commit 2f064f3485cd29633ad1b3cfb00cc519509a3d72 upstream.
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
This patch removes mm->mmap_sem from mm->exe_file read side.
Also it kills dup_mm_exe_file() and moves exe_file duplication into
dup_mmap() where both mmap_sems are locked.
[akpm@linux-foundation.org: fix comment typo]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
CONFIG_PGTABLE_LEVELS is now available on every architecture and we can
use it to check if we need to add nr_pmds into mm_struct.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Richard Weinberger <richard@nod.at>
Dave noticed that unprivileged process can allocate significant amount of
memory -- >500 MiB on x86_64 -- and stay unnoticed by oom-killer and
memory cgroup. The trick is to allocate a lot of PMD page tables. Linux
kernel doesn't account PMD tables to the process, only PTE.
The use-cases below use few tricks to allocate a lot of PMD page tables
while keeping VmRSS and VmPTE low. oom_score for the process will be 0.
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/prctl.h>
#define PUD_SIZE (1UL << 30)
#define PMD_SIZE (1UL << 21)
#define NR_PUD 130000
int main(void)
char *addr = NULL;
unsigned long i;
prctl(PR_SET_THP_DISABLE);
for (i = 0; i < NR_PUD ; i++) {
addr = mmap(addr + PUD_SIZE, PUD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE, -1, 0);
if (addr == MAP_FAILED) {
perror("mmap");
break;
*addr = 'x';
munmap(addr, PMD_SIZE);
mmap(addr, PMD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE|MAP_FIXED, -1, 0);
perror("re-mmap"), exit(1);
printf("PID %d consumed %lu KiB in PMD page tables\n",
getpid(), i * 4096 >> 10);
return pause();
The patch addresses the issue by account PMD tables to the process the
same way we account PTE.
The main place where PMD tables is accounted is __pmd_alloc() and
free_pmd_range(). But there're few corner cases:
- HugeTLB can share PMD page tables. The patch handles by accounting
the table to all processes who share it.
- x86 PAE pre-allocates few PMD tables on fork.
- Architectures with FIRST_USER_ADDRESS > 0. We need to adjust sanity
check on exit(2).
Accounting only happens on configuration where PMD page table's level is
present (PMD is not folded). As with nr_ptes we use per-mm counter. The
counter value is used to calculate baseline for badness score by
oom-killer.
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Currently, we use lru.next/lru.prev plus cast to access or set
destructor and order of compound page.
Let's replace it with explicit fields in struct page.
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Acked-by: Christoph Lameter <cl@linux.com>
After removing vma->shared.nonlinear we have only one member of
vma->shared union, which doesn't make much sense.
This patch drops the union and move struct vma->shared.linear to
vma->shared.
We don't create non-linear mappings anymore. Let's drop code which
handles them in rmap.
Until now, debug-pagealloc needs extra flags in struct page, so we need to
recompile whole source code when we decide to use it. This is really
painful, because it takes some time to recompile and sometimes rebuild is
not possible due to third party module depending on struct page. So, we
can't use this good feature in many cases.
Now, we have the page extension feature that allows us to insert extra
flags to outside of struct page. This gets rid of third party module
issue mentioned above. And, this allows us to determine if we need extra
memory for this page extension in boottime. With these property, we can
avoid using debug-pagealloc in boottime with low computational overhead in
the kernel built with CONFIG_DEBUG_PAGEALLOC. This will help our
development process greatly.
This patch is the preparation step to achive above goal. debug-pagealloc
originally uses extra field of struct page, but, after this patch, it will
use field of struct page_ext. Because memory for page_ext is allocated
later than initialization of page allocator in CONFIG_SPARSEMEM, we should
disable debug-pagealloc feature temporarily until initialization of
page_ext. This patch implements this.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Dave Hansen <dave@sr71.net>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Jungsoo Son <jungsoo.son@lge.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
swp_entry_t being defined in include/linux/swap.h instead of
include/linux/mm_types.h causes cyclic include dependency later when
include/linux/page_cgroup.h is included from writeback path. Move the
definition to include/linux/mm_types.h.
While at it, reformat the comment above it.
Memory cgroups used to have 5 per-page pointers. To allow users to
disable that amount of overhead during runtime, those pointers were
allocated in a separate array, with a translation layer between them and
struct page.
