path: root/include/linux/memory_hotplug.h
2011-07-25mm: extend memory hotplug API to allow memory hotplug in virtual machinesDaniel Kiper
This patch contains online_page_callback and apropriate functions for registering/unregistering online page callbacks. It allows to do some machine specific tasks during online page stage which is required to implement memory hotplug in virtual machines. Currently this patch is required by latest memory hotplug support for Xen balloon driver patch which will be posted soon. Additionally, originial online_page() function was splited into following functions doing "atomic" operations: - __online_page_set_limits() - set new limits for memory management code, - __online_page_increment_counters() - increment totalram_pages and totalhigh_pages, - __online_page_free() - free page to allocator. It was done to: - not duplicate existing code, - ease hotplug code devolpment by usage of well defined interface, - avoid stupid bugs which are unavoidable when the same code (by design) is developed in many places. [akpm@linux-foundation.org: use explicit indirect-call syntax] Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-15Merge branch 'slub/hotplug' into slab/urgentPekka Enberg
2011-01-13thp: remove PG_buddyAndrea Arcangeli
PG_buddy can be converted to _mapcount == -2. So the PG_compound_lock can be added to page->flags without overflowing (because of the sparse section bits increasing) with CONFIG_X86_PAE=y and CONFIG_X86_PAT=y. This also has to move the memory hotplug code from _mapcount to lru.next to avoid any risk of clashes. We can't use lru.next for PG_buddy removal, but memory hotplug can use lru.next even more easily than the mapcount instead. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-11memory hotplug: one more lock on memory hotplugKAMEZAWA Hiroyuki
Now, memory_hotplug_(un)lock() is used for add/remove/offline pages for avoiding races with hibernation. But this should be held in online_pages(), too. It seems asymmetric. There are cases where one has to avoid a race with memory hotplug notifier and his own local code, and hotplug v.s. hotplug. This will add a generic solution for avoiding races. In other view, having lock here has no big impacts. online pages is tend to be done by udev script at el against each memory section one by one. Then, it's better to have lock here, too. Cc: <stable@kernel.org> # 2.6.37 Reviewed-by: Christoph Lameter <cl@linux.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2010-12-02mem-hotplug: introduce {un}lock_memory_hotplug()KOSAKI Motohiro
Presently hwpoison is using lock_system_sleep() to prevent a race with memory hotplug. However lock_system_sleep() is a no-op if CONFIG_HIBERNATION=n. Therefore we need a new lock. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Suggested-by: Hugh Dickins <hughd@google.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26memory hotplug: unify is_removable and offline detection codeKAMEZAWA Hiroyuki
Now, sysfs interface of memory hotplug shows whether the section is removable or not. But it checks only migrateype of pages and doesn't check details of cluster of pages. Next, memory hotplug's set_migratetype_isolate() has the same kind of check, too. This patch adds the function __count_unmovable_pages() and makes above 2 checks to use the same logic. Then, is_removable and hotremove code uses the same logic. No changes in the hotremove logic itself. TODO: need to find a way to check RECLAMABLE. But, considering bit, calling shrink_slab() against a range before starting memory hotremove sounds better. If so, this patch's logic doesn't need to be changed. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reported-by: Michal Hocko <mhocko@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25cpu/mem hotplug: enable CPUs online before local memory onlineminskey guo
Enable users to online CPUs even if the CPUs belongs to a numa node which doesn't have onlined local memory. The zonlists(pg_data_t.node_zonelists[]) of a numa node are created either in system boot/init period, or at the time of local memory online. For a numa node without onlined local memory, its zonelists are not initialized at present. As a result, any memory allocation operations executed by CPUs within this node will fail. In fact, an out-of-memory error is triggered when attempt to online CPUs before memory comes to online. This patch tries to create zonelists for such numa nodes, so that the memory allocation for this node can be fallback'ed to other nodes. [akpm@linux-foundation.org: remove unneeded export] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: minskey guo<chaohong.guo@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: memory_hotplug: make offline_pages() staticAndrew Morton
It has no references outside memory_hotplug.c. Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Andi Kleen <andi@firstfloor.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23walk system ram rangeKAMEZAWA Hiroyuki
