path: root/include/linux/memcontrol.h
2014-01-23memcg, slab: clean up memcg cache initialization/destructionVladimir Davydov
Currently, we have rather a messy function set relating to per-memcg kmem cache initialization/destruction. Per-memcg caches are created in memcg_create_kmem_cache(). This function calls kmem_cache_create_memcg() to allocate and initialize a kmem cache and then "registers" the new cache in the memcg_params::memcg_caches array of the parent cache. During its work-flow, kmem_cache_create_memcg() executes the following memcg-related functions: - memcg_alloc_cache_params(), to initialize memcg_params of the newly created cache; - memcg_cache_list_add(), to add the new cache to the memcg_slab_caches list. On the other hand, kmem_cache_destroy() called on a cache destruction only calls memcg_release_cache(), which does all the work: it cleans the reference to the cache in its parent's memcg_params::memcg_caches, removes the cache from the memcg_slab_caches list, and frees memcg_params. Such an inconsistency between destruction and initialization paths make the code difficult to read, so let's clean this up a bit. This patch moves all the code relating to registration of per-memcg caches (adding to memcg list, setting the pointer to a cache from its parent) to the newly created memcg_register_cache() and memcg_unregister_cache() functions making the initialization and destruction paths look symmetrical. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Glauber Costa <glommer@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23memcg, slab: kmem_cache_create_memcg(): fix memleak on fail pathVladimir Davydov
We do not free the cache's memcg_params if __kmem_cache_create fails. Fix this. Plus, rename memcg_register_cache() to memcg_alloc_cache_params(), because it actually does not register the cache anywhere, but simply initialize kmem_cache::memcg_params. [akpm@linux-foundation.org: fix build] Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Glauber Costa <glommer@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16mm: memcg: handle non-error OOM situations more gracefullyJohannes Weiner
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full callstack on OOM") assumed that only a few places that can trigger a memcg OOM situation do not return VM_FAULT_OOM, like optional page cache readahead. But there are many more and it's impractical to annotate them all. First of all, we don't want to invoke the OOM killer when the failed allocation is gracefully handled, so defer the actual kill to the end of the fault handling as well. This simplifies the code quite a bit for added bonus. Second, since a failed allocation might not be the abrupt end of the fault, the memcg OOM handler needs to be re-entrant until the fault finishes for subsequent allocation attempts. If an allocation is attempted after the task already OOMed, allow it to bypass the limit so that it can quickly finish the fault and invoke the OOM killer. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg, vmscan: integrate soft reclaim tighter with zone shrinking code"Andrew Morton
Revert commit 3b38722efd9f ("memcg, vmscan: integrate soft reclaim tighter with zone shrinking code") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "vmscan, memcg: do softlimit reclaim also for targeted reclaim"Andrew Morton
Revert commit a5b7c87f9207 ("vmscan, memcg: do softlimit reclaim also for targeted reclaim") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24revert "memcg: enhance memcg iterator to support predicates"Andrew Morton
Revert commit de57780dc659 ("memcg: enhance memcg iterator to support predicates") I merged this prematurely - Michal and Johannes still disagree about the overall design direction and the future remains unclear. Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12memcg: add per cgroup writeback pages accountingSha Zhengju
Add memcg routines to count writeback pages, later dirty pages will also be accounted. After Kame's commit 89c06bd52fb9 ("memcg: use new logic for page stat accounting"), we can use 'struct page' flag to test page state instead of per page_cgroup flag. But memcg has a feature to move a page from a cgroup to another one and may have race between "move" and "page stat accounting". So in order to avoid the race we have designed a new lock: mem_cgroup_begin_update_page_stat() modify page information -->(a) mem_cgroup_update_page_stat() -->(b) mem_cgroup_end_update_page_stat() It requires both (a) and (b)(writeback pages accounting) to be pretected in mem_cgroup_{begin/end}_update_page_stat(). It's full no-op for !CONFIG_MEMCG, almost no-op if memcg is disabled (but compiled in), rcu read lock in the most cases (no task is moving), and spin_lock_irqsave on top in the slow path. There're two writeback interfaces to modify: test_{clear/set}_page_writeback(). And the lock order is: --> memcg->move_lock --> mapping->tree_lock Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Greg Thelen <gthelen@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12memcg: remove MEMCG_NR_FILE_MAPPEDSha Zhengju
While accounting memcg page stat, it's not worth to use MEMCG_NR_FILE_MAPPED as an extra layer of indirection because of the complexity and presumed performance overhead. We can use MEM_CGROUP_STAT_FILE_MAPPED directly. Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Reviewed-by: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12mm: memcg: do not trap chargers with full callstack on OOMJohannes Weiner
The memcg OOM handling is incredibly fragile and can deadlock. When a task fails to charge memory, it invokes the OOM killer and loops right there in the charge code until it succeeds. Comparably, any other task that enters the charge path at this point will go to a waitqueue right then and there and sleep until the OOM situation is resolved. The problem is that these tasks may hold filesystem locks and the mmap_sem; locks that the selected OOM victim may need to exit. For example, in one reported case, the task invoking the OOM killer was about to charge a page cache page during a write(), which holds the i_mutex. The OOM killer selected a task that was just entering truncate() and trying to acquire the i_mutex: OOM invoking task: mem_cgroup_handle_oom+0x241/0x3b0 mem_cgroup_cache_charge+0xbe/0xe0 add_to_page_cache_locked+0x4c/0x140 add_to_page_cache_lru+0x22/0x50 grab_cache_page_write_begin+0x8b/0xe0 ext3_write_begin+0x88/0x270 generic_file_buffered_write+0x116/0x290 __generic_file_aio_write+0x27c/0x480 generic_file_aio_write+0x76/0xf0 # takes ->i_mutex do_sync_write+0xea/0x130 vfs_write+0xf3/0x1f0 sys_write+0x51/0x90 system_call_fastpath+0x18/0x1d OOM kill victim: do_truncate+0x58/0xa0 # takes i_mutex do_last+0x250/0xa30 path_openat+0xd7/0x440 do_filp_open+0x49/0xa0 do_sys_open+0x106/0x240 sys_open+0x20/0x30 system_call_fastpath+0x18/0x1d The OOM handling task will retry the charge indefinitely while the OOM killed task is not releasing any resources. A similar scenario can happen when the kernel OOM killer for a memcg is disabled and a userspace task is in charge of resolving OOM situations. In this case, ALL tasks that enter the OOM path will be made to sleep on the OOM waitqueue and wait for userspace to free resources or increase the group's limit. But a userspace OOM handler is prone to deadlock itself on the locks held by the waiting tasks. For example one of the sleeping tasks may be stuck in a brk() call with the mmap_sem held for writing but the userspace handler, in order to pick an optimal victim, may need to read files from /proc/<pid>, which tries to acquire the same mmap_sem for reading and deadlocks. This patch changes the way tasks behave after detecting a memcg OOM and makes sure nobody loops or sleeps with locks held: 1. When OOMing in a user fault, invoke the OOM killer and restart the fault instead of looping on the charge attempt. This way, the OOM victim can not get stuck on locks the looping task may hold. 2. When OOMing in a user fault but somebody else is handling it (either the kernel OOM killer or a userspace handler), don't go to sleep in the charge context. Instead, remember the OOMing memcg in the task struct and then fully unwind the page fault stack with -ENOMEM. pagefault_out_of_memory() will then call back into the memcg code to check if the -ENOMEM came from the memcg, and then either put the task to sleep on the memcg's OOM waitqueue or just restart the fault. The OOM victim can no longer get stuck on any lock a sleeping task may hold. Debugged by Michal Hocko. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: azurIt <azurit@pobox.sk> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12mm: memcg: enable memcg OOM killer only for user faultsJohannes Weiner
System calls and kernel faults (uaccess, gup) can handle an out of memory situation gracefully and just return -ENOMEM. Enable the memcg OOM killer only for user faults, where it's really the only option available. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12memcg: enhance memcg iterator to support predicatesMichal Hocko
The caller of the iterator might know that some nodes or even subtrees should be skipped but there is no way to tell iterators about that so the only choice left is to let iterators to visit each node and do the selection outside of the iterating code. This, however, doesn't scale well with hierarchies with many groups where only few groups are interesting. This patch adds mem_cgroup_iter_cond variant of the iterator with a callback which gets called for every visited node. There are three possible ways how the callback can influence the walk. Either the node is visited, it is skipped but the tree walk continues down the tree or the whole subtree of the current group is skipped. [hughd@google.com: fix memcg-less page reclaim] Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Glauber Costa <glommer@openvz.org> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michel Lespinasse <walken@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12vmscan, memcg: do softlimit reclaim also for targeted reclaimMichal Hocko
Soft reclaim has been done only for the global reclaim (both background and direct). Since "memcg: integrate soft reclaim tighter with zone shrinking code" there is no reason for this limitation anymore as the soft limit reclaim doesn't use any special code paths and it is a part of the zone shrinking code which is used by both global and targeted reclaims. From the semantic point of view it is natural to consider soft limit before touching all groups in the hierarchy tree which is touching the hard limit because soft limit tells us where to push back when there is a memory pressure. It is not important whether the pressure comes from the limit or imbalanced zones. This patch simply enables soft reclaim unconditionally in mem_cgroup_should_soft_reclaim so it is enabled for both global and targeted reclaim paths. mem_cgroup_soft_reclaim_eligible needs to learn about the root of the reclaim to know where to stop checking soft limit state of parents up the hierarchy. Say we have A (over soft limit) \ B (below s.l., hit the hard limit) / \ C D (below s.l.) B is the source of the outside memory pressure now for D but we shouldn't soft reclaim it because it is behaving well under B subtree and we can still reclaim from C (pressumably it is over the limit). mem_cgroup_soft_reclaim_eligible should therefore stop climbing up the hierarchy at B (root of the memory pressure). Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Glauber Costa <glommer@openvz.org> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12memcg, vmscan: integrate soft reclaim tighter with zone shrinking codeMichal Hocko
This patchset is sitting out of tree for quite some time without any objections. I would be really happy if it made it into 3.12. I do not want to push it too hard but I think this work is basically ready and waiting more doesn't help. The basic idea is quite simple. Pull soft reclaim into shrink_zone in the first step and get rid of the previous soft reclaim infrastructure. shrink_zone is done in two passes now. First it tries to do the soft limit reclaim and it falls back to reclaim-all mode if no group is over the limit or no pages have been scanned. The second pass happens at the same priority so the only time we waste is the memcg tree walk which has been updated in the third step to have only negligible overhead. As a bonus we will get rid of a _lot_ of code by this and soft reclaim will not stand out like before when it wasn't integrated into the zone shrinking code and it reclaimed at priority 0 (the testing results show that some workloads suffers from such an aggressive reclaim). The clean up is in a separate patch because I felt it would be easier to review that way. The second step is soft limit reclaim integration into targeted reclaim. It should be rather straight forward. Soft limit has been used only for the global reclaim so far but it makes sense for any kind of pressure coming from up-the-hierarchy, including targeted reclaim. The third step (patches 4-8) addresses the tree walk overhead by enhancing memcg iterators to enable skipping whole subtrees and tracking number of over soft limit children at each level of the hierarchy. This information is updated same way the old soft limit tree was updated (from memcg_check_events) so we shouldn't