path: root/include/linux/mnt_namespace.h
2012-01-03vfs: take /proc/*/mounts and friends to fs/proc_namespace.cAl Viro
rationale: that stuff is far tighter bound to fs/namespace.c than to the guts of procfs proper. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03unexport put_mnt_ns(), make create_mnt_ns() static outrightAl Viro
2011-07-20fs: seq_file - add event counter to simplify poll() supportKay Sievers
Moving the event counter into the dynamically allocated 'struc seq_file' allows poll() support without the need to allocate its own tracking structure. All current users are switched over to use the new counter. Requested-by: Andrew Morton akpm@linux-foundation.org Acked-by: NeilBrown <neilb@suse.de> Tested-by: Lucas De Marchi lucas.demarchi@profusion.mobi Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03take check for new events in namespace (guts of mounts_poll()) to namespace.cAl Viro
2009-12-17Revert "fix mismerge with Trond's stuff (create_mnt_ns() export is gone now)"Linus Torvalds
This reverts commit e9496ff46a20a8592fdc7bdaaf41b45eb808d310. Quoth Al: "it's dependent on a lot of other stuff not currently in mainline and badly broken with current fs/namespace.c. Sorry, badly out-of-order cherry-pick from old queue. PS: there's a large pending series reworking the refcounting and lifetime rules for vfsmounts that will, among other things, allow to rip a subtree away _without_ dissolving connections in it, to be garbage-collected when all active references are gone. It's considerably saner wrt "is the subtree busy" logics, but it's nowhere near being ready for merge at the moment; this changeset is one of the things becoming possible with that sucker, but it certainly shouldn't have been picked during this cycle. My apologies..." Noticed-by: Eric Paris <eparis@redhat.com> Requested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fix mismerge with Trond's stuff (create_mnt_ns() export is gone now)Al Viro
2009-07-08headers: mnt_namespace.h reduxAlexey Dobriyan
Fix various silly problems wrt mnt_namespace.h: - exit_mnt_ns() isn't used, remove it - done that, sched.h and nsproxy.h inclusions aren't needed - mount.h inclusion was need for vfsmount_lock, but no longer - remove mnt_namespace.h inclusion from files which don't use anything from mnt_namespace.h Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22VFS: Add VFS helper functions for setting up private namespacesTrond Myklebust
The purpose of this patch is to improve the remote mount path lookup support for distributed filesystems such as the NFSv4 client. When given a mount command of the form "mount server:/foo/bar /mnt", the NFSv4 client is required to look up the filehandle for "server:/", and then look up each component of the remote mount path "foo/bar" in order to find the directory that is actually going to be mounted on /mnt. Following that remote mount path may involve following symlinks, crossing server-side mount points and even following referrals to filesystem volumes on other servers. Since the standard VFS path lookup code already supports walking paths that contain all these features (using in-kernel automounts for following referrals) we would like to be able to reuse that rather than duplicate the full path traversal functionality in the NFSv4 client code. This patch therefore defines a VFS helper function create_mnt_ns(), that sets up a temporary filesystem namespace and attaches a root filesystem to it. It exports the create_mnt_ns() and put_mnt_ns() function for use by filesystem modules. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22VFS: Uninline the function put_mnt_ns()Trond Myklebust
In order to allow modules to use it without having to export vfsmount_lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 6/7] vfs: mountinfo: add /proc/<pid>/mountinfoRam Pai
[mszeredi@suse.cz] rewrite and split big patch into managable chunks /proc/mounts in its current form lacks important information: - propagation state - root of mount for bind mounts - the st_dev value used within the filesystem - identifier for each mount and it's parent It also suffers from the following problems: - not easily extendable - ambiguity of mountpoints within a chrooted environment - doesn't distinguish between filesystem dependent and independent options - doesn't distinguish between per mount and per super block options This patch introduces /proc/<pid>/mountinfo which attempts to address all these deficiencies. Code shared between /proc/<pid>/mounts and /proc/<pid>/mountinfo is extracted into separate functions. Thanks to Al Viro for the help in getting the design right. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 5/7] vfs: mountinfo: allow using process rootMiklos Szeredi
Allow /proc/<pid>/mountinfo to use the root of <pid> to calculate mountpoints. - move definition of 'struct proc_mounts' to <linux/mnt_namespace.h> - add the process's namespace and root to this structure - pass a pointer to 'struct proc_mounts' into seq_operations In addition the following cleanups are made: - use a common open function for /proc/<pid>/{mounts,mountstat} - surround namespace.c part of these proc files with #ifdef CONFIG_PROC_FS - make the seq_operations structures const Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-07-16namespace: ensure clone_flags are always stored in an unsigned longEric W. Biederman
While working on unshare support for the network namespace I noticed we were putting clone flags in an int. Which is weird because the syscall uses unsigned long and we at least need an unsigned to properly hold all of the unshare flags. So to make the code consistent, this patch updates the code to use unsigned long instead of int for the clone flags in those places where we get it wrong today. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] rename struct namespace to struct mnt_namespaceKirill Korotaev
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with other namespaces being developped for the containers : pid, uts, ipc, etc. 'namespace' variables and attributes are also renamed to 'mnt_ns' Signed-off-by: Kirill Korotaev <dev@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