There is now only one page pointer remaining: the memcg pointer, that
indicates which cgroup the page is associated with when charged. The
complexity of runtime allocation and the runtime translation overhead is
no longer justified to save that *potential* 0.19% of memory. With
CONFIG_SLUB, page->mem_cgroup actually sits in the doubleword padding
after the page->private member and doesn't even increase struct page,
and then this patch actually saves space. Remaining users that care can
still compile their kernels without CONFIG_MEMCG.
8828345 1725264 983040 11536649 b00909 vmlinux.old
8827425 1725264 966656 11519345 afc571 vmlinux.new
[mhocko@suse.cz: update Documentation/cgroups/memory.txt]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Vladimir Davydov <vdavydov@parallels.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: Tejun Heo <tj@kernel.org>
Acked-by: Konstantin Khlebnikov <koct9i@gmail.com>
This is really the meat of the MPX patch set. If there is one patch to
review in the entire series, this is the one. There is a new ABI here
and this kernel code also interacts with userspace memory in a
relatively unusual manner. (small FAQ below).
Long Description:
This patch adds two prctl() commands to provide enable or disable the
management of bounds tables in kernel, including on-demand kernel
allocation (See the patch "on-demand kernel allocation of bounds tables")
and cleanup (See the patch "cleanup unused bound tables"). Applications
do not strictly need the kernel to manage bounds tables and we expect
some applications to use MPX without taking advantage of this kernel
support. This means the kernel can not simply infer whether an application
needs bounds table management from the MPX registers. The prctl() is an
explicit signal from userspace.
PR_MPX_ENABLE_MANAGEMENT is meant to be a signal from userspace to
require kernel's help in managing bounds tables.
PR_MPX_DISABLE_MANAGEMENT is the opposite, meaning that userspace don't
want kernel's help any more. With PR_MPX_DISABLE_MANAGEMENT, the kernel
won't allocate and free bounds tables even if the CPU supports MPX.
PR_MPX_ENABLE_MANAGEMENT will fetch the base address of the bounds
directory out of a userspace register (bndcfgu) and then cache it into
a new field (->bd_addr) in the 'mm_struct'. PR_MPX_DISABLE_MANAGEMENT
will set "bd_addr" to an invalid address. Using this scheme, we can
use "bd_addr" to determine whether the management of bounds tables in
kernel is enabled.
Also, the only way to access that bndcfgu register is via an xsaves,
which can be expensive. Caching "bd_addr" like this also helps reduce
the cost of those xsaves when doing table cleanup at munmap() time.
Unfortunately, we can not apply this optimization to #BR fault time
because we need an xsave to get the value of BNDSTATUS.
==== Why does the hardware even have these Bounds Tables? ====
MPX only has 4 hardware registers for storing bounds information.
If MPX-enabled code needs more than these 4 registers, it needs to
spill them somewhere. It has two special instructions for this
which allow the bounds to be moved between the bounds registers
and some new "bounds tables".
They are similar conceptually to a page fault and will be raised by
the MPX hardware during both bounds violations or when the tables
are not present. This patch handles those #BR exceptions for
not-present tables by carving the space out of the normal processes
address space (essentially calling the new mmap() interface indroduced
earlier in this patch set.) and then pointing the bounds-directory
over to it.
The tables *need* to be accessed and controlled by userspace because
the instructions for moving bounds in and out of them are extremely
frequent. They potentially happen every time a register pointing to
memory is dereferenced. Any direct kernel involvement (like a syscall)
to access the tables would obviously destroy performance.
==== Why not do this in userspace? ====
This patch is obviously doing this allocation in the kernel.
However, MPX does not strictly *require* anything in the kernel.
It can theoretically be done completely from userspace. Here are
a few ways this *could* be done. I don't think any of them are
practical in the real-world, but here they are.
Q: Can virtual space simply be reserved for the bounds tables so
that we never have to allocate them?
A: As noted earlier, these tables are *HUGE*. An X-GB virtual
area needs 4*X GB of virtual space, plus 2GB for the bounds
directory. If we were to preallocate them for the 128TB of
user virtual address space, we would need to reserve 512TB+2GB,
which is larger than the entire virtual address space today.