see an additional overhead. In fact mem_cgroup_update_soft_limit is much simpler than tree manipulation done previously. __shrink_zone uses mem_cgroup_soft_reclaim_eligible as a predicate for mem_cgroup_iter so the decision whether a particular group should be visited is done at the iterator level which allows us to decide to skip the whole subtree as well (if there is no child in excess). This reduces the tree walk overhead considerably. * TEST 1 ======== My primary test case was a parallel kernel build with 2 groups (make is running with -j8 with a distribution .config in a separate cgroup without any hard limit) on a 32 CPU machine booted with 1GB memory and both builds run taskset to Node 0 cpus. I was mostly interested in 2 setups. Default - no soft limit set and - and 0 soft limit set to both groups. The first one should tell us whether the rework regresses the default behavior while the second one should show us improvements in an extreme case where both workloads are always over the soft limit. /usr/bin/time -v has been used to collect the statistics and each configuration had 3 runs after fresh boot without any other load on the system. base is mmotm-2013-07-18-16-40 rework all 8 patches applied on top of base * No-limit User no-limit/base: min: 651.92 max: 672.65 avg: 664.33 std: 8.01 runs: 6 no-limit/rework: min: 657.34 [100.8%] max: 668.39 [99.4%] avg: 663.13 [99.8%] std: 3.61 runs: 6 System no-limit/base: min: 69.33 max: 71.39 avg: 70.32 std: 0.79 runs: 6 no-limit/rework: min: 69.12 [99.7%] max: 71.05 [99.5%] avg: 70.04 [99.6%] std: 0.59 runs: 6 Elapsed no-limit/base: min: 398.27 max: 422.36 avg: 408.85 std: 7.74 runs: 6 no-limit/rework: min: 386.36 [97.0%] max: 438.40 [103.8%] avg: 416.34 [101.8%] std: 18.85 runs: 6 The results are within noise. Elapsed time has a bigger variance but the average looks good. * 0-limit User 0-limit/base: min: 573.76 max: 605.63 avg: 585.73 std: 12.21 runs: 6 0-limit/rework: min: 645.77 [112.6%] max: 666.25 [110.0%] avg: 656.97 [112.2%] std: 7.77 runs: 6 System 0-limit/base: min: 69.57 max: 71.13 avg: 70.29 std: 0.54 runs: 6 0-limit/rework: min: 68.68 [98.7%] max: 71.40 [100.4%] avg: 69.91 [99.5%] std: 0.87 runs: 6 Elapsed 0-limit/base: min: 1306.14 max: 1550.17 avg: 1430.35 std: 90.86 runs: 6 0-limit/rework: min: 404.06 [30.9%] max: 465.94 [30.1%] avg: 434.81 [30.4%] std: 22.68 runs: 6 The improvement is really huge here (even bigger than with my previous testing and I suspect that this highly depends on the storage). Page fault statistics tell us at least part of the story: Minor 0-limit/base: min: 37180461.00 max: 37319986.00 avg: 37247470.00 std: 54772.71 runs: 6 0-limit/rework: min: 36751685.00 [98.8%] max: 36805379.00 [98.6%] avg: 36774506.33 [98.7%] std: 17109.03 runs: 6 Major 0-limit/base: min: 170604.00 max: 221141.00 avg: 196081.83 std: 18217.01 runs: 6 0-limit/rework: min: 2864.00 [1.7%] max: 10029.00 [4.5%] avg: 5627.33 [2.9%] std: 2252.71 runs: 6 Same as with my previous testing Minor faults are more or less within noise but Major fault count is way bellow the base kernel. While this looks as a nice win it is fair to say that 0-limit configuration is quite artificial. So I was playing with 0-no-limit loads as well. * TEST 2 ======== The following results are from 2 groups configuration on a 16GB machine (single NUMA node). - A running stream IO (dd if=/dev/zero of=local.file bs=1024) with 2*TotalMem with 0 soft limit. - B running a mem_eater which consumes TotalMem-1G without any limit. The mem_eater consumes the memory in 100 chunks with 1s nap after each mmap+poppulate so that both loads have chance to fight for the memory. The expected result is that B shouldn't be reclaimed and A shouldn't see a big dropdown in elapsed time. User base: min: 2.68 max: 2.89 avg: 2.76 std: 0.09 runs: 3 rework: min: 3.27 [122.0%] max: 3.74 [129.4%] avg: 3.44 [124.6%] std: 0.21 runs: 3 System base: min: 86.26 max: 88.29 avg: 87.28 std: 0.83 runs: 3 rework: min: 81.05 [94.0%] max: 84.96 [96.2%] avg: 83.14 [95.3%] std: 1.61 runs: 3 Elapsed base: min: 317.28 max: 332.39 avg: 325.84 std: 6.33 runs: 3 rework: min: 281.53 [88.7%] max: 298.16 [89.7%] avg: 290.99 [89.3%] std: 6.98 runs: 3 System time improved slightly as well as Elapsed. My previous testing has shown worse numbers but this again seem to depend on the storage speed. My theory is that the writeback doesn't catch up and prio-0 soft reclaim falls into wait on writeback page too often in the base kernel. The patched kernel doesn't do that because the soft reclaim is done from the kswapd/direct reclaim context. This can be seen on the following graph nicely. The A's group usage_in_bytes regurarly drops really low very often. All 3 runs http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/stream.png resp. a detail of the single run http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/stream-one-run.png mem_eater seems to be doing better as well. It gets to the full allocation size faster as can be seen on the following graph: http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/mem_eater-one-run.png /proc/meminfo collected during the test also shows that rework kernel hasn't swapped that much (well almost not at all): base: max: 123900 K avg: 56388.29 K rework: max: 300 K avg: 128.68 K kswapd and direct reclaim statistics are of no use unfortunatelly because soft reclaim is not accounted properly as the counters are hidden by global_reclaim() checks in the base kernel. * TEST 3 ======== Another test was the same configuration as TEST2 except the stream IO was replaced by a single kbuild (16 parallel jobs bound to Node0 cpus same as in TEST1) and mem_eater allocated TotalMem-200M so kbuild had only 200MB left. Kbuild did better with the rework kernel here as well: User base: min: 860.28 max: 872.86 avg: 868.03 std: 5.54 runs: 3 rework: min: 880.81 [102.4%] max: 887.45 [101.7%] avg: 883.56 [101.8%] std: 2.83 runs: 3 System base: min: 84.35 max: 85.06 avg: 84.79 std: 0.31 runs: 3 rework: min: 85.62 [101.5%] max: 86.09 [101.2%] avg: 85.79 [101.2%] std: 0.21 runs: 3 Elapsed base: min: 135.36 max: 243.30 avg: 182.47 std: 45.12 runs: 3 rework: min: 110.46 [81.6%] max: 116.20 [47.8%] avg: 114.15 [62.6%] std: 2.61 runs: 3 Minor base: min: 36635476.00 max: 36673365.00 avg: 36654812.00 std: 15478.03 runs: 3 rework: min: 36639301.00 [100.0%] max: 36695541.00 [100.1%] avg: 36665511.00 [100.0%] std: 23118.23 runs: 3 Major base: min: 14708.00 max: 53328.00 avg: 31379.00 std: 16202.24 runs: 3 rework: min: 302.00 [2.1%] max: 414.00 [0.8%] avg: 366.33 [1.2%] std: 47.22 runs: 3 Again we can see a significant improvement in Elapsed (it also seems to be more stable), there is a huge dropdown for the Major page