_node_nr_file_lru_pages
mem_cgroup_nr_file_lru_pages
mem_cgroup_node_nr_anon_lru_pages
mem_cgroup_nr_anon_lru_pages
mem_cgroup_node_nr_unevictable_lru_pages
mem_cgroup_nr_unevictable_lru_pages
mem_cgroup_node_nr_lru_pages
mem_cgroup_nr_lru_pages
mem_cgroup_get_local_zonestat
Some of them are under #ifdef MAX_NUMNODES >1 and others are not.
This seems bad. This patch consolidates all functions into
mem_cgroup_zone_nr_lru_pages()
mem_cgroup_node_nr_lru_pages()
mem_cgroup_nr_lru_pages()
For these functions, "which LRU?" information is passed by a mask.
example:
mem_cgroup_nr_lru_pages(mem, BIT(LRU_ACTIVE_ANON))
And I added some macro as ALL_LRU, ALL_LRU_FILE, ALL_LRU_ANON.
example:
mem_cgroup_nr_lru_pages(mem, ALL_LRU)
BTW, considering layout of NUMA memory placement of counters, this patch seems
to be better.
Now, when we gather all LRU information, we scan in following orer
for_each_lru -> for_each_node -> for_each_zone.
This means we'll touch cache lines in different node in turn.
After patch, we'll scan
for_each_node -> for_each_zone -> for_each_lru(mask)
Then, we'll gather information in the same cacheline at once.
[akpm@linux-foundation.org: fix warnigns, build error]
Currently, memcg reclaim can disable swap token even if the swap token mm
doesn't belong in its memory cgroup. It's slightly risky. If an admin
creates very small mem-cgroup and silly guy runs contentious heavy memory
pressure workload, every tasks are going to lose swap token and then
system may become unresponsive. That's bad.
This patch adds 'memcg' parameter into disable_swap_token(). and if the
parameter doesn't match swap token, VM doesn't disable it.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Rik van Riel<riel@redhat.com>
Two new stats in per-memcg memory.stat which tracks the number of page
faults and number of major page faults.
"pgfault"
"pgmajfault"
They are different from "pgpgin"/"pgpgout" stat which count number of
pages charged/discharged to the cgroup and have no meaning of reading/
writing page to disk.
It is valuable to track the two stats for both measuring application's
performance as well as the efficiency of the kernel page reclaim path.
Counting pagefaults per process is useful, but we also need the aggregated
value since processes are monitored and controlled in cgroup basis in
memcg.
Functional test: check the total number of pgfault/pgmajfault of all
memcgs and compare with global vmstat value:
$ cat /proc/vmstat | grep fault
pgfault 1070751
pgmajfault 553
$ cat /dev/cgroup/memory.stat | grep fault
pgfault 1071138
pgmajfault 553
total_pgfault 1071142
total_pgmajfault 553
$ cat /dev/cgroup/A/memory.stat | grep fault
pgfault 199
pgmajfault 0
total_pgfault 199
total_pgmajfault 0
Performance test: run page fault test(pft) wit 16 thread on faulting in
15G anon pages in 16G container. There is no regression noticed on the
"flt/cpu/s"
Sample output from pft:
TAG pft:anon-sys-default:
Gb Thr CLine User System Wall flt/cpu/s fault/wsec
15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260
N Min Max Median Avg Stddev
x 10 16682.962 17344.027 16913.524 16928.812 166.5362
+ 10 16695.568 16923.896 16820.604 16824.652 84.816568
No difference proven at 95.0% confidence
[akpm@linux-foundation.org: fix build]
[hughd@google.com: shmem fix]
Signed-off-by: Ying Han <yinghan@google.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
The caller of the function has been renamed to zone_nr_lru_pages(), and
this is just fixing up in the memcg code. The current name is easily to
be mis-read as zone's total number of pages.
Cc: Balbir Singh <balbir@in.ibm.com>
Presently, memory cgroup's direct reclaim frees memory from the current
node. But this has some troubles. Usually when a set of threads works in
a cooperative way, they tend to operate on the same node. So if they hit
limits under memcg they will reclaim memory from themselves, damaging the
active working set.
For example, assume 2 node system which has Node 0 and Node 1 and a memcg
which has 1G limit. After some work, file cache remains and the usages
are
Node 0: 1M
Node 1: 998M.
and run an application on Node 0, it will eat its foot before freeing
unnecessary file caches.