This means they can not be reserved ahead of time. Also, a
single process's pre-popualated bounds directory consumes 2GB
of virtual *AND* physical memory. IOW, it's completely
infeasible to prepopulate bounds directories.
Q: Can we preallocate bounds table space at the same time memory
is allocated which might contain pointers that might eventually
need bounds tables?
A: This would work if we could hook the site of each and every
memory allocation syscall. This can be done for small,
constrained applications. But, it isn't practical at a larger
scale since a given app has no way of controlling how all the
parts of the app might allocate memory (think libraries). The
kernel is really the only place to intercept these calls.
Q: Could a bounds fault be handed to userspace and the tables
allocated there in a signal handler instead of in the kernel?
A: (thanks to tglx) mmap() is not on the list of safe async
handler functions and even if mmap() would work it still
requires locking or nasty tricks to keep track of the
allocation state there.
Having ruled out all of the userspace-only approaches for managing
bounds tables that we could think of, we create them on demand in
the kernel.
Based-on-patch-by: Qiaowei Ren <qiaowei.ren@intel.com>
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: linux-mm@kvack.org
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/20141114151829.AD4310DE@viggo.jf.intel.com
mm initialization on fork/exec is spread all over the place, which makes
the code look inconsistent.
We have mm_init(), which is supposed to init/nullify mm's internals, but
it doesn't init all the fields it should:
- on fork ->mmap,mm_rb,vmacache_seqnum,map_count,mm_cpumask,locked_vm
are zeroed in dup_mmap();
- on fork ->pmd_huge_pte is zeroed in dup_mm(), immediately before
calling mm_init();
- ->cpu_vm_mask_var ptr is initialized by mm_init_cpumask(), which is
called before mm_init() on both fork and exec;
- ->context is initialized by init_new_context(), which is called after
Let's consolidate all the initializations in mm_init() to make the code
look cleaner.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
We don't have any good way to figure out what kinds of flushes
are being attempted. Right now, we can try to use the vm
counters, but those only tell us what we actually did with the
hardware (one-by-one vs full) and don't tell us what was actually
_requested_.
This allows us to select out "interesting" TLB flushes that we
might want to optimize (like the ranged ones) and ignore the ones
that we have very little control over (the ones at context
switch).
Link: http://lkml.kernel.org/r/20140731154059.4C96CBA5@viggo.jf.intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86 cdso updates from Peter Anvin:
"Vdso cleanups and improvements largely from Andy Lutomirski. This
makes the vdso a lot less ''special''"
* 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso, build: Make LE access macros clearer, host-safe
x86/vdso, build: Fix cross-compilation from big-endian architectures
x86/vdso, build: When vdso2c fails, unlink the output
x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET
x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls
x86, mm: Improve _install_special_mapping and fix x86 vdso naming
mm, fs: Add vm_ops->name as an alternative to arch_vma_name
x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments
x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO
x86, vdso: Move the 32-bit vdso special pages after the text
x86, vdso: Reimplement vdso.so preparation in build-time C
x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c
x86, vdso: Clean up 32-bit vs 64-bit vdso params
x86, mm: Ensure correct alignment of the fixmap
CONFIG_MM_OWNER makes no sense. It is not user-selectable, it is only
selected by CONFIG_MEMCG automatically. So we can kill this option in
init/Kconfig and do s/CONFIG_MM_OWNER/CONFIG_MEMCG/ globally.
Using arch_vma_name to give special mappings a name is awkward. x86
currently implements it by comparing the start address of the vma to
the expected address of the vdso. This requires tracking the start
address of special mappings and is probably buggy if a special vma
is split or moved.
Improve _install_special_mapping to just name the vma directly. Use
it to give the x86 vvar area a name, which should make CRIU's life
easier.
As a side effect, the vvar area will show up in core dumps. This
could be considered weird and is fixable.
[hpa: I say we accept this as-is but be prepared to deal with knocking
out the vvars from core dumps if this becomes a problem.]