faults and much more swapping: base: max: 583736 K avg: 112547.43 K rework: max: 4012 K avg: 124.36 K Graphs from all three runs show the variability of the kbuild quite nicely. It even seems that it took longer after every run with the base kernel which would be quite surprising as the source tree for the build is removed and caches are dropped after each run so the build operates on a freshly extracted sources everytime. http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/kbuild-mem_eater.png My other testing shows that this is just a matter of timing and other runs behave differently the std for Elapsed time is similar ~50. Example of other three runs: http://labs.suse.cz/mhocko/soft_limit_rework/stream_io-vs-mem_eater/kbuild-mem_eater2.png So to wrap this up. The series is still doing good and improves the soft limit. The testing results for bunch of cgroups with both stream IO and kbuild loads can be found in "memcg: track children in soft limit excess to improve soft limit". This patch: Memcg soft reclaim has been traditionally triggered from the global reclaim paths before calling shrink_zone. mem_cgroup_soft_limit_reclaim then picked up a group which exceeds the soft limit the most and reclaimed it with 0 priority to reclaim at least SWAP_CLUSTER_MAX pages. The infrastructure requires per-node-zone trees which hold over-limit groups and keep them up-to-date (via memcg_check_events) which is not cost free. Although this overhead hasn't turned out to be a bottle neck the implementation is suboptimal because mem_cgroup_update_tree has no idea which zones consumed memory over the limit so we could easily end up having a group on a node-zone tree having only few pages from that node-zone. This patch doesn't try to fix node-zone trees management because it seems that integrating soft reclaim into zone shrinking sounds much easier and more appropriate for several reasons. First of all 0 priority reclaim was a crude hack which might lead to big stalls if the group's LRUs are big and hard to reclaim (e.g. a lot of dirty/writeback pages). Soft reclaim should be applicable also to the targeted reclaim which is awkward right now without additional hacks. Last but not least the whole infrastructure eats quite some code. After this patch shrink_zone is done in 2 passes. First it tries to do the soft reclaim if appropriate (only for global reclaim for now to keep compatible with the original state) and fall back to ignoring soft limit if no group is eligible to soft reclaim or nothing has been scanned during the first pass. Only groups which are over their soft limit or any of their parents up the hierarchy is over the limit are considered eligible during the first pass. Soft limit tree which is not necessary anymore will be removed in the follow up patch to make this patch smaller and easier to review. Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Glauber Costa <glommer@openvz.org> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Glauber Costa <glommer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-08cgroup: pass around cgroup_subsys_state instead of cgroup in file methodsTejun Heo
cgroup is currently in the process of transitioning to using struct cgroup_subsys_state * as the primary handle instead of struct cgroup. Please see the previous commit which converts the subsystem methods for rationale. This patch converts all cftype file operations to take @css instead of @cgroup. cftypes for the cgroup core files don't have their subsytem pointer set. These will automatically use the dummy_css added by the previous patch and can be converted the same way. Most subsystem conversions are straight forwards but there are some interesting ones. * freezer: update_if_frozen() is also converted to take @css instead of @cgroup for consistency. This will make the code look simpler too once iterators are converted to use css. * memory/vmpressure: mem_cgroup_from_css() needs to be exported to vmpressure while mem_cgroup_from_cont() can be made static. Updated accordingly. * cpu: cgroup_tg() doesn't have any user left. Removed. * cpuacct: cgroup_ca() doesn't have any user left. Removed. * hugetlb: hugetlb_cgroup_form_cgroup() doesn't have any user left. Removed. * net_cls: cgrp_cls_state() doesn't have any user left. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-07-03mm, memcg: don't take task_lock in task_in_mem_cgroupDavid Rientjes
For processes that have detached their mm's, task_in_mem_cgroup() unnecessarily takes task_lock() when rcu_read_lock() is all that is necessary to call mem_cgroup_from_task(). While we're here, switch task_in_mem_cgroup() to return bool. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: refactor inactive_file_is_low() to use get_lru_size()Johannes Weiner
An inactive file list is considered low when its active counterpart is bigger, regardless of whether it is a global zone LRU list or a memcg zone LRU list. The only difference is in how the LRU size is assessed. get_lru_size() does the right thing for both global and memcg reclaim situations. Get rid of inactive_file_is_low_global() and mem_cgroup_inactive_file_is_low() by using get_lru_size() and compare the numbers in common code. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-05memcg: fix typo in kmemcg cache walk macroGlauber Costa
The macro for_each_memcg_cache_index contains a silly yet potentially deadly mistake. Although the macro parameter is _idx, the loop tests are done over i, not _idx. This hasn't generated any problems so far, because all users use i as a loop index. However, while playing with an extension of the code I ended using another loop index and the compiler was quick to complain. Unfortunately, this is not the kind of thing that testing reveals =( Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: add comments clarifying aspects of cache attribute propagationGlauber Costa
This patch clarifies two aspects of cache attribute propagation. First, the expected context for the for_each_memcg_cache macro in memcontrol.h. The usages already in the codebase are safe. In mm/slub.c, it is trivially safe because the lock is acquired right before the loop. In mm/slab.c, it is less so: the lock is acquired by an outer function a few steps back in the stack, so a VM_BUG_ON() is added to make sure it is indeed safe. A comment is also added to detail why we are returning the value of the parent cache and ignoring the children's when we propagate the attributes. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18slab: propagate tunable valuesGlauber Costa