This patch adds round-robin for NUMA and adds equal pressure to each node.
When using cpuset's spread memory feature, this will work very well.
But yes, a better algorithm is needed.
[akpm@linux-foundation.org: comment editing]
[kamezawa.hiroyu@jp.fujitsu.com: fix time comparisons]
The global kswapd scans per-zone LRU and reclaims pages regardless of the
cgroup. It breaks memory isolation since one cgroup can end up reclaiming
pages from another cgroup. Instead we should rely on memcg-aware target
reclaim including per-memcg kswapd and soft_limit hierarchical reclaim under
memory pressure.
In the global background reclaim, we do soft reclaim before scanning the
per-zone LRU. However, the return value is ignored. This patch is the first
step to skip shrink_zone() if soft_limit reclaim does enough work.
This is part of the effort which tries to reduce reclaiming pages in global
LRU in memcg. The per-memcg background reclaim patchset further enhances the
per-cgroup targetting reclaim, which I should have V4 posted shortly.
Try running multiple memory intensive workloads within seperate memcgs. Watch
the counters of soft_steal in memory.stat.
$ cat /dev/cgroup/A/memory.stat | grep 'soft'
soft_steal 240000
soft_scan 240000
total_soft_steal 240000
total_soft_scan 240000
This patch:
We would like to skip shrink_zone() if soft_limit reclaim does enough
work. Also, we need to make the memory pressure balanced across per-memcg
zones, like the logic vm-core. This patch is the first step where we
start with counting the nr_scanned and nr_reclaimed from soft_limit
reclaim into the global scan_control.
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
commit 3f58a8294333 ("move memcg reclaimable page into tail of inactive
list") added inline keyword twice in its prototype.
CC arch/x86/kernel/asm-offsets.s
In file included from include/linux/swap.h:8,
from include/linux/suspend.h:4,
from arch/x86/kernel/asm-offsets.c:12:
include/linux/memcontrol.h:220: error: duplicate `inline'
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Add checks at allocating or freeing a page whether the page is used (iow,
charged) from the view point of memcg.
This check may be useful in debugging a problem and we did similar checks
before the commit 52d4b9ac(memcg: allocate all page_cgroup at boot).
This patch adds some overheads at allocating or freeing memory, so it's
enabled only when CONFIG_DEBUG_VM is enabled.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
The rotate_reclaimable_page function moves just written out pages, which
the VM wanted to reclaim, to the end of the inactive list. That way the
VM will find those pages first next time it needs to free memory.
This patch applies the rule in memcg. It can help to prevent unnecessary
working page eviction of memcg.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
This function basically does:
remove_from_page_cache(old);
page_cache_release(old);
add_to_page_cache_locked(new);
Except it does this atomically, so there's no possibility for the "add" to
fail because of a race.
If memory cgroups are enabled, then the memory cgroup charge is also moved
from the old page to the new.
This function is currently used by fuse to move pages into the page cache
on read, instead of copying the page contents.
[minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Now, under THP:
at charge:
- PageCgroupUsed bit is set to all page_cgroup on a hugepage.
....set to 512 pages.
at uncharge
- PageCgroupUsed bit is unset on the head page.
So, some pages will remain with "Used" bit.
This patch fixes that Used bit is set only to the head page.
Used bits for tail pages will be set at splitting if necessary.
This patch adds this lock order:
compound_lock() -> page_cgroup_move_lock().
[akpm@linux-foundation.org: fix warning]
In the current implementation mem_cgroup_end_migration() decides whether
the page migration has succeeded or not by checking "oldpage->mapping".
But if we are tring to migrate a shmem swapcache, the page->mapping of it
is NULL from the begining, so the check would be invalid. As a result,
mem_cgroup_end_migration() assumes the migration has succeeded even if
it's not, so "newpage" would be freed while it's not uncharged.
This patch fixes it by passing mem_cgroup_end_migration() the result of
the page migration.
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Replace usage of the mem_cgroup_update_file_mapped() memcg
statistic update routine with two new routines:
* mem_cgroup_inc_page_stat()
* mem_cgroup_dec_page_stat()
As before, only the file_mapped statistic is managed. However, these more
general interfaces allow for new statistics to be more easily added. New
statistics are added with memcg dirty page accounting.