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/276b39b6b645fb11e345457b503f17b83c2c6fd0.1400538962.git.luto@amacapital.net
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull slab changes from Pekka Enberg:
"The biggest change is byte-sized freelist indices which reduces slab
freelist memory usage:
https://lkml.org/lkml/2013/12/2/64"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm: slab/slub: use page->list consistently instead of page->lru
mm/slab.c: cleanup outdated comments and unify variables naming
slab: fix wrongly used macro
slub: fix high order page allocation problem with __GFP_NOFAIL
slab: Make allocations with GFP_ZERO slightly more efficient
slab: make more slab management structure off the slab
slab: introduce byte sized index for the freelist of a slab
slab: restrict the number of objects in a slab
slab: introduce helper functions to get/set free object
slab: factor out calculate nr objects in cache_estimate
'struct page' has two list_head fields: 'lru' and 'list'. Conveniently,
they are unioned together. This means that code can use them
interchangably, which gets horribly confusing like with this nugget from
slab.c:
> list_del(&page->lru);
> if (page->active == cachep->num)
> list_add(&page->list, &n->slabs_full);
This patch makes the slab and slub code use page->lru universally instead
of mixing ->list and ->lru.
So, the new rule is: page->lru is what the you use if you want to keep
your page on a list. Don't like the fact that it's not called ->list?
Too bad.
Acked-by: David Rientjes <rientjes@google.com>
Cc: Pekka Enberg <penberg@kernel.org>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
In struct page we have enough space to fit long-size page->ptl there,
but we use dynamically-allocated page->ptl if size(spinlock_t) is larger
than sizeof(int).
It hurts 64-bit architectures with CONFIG_GENERIC_LOCKBREAK, where
sizeof(spinlock_t) == 8, but it easily fits into struct page.
table updates
According to documentation on barriers, stores issued before a LOCK can
complete after the lock implying that it's possible tlb_flush_pending
can be visible after a page table update. As per revised documentation,
this patch adds a smp_mb__before_spinlock to guarantee the correct
ordering.
Cc: <stable@vger.kernel.org>
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
Pull SLAB changes from Pekka Enberg:
"The patches from Joonsoo Kim switch mm/slab.c to use 'struct page' for
slab internals similar to mm/slub.c. This reduces memory usage and
improves performance:
https://lkml.org/lkml/2013/10/16/155
Rest of the changes are bug fixes from various people"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: (21 commits)
mm, slub: fix the typo in mm/slub.c
mm, slub: fix the typo in include/linux/slub_def.h
slub: Handle NULL parameter in kmem_cache_flags
slab: replace non-existing 'struct freelist *' with 'void *'
slab: fix to calm down kmemleak warning
slub: proper kmemleak tracking if CONFIG_SLUB_DEBUG disabled
slab: rename slab_bufctl to slab_freelist
slab: remove useless statement for checking pfmemalloc
slab: use struct page for slab management
slab: replace free and inuse in struct slab with newly introduced active
slab: remove SLAB_LIMIT
slab: remove kmem_bufctl_t
slab: change the management method of free objects of the slab
slab: use __GFP_COMP flag for allocating slab pages
slab: use well-defined macro, virt_to_slab()
slab: overloading the RCU head over the LRU for RCU free
slab: remove cachep in struct slab_rcu
slab: remove nodeid in struct slab
slab: remove colouroff in struct slab
slab: change return type of kmem_getpages() to struct page
I don't know what went wrong, mis-merge or something, but ->pmd_huge_pte
placed in wrong union within struct page.
In original patch[1] it's placed to union with ->lru and ->slab, but in
commit e009bb30c8df ("mm: implement split page table lock for PMD
level") it's in union with ->index and ->freelist.
That union seems also unused for pages with table tables and safe to
re-use, but it's not what I've tested.
Let's move it to original place. It fixes indentation at least. :)
[1] https://lkml.org/lkml/2013/10/7/288
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Use kernel/bounds.c to convert build-time spinlock_t size check into a
preprocessor symbol and apply that to properly separate the page::ptl
situation.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
If split page table lock is in use, we embed the lock into struct page
of table's page. We have to disable split lock, if spinlock_t is too
big be to be embedded, like when DEBUG_SPINLOCK or DEBUG_LOCK_ALLOC
enabled.
This patch add support for dynamic allocation of split page table lock
if we can't embed it to struct page.
page->ptl is unsigned long now and we use it as spinlock_t if
sizeof(spinlock_t) <= sizeof(long), otherwise it's pointer to spinlock_t.