SLAB allows us to tune a particular cache behavior with tunables. When creating a new memcg cache copy, we'd like to preserve any tunables the parent cache already had. This could be done by an explicit call to do_tune_cpucache() after the cache is created. But this is not very convenient now that the caches are created from common code, since this function is SLAB-specific. Another method of doing that is taking advantage of the fact that do_tune_cpucache() is always called from enable_cpucache(), which is called at cache initialization. We can just preset the values, and then things work as expected. It can also happen that a root cache has its tunables updated during normal system operation. In this case, we will propagate the change to all caches that are already active. This change will require us to move the assignment of root_cache in memcg_params a bit earlier. We need this to be already set - which memcg_kmem_register_cache will do - when we reach __kmem_cache_create() Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: aggregate memcg cache values in slabinfoGlauber Costa
When we create caches in memcgs, we need to display their usage information somewhere. We'll adopt a scheme similar to /proc/meminfo, with aggregate totals shown in the global file, and per-group information stored in the group itself. For the time being, only reads are allowed in the per-group cache. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg/sl[au]b: track all the memcg children of a kmem_cacheGlauber Costa
This enables us to remove all the children of a kmem_cache being destroyed, if for example the kernel module it's being used in gets unloaded. Otherwise, the children will still point to the destroyed parent. Signed-off-by: Suleiman Souhlal <suleiman@google.com> Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: destroy memcg cachesGlauber Costa
Implement destruction of memcg caches. Right now, only caches where our reference counter is the last remaining are deleted. If there are any other reference counters around, we just leave the caches lying around until they go away. When that happens, a destruction function is called from the cache code. Caches are only destroyed in process context, so we queue them up for later processing in the general case. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18sl[au]b: always get the cache from its page in kmem_cache_free()Glauber Costa
struct page already has this information. If we start chaining caches, this information will always be more trustworthy than whatever is passed into the function. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: infrastructure to match an allocation to the right cacheGlauber Costa
The page allocator is able to bind a page to a memcg when it is allocated. But for the caches, we'd like to have as many objects as possible in a page belonging to the same cache. This is done in this patch by calling memcg_kmem_get_cache in the beginning of every allocation function. This function is patched out by static branches when kernel memory controller is not being used. It assumes that the task allocating, which determines the memcg in the page allocator, belongs to the same cgroup throughout the whole process. Misaccounting can happen if the task calls memcg_kmem_get_cache() while belonging to a cgroup, and later on changes. This is considered acceptable, and should only happen upon task migration. Before the cache is created by the memcg core, there is also a possible imbalance: the task belongs to a memcg, but the cache being allocated from is the global cache, since the child cache is not yet guaranteed to be ready. This case is also fine, since in this case the GFP_KMEMCG will not be passed and the page allocator will not attempt any cgroup accounting. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: allocate memory for memcg caches whenever a new memcg appearsGlauber Costa
Every cache that is considered a root cache (basically the "original" caches, tied to the root memcg/no-memcg) will have an array that should be large enough to store a cache pointer per each memcg in the system. Theoreticaly, this is as high as 1 << sizeof(css_id), which is currently in the 64k pointers range. Most of the time, we won't be using that much. What goes in this patch, is a simple scheme to dynamically allocate such an array, in order to minimize memory usage for memcg caches. Because we would also like to avoid allocations all the time, at least for now, the array will only grow. It will tend to be big enough to hold the maximum number of kmem-limited memcgs ever achieved. We'll allocate it to be a minimum of 64 kmem-limited memcgs. When we have more than that, we'll start doubling the size of this array every time the limit is reached. Because we are only considering kmem limited memcgs, a natural point for this to happen is when we write to the limit. At that point, we already have set_limit_mutex held, so that will become our natural synchronization mechanism. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18slab/slub: consider a memcg parameter in kmem_create_cacheGlauber Costa
Allow a memcg parameter to be passed during cache creation. When the slub allocator is being used, it will only merge caches that belong to the same memcg. We'll do this by scanning the global list, and then translating the cache to a memcg-specific cache Default function is created as a wrapper, passing NULL to the memcg version. We only merge caches that belong to the same memcg. A helper is provided, memcg_css_id: because slub needs a unique cache name for sysfs. Since this is visible, but not the canonical location for slab data, the cache name is not used, the css_id should suffice. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: JoonSoo Kim <js1304@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: use static branches when code not in useGlauber Costa
We can use static branches to patch the code in or out when not used. Because the _ACTIVE bit on kmem_accounted is only set after the increment is done, we guarantee that the root memcg will always be selected for kmem charges until all call sites are patched (see memcg_kmem_enabled). This guarantees that no mischarges are applied. Static branch decrement happens when the last reference count from the kmem accounting in memcg dies. This will only happen when the charges drop down to 0. When that happens, we need to disable the static branch only on those memcgs that enabled it. To achieve this, we would be forced to complicate the code by keeping track of which memcgs were the ones that actually enabled limits, and which ones got it from its parents. It is a lot simpler just to do static_key_slow_inc() on every child that is accounted. Signed-off-by: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Suleiman Souhlal <suleiman@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: JoonSoo Kim <js1304@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-18memcg: kmem controller infrastructureGlauber Costa
