On some architectures (for example, arm), we don't end up indirectly
pulling in the declaration of kzalloc() and kfree(), and so building
anything that includes <linux/mlx5/driver.h> breaks. Fix this by adding
an explicit include to get the declaration.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Commit c1be5232d21d ("Fix micro UAR allocator") broke binary compatibility
between libmlx5 and mlx5_ib since it defines a different value to the number
of micro UARs per page, leading to wrong calculation in libmlx5. This patch
defines struct mlx5_ib_alloc_ucontext_req_v2 as an extension to struct
mlx5_ib_alloc_ucontext_req. The extended size is determined in mlx5_ib_alloc_ucontext()
and in case of old library we use uuarn 0 which works fine -- this is
acheived due to create_user_qp() falling back from high to medium then to
low class where low class will return 0. For new libraries we use the
more sophisticated allocation algorithm.
Signed-off-by: Eli Cohen <eli@mellanox.com>
Reviewed-by: Yann Droneaud <ydroneaud@opteya.com>
Connect-IB firmware requires 4K pages to be communicated with the
driver. This patch breaks larger pages to 4K units to enable support
for architectures utilizing larger page size, such as PowerPC. This
patch also fixes several places that referred to PAGE_SHIFT instead of
explicit 12 which is the inherent page shift on Connect-IB.
Use asynchronous commands to execute up to eight concurrent create MR
commands. This is to fill memory caches faster so we keep consuming
from there. Also, increase timeout for shrinking caches to five
minutes.
It's helpful for a driver to put the pci slot name in its interrupt
names, so /proc/interrupts will show the pci slot of the device.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Checksum calculations consume CPU resources and can be significant to
the rate of resource creation/destruction.
In the previous QUERY_PAGES command version we used one command to get the
required amount of boot, init and post init pages. The new version uses the
op_mod field to specify whether the query is for the required amount of boot,
init or post init pages. In addition the output field size for the required
amount of pages increased from 16 to 32 bits.
In MANAGE_PAGES command the input_num_entries and output_num_entries fields
sizes changed from 16 to 32 bits and the PAS tables offset changed to 0x10.
In the pages request event the num_pages field also changed to 32 bits.
In the HCA-capabilities-layout the size and location of max_qp_mcg field has
been changed to support 24 bits.
This patch isn't compatible with firmware versions < 5; however, it turns out that the
first GA firmware we will publish will not support previous versions so this should be OK.
Signed-off-by: Moshe Lazer <moshel@mellanox.com>
Remove this code, per Dave Miller's request, since it is not being used
anywhere in the kernel.
Introduce enbale_hca and disable_hca commands to signify when the
driver starts or ceases to operate on the device.
In addition the driver will use boot and init pages count; boot pages
is required to allow firmware to complete boot commands and the other
to complete init hca. Command interface revision is bumped to 4 to
enforce using supported firmware.
This patch breaks compatibility with old versions of firmware (< 4);
however, the first GA firmware we will publish will support version 4
so this should not be a problem.
This deals with the sparse warning:
drivers/net/ethernet/mellanox/mlx5/core/health.c:94:54: warning: incorrect type in argument 2 (different address spaces)
drivers/net/ethernet/mellanox/mlx5/core/health.c:94:54: expected void *buf
drivers/net/ethernet/mellanox/mlx5/core/health.c:94:54: got struct health_buffer [noderef] <asn:2>*health
The driver is comprised of two kernel modules: mlx5_ib and mlx5_core.
This partitioning resembles what we have for mlx4, except that mlx5_ib
is the pci device driver and not mlx5_core.
mlx5_core is essentially a library that provides general functionality
that is intended to be used by other Mellanox devices that will be
introduced in the future. mlx5_ib has a similar role as any hardware
device under drivers/infiniband/hw.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[ Merge in coccinelle fixes from Fengguang Wu <fengguang.wu@intel.com>.
- Roland ]
