This is the same driver submitted by ST Micros SPEAr team but
generalized and tested on the ST-Ericsson U300. It probably
easily works on the NHK8815 too.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
This patch adds support for reading NAND device ONFI parameters and use
the ONFI informations to define its geometry. In case the device supports
ONFI, the onfi_version field in struct nand_chip contains the version (BCD)
and the onfi_params structure can be used by drivers to set up timings and
such. We currently only support ONFI 1.0 parameters.
Signed-off-by: Brian Norris <norris@broadcom.com>
Signed-off-by: Matthieu Castet <matthieu.castet@parrot.com>
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
This command is used to read the device ONFI parameters page.
An increase in NAND_MAX_OOBSIZE and NAND_MAX_PAGESIZE is necessary
in order to support many new chips. Among those:
Toshiba TC58TxG4S2FBAxx 8KB page, 576B OOB
Micron MT29F64G08CBAAA 8KB page, 448B OOB
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
There were some improvements and additions necessary in the
comments explaining of the expansion of nand_ecclayout, the
introduction of nand_ecclayout_user, and the deprecation of the
ioctl ECCGETLAYOUT.
Also, I found a better placement for the macro MTD_MAX_ECCPOS_ENTRIES;
next to the definition of MTD_MAX_OOBFREE_ENTRIES in mtd-abi.h. The macro
is really only important for the ioctl code (found in drivers/mtd/mtdchar.c)
but since there are small edits being made to the user-space header, I
figured this is a better location.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
struct nand_ecclayout is too small for many new chips; OOB regions can be as
large as 448 bytes and may increase more in the future. Thus, copying that
struct to user-space with the ECCGETLAYOUT ioctl is not a good idea; the ioctl
would have to be updated every time there's a change to the current largest
size.
Instead, the old nand_ecclayout is renamed to nand_ecclayout_user and a
new struct nand_ecclayout is created that can accomodate larger sizes and
expand without affecting the user-space. struct nand_ecclayout can still
be used in board drivers without modification -- at least for now.
A new function is provided to convert from the new to the old in order to
allow the deprecated ioctl to continue to work with truncated data. Perhaps
the ioctl, the conversion process, and the struct nand_ecclayout_user can be
removed altogether in the future.
Note: There are comments in nand/davinci_nand.c::nand_davinci_probe()
regarding this issue; this driver (and maybe others) can be updated to
account for extra space. All kernel drivers can use the expanded
nand_ecclayout as a drop-in replacement and ignore its benefits.
Replaced some spaces with tabs to fit CodingStyle guidelines
There are three reasons to add this support:
1. users probably know the interface type of their flashs, then probe
can be faster if they give the right type in platform data since wrong
types will not be detected.
2. sometimes, detecting can cause destory to system. For example, for
kernel XIP, detecting can cause NOR enter a mode instructions can not
be fetched right, which will make kernel crash.
3. For a new probe which is not listed in the rom_probe_types, if users
assign it in board files, physmap can still probe it.
Signed-off-by: Barry Song <21cnbao@gmail.com>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
This patch prevent to schedule while atomic by changing the
flchip_shared spinlock into a mutex. This should be save since no atomic
path will use this lock.
It was suggested by Arnd Bergmann and Vasiliy Kulikov.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Samsung SoCs use the own OneNAND controler and detect OneNAND chip at power on.
To use this feature, introduce the chip_probe function.
Also remove workaround for Samsung SoCs.
This is a revision to PATCH 2/2 that I sent. Link:
http://lists.infradead.org/pipermail/linux-mtd/2010-July/030911.html
Added new flag for scanning of both bytes 1 and 6 of the OOB for
a BB marker (instead of simply one or the other).
The "check_pattern" and "check_short_pattern" functions were updated
to include support for scanning the two different locations in the OOB.
In order to handle increases in variety of necessary scanning patterns,
I implemented dynamic memory allocation of nand_bbt_descr structs
in new function 'nand_create_default_bbt_descr()'. This replaces
some increasingly-unwieldy, statically-declared descriptors. It can
replace several more (e.g. "flashbased" structs). However, I do not
test the flashbased options personally.
How this was tested:
I referenced 30+ data sheets (covering 100+ parts), and I tested a
selection of 10 different chips to varying degrees. Particularly, I
tested the creation of bad-block descriptors and basic BB scanning on
three parts:
ST NAND04GW3B2D, 2K page
ST NAND128W3A, 512B page
Samsung K9F1G08U0A, 2K page
To test these, I wrote some fake bad block markers to the flash (in OOB
bytes 1, 6, and elsewhere) to see if the scanning routine would detect
them properly. However, this method was somewhat limited because the
driver I am using has some bugs in its OOB write functionality.
NAND_BB_LAST_PAGE used to be in nand.h, but it pertained to bad block
management and so belongs next to NAND_BBT_SCAN2NDPAGE in bbm.h. Also,
its previous flag value (0x00000400) conflicted with NAND_BBT_SCANALLPAGES
so I changed its value to 0x00008000. All uses of the name were modified to
provide consistency with other "NAND_BBT_*" flags.
This patchs adds a way for user space programs to find out whether a
flash sector is locked. An optional driver method in the mtd_info struct
provides the information.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
This is a slightly modified version of a patch submitted last year by
Reuben Dowle <reuben.dowle@navico.com>. His original comments follow:
This patch adds support for some MLC NAND flashes that place the BB
marker in the LAST page of the bad block rather than the FIRST page used
for SLC NAND and other types of MLC nand.
Lifted from Samsung datasheet for K9LG8G08U0A (1Gbyte MLC NAND):
Identifying Initial Invalid Block(s)
All device locations are erased(FFh) except locations where the initial
invalid block(s) information is written prior to shipping. The initial
invalid block(s) status is defined by the 1st byte in the spare area.