Originally, walk_memory_resource() was introduced to traverse all memory of "System RAM" for detecting memory hotplug/unplug range. For doing so, flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for memory hotplug. But for using other purpose, /proc/kcore, this may includes some firmware area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the check strict to find out busy "System RAM". Note: PPC64 keeps their own walk_memory_resouce(), which walk through ppc64's lmb informaton. Because old kclist_add() is called per lmb, this patch makes no difference in behavior, finally. And this patch removes CONFIG_MEMORY_HOTPLUG check from this function. Because pfn_valid() just show "there is memmap or not* and cannot be used for "there is physical memory or not", this function is useful in generic to scan physical memory range. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: show node to memory section relationship with symlinks in sysfsGary Hade
Show node to memory section relationship with symlinks in sysfs Add /sys/devices/system/node/nodeX/memoryY symlinks for all the memory sections located on nodeX. For example: /sys/devices/system/node/node1/memory135 -> ../../memory/memory135 indicates that memory section 135 resides on node1. Also revises documentation to cover this change as well as updating Documentation/ABI/testing/sysfs-devices-memory to include descriptions of memory hotremove files 'phys_device', 'phys_index', and 'state' that were previously not described there. In addition to it always being a good policy to provide users with the maximum possible amount of physical location information for resources that can be hot-added and/or hot-removed, the following are some (but likely not all) of the user benefits provided by this change. Immediate: - Provides information needed to determine the specific node on which a defective DIMM is located. This will reduce system downtime when the node or defective DIMM is swapped out. - Prevents unintended onlining of a memory section that was previously offlined due to a defective DIMM. This could happen during node hot-add when the user or node hot-add assist script onlines _all_ offlined sections due to user or script inability to identify the specific memory sections located on the hot-added node. The consequences of reintroducing the defective memory could be ugly. - Provides information needed to vary the amount and distribution of memory on specific nodes for testing or debugging purposes. Future: - Will provide information needed to identify the memory sections that need to be offlined prior to physical removal of a specific node. Symlink creation during boot was tested on 2-node x86_64, 2-node ppc64, and 2-node ia64 systems. Symlink creation during physical memory hot-add tested on a 2-node x86_64 system. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory-hotplug: add sysfs removable attribute for hotplug memory removeBadari Pulavarty
Memory may be hot-removed on a per-memory-block basis, particularly on POWER where the SPARSEMEM section size often matches the memory-block size. A user-level agent must be able to identify which sections of memory are likely to be removable before attempting the potentially expensive operation. This patch adds a file called "removable" to the memory directory in sysfs to help such an agent. In this patch, a memory block is considered removable if; o It contains only MOVABLE pageblocks o It contains only pageblocks with free pages regardless of pageblock type On the other hand, a memory block starting with a PageReserved() page will never be considered removable. Without this patch, the user-agent is forced to choose a memory block to remove randomly. Sample output of the sysfs files: ./memory/memory0/removable: 0 ./memory/memory1/removable: 0 ./memory/memory2/removable: 0 ./memory/memory3/removable: 0 ./memory/memory4/removable: 0 ./memory/memory5/removable: 0 ./memory/memory6/removable: 0 ./memory/memory7/removable: 1 ./memory/memory8/removable: 0 ./memory/memory9/removable: 0 ./memory/memory10/removable: 0 ./memory/memory11/removable: 0 ./memory/memory12/removable: 0 ./memory/memory13/removable: 0 ./memory/memory14/removable: 0 ./memory/memory15/removable: 0 ./memory/memory16/removable: 0 ./memory/memory17/removable: 1 ./memory/memory18/removable: 1 ./memory/memory19/removable: 1 ./memory/memory20/removable: 1 ./memory/memory21/removable: 1 ./memory/memory22/removable: 1 Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory hotplug: small fixes to bootmem freeing for memory hotremoveYasunori Goto
- Change some naming * Magic -> types * MIX_INFO -> MIX_SECTION_INFO * Change definition of bootmem type from direct hex value - __free_pages_bootmem() becomes __meminit. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-09[POWERPC] Make walk_memory_resource available with MEMORY_HOTPLUG=nNathan Lynch
The ehea driver was recently changed[1] to use walk_memory_resource() to detect the system's memory layout. However, walk_memory_resource() is available only when memory hotplug is enabled. So CONFIG_EHEA was made to depend on MEMORY_HOTPLUG [2], but it is inappropriate for a network driver to have such a dependency. Make the declaration of walk_memory_resource() and its powerpc implementation (ehea is powerpc-specific) unconditionally available. [1] 48cfb14f8b89d4d5b3df6c16f08b258686fb12ad "ehea: Add DLPAR memory remove support" [2] fb7b6ca2b6b7c23b52be143bdd5f55a23b9780c8 "ehea: Add dependency to Kconfig" Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-28memory hotplug: register section/node id to freeYasunori Goto
