path: root/include/linux/msdos_fs.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-05-31fat: introduce special inode for managing the FSINFO blockArtem Bityutskiy
This is patchset makes fatfs stop using the VFS '->write_super()' method for writing out the FSINFO block. The final goal is to get rid of the 'sync_supers()' kernel thread. This kernel thread wakes up every 5 seconds (by default) and calls '->write_super()' for all mounted file-systems. And the bad thing is that this is done even if all the superblocks are clean. Moreover, some file-systems do not even need this end they do not register the '->write_super()' method at all (e.g., btrfs). So 'sync_supers()' most often just generates useless wake-ups and wastes power. I am trying to make all file-systems independent of '->write_super()' and plan to remove 'sync_supers()' and '->write_super' completely once there are no more users. The '->write_supers()' method is mostly used by baroque file-systems like hfs, udf, etc. Modern file-systems like btrfs and xfs do not use it. This justifies removing this stuff from VFS completely and make every FS self-manage own superblock. Tested with xfstests. This patch: Preparation for further changes. It introduces a special inode ('fsinfo_inode') in FAT file-system which we'll later use for managing the FSINFO block. Note, this there is already one special inode ('fat_inode') which is used for managing the FAT tables. Introduce new 'MSDOS_FSINFO_INO' constant for this special inode. It is safe to do because FAT file-system does not store inode numbers on the media but generates them run-time. I've also cleaned up the comment to existing 'MSDOS_ROOT_INO' constant, while on it. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-10fat: Fix stat->f_namelenKevin Dankwardt
I found that the length of a file name when created cannot exceed 255 characters, yet, pathconf(), via statfs(), returns the maximum as 260. Signed-off-by: Kevin Dankwardt <k@kcomputing.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-01-31headers_check fix: linux/msdos_fs.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/msdos_fs.h:100: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-11-06fat: Cleanup FAT attribute stuffOGAWA Hirofumi
This adds three helpers: fat_make_attrs() - makes FAT attributes from inode. fat_make_mode() - makes mode_t from FAT attributes. fat_save_attrs() - saves FAT attributes to inode. Then this replaces: MSDOS_MKMODE() by fat_make_mode(), fat_attr() by fat_make_attrs(), ->i_attrs = attr & ATTR_UNUSED by fat_save_attrs(). And for root inode, those is used with ATTR_DIR instead of bogus ATTR_NONE. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: split include/msdos_fs.hOGAWA Hirofumi
This splits __KERNEL__ stuff in include/msdos_fs.h into fs/fat/fat.h. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fatfs: add UTC timestamp optionJoe Peterson
Provide a new mount option ("tz=UTC") for DOS (vfat/msdos) filesystems, allowing timestamps to be in coordinated universal time (UTC) rather than local time in applications where doing this is advantageous. In particular, portable devices that use fat/vfat (such as digital cameras) can benefit from using UTC in their internal clocks, thus avoiding daylight saving time errors and general time ambiguity issues. The user of the device does not have to worry about changing the time when moving from place or when daylight saving changes. The new mount option, when set, disables the counter-adjustment that Linux currently makes to FAT timestamp info in anticipation of the normal userspace time zone correction. When used in this new mode, all daylight saving time and time zone handling is done in userspace as is normal for many other filesystems (like ext3). The default mode, which remains unchanged, is still appropriate when mounting volumes written in Windows (because of its use of local time). I originally based this patch on one submitted last year by Paul Collins, but I updated it to work with current source and changed variable/option naming. Ogawa Hirofumi (who maintains these filesystems) and I discussed this patch at length on lkml, and he suggested using the option name in the attached version of the patch. Barry Bouwsma pointed out a good addition to the patch as well. Signed-off-by: Joe Peterson <joe@skyrush.com> Signed-off-by: Paul Collins <paul@ondioline.org> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Barry Bouwsma <free_beer_for_all@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25msdos fs: remove unsettable atari optionRene Scharfe
It has been impossible to set the option 'atari' of the MSDOS filesystem for several years. Since nobody seems to have missed it, let's remove its remains. Signed-off-by: Rene Scharfe <rene.scharfe@lsrfire.ath.cx> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fat: fix VFAT_IOCTL_READDIR_xxx and cleanup for userlandOGAWA Hirofumi