The spinlock_t allocated in pgtable_page_ctor() for PTE table and in
pgtable_pmd_page_ctor() for PMD table. All other helpers converted to
support dynamically allocated page->ptl.
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
The basic idea is the same as with PTE level: the lock is embedded into
struct page of table's page.
We can't use mm->pmd_huge_pte to store pgtables for THP, since we don't
take mm->page_table_lock anymore. Let's reuse page->lru of table's page
for that.
pgtable_pmd_page_ctor() returns true, if initialization is successful
and false otherwise. Current implementation never fails, but assumption
that constructor can fail will help to port it to -rt where spinlock_t
is rather huge and cannot be embedded into struct page -- dynamic
allocation is required.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
With split page table lock for PMD level we can't hold mm->page_table_lock
while updating nr_ptes.
Let's convert it to atomic_long_t to avoid races.
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
We're going to introduce split page table lock for PMD level. Let's
rename existing split ptlock for PTE level to avoid confusion.
Now, there are a few field in struct slab, so we can overload these
over struct page. This will save some memory and reduce cache footprint.
After this change, slabp_cache and slab_size no longer related to
a struct slab, so rename them as freelist_cache and freelist_size.
These changes are just mechanical ones and there is no functional change.
Acked-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Pekka Enberg <penberg@iki.fi>
With build-time size checking, we can overload the RCU head over the LRU
of struct page to free pages of a slab in rcu context. This really help to
implement to overload the struct slab over the struct page and this
eventually reduce memory usage and cache footprint of the SLAB.
With scan rate adaptions based on whether the workload has properly
converged or not there should be no need for the scan period reset
hammer. Get rid of it.
Link: http://lkml.kernel.org/r/1381141781-10992-60-git-send-email-mgorman@suse.de
Change the per page last fault tracking to use cpu,pid instead of
nid,pid. This will allow us to try and lookup the alternate task more
easily. Note that even though it is the cpu that is store in the page
flags that the mpol_misplaced decision is still based on the node.
Link: http://lkml.kernel.org/r/1381141781-10992-43-git-send-email-mgorman@suse.de
[ Fixed build failure on 32-bit systems. ]
Ideally it would be possible to distinguish between NUMA hinting faults that
are private to a task and those that are shared. If treated identically
there is a risk that shared pages bounce between nodes depending on
the order they are referenced by tasks. Ultimately what is desirable is
that task private pages remain local to the task while shared pages are
interleaved between sharing tasks running on different nodes to give good
average performance. This is further complicated by THP as even
applications that partition their data may not be partitioning on a huge
page boundary.
To start with, this patch assumes that multi-threaded or multi-process
applications partition their data and that in general the private accesses
are more important for cpu->memory locality in the general case. Also,
no new infrastructure is required to treat private pages properly but
interleaving for shared pages requires additional infrastructure.
To detect private accesses the pid of the last accessing task is required
but the storage requirements are a high. This patch borrows heavily from
Ingo Molnar's patch "numa, mm, sched: Implement last-CPU+PID hash tracking"
to encode some bits from the last accessing task in the page flags as
well as the node information. Collisions will occur but it is better than
just depending on the node information. Node information is then used to
determine if a page needs to migrate. The PID information is used to detect
private/shared accesses. The preferred NUMA node is selected based on where
the maximum number of approximately private faults were measured. Shared
faults are not taken into consideration for a few reasons.
First, if there are many tasks sharing the page then they'll all move
towards the same node. The node will be compute overloaded and then
scheduled away later only to bounce back again. Alternatively the shared
tasks would just bounce around nodes because the fault information is
effectively noise. Either way accounting for shared faults the same as
private faults can result in lower performance overall.
The second reason is based on a hypothetical workload that has a small
number of very important, heavily accessed private pages but a large shared
array. The shared array would dominate the number of faults and be selected
as a preferred node even though it's the wrong decision.
The third reason is that multiple threads in a process will race each
other to fault the shared page making the fault information unreliable.