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Andrea Righi <arighi@develer.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
mem_cgroup_soft_limit_reclaim() has zone, nid and zid argument. but nid
and zid can be calculated from zone. So remove it.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp>
This a complete rewrite of the oom killer's badness() heuristic which is
used to determine which task to kill in oom conditions. The goal is to
make it as simple and predictable as possible so the results are better
understood and we end up killing the task which will lead to the most
memory freeing while still respecting the fine-tuning from userspace.
Instead of basing the heuristic on mm->total_vm for each task, the task's
rss and swap space is used instead. This is a better indication of the
amount of memory that will be freeable if the oom killed task is chosen
and subsequently exits. This helps specifically in cases where KDE or
GNOME is chosen for oom kill on desktop systems instead of a memory
hogging task.
The baseline for the heuristic is a proportion of memory that each task is
currently using in memory plus swap compared to the amount of "allowable"
memory. "Allowable," in this sense, means the system-wide resources for
unconstrained oom conditions, the set of mempolicy nodes, the mems
attached to current's cpuset, or a memory controller's limit. The
proportion is given on a scale of 0 (never kill) to 1000 (always kill),
roughly meaning that if a task has a badness() score of 500 that the task
consumes approximately 50% of allowable memory resident in RAM or in swap
space.
The proportion is always relative to the amount of "allowable" memory and
not the total amount of RAM systemwide so that mempolicies and cpusets may
operate in isolation; they shall not need to know the true size of the
machine on which they are running if they are bound to a specific set of
nodes or mems, respectively.
Root tasks are given 3% extra memory just like __vm_enough_memory()
provides in LSMs. In the event of two tasks consuming similar amounts of
memory, it is generally better to save root's task.
Because of the change in the badness() heuristic's baseline, it is also
necessary to introduce a new user interface to tune it. It's not possible
to redefine the meaning of /proc/pid/oom_adj with a new scale since the
ABI cannot be changed for backward compatability. Instead, a new tunable,
/proc/pid/oom_score_adj, is added that ranges from -1000 to +1000. It may
be used to polarize the heuristic such that certain tasks are never
considered for oom kill while others may always be considered. The value
is added directly into the badness() score so a value of -500, for
example, means to discount 50% of its memory consumption in comparison to
other tasks either on the system, bound to the mempolicy, in the cpuset,
or sharing the same memory controller.
/proc/pid/oom_adj is changed so that its meaning is rescaled into the
units used by /proc/pid/oom_score_adj, and vice versa. Changing one of
these per-task tunables will rescale the value of the other to an
equivalent meaning. Although /proc/pid/oom_adj was originally defined as
a bitshift on the badness score, it now shares the same linear growth as
/proc/pid/oom_score_adj but with different granularity. This is required
so the ABI is not broken with userspace applications and allows oom_adj to
be deprecated for future removal.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Nick Piggin <npiggin@suse.de>
Since 2.6.28 zone->prev_priority is unused. Then it can be removed
safely. It reduce stack usage slightly.
Now I have to say that I'm sorry. 2 years ago, I thought prev_priority
can be integrate again, it's useful. but four (or more) times trying
haven't got good performance number. Thus I give up such approach.
The rest of this changelog is notes on prev_priority and why it existed in
the first place and why it might be not necessary any more. This information
is based heavily on discussions between Andrew Morton, Rik van Riel and
Kosaki Motohiro who is heavily quotes from.
Historically prev_priority was important because it determined when the VM
would start unmapping PTE pages. i.e. there are no balances of note within
the VM, Anon vs File and Mapped vs Unmapped. Without prev_priority, there
is a potential risk of unnecessarily increasing minor faults as a large
amount of read activity of use-once pages could push mapped pages to the
end of the LRU and get unmapped.
There is no proof this is still a problem but currently it is not considered
to be. Active files are not deactivated if the active file list is smaller
than the inactive list reducing the liklihood that file-mapped pages are
being pushed off the LRU and referenced executable pages are kept on the
active list to avoid them getting pushed out by read activity.
Even if it is a problem, prev_priority prev_priority wouldn't works
nowadays. First of all, current vmscan still a lot of UP centric code. it
expose some weakness on some dozens CPUs machine. I think we need more and
more improvement.