Introduce infrastructure for tracking kernel memory pages to a given memcg. This will happen whenever the caller includes the flag __GFP_KMEMCG flag, and the task belong to a memcg other than the root. In memcontrol.h those functions are wrapped in inline acessors. The idea is to later on, patch those with static branches, so we don't incur any overhead when no mem cgroups with limited kmem are being used. Users of this functionality shall interact with the memcg core code through the following functions: memcg_kmem_newpage_charge: will return true if the group can handle the allocation. At this point, struct page is not yet allocated. memcg_kmem_commit_charge: will either revert the charge, if struct page allocation failed, or embed memcg information into page_cgroup. memcg_kmem_uncharge_page: called at free time, will revert the charge. Signed-off-by: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: JoonSoo Kim <js1304@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Suleiman Souhlal <suleiman@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12mm, memcg: avoid unnecessary function call when memcg is disabledDavid Rientjes
While profiling numa/core v16 with cgroup_disable=memory on the command line, I noticed mem_cgroup_count_vm_event() still showed up as high as 0.60% in perftop. This occurs because the function is called extremely often even when memcg is disabled. To fix this, inline the check for mem_cgroup_disabled() so we avoid the unnecessary function call if memcg is disabled. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-11memcg, kmem: fix build error when CONFIG_INET is disabledDavid Rientjes
Commit e1aab161e013 ("socket: initial cgroup code.") causes a build error when CONFIG_INET is disabled in Linus' tree: net/built-in.o: In function `sk_update_clone': net/core/sock.c:1336: undefined reference to `sock_update_memcg' sock_update_memcg() is only defined when CONFIG_INET is enabled, so fix it by defining the dummy function without this option. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Glauber Costa <glommer@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: memcg: clean up mm_match_cgroup() signatureJohannes Weiner
It really should return a boolean for match/no match. And since it takes a memcg, not a cgroup, fix that parameter name as well. [akpm@linux-foundation.org: mm_match_cgroup() is not a macro] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: memcg: fix compaction/migration failing due to memcg limitsJohannes Weiner
Compaction (and page migration in general) can currently be hindered through pages being owned by memory cgroups that are at their limits and unreclaimable. The reason is that the replacement page is being charged against the limit while the page being replaced is also still charged. But this seems unnecessary, given that only one of the two pages will still be in use after migration finishes. This patch changes the memcg migration sequence so that the replacement page is not charged. Whatever page is still in use after successful or failed migration gets to keep the charge of the page that was going to be replaced. The replacement page will still show up temporarily in the rss/cache statistics, this can be fixed in a later patch as it's less urgent. Reported-by: David Rientjes <rientjes@google.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Wanpeng Li <liwp.linux@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, memcg: move all oom handling to memcontrol.cDavid Rientjes
By globally defining check_panic_on_oom(), the memcg oom handler can be moved entirely to mm/memcontrol.c. This removes the ugly #ifdef in the oom killer and cleans up the code. Signed-off-by: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, memcg: introduce own oom handler to iterate only over its own threadsDavid Rientjes
The global oom killer is serialized by the per-zonelist try_set_zonelist_oom() which is used in the page allocator. Concurrent oom kills are thus a rare event and only occur in systems using mempolicies and with a large number of nodes. Memory controller oom kills, however, can frequently be concurrent since there is no serialization once the oom killer is called for oom conditions in several different memcgs in parallel. This creates a massive contention on tasklist_lock since the oom killer requires the readside for the tasklist iteration. If several memcgs are calling the oom killer, this lock can be held for a substantial amount of time, especially if threads continue to enter it as other threads are exiting. Since the exit path grabs the writeside of the lock with irqs disabled in a few different places, this can cause a soft lockup on cpus as a result of tasklist_lock starvation. The kernel lacks unfair writelocks, and successful calls to the oom killer usually result in at least one thread entering the exit path, so an alternative solution is needed. This patch introduces a seperate oom handler for memcgs so that they do not require tasklist_lock for as much time. Instead, it iterates only over the threads attached to the oom memcg and grabs a reference to the selected thread before calling oom_kill_process() to ensure it doesn't prematurely exit. This still requires tasklist_lock for the tasklist dump, iterating children of the selected process, and killing all other threads on the system sharing the same memory as the selected victim. So while this isn't a complete solution to tasklist_lock starvation, it significantly reduces the amount of time that it is held. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Sha Zhengju <handai.szj@taobao.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm, oom: move declaration for mem_cgroup_out_of_memory to oom.hDavid Rientjes
mem_cgroup_out_of_memory() is defined in mm/oom_kill.c, so declare it in linux/oom.h rather than linux/memcontrol.h. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31memcg: rename config variablesAndrew Morton
Sanity: CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM [mhocko@suse.cz: fix missed bits] Cc: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: apply add/del_page to lruvecHugh Dickins