[ Fix complication error when !NUMA_BALANCING. ]
Link: http://lkml.kernel.org/r/1381141781-10992-30-git-send-email-mgorman@suse.de
new node"
PTE scanning and NUMA hinting fault handling is expensive so commit
5bca2303 ("mm: sched: numa: Delay PTE scanning until a task is scheduled
on a new node") deferred the PTE scan until a task had been scheduled on
another node. The problem is that in the purely shared memory case that
this may never happen and no NUMA hinting fault information will be
captured. We are not ruling out the possibility that something better
can be done here but for now, this patch needs to be reverted and depend
entirely on the scan_delay to avoid punishing short-lived processes.
Link: http://lkml.kernel.org/r/1381141781-10992-16-git-send-email-mgorman@suse.de
Pull aio changes from Ben LaHaise:
"First off, sorry for this pull request being late in the merge window.
Al had raised a couple of concerns about 2 items in the series below.
I addressed the first issue (the race introduced by Gu's use of
mm_populate()), but he has not provided any further details on how he
wants to rework the anon_inode.c changes (which were sent out months
ago but have yet to be commented on).
The bulk of the changes have been sitting in the -next tree for a few
months, with all the issues raised being addressed"
* git://git.kvack.org/~bcrl/aio-next: (22 commits)
aio: rcu_read_lock protection for new rcu_dereference calls
aio: fix race in ring buffer page lookup introduced by page migration support
aio: fix rcu sparse warnings introduced by ioctx table lookup patch
aio: remove unnecessary debugging from aio_free_ring()
aio: table lookup: verify ctx pointer
staging/lustre: kiocb->ki_left is removed
aio: fix error handling and rcu usage in "convert the ioctx list to table lookup v3"
aio: be defensive to ensure request batching is non-zero instead of BUG_ON()
aio: convert the ioctx list to table lookup v3
aio: double aio_max_nr in calculations
aio: Kill ki_dtor
aio: Kill ki_users
aio: Kill unneeded kiocb members
aio: Kill aio_rw_vect_retry()
aio: Don't use ctx->tail unnecessarily
aio: io_cancel() no longer returns the io_event
aio: percpu ioctx refcount
aio: percpu reqs_available
aio: reqs_active -> reqs_available
aio: fix build when migration is disabled
This is the updated version of df54d6fa5427 ("x86 get_unmapped_area():
use proper mmap base for bottom-up direction") that only randomizes the
mmap base address once.
Signed-off-by: Radu Caragea <sinaelgl@gmail.com>
Reported-and-tested-by: Jeff Shorey <shoreyjeff@gmail.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Adrian Sendroiu <molecula2788@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: Kamal Mostafa <kamal@canonical.com>
On Wed, Jun 12, 2013 at 11:14:40AM -0700, Kent Overstreet wrote:
> On Mon, Apr 15, 2013 at 02:40:55PM +0300, Octavian Purdila wrote:
> > When using a large number of threads performing AIO operations the
> > IOCTX list may get a significant number of entries which will cause
> > significant overhead. For example, when running this fio script:
> > rw=randrw; size=256k ;directory=/mnt/fio; ioengine=libaio; iodepth=1
> > blocksize=1024; numjobs=512; thread; loops=100
> > on an EXT2 filesystem mounted on top of a ramdisk we can observe up to
> > 30% CPU time spent by lookup_ioctx:
> > 32.51% [guest.kernel] [g] lookup_ioctx
> > 9.19% [guest.kernel] [g] __lock_acquire.isra.28
> > 4.40% [guest.kernel] [g] lock_release
> > 4.19% [guest.kernel] [g] sched_clock_local
> > 3.86% [guest.kernel] [g] local_clock
> > 3.68% [guest.kernel] [g] native_sched_clock
> > 3.08% [guest.kernel] [g] sched_clock_cpu
> > 2.64% [guest.kernel] [g] lock_release_holdtime.part.11
> > 2.60% [guest.kernel] [g] memcpy
> > 2.33% [guest.kernel] [g] lock_acquired
> > 2.25% [guest.kernel] [g] lock_acquire
> > 1.84% [guest.kernel] [g] do_io_submit
> > This patchs converts the ioctx list to a radix tree. For a performance
> > comparison the above FIO script was run on a 2 sockets 8 core
> > machine. This are the results (average and %rsd of 10 runs) for the
> > original list based implementation and for the radix tree based
> > implementation:
> > cores 1 2 4 8 16 32
> > list 109376 ms 69119 ms 35682 ms 22671 ms 19724 ms 16408 ms
> > %rsd 0.69% 1.15% 1.17% 1.21% 1.71% 1.43%
> > radix 73651 ms 41748 ms 23028 ms 16766 ms 15232 ms 13787 ms
> > %rsd 1.19% 0.98% 0.69% 1.13% 0.72% 0.75%
> > % of radix
> > relative 66.12% 65.59% 66.63% 72.31% 77.26% 83.66%
> > to list
> > To consider the impact of the patch on the typical case of having
> > only one ctx per process the following FIO script was run:
> > rw=randrw; size=100m ;directory=/mnt/fio; ioengine=libaio; iodepth=1
> > blocksize=1024; numjobs=1; thread; loops=100
> > on the same system and the results are the following:
> > list 58892 ms
> > %rsd 0.91%
> > radix 59404 ms
> > %rsd 0.81%
> > % of radix
> > relative 100.87%
> > to list
> So, I was just doing some benchmarking/profiling to get ready to send
> out the aio patches I've got for 3.11 - and it looks like your patch is
> causing a ~1.5% throughput regression in my testing :/
... <snip>
I've got an alternate approach for fixing this wart in lookup_ioctx()...