The problem is, current vmscan mix up per-system-pressure, per-zone-pressure
and per-task-pressure a bit. example, prev_priority try to boost priority to
other concurrent priority. but if the another task have mempolicy restriction,
it is unnecessary, but also makes wrong big latency and exceeding reclaim.
per-task based priority + prev_priority adjustment make the emulation of
per-system pressure. but it have two issue 1) too rough and brutal emulation
2) we need per-zone pressure, not per-system.
Another example, currently DEF_PRIORITY is 12. it mean the lru rotate about
2 cycle (1/4096 + 1/2048 + 1/1024 + .. + 1) before invoking OOM-Killer.
but if 10,0000 thrreads enter DEF_PRIORITY reclaim at the same time, the
system have higher memory pressure than priority==0 (1/4096*10,000 > 2).
prev_priority can't solve such multithreads workload issue. In other word,
prev_priority concept assume the sysmtem don't have lots threads."
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Michael Rubin <mrubin@google.com>
FILE_MAPPED per memcg of migrated file cache is not properly updated,
because our hook in page_add_file_rmap() can't know to which memcg
FILE_MAPPED should be counted.
Basically, this patch is for fixing the bug but includes some big changes
to fix up other messes.
Now, at migrating mapped file, events happen in following sequence.
1. allocate a new page.
2. get memcg of an old page.
3. charge ageinst a new page before migration. But at this point,
no changes to new page's page_cgroup, no commit for the charge.
(IOW, PCG_USED bit is not set.)
4. page migration replaces radix-tree, old-page and new-page.
5. page migration remaps the new page if the old page was mapped.
6. Here, the new page is unlocked.
7. memcg commits the charge for newpage, Mark the new page's page_cgroup
as PCG_USED.
Because "commit" happens after page-remap, we can count FILE_MAPPED
at "5", because we should avoid to trust page_cgroup->mem_cgroup.
if PCG_USED bit is unset.
(Note: memcg's LRU removal code does that but LRU-isolation logic is used
for helping it. When we overwrite page_cgroup->mem_cgroup, page_cgroup is
not on LRU or page_cgroup->mem_cgroup is NULL.)
We can lose file_mapped accounting information at 5 because FILE_MAPPED
is updated only when mapcount changes 0->1. So we should catch it.
BTW, historically, above implemntation comes from migration-failure
of anonymous page. Because we charge both of old page and new page
with mapcount=0, we can't catch
- the page is really freed before remap.
- migration fails but it's freed before remap
or .....corner cases.
New migration sequence with memcg is:
2. mark PageCgroupMigration to the old page.
3. charge against a new page onto the old page's memcg. (here, new page's pc
is marked as PageCgroupUsed.)
4. page migration replaces radix-tree, page table, etc...
5. At remapping, new page's page_cgroup is now makrked as "USED"
We can catch 0->1 event and FILE_MAPPED will be properly updated.
And we can catch SWAPOUT event after unlock this and freeing this
page by unmap() can be caught.
7. Clear PageCgroupMigration of the old page.
So, FILE_MAPPED will be correctly updated.
Then, for what MIGRATION flag is ?
Without it, at migration failure, we may have to charge old page again
because it may be fully unmapped. "charge" means that we have to dive into
memory reclaim or something complated. So, it's better to avoid
charge it again. Before this patch, __commit_charge() was working for
both of the old/new page and fixed up all. But this technique has some
racy condtion around FILE_MAPPED and SWAPOUT etc...
Now, the kernel use MIGRATION flag and don't uncharge old page until
the end of migration.
I hope this change will make memcg's page migration much simpler. This
page migration has caused several troubles. Worth to add a flag for
simplification.
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
For now, we have global isolation vs. memory control group isolation, do
not allow the reclaim entry function to set an arbitrary page isolation
callback, we do not need that flexibility.
And since we already pass around the group descriptor for the memory
control group isolation case, just use it to decide which one of the two
isolator functions to use.
The decisions can be merged into nearby branches, so no extra cost there.
In fact, we save the indirect calls.
In current page-fault code,
handle_mm_fault()
-> mem_cgroup_charge()
-> map page or handle error.
-> check return code.
If page fault's return code is VM_FAULT_OOM, page_fault_out_of_memory() is
called. But if it's caused by memcg, OOM should have been already
invoked.
Then, I added a patch: a636b327f731143ccc544b966cfd8de6cb6d72c6. That
patch records last_oom_jiffies for memcg's sub-hierarchy and prevents
page_fault_out_of_memory from being invoked in near future.