Take lruvec further: pass it instead of zone to add_page_to_lru_list() and del_page_from_lru_list(); and pagevec_lru_move_fn() pass lruvec down to its target functions. This cleanup eliminates a swathe of cruft in memcontrol.c, including mem_cgroup_lru_add_list(), mem_cgroup_lru_del_list() and mem_cgroup_lru_move_lists() - which never actually touched the lists. In their place, mem_cgroup_page_lruvec() to decide the lruvec, previously a side-effect of add, and mem_cgroup_update_lru_size() to maintain the lru_size stats. Whilst these are simplifications in their own right, the goal is to bring the evaluation of lruvec next to the spin_locking of the lrus, in preparation for a future patch. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: get_lru_size not get_lruvec_sizeHugh Dickins
Konstantin just introduced mem_cgroup_get_lruvec_size() and get_lruvec_size(), I'm about to add mem_cgroup_update_lru_size(): but we're dealing with the same thing, lru_size[lru]. We ought to agree on the naming, and I do think lru_size is the more correct: so rename his ones to get_lru_size(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/vmscan: push lruvec pointer into inactive_list_is_low()Konstantin Khlebnikov
Switch mem_cgroup_inactive_anon_is_low() to lruvec pointers, mem_cgroup_get_lruvec_size() is more effective than mem_cgroup_zone_nr_lru_pages() Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/vmscan: replace zone_nr_lru_pages() with get_lruvec_size()Konstantin Khlebnikov
If memory cgroup is enabled we always use lruvecs which are embedded into struct mem_cgroup_per_zone, so we can reach lru_size counters via container_of(). Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: kill mem_cgroup_lru_del()Konstantin Khlebnikov
This patch kills mem_cgroup_lru_del(), we can use mem_cgroup_lru_del_list() instead. On 0-order isolation we already have right lru list id. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/memcg: move reclaim_stat into lruvecHugh Dickins
With mem_cgroup_disabled() now explicit, it becomes clear that the zone_reclaim_stat structure actually belongs in lruvec, per-zone when memcg is disabled but per-memcg per-zone when it's enabled. We can delete mem_cgroup_get_reclaim_stat(), and change update_page_reclaim_stat() to update just the one set of stats, the one which get_scan_count() will actually use. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Glauber Costa <glommer@parallels.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: memcg: count pte references from every member of the reclaimed hierarchyJohannes Weiner
The rmap walker checking page table references has historically ignored references from VMAs that were not part of the memcg that was being reclaimed during memcg hard limit reclaim. When transitioning global reclaim to memcg hierarchy reclaim, I missed that bit and now references from outside a memcg are ignored even during global reclaim. Reverting back to traditional behaviour - count all references during global reclaim and only mind references of the memcg being reclaimed during limit reclaim would be one option. However, the more generic idea is to ignore references exactly then when they are outside the hierarchy that is currently under reclaim; because only then will their reclamation be of any use to help the pressure situation. It makes no sense to ignore references from a sibling memcg and then evict a page that will be immediately refaulted by that sibling which contributes to the same usage of the common ancestor under reclaim. The solution: make the rmap walker ignore references from VMAs that are not part of the hierarchy that is being reclaimed. Flat limit reclaim will stay the same, hierarchical limit reclaim will mind the references only to pages that the hierarchy owns. Global reclaim, since it reclaims from all memcgs, will be fixed to regard all references. [akpm@linux-foundation.org: name the args in the declaration] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Konstantin Khlebnikov<khlebnikov@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: fix performance of mem_cgroup_begin_update_page_stat()KAMEZAWA Hiroyuki
mem_cgroup_begin_update_page_stat() should be very fast because it's called very frequently. Now, it needs to look up page_cgroup and its memcg....this is slow. This patch adds a global variable to check "any memcg is moving or not". With this, the caller doesn't need to visit page_cgroup and memcg. Here is a test result. A test program makes page faults onto a file, MAP_SHARED and makes each page's page_mapcount(page) > 1, and free the range by madvise() and page fault again. This program causes 26214400 times of page fault onto a file(size was 1G.) and shows shows the cost of mem_cgroup_begin_update_page_stat(). Before this patch for mem_cgroup_begin_update_page_stat() [kamezawa@bluextal test]$ time ./mmap 1G real 0m21.765s user 0m5.999s sys 0m15.434s 27.46% mmap mmap [.] reader 21.15% mmap [kernel.kallsyms] [k] page_fault 9.17% mmap [kernel.kallsyms] [k] filemap_fault 2.96% mmap [kernel.kallsyms] [k] __do_fault 2.83% mmap [kernel.kallsyms] [k] __mem_cgroup_begin_update_page_stat After this patch [root@bluextal test]# time ./mmap 1G real 0m21.373s user 0m6.113s sys 0m15.016s In usual path, calls to __mem_cgroup_begin_update_page_stat() goes away. Note: we may be able to remove this optimization in future if we can get pointer to memcg directly from struct page. [akpm@linux-foundation.org: don't return a void] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Greg Thelen <gthelen@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: use new logic for page stat accountingKAMEZAWA Hiroyuki
Now, page-stat-per-memcg is recorded into per page_cgroup flag by duplicating page's status into the flag. The reason is that memcg has a feature to move a page from a group to another group and we have race between "move" and "page stat accounting", Under current logic, assume CPU-A and CPU-B. CPU-A does "move" and CPU-B does "page stat accounting". When CPU-A goes 1st, CPU-A CPU-B update "struct page" info. move_lock_mem_cgroup(memcg) see pc->flags copy page stat to new group overwrite pc->mem_cgroup. move_unlock_mem_cgroup(memcg) move_lock_mem_cgroup(mem) set pc->flags update page stat accounting move_unlock_mem_cgroup(mem) stat accounting is guarded by move_lock_mem_cgroup() and "move" logic (CPU-A) doesn't see changes in "struct page" information. But it's costly to have the same information both in 'struct page' and 'struct page_cgroup'. And, there is a potential problem. For example, assume we have PG_dirty accounting in memcg. PG_..is a flag for struct page. PCG_ is a flag for struct page_cgroup. (This is just an example. The same problem can be found in any kind of page stat accounting.) CPU-A CPU-B TestSet PG_dirty (delay) TestClear PG_dirty if (TestClear(PCG_dirty)) memcg->nr_dirty-- if (TestSet(PCG_dirty)) memcg->nr_dirty++ Here, memcg->nr_dirty = +1, this is wrong. This race was reported by Greg Thelen <gthelen@google.com>. Now, only FILE_MAPPED is supported but fortunately, it's