Instead of using an rbtree, just use the reserved id in the ring buffer
header to index an array pointing the ioctx. It's not finished yet, and
it needs to be tidied up, but is most of the way there.
-ben
"Thought is the essence of where you are now."
kmo> And, a rework of Ben's code, but this was entirely his idea
kmo> -Kent
bcrl> And fix the code to use the right mm_struct in kill_ioctx(), actually
free memory.
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Since all architectures have been converted to use vm_unmapped_area(),
there is no remaining use for the free_area_cache.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
page->_last_nid fits into page->flags on 64-bit. The unlikely 32-bit
NUMA configuration with NUMA Balancing will still need an extra page
field. As Peter notes "Completely dropping 32bit support for
CONFIG_NUMA_BALANCING would simplify things, but it would also remove
the warning if we grow enough 64bit only page-flags to push the last-cpu
out."
[mgorman@suse.de: minor modifications]
Cc: Simon Jeons <simon.jeons@gmail.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
This is a preparation patch for moving page->_last_nid into page->flags
that moves page flag layout information to a separate header. This
patch is necessary because otherwise there would be a circular
dependency between mm_types.h and mm.h.
s/me/be/ and clarify the comment a bit when we're changing it anyway.
Suggested-by: Simon Jeons <simon.jeons@gmail.com>
"This contains preparational work from Christoph Lameter and Glauber
Costa for SLAB memcg and cleanups and improvements from Ezequiel
Garcia and Joonsoo Kim.
Please note that the SLOB cleanup commit from Arnd Bergmann already
appears in your tree but I had also merged it myself which is why it
shows up in the shortlog."
* 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm/sl[aou]b: Common alignment code
slab: Use the new create_boot_cache function to simplify bootstrap
slub: Use statically allocated kmem_cache boot structure for bootstrap
mm, sl[au]b: create common functions for boot slab creation
slab: Simplify bootstrap
slub: Use correct cpu_slab on dead cpu
mm: fix slab.c kernel-doc warnings
mm/slob: use min_t() to compare ARCH_SLAB_MINALIGN
slab: Ignore internal flags in cache creation
mm/slob: Use free_page instead of put_page for page-size kmalloc allocations
mm/sl[aou]b: Move common kmem_cache_size() to slab.h
mm/slob: Use object_size field in kmem_cache_size()
mm/slob: Drop usage of page->private for storing page-sized allocations
slub: Commonize slab_cache field in struct page
sl[au]b: Process slabinfo_show in common code
mm/sl[au]b: Move print_slabinfo_header to slab_common.c
mm/sl[au]b: Move slabinfo processing to slab_common.c
slub: remove one code path and reduce lock contention in __slab_free()
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
The kernel walks the VMA rbtree in various places, including the page
fault path. However, the vm_rb node spanned two cache lines, on 64 bit
systems with 64 byte cache lines (most x86 systems).
Rearrange vm_area_struct a little, so all the information we need to do a
VMA tree walk is in the first cache line.
