path: root/include/linux/mempool.h
2009-09-22mm: remove broken 'kzalloc' mempoolSage Weil
The kzalloc mempool zeros items when they are initially allocated, but does not rezero used items that are returned to the pool. Consequently mempool_alloc()s may return non-zeroed memory. Since there are/were only two in-tree users for mempool_create_kzalloc_pool(), and 'fixing' this in a way that will re-zero used (but not new) items before first use is non-trivial, just remove it. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-26[PATCH] mempool: add mempool_create_slab_pool()Matthew Dobson
Create a simple wrapper function for the common case of creating a slab-based mempool. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: add kzalloc allocatorMatthew Dobson
Add another allocator to the common mempool code: a kzalloc/kfree allocator This will be used by the next patch in the series to replace a mempool-backed kzalloc allocator. It is also very likely that there will be more users in the future. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: add kmalloc allocatorMatthew Dobson
Add another allocator to the common mempool code: a kmalloc/kfree allocator This will be used by the next patch in the series to replace duplicate mempool-backed kmalloc allocators in several places in the kernel. It is also very likely that there will be more users in the future. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] mempool: add page allocatorMatthew Dobson
This will be used by the next patch in the series to replace duplicate mempool-backed page allocators in 2 places in the kernel. It is also likely that there will be more users in the future. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] NUMA aware block device control structure allocationChristoph Lameter
Patch to allocate the control structures for for ide devices on the node of the device itself (for NUMA systems). The patch depends on the Slab API change patch by Manfred and me (in mm) and the pcidev_to_node patch that I posted today. Does some realignment too. Signed-off-by: Justin M. Forbes <jmforbes@linuxtx.org> Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Pravin Shelar <pravin@calsoftinc.com> Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