serialized by page table lock and this is not real bug, _now_, If this potential problem is caused by having duplicated information in struct page and struct page_cgroup, we may be able to fix this by using original 'struct page' information. But we'll have a problem in "move account" Assume we use only PG_dirty. CPU-A CPU-B TestSet PG_dirty (delay) move_lock_mem_cgroup() if (PageDirty(page)) new_memcg->nr_dirty++ pc->mem_cgroup = new_memcg; move_unlock_mem_cgroup() move_lock_mem_cgroup() memcg = pc->mem_cgroup new_memcg->nr_dirty++ accounting information may be double-counted. This was original reason to have PCG_xxx flags but it seems PCG_xxx has another problem. I think we need a bigger lock as move_lock_mem_cgroup(page) TestSetPageDirty(page) update page stats (without any checks) move_unlock_mem_cgroup(page) This fixes both of problems and we don't have to duplicate page flag into page_cgroup. Please note: move_lock_mem_cgroup() is held only when there are possibility of "account move" under the system. So, in most path, status update will go without atomic locks. This patch introduces mem_cgroup_begin_update_page_stat() and mem_cgroup_end_update_page_stat() both should be called at modifying 'struct page' information if memcg takes care of it. as mem_cgroup_begin_update_page_stat() modify page information mem_cgroup_update_page_stat() => never check any 'struct page' info, just update counters. mem_cgroup_end_update_page_stat(). This patch is slow because we need to call begin_update_page_stat()/ end_update_page_stat() regardless of accounted will be changed or not. A following patch adds an easy optimization and reduces the cost. [akpm@linux-foundation.org: s/lock/locked/] [hughd@google.com: fix deadlock by avoiding stat lock when anon] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Greg Thelen <gthelen@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: kill dead prev_priority stubsKonstantin Khlebnikov
This code was removed in 25edde033291 ("vmscan: kill prev_priority completely") Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: replace MEM_CONT by MEM_RES_CTLRHugh Dickins
Correct an #endif comment in memcontrol.h from MEM_CONT to MEM_RES_CTLR. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, memcg: pass charge order to oom killerDavid Rientjes
The oom killer typically displays the allocation order at the time of oom as a part of its diangostic messages (for global, cpuset, and mempolicy ooms). The memory controller may also pass the charge order to the oom killer so it can emit the same information. This is useful in determining how large the memory allocation is that triggered the oom killer. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05memcg: fix GPF when cgroup removal races with last exitHugh Dickins
When moving tasks from old memcg (with move_charge_at_immigrate on new memcg), followed by removal of old memcg, hit General Protection Fault in mem_cgroup_lru_del_list() (called from release_pages called from free_pages_and_swap_cache from tlb_flush_mmu from tlb_finish_mmu from exit_mmap from mmput from exit_mm from do_exit). Somewhat reproducible, takes a few hours: the old struct mem_cgroup has been freed and poisoned by SLAB_DEBUG, but mem_cgroup_lru_del_list() is still trying to update its stats, and take page off lru before freeing. A task, or a charge, or a page on lru: each secures a memcg against removal. In this case, the last task has been moved out of the old memcg, and it is exiting: anonymous pages are uncharged one by one from the memcg, as they are zapped from its pagetables, so the charge gets down to 0; but the pages themselves are queued in an mmu_gather for freeing. Most of those pages will be on lru (and force_empty is careful to lru_add_drain_all, to add pages from pagevec to lru first), but not necessarily all: perhaps some have been isolated for page reclaim, perhaps some isolated for other reasons. So, force_empty may find no task, no charge and no page on lru, and let the removal proceed. There would still be no problem if these pages were immediately freed; but typically (and the put_page_testzero protocol demands it) they have to be added back to lru before they are found freeable, then removed from lru and freed. We don't see the issue when adding, because the mem_cgroup_iter() loops keep their own reference to the memcg being scanned; but when it comes to mem_cgroup_lru_del_list(). I believe this was not an issue in v3.2: there, PageCgroupAcctLRU and PageCgroupUsed flags were used (like a trick with mirrors) to deflect view of pc->mem_cgroup to the stable root_mem_cgroup when neither set. 38c5d72f3ebe ("memcg: simplify LRU handling by new rule") mercifully removed those convolutions, but left this General Protection Fault. But it's surprisingly easy to restore the old behaviour: just check PageCgroupUsed in mem_cgroup_lru_add_list() (which decides on which lruvec to add), and reset pc to root_mem_cgroup if page is uncharged. A risky change? just going back to how it worked before; testing, and an audit of uses of pc->mem_cgroup, show no problem. And there's a nice bonus: with mem_cgroup_lru_add_list() itself making sure that an uncharged page goes to root lru, mem_cgroup_reset_owner() no longer has any purpose, and we can safely revert 4e5f01c2b9b9 ("memcg: clear pc->mem_cgroup if necessary"). Calling update_page_reclaim_stat() after add_page_to_lru_list() in swap.c is not strictly necessary: the lru_lock there, with RCU before memcg structures are freed, makes mem_cgroup_get_reclaim_stat_from_page safe without that; but it seems cleaner to rely on one dependency less. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: clear pc->mem_cgroup if necessary.KAMEZAWA Hiroyuki
This is a preparation before removing a flag PCG_ACCT_LRU in page_cgroup and reducing atomic ops/complexity in memcg LRU handling. In some cases, pages are added to lru before charge to memcg and pages are not classfied to memory cgroup at lru addtion. Now, the lru where the page should be added is determined a bit in page_cgroup->flags and pc->mem_cgroup. I'd like to remove the check of flag. To handle the case pc->mem_cgroup may contain stale pointers if pages are added to LRU before classification. This patch resets pc->mem_cgroup to root_mem_cgroup before lru additions. [akpm@linux-foundation.org: fix CONFIG_CGROUP_MEM_CONT=n build] [hughd@google.com: fix CONFIG_CGROUP_MEM_RES_CTLR=y CONFIG_CGROUP_MEM_RES_CTLR_SWAP=n build] [akpm@linux-foundation.org: ksm.c needs memcontrol.h, per Michal] [hughd@google.com: stop oops in mem_cgroup_reset_owner()] [hughd@google.com: fix page migration to reset_owner] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
