path: root/include/linux/mtd/nand.h
2005-11-07[MTD] includes: Clean up trailing white spacesThomas Gleixner
2005-11-06[MTD] NAND: Add suspend/resume functionalityVitaly Wool
The changes introduced allow to suspend/resume NAND flash. A new state (FL_PM_SUSPENDED) is introduced, as well as routines for mtd->suspend and mtd->resume to put the flash in suspended state from software pov. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-06-29[MTD] NAND: Reorganize chip lockingThomas Gleixner
The code was wrong in several aspects. The locking order was inconsistent, the device aquire code did not reset a variable after a wakeup and the wakeup handling was not working for applications where multiple chips are sharing a single hardware controller. When a hardware controller is available the locking is now reduced to the hardware controller lock and the waitqueue is moved to the hardware controller structure in order to avoid a wake_up_all(). The problem was pointed out by Ben Dooks, who also found the missing variable reset as main cause for his deadlock problem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-27[MTD] NAND: Add Hynix to manufacturer listNicolas S. Dade
Signed-off-by: Nicolas S. Dade <daden@symbol.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[MTD] NAND: Skip bad block table scan on requestThomas Gleixner
2005-05-23[MTD] NAND Add optional ECC status check callbackDavid A. Marlin
Add optional hardware specific callback routine to perform extra error status checks on erase and write failures for devices with hardware ECC. Signed-off-by: David A. Marlin <dmarlin@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[MTD] NAND extended commands, badb block table autorefresh David A. Marlin
Added extended commands for AG-AND device and added option for BBT_AUTO_REFRESH. Signed-off-by: David A. Marlin <dmarlin@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