But Nishimura-san reported that check by jiffies is not enough when the
system is terribly heavy.
This patch changes memcg's oom logic as.
* If memcg causes OOM-kill, continue to retry.
* remove jiffies check which is used now.
* add memcg-oom-lock which works like perzone oom lock.
* If current is killed(as a process), bypass charge.
Something more sophisticated can be added but this pactch does
fundamental things.
TODO:
- add oom notifier
- add permemcg disable-oom-kill flag and freezer at oom.
- more chances for wake up oom waiter (when changing memory limit etc..)
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (34 commits)
HWPOISON: Remove stray phrase in a comment
HWPOISON: Try to allocate migration page on the same node
HWPOISON: Don't do early filtering if filter is disabled
HWPOISON: Add a madvise() injector for soft page offlining
HWPOISON: Add soft page offline support
HWPOISON: Undefine short-hand macros after use to avoid namespace conflict
HWPOISON: Use new shake_page in memory_failure
HWPOISON: Use correct name for MADV_HWPOISON in documentation
HWPOISON: mention HWPoison in Kconfig entry
HWPOISON: Use get_user_page_fast in hwpoison madvise
HWPOISON: add an interface to switch off/on all the page filters
HWPOISON: add memory cgroup filter
memcg: add accessor to mem_cgroup.css
memcg: rename and export try_get_mem_cgroup_from_page()
HWPOISON: add page flags filter
mm: export stable page flags
HWPOISON: limit hwpoison injector to known page types
HWPOISON: add fs/device filters
HWPOISON: return 0 to indicate success reliably
HWPOISON: make semantics of IGNORED/DELAYED clear
In global VM, FILE_MAPPED is used but memcg uses MAPPED_FILE. This makes
grep difficult. Replace memcg's MAPPED_FILE with FILE_MAPPED
And in global VM, mapped shared memory is accounted into FILE_MAPPED.
But memcg doesn't. fix it.
Note:
page_is_file_cache() just checks SwapBacked or not.
So, we need to check PageAnon.
In massive parallel enviroment, res_counter can be a performance
bottleneck. One strong techinque to reduce lock contention is reducing
calls by coalescing some amount of calls into one.
Considering charge/uncharge chatacteristic,
- charge is done one by one via demand-paging.
- uncharge is done by
- in chunk at munmap, truncate, exit, execve...
- one by one via vmscan/paging.
It seems we have a chance to coalesce uncharges for improving scalability
at unmap/truncation.
This patch is a for coalescing uncharge. For avoiding scattering memcg's
structure to functions under /mm, this patch adds memcg batch uncharge
information to the task. A reason for per-task batching is for making use
of caller's context information. We do batched uncharge (deleyed
uncharge) when truncation/unmap occurs but do direct uncharge when
uncharge is called by memory reclaim (vmscan.c).
The degree of coalescing depends on callers
- at invalidate/trucate... pagevec size
- at unmap ....ZAP_BLOCK_SIZE
(memory itself will be freed in this degree.)
Then, we'll not coalescing too much.
On x86-64 8cpu server, I tested overheads of memcg at page fault by
running a program which does map/fault/unmap in a loop. Running
a task per a cpu by taskset and see sum of the number of page faults
in 60secs.
[without memcg config]
40156968 page-faults # 0.085 M/sec ( +- 0.046% )
27.67 cache-miss/faults
[root cgroup]
36659599 page-faults # 0.077 M/sec ( +- 0.247% )
31.58 miss/faults
[in a child cgroup]
18444157 page-faults # 0.039 M/sec ( +- 0.133% )
69.96 miss/faults
[child with this patch]
27133719 page-faults # 0.057 M/sec ( +- 0.155% )
47.16 miss/faults
We can see some amounts of improvement.
(root cgroup doesn't affected by this patch)
Another patch for "charge" will follow this and above will be improved more.
Changelog(since 2009/10/02):
- renamed filed of memcg_batch (as pages to bytes, memsw to memsw_bytes)
- some clean up and commentary/description updates.
- added initialize code to copy_process(). (possible bug fix)
Changelog(old):
- fixed !CONFIG_MEM_CGROUP case.
- rebased onto the latest mmotm + softlimit fix patches.
- unified patch for callers
- added commetns.
- make ->do_batch as bool.
- removed css_get() at el. We don't need it.