This patch set is to free pages which is allocated by bootmem for memory-hotremove. Some structures of memory management are allocated by bootmem. ex) memmap, etc. To remove memory physically, some of them must be freed according to circumstance. This patch set makes basis to free those pages, and free memmaps. Basic my idea is using remain members of struct page to remember information of users of bootmem (section number or node id). When the section is removing, kernel can confirm it. By this information, some issues can be solved. 1) When the memmap of removing section is allocated on other section by bootmem, it should/can be free. 2) When the memmap of removing section is allocated on the same section, it shouldn't be freed. Because the section has to be logical memory offlined already and all pages must be isolated against page allocater. If it is freed, page allocator may use it which will be removed physically soon. 3) When removing section has other section's memmap, kernel will be able to show easily which section should be removed before it for user. (Not implemented yet) 4) When the above case 2), the page isolation will be able to check and skip memmap's page when logical memory offline (offline_pages()). Current page isolation code fails in this case because this page is just reserved page and it can't distinguish this pages can be removed or not. But, it will be able to do by this patch. (Not implemented yet.) 5) The node information like pgdat has similar issues. But, this will be able to be solved too by this. (Not implemented yet, but, remembering node id in the pages.) Fortunately, current bootmem allocator just keeps PageReserved flags, and doesn't use any other members of page struct. The users of bootmem doesn't use them too. This patch: This is to register information which is node or section's id. Kernel can distinguish which node/section uses the pages allcated by bootmem. This is basis for hot-remove sections or nodes. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28hotplug memory remove: generic __remove_pages() supportBadari Pulavarty
Generic helper function to remove section mappings and sysfs entries for the section of the memory we are removing. offline_pages() correctly adjusted zone and marked the pages reserved. TODO: Yasunori Goto is working on patches to free up allocations from bootmem. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fix memory hot remove not configured case.KAMEZAWA Hiroyuki
Now, arch dependent code around CONFIG_MEMORY_HOTREMOVE is a mess. This patch cleans up them. This is against 2.6.23-rc6-mm1. - fix compile failure on ia64/ CONFIG_MEMORY_HOTPLUG && !CONFIG_MEMORY_HOTREMOVE case. - For !CONFIG_MEMORY_HOTREMOVE, add generic no-op remove_memory(), which returns -EINVAL. - removed remove_pages() only used in powerpc. - removed no-op remove_memory() in i386, sh, sparc64, x86_64. - only powerpc returns -ENOSYS at memory hot remove(no-op). changes it to return -EINVAL. Note: Currently, only ia64 supports CONFIG_MEMORY_HOTREMOVE. I welcome other archs if there are requirements and testers. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: page offlineKAMEZAWA Hiroyuki
Logic. - set all pages in [start,end) as isolated migration-type. by this, all free pages in the range will be not-for-use. - Migrate all LRU pages in the range. - Test all pages in the range's refcnt is zero or not. Todo: - allocate migration destination page from better area. - confirm page_count(page)== 0 && PageReserved(page) page is safe to be freed.. (I don't like this kind of page but.. - Find out pages which cannot be migrated. - more running tests. - Use reclaim for unplugging other memory type area. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory unplug: memory hotplug cleanupKAMEZAWA Hiroyuki
A clean up patch for "scanning memory resource [start, end)" operation. Now, find_next_system_ram() function is used in memory hotplug, but this interface is not easy to use and codes are complicated. This patch adds walk_memory_resouce(start,len,arg,func) function. The function 'func' is called per valid memory resouce range in [start,pfn). [pbadari@us.ibm.com: Error handling in walk_memory_resource()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Clean up duplicate includes in include/linux/memory_hotplug.hJesper Juhl
This patch cleans up duplicate includes in include/linux/memory_hotplug.h Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] hot-add-mem x86_64: fixup externsKeith Mannthey
Fix up externs in memory_hotplug.c. Cleanup. Signed-off-by: Keith Mannthey <kmannth@us.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation and update for ia64 of memory hotplug: allocate ↵Yasunori Goto