"struct dirent" is a kernel type here, but is a **different type** in userspace! This means both the structure and the IOCTL number is wrong! So, this adds new "struct __fat_dirent" to generate correct IOCTL number. And kernel stuff moves to under __KERNEL__. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-08fat_valid_media() isn't for userspaceAdrian Bunk
Commit 73f20e58b1d586e9f6d3ddc3aad872829aca7743 ("FAT_VALID_MEDIA(): remove pointless test") wrongly added the new fat_valid_media() function to the userspace-visible part of include/linux/msdos_fs.h Move it to the part of include/linux/msdos_fs.h that is not exported to userspace. Reported-by: Onur Küçük <onur@pardus.org.tr> Reported-by: S.Çağlar Onur <caglar@pardus.org.tr> Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28FAT_VALID_MEDIA(): remove pointless testAndrew Morton
The on-disk media specification field in FAT is only 8-bits, so testing for <=0xff is pointless, and can generate a "comparison is always true due to limited range of data type" warning. While we're there, convert FAT_VALID_MEDIA() into a C function - the present implementation is buggy: it generates either one or two references to its argument. Cc: Frank Seidel <fseidel@suse.de> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: Update free_clusters even if it is untrustedOGAWA Hirofumi
Currently, free_clusters is not updated until it is trusted, because Windows doesn't update it correctly. But if user is using FAT driver of Linux, it updates free_clusters correctly. Instead, this updates it even if it's untrusted, so if free_clustes is correct, now keep correct value. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: Add allow_utime optionOGAWA Hirofumi
Normally utime(2) checks current process is owner of the file, or it has CAP_FOWNER capability. But FAT filesystem doesn't have uid/gid as on disk info, so normal check is too unflexible. With this option you can relax it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fat: fat_notify_change() and check_mode() cleanupOGAWA Hirofumi
- Rename fat_notify_change() to fat_setattr() - check_mode() cleanup - Change layout of code Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fat: gcc 4.3 warning fixOGAWA Hirofumi
This patch fixes the following warnings. fs/fat/dir.c: In function 'fat_parse_long': include/linux/msdos_fs.h:294: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds The ->name is defined as "name[8], ext[3]", but fat_checksum() uses those as name[11]. There is no actual problem, but it's not a good manner. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fat: don't use free_clusters for fat32OGAWA Hirofumi
It seems that the recent Windows changed specification, and it's undocumented. Windows doesn't update ->free_clusters correctly. This patch doesn't use ->free_clusters by default. (instead, add "usefree" for forcing to use it) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Juergen Beisert <juergen127@kreuzholzen.de> Cc: Andreas Schwab <schwab@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-11-16[PATCH] fat: add fat_getattr()OGAWA Hirofumi
This adds fat_getattr() for setting stat->blksize. (FAT uses the size of cluster for proper I/O) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] add -o flush for fatChris Mason
Fat is commonly used on removable media. Mounting with -o flush tells the FS to write things to disk as quickly as possible. It is like -o sync, but much faster (and not as safe). Signed-off-by: Chris Mason <mason@suse.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] fs/fat/: proper prototypes for two functionsAdrian Bunk
Add proper prototypes for fat_cache_init() and fat_cache_destroy() in msdos_fs.h. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] fat_lock is used as a mutex, convert it to using the new mutex primitiveArjan van de Ven
The fat code uses the fat_lock always in a mutex way (taking and releasing the lock in the same function), the patch below converts it into the new mutex primitive. Please consider this patch for the code. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22It's UTF-8Alexey Dobriyan
Fix some comments to "UTF-8". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-08[PATCH] fat: support ->direct_IO()OGAWA Hirofumi
This patch add to support of ->direct_IO() for mostly read. The user of this seems to want to use for streaming read. So, current direct I/O has limitation, it can only overwrite. (For write operation, mainly we need to handle the hole etc..) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fat: cleanup and optimization of checksumOGAWA Hirofumi