So that an outside user can free the reference count grabbed by
try_get_mem_cgroup_from_page().
CC: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
CC: Hugh Dickins <hugh.dickins@tiscali.co.uk>
CC: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
CC: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
So that the hwpoison injector can get mem_cgroup for arbitrary page
and thus know whether it is owned by some mem_cgroup task(s).
[AK: Merged with latest git tree]
Implement reclaim from groups over their soft limit
Permit reclaim from memory cgroups on contention (via the direct reclaim
path).
memory cgroup soft limit reclaim finds the group that exceeds its soft
limit by the largest number of pages and reclaims pages from it and then
reinserts the cgroup into its correct place in the rbtree.
Add additional checks to mem_cgroup_hierarchical_reclaim() to detect long
loops in case all swap is turned off. The code has been refactored and
the loop check (loop < 2) has been enhanced for soft limits. For soft
limits, we try to do more targetted reclaim. Instead of bailing out after
two loops, the routine now reclaims memory proportional to the size by
which the soft limit is exceeded. The proportion has been empirically
determined.
[akpm@linux-foundation.org: build fix]
[kamezawa.hiroyu@jp.fujitsu.com: fix softlimit css refcnt handling]
[nishimura@mxp.nes.nec.co.jp: refcount of the "victim" should be decremented before exiting the loop]
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Add file RSS tracking per memory cgroup
We currently don't track file RSS, the RSS we report is actually anon RSS.
All the file mapped pages, come in through the page cache and get
accounted there. This patch adds support for accounting file RSS pages.
It should
1. Help improve the metrics reported by the memory resource controller
2. Will form the basis for a future shared memory accounting heuristic
that has been proposed by Kamezawa.
Unfortunately, we cannot rename the existing "rss" keyword used in
memory.stat to "anon_rss". We however, add "mapped_file" data and hope to
educate the end user through documentation.
[hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops]
Cc: Li Zefan <lizf@cn.fujitsu.cn>
Cc: Paul Menage <menage@google.com>
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
When the file LRU lists are dominated by streaming IO pages, evict those
pages first, before considering evicting other pages.
This should be safe from deadlocks or performance problems
because only three things can happen to an inactive file page:
1) referenced twice and promoted to the active list
2) evicted by the pageout code
3) under IO, after which it will get evicted or promoted
The pages freed in this way can either be reused for streaming IO, or
allocated for something else. If the pages are used for streaming IO,
this pageout pattern continues. Otherwise, we will fall back to the
normal pageout pattern.
Signed-off-by: Rik van Riel <riel@redhat.com>
Reported-by: Elladan <elladan@eskimo.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Current mem_cgroup_shrink_usage() has two problems.
1. It doesn't call mem_cgroup_out_of_memory and doesn't update
last_oom_jiffies, so pagefault_out_of_memory invokes global OOM.
2. Considering hierarchy, shrinking has to be done from the
mem_over_limit, not from the memcg which the page would be charged to.
mem_cgroup_try_charge_swapin() does all of these things properly, so we
use it and call cancel_charge_swapin when it succeeded.
The name of "shrink_usage" is not appropriate for this behavior, so we
change it too.
mm->owner should be accessed with rcu_dereference().
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
commit 4f98a2fee8acdb4ac84545df98cccecfd130f8db (vmscan: split LRU lists
into anon & file sets) removed mem_cgroup_reclaim_imbalance(), but there
are some leftovers in memcontrol.h.
Currently, mem_cgroup_calc_mapped_ratio() is unused at all. it can be
removed and KAMEZAWA-san suggested it.
Add RSS and swap to OOM output from memcg
Display memcg values like failcnt, usage and limit when an OOM occurs due
to memcg.
Thanks to Johannes Weiner, Li Zefan, David Rientjes, Kamezawa Hiroyuki,
Daisuke Nishimura and KOSAKI Motohiro for review.
Sample output
Task in /a/x killed as a result of limit of /a
memory: usage 1048576kB, limit 1048576kB, failcnt 4183
memory+swap: usage 1400964kB, limit 9007199254740991kB, failcnt 0
[akpm@linux-foundation.org: compilation fix]
[akpm@linux-foundation.org: fix kerneldoc and whitespace]
[akpm@linux-foundation.org: add printk facility level]
Now, you can see following even when swap accounting is enabled.