[akpm@linux-foundation.org: checkpatch fixes]
Cc: Chris Metcalf <cmetcalf@tilera.com>
Define vma->rb_subtree_gap as the largest gap between any vma in the
subtree rooted at that vma, and their predecessor. Or, for a recursive
definition, vma->rb_subtree_gap is the max of:
- vma->vm_start - vma->vm_prev->vm_end
- rb_subtree_gap fields of the vmas pointed by vma->rb.rb_left and
vma->rb.rb_right
This will allow get_unmapped_area_* to find a free area of the right
size in O(log(N)) time, instead of potentially having to do a linear
walk across all the VMAs.
Also define mm->highest_vm_end as the vm_end field of the highest vma,
so that we can easily check if the following gap is suitable.
This does have the potential to make unmapping VMAs more expensive,
especially for processes with very large numbers of VMAs, where the VMA
rbtree can grow quite deep.
Due to the fact that migrations are driven by the CPU a task is running
on there is no point tracking NUMA faults until one task runs on a new
node. This patch tracks the first node used by an address space. Until
it changes, PTE scanning is disabled and no NUMA hinting faults are
trapped. This should help workloads that are short-lived, do not care
about NUMA placement or have bound themselves to a single node.
This takes advantage of the logic in "mm: sched: numa: Implement slow
start for working set sampling" to delay when the checks are made. This
will take advantage of processes that set their CPU and node bindings
early in their lifetime. It will also potentially allow any initial load
balancing to take place.
The PTE scanning rate and fault rates are two of the biggest sources of
system CPU overhead with automatic NUMA placement. Ideally a proper policy
would detect if a workload was properly placed, schedule and adjust the
PTE scanning rate accordingly. We do not track the necessary information
to do that but we at least know if we migrated or not.
This patch scans slower if a page was not migrated as the result of a
NUMA hinting fault up to sysctl_numa_balancing_scan_period_max which is
now higher than the previous default. Once every minute it will reset
the scanner in case of phase changes.
This is hilariously crude and the numbers are arbitrary. Workloads will
converge quite slowly in comparison to what a proper policy should be able
to do. On the plus side, we will chew up less CPU for workloads that have
no need for automatic balancing.
This patch introduces a last_nid field to the page struct. This is used
to build a two-stage filter in the next patch that is aimed at
mitigating a problem whereby pages migrate to the wrong node when
referenced by a process that was running off its home node.
Previously, to probe the working set of a task, we'd use
a very simple and crude method: mark all of its address
space PROT_NONE.
That method has various (obvious) disadvantages:
- it samples the working set at dissimilar rates,
giving some tasks a sampling quality advantage
over others.
- creates performance problems for tasks with very
large working sets
- over-samples processes with large address spaces but
which only very rarely execute
Improve that method by keeping a rotating offset into the
address space that marks the current position of the scan,
and advance it by a constant rate (in a CPU cycles execution
proportional manner). If the offset reaches the last mapped
address of the mm then it then it starts over at the first
address.
The per-task nature of the working set sampling functionality in this tree
allows such constant rate, per task, execution-weight proportional sampling
of the working set, with an adaptive sampling interval/frequency that
goes from once per 100ms up to just once per 8 seconds. The current
sampling volume is 256 MB per interval.
As tasks mature and converge their working set, so does the
sampling rate slow down to just a trickle, 256 MB per 8
seconds of CPU time executed.
This, beyond being adaptive, also rate-limits rarely
executing systems and does not over-sample on overloaded
systems.
[ In AutoNUMA speak, this patch deals with the effective sampling
rate of the 'hinting page fault'. AutoNUMA's scanning is
currently rate-limited, but it is also fundamentally
single-threaded, executing in the knuma_scand kernel thread,
so the limit in AutoNUMA is global and does not scale up with
the number of CPUs, nor does it scan tasks in an execution
proportional manner.
So the idea of rate-limiting the scanning was first implemented
in the AutoNUMA tree via a global rate limit. This patch goes
beyond that by implementing an execution rate proportional
working set sampling rate that is not implemented via a single
global scanning daemon. ]
[ Dan Carpenter pointed out a possible NULL pointer dereference in the
first version of this patch. ]
Based-on-idea-by: Andrea Arcangeli <aarcange@redhat.com>
Bug-Found-By: Dan Carpenter <dan.carpenter@oracle.com>
[ Wrote changelog and fixed bug. ]