pgdat and per node data This is a patch to allocate pgdat and per node data area for ia64. The size for them can be calculated by compute_pernodesize(). Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation and update for ia64 of memory hotplug: update pgdat ↵Yasunori Goto
address array This is to refresh node_data[] array for ia64. As I mentioned previous patches, ia64 has copies of information of pgdat address array on each node as per node data. At v2 of node_add, this function used stop_machine_run() to update them. (I wished that they were copied safety as much as possible.) But, in this patch, this arrays are just copied simply, and set node_online_map bit after completion of pgdat initialization. So, kernel must touch NODE_DATA() macro after checking node_online_map(). (Current code has already done it.) This is more simple way for just hot-add..... Note : It will be problem when hot-remove will occur, because, even if online_map bit is set, kernel may touch NODE_DATA() due to race condition. :-( Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation for new node add (refresh node_data[])Yasunori Goto
Refresh NODE_DATA() for generic archs. In this case, NODE_DATA(nid) == node_data[nid]. node_data[] is array of address of pgdat. So, refresh is quite simple. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation for new node add (generic alloc node_data)Yasunori Goto
For node hotplug, basically we have to allocate new pgdat. But, there are several types of implementations of pgdat. 1. Allocate only pgdat. This style allocate only pgdat area. And its address is recorded in node_data[]. It is most popular style. 2. Static array of pgdat In this case, all of pgdats are static array. Some archs use this style. 3. Allocate not only pgdat, but also per node data. To increase performance, each node has copy of some data as a per node data. So, this area must be allocated too. Ia64 is this style. Ia64 has the copies of node_data[] array on each per node data to increase performance. In this series of patches, treat (1) as generic arch. generic archs can use generic function. (2) and (3) should have its own if necessary. This patch defines pgdat allocator. Updating NODE_DATA() macro function is in other patch. Signed-off-by: Yasonori Goto <y-goto@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation for new node add (specify node id)Yasunori Goto
Change the name of old add_memory() to arch_add_memory. And use node id to get pgdat for the node at NODE_DATA(). Note: Powerpc's old add_memory() is defined as __devinit. However, add_memory() is usually called only after bootup. I suppose it may be redundant. But, I'm not well known about powerpc. So, I keep it. (But, __meminit is better at least.) Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] memory_hotplug.h cleanupAdrian Bunk
We don't have to #if guard prototypes. This also fixes a bug observed by Randy Dunlap due to a misspelled option in the #if. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[PATCH] x86_64: Support memory hotadd without sparsememAndi Kleen
Memory hotadd doesn't need SPARSEMEM, but can be handled by just preallocating mem_maps. This only needs some untangling of ifdefs to enable the necessary code even without SPARSEMEM. Originally from Keith Mannthey, hacked by AK. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] memory-hotplug compile fixKAMEZAWA Hiroyuki
include/linux/memory_hotplug.h:53: warning: 'struct page' declared inside parameter list (akpm: I tossed in a couple more possibly-needed-sometime struct decls too) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug: sysfs and add/remove functionsDave Hansen
This adds generic memory add/remove and supporting functions for memory hotplug into a new file as well as a memory hotplug kernel config option. Individual architecture patches will follow. For now, disable memory hotplug when swsusp is enabled. There's a lot of churn there right now. We'll fix it up properly once it calms down. Signed-off-by: Matt Tolentino <matthew.e.tolentino@intel.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug locking: zone span seqlockDave Hansen
See the "fixup bad_range()" patch for more information, but this actually creates a the lock to protect things making assumptions about a zone's size staying constant at runtime. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug locking: node_size_lockDave Hansen
pgdat->node_size_lock is basically only neeeded in one place in the normal code: show_mem(), which is the arch-specific sysrq-m printing function. Strictly speaking, the architectures not doing memory hotplug do no need this locking in show_mem(). However, they are all included for completeness. This should also make any future consolidation of all of the implementations a little more straightforward. This lock is also held in the sparsemem code during a memory removal, as sections are invalidated. This is the place there pfn_valid() is made false for a memory area that's being removed. The lock is only required when doing pfn_valid() operations on memory which the user does not already have a reference on the page, such as in show_mem(). Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