1. Create Group 01, and 02.
2. allocate a "file" on tmpfs by a task under 01.
3. swap out the "file" (by memory pressure)
4. Read "file" from a task in group 02.
5. the charge of "file" is moved to group 02.
This is not ideal behavior. This is because SwapCache which was loaded
by read-ahead is not taken into account..
This is a patch to fix shmem's swapcache behavior.
- remove mem_cgroup_cache_charge_swapin().
- Add SwapCache handler routine to mem_cgroup_cache_charge().
By this, shmem's file cache is charged at add_to_page_cache()
with GFP_NOWAIT.
- pass the page of swapcache to shrink_mem_cgroup.
Cc: Hugh Dickins <hugh@veritas.com>
After previous patch, mem_cgroup_try_charge is not used by anyone, so we
can remove it.
Currently, inactive_ratio of memcg is calculated at setting limit.
because page_alloc.c does so and current implementation is straightforward
porting.
However, memcg introduced hierarchy feature recently. In hierarchy
restriction, memory limit is not only decided memory.limit_in_bytes of
current cgroup, but also parent limit and sibling memory usage.
Then, The optimal inactive_ratio is changed frequently. So, everytime
calculation is better.
Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Now, get_scan_ratio() return correct value although memcg reclaim. Then,
mem_cgroup_calc_reclaim() can be removed.
So, memcg reclaim get the same capability of anon/file reclaim balancing
as global reclaim now.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@redhat.com>
Introduce mem_cgroup_per_zone::reclaim_stat member and its statics
collecting function.
Now, get_scan_ratio() can calculate correct value on memcg reclaim.
[hugh@veritas.com: avoid reclaim_stat oops when disabled]
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Introduce mem_cgroup_zone_nr_pages(). It is called by zone_nr_pages()
helper function.
This patch doesn't have any behavior change.
Acked-by: Balbir Singh <balbir@in.ibm.com>
The inactive_anon_is_low() is key component of active/inactive anon
balancing on reclaim. However current inactive_anon_is_low() function
only consider global reclaim.
Therefore, we need following ugly scan_global_lru() condition.
if (lru == LRU_ACTIVE_ANON &&
(!scan_global_lru(sc) || inactive_anon_is_low(zone))) {
shrink_active_list(nr_to_scan, zone, sc, priority, file);
return 0;
it cause that memcg reclaim always deactivate pages when shrink_list() is
called. To make mem_cgroup_inactive_anon_is_low() improve active/inactive
anon balancing of memcgroup.
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: "Pekka Enberg" <penberg@cs.helsinki.fi>
My patch, memcg-fix-gfp_mask-of-callers-of-charge.patch changed gfp_mask
of callers of charge to be GFP_HIGHUSER_MOVABLE for showing what will
happen at memory reclaim.
But in recent discussion, it's NACKed because it sounds ugly.
This patch is for reverting it and add some clean up to gfp_mask of
callers of charge. No behavior change but need review before generating
HUNK in deep queue.
This patch also adds explanation to meaning of gfp_mask passed to charge
functions in memcontrol.h.
Current mmtom has new oom function as pagefault_out_of_memory(). It's
added for select bad process rathar than killing current.
When memcg hit limit and calls OOM at page_fault, this handler called and
system-wide-oom handling happens. (means kernel panics if panic_on_oom is
true....)
To avoid overkill, check memcg's recent behavior before starting
system-wide-oom.
And this patch also fixes to guarantee "don't accnout against process with
TIF_MEMDIE". This is necessary for smooth OOM.
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Cc: Jan Blunck <jblunck@suse.de>
Cc: Hirokazu Takahashi <taka@valinux.co.jp>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
mm_match_cgroup() calls cgroup_subsys_state().
We must use rcu_read_lock() to protect cgroup_subsys_state().
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
We check mem_cgroup is disabled or not by checking
mem_cgroup_subsys.disabled. I think it has more references than expected,
now.
replacing
if (mem_cgroup_subsys.disabled)
with
if (mem_cgroup_disabled())
give us good look, I think.
[kamezawa.hiroyu@jp.fujitsu.com: fix typo]
A big patch for changing memcg's LRU semantics.
Now,
- page_cgroup is linked to mem_cgroup's its own LRU (per zone).
- LRU of page_cgroup is not synchronous with global LRU.
- page and page_cgroup is one-to-one and statically allocated.
- To find page_cgroup is on what LRU, you have to check pc->mem_cgroup as
- lru = page_cgroup_zoneinfo(pc, nid_of_pc, zid_of_pc);
- SwapCache is handled.
And, when we handle LRU list of page_cgroup, we do following.
pc = lookup_page_cgroup(page);
lock_page_cgroup(pc); .....................(1)
mz = page_cgroup_zoneinfo(pc);
spin_lock(&mz->lru_lock);
.....add to LRU
spin_unlock(&mz->lru_lock);
unlock_page_cgroup(pc);
But (1) is spin_lock and we have to be afraid of dead-lock with zone->lru_lock.
So, trylock() is used at (1), now. Without (1), we can't trust "mz" is correct.
This is a trial to remove this dirty nesting of locks.
This patch changes mz->lru_lock to be zone->lru_lock.
Then, above sequence will be written as
spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU
mem_cgroup_add/remove/etc_lru() {
if (PageCgroupUsed(pc)) {
....add to LRU
This is much simpler.
(*) We're safe even if we don't take lock_page_cgroup(pc). Because..
1. When pc->mem_cgroup can be modified.
- at charge.
- at account_move().
2. at charge
the PCG_USED bit is not set before pc->mem_cgroup is fixed.
3. at account_move()
the page is isolated and not on LRU.
Pros.
- easy for maintenance.
- memcg can make use of laziness of pagevec.
- we don't have to duplicated LRU/Active/Unevictable bit in page_cgroup.
- LRU status of memcg will be synchronized with global LRU's one.
- # of locks are reduced.
- account_move() is simplified very much.
Cons.
- may increase cost of LRU rotation.
(no impact if memcg is not configured.)
This patch implements per cgroup limit for usage of memory+swap. However
there are SwapCache, double counting of swap-cache and swap-entry is
avoided.
Mem+Swap controller works as following.
- memory usage is limited by memory.limit_in_bytes.
- memory + swap usage is limited by memory.memsw_limit_in_bytes.
This has following benefits.
- A user can limit total resource usage of mem+swap.
Without this, because memory resource controller doesn't take care of
usage of swap, a process can exhaust all the swap (by memory leak.)
We can avoid this case.
And Swap is shared resource but it cannot be reclaimed (goes back to memory)
until it's used. This characteristic can be trouble when the memory
is divided into some parts by cpuset or memcg.
Assume group A and group B.
After some application executes, the system can be..
Group A -- very large free memory space but occupy 99% of swap.
Group B -- under memory shortage but cannot use swap...it's nearly full.
Ability to set appropriate swap limit for each group is required.
Maybe someone wonder "why not swap but mem+swap ?"
- The global LRU(kswapd) can swap out arbitrary pages. Swap-out means
to move account from memory to swap...there is no change in usage of
mem+swap.
In other words, when we want to limit the usage of swap without affecting
global LRU, mem+swap limit is better than just limiting swap.
Accounting target information is stored in swap_cgroup which is
per swap entry record.
Charge is done as following.
map
- charge page and memsw.
unmap
- uncharge page/memsw if not SwapCache.
swap-out (__delete_from_swap_cache)
- uncharge page
- record mem_cgroup information to swap_cgroup.
swap-in (do_swap_page)
- charged as page and memsw.
record in swap_cgroup is cleared.
memsw accounting is decremented.
swap-free (swap_free())
- if swap entry is freed, memsw is uncharged by PAGE_SIZE.
There are people work under never-swap environments and consider swap as
something bad. For such people, this mem+swap controller extension is just an
overhead. This overhead is avoided by config or boot option.
(see Kconfig. detail is not in this patch.)
TODO:
- maybe more optimization can be don in swap-in path. (but not very safe.)
But we just do simple accounting at this stage.
[nishimura@mxp.nes.nec.co.jp: make resize limit hold mutex]
[hugh@veritas.com: memswap controller core swapcache fixes]
Config and control variable for mem+swap controller.
This patch adds CONFIG_CGROUP_MEM_RES_CTLR_SWAP
(memory resource controller swap extension.)
For accounting swap, it's obvious that we have to use additional memory to
remember "who uses swap". This adds more overhead. So, it's better to
offer "choice" to users. This patch adds 2 choices.
This patch adds 2 parameters to enable swap extension or not.
- CONFIG
- boot option