Samsung makes sure that the last page of every initial invalid block has
non-FFh data at the column address of 2,048.
As far as I can tell, this is the same for all Samsung MLC nand, and in
fact the samsung bsp for the processor used in our project (s3c6410)
actually contained a hack similar to this patch but less portable to
enable use of their NAND parts. I discovered this problem when trying to
use a Micron NAND which does not used this layout - I wish samsung would
put their stuff in main-line to avoid this type of problem.
Currently this patch causes all MLC nand with manufacturer codes from
Samsung and ST(Numonyx) to use this alternative location, since these
are the manufactures that I know of that use this layout.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Some of the newer MLC devices have a 6-byte ID sequence in which
several field definitions differ from older chips in a manner that is
not backward compatible. For instance:
Samsung K9GAG08U0M (5-byte sequence): ec d5 14 b6 74
4th byte, bits 1:0 encode the page size: 0=1KiB, 1=2KiB, 2=4KiB, 3=8KiB
4th byte, bits 5:4 encode the block size: 0=64KiB, 1=128KiB, ...
4th byte, bit 6 encodes the OOB size: 0=8B/512B, 1=16B/512B
Samsung K9GAG08U0D (6-byte sequence): ec d5 94 29 34 41
4th byte, bits 1:0 encode the page size: 0=2KiB, 1=4KiB, 3=8KiB, 4=rsvd
4th byte, bits 7;5:4 encode the block size: 0=128KiB, 1=256KiB, ...
4th byte, bits 6;3:2 encode the OOB size: 1=128B/page, 2=218B/page
This patch uses the new 6-byte scheme if the following conditions are
all true:
1) The ID code wraps around after exactly 6 bytes
2) Manufacturer is Samsung
3) 6th byte is zero
The patch also extends the maximum OOB size from 128B to 256B.
With gcc 4.4.3 -O2 on MIPS32:
drivers/mtd/chips/cfi_util.c: In function 'cfi_qry_present':
include/linux/mtd/map.h:390: warning: 'r' may be used uninitialized in this function
include/linux/mtd/map.h:375: note: 'r' was declared here
This patch adds a new callback for the underlying drivers, which is
called instead of accessing the buffer ram directly. This callback will
be used by Samsung OneNAND driver to implement DMA transfers on S5PC110
SoC.
This patch extends OneNAND core code with support for OneNAND verify
write check. This is done by allocating the buffer for verify read
directly from the core code.
This patch adds support for OneNAND chips that have 4KiB page size.
Factor out old manufacturers and use the generic ones from cfi.h
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
SST 39VF160x and 39VF320x chips use vendorname id 0x0701 and alternative
unlock addresses. Add support for them in cfi_probe.c.
Signed-off-by: Guillaume LECERF <glecerf@gmail.com>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
This patch fixes a build failure[1] by simply moving the function mtd_to_flctl
beneath the definition of sh_flctl which it uses.
BF introduced by patch
'mtd/nand/sh_flctl: Replace the dangerous mtd_to_flctl macro' (67026418)
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
The use of a memcpy() during a spinlock operation will cause very long
thread context switch delays if the flash chip bandwidth is low and the
data to be copied large, because a spinlock will disable preemption.
For example: A flash with 6,5 MB/s bandwidth will cause under ubifs,
which request sometimes 128 KiB (the flash erase size), a preemption delay of
20 milliseconds. High priority threads will not be served during this
time, regardless whether this threads access the flash or not. This behavior
breaks real time.
The patch changes all the use of spin_lock operations for xxxx->mutex
into mutex operations, which is exact what the name says and means.
I have checked the code of the drivers and there is no use of atomic
pathes like interrupt or timers. The mtdoops facility will also not be used
by this drivers. So it is dave to replace the spin_lock against mutex.
There is no performance regression since the mutex is normally not
acquired.
Changelog:
06.03.2010 First release
26.03.2010 Fix mutex[1] issue and tested it for compile failure
The original macro worked only when applied to variables named 'mtd'.
While this could have been fixed by simply renaming the macro argument,
a more type-safe replacement is preferred.
Signed-off-by: Ferenc Wagner <wferi@niif.hu>
include/linux/mtd/mtdram.h:6: ERROR: code indent should use tabs where possible
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/mtd/nand/sh_flctl.c
Maxim's patch to initialise sysfs attributes depends on the patch which
actually adds sysfs_attr_init().
The SmartMedia FTL code depends on new kfifo bits from 2.6.33
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
This can be used to protect against bitflips in that field, but now mostly
for smartmedia.
This changes the behavier of MTD_OOB_RAW. It used to read both OOB and
data to the data buffer, however you would still need to specify the
dummy oob buffer.
This is only used in one place, but makes it hard to read data+oob
without ECC test, thus I removed that behavier, and fixed the user.
Now MTD_OOB_RAW behaves just like MTD_OOB_PLACE, but doesn't do ECC
validation
This patch adds an ability to export sysfs attributes below
the block disk device.
This can be used to pass the udev an information about the FTL
and could include the vendor, serial, version, etc...
* Add locking where it was missing.
* Don't do a get_mtd_device in blktrans_open because it would lead to a
deadlock; instead do that in add_mtd_blktrans_dev.
* Only free the mtd_blktrans_dev structure when the last user exits.
* Flush request queue on device removal.
* Track users, and call tr->release in del_mtd_blktrans_dev
Due to that ->open and release aren't called more that once.
Now it is safe to call del_mtd_blktrans_dev while the device is still in use.
This is the biggest change. To make hotplug possible, and this layer
clean, the mtd_blktrans_dev now contains everything for a single mtd
block translation device. Also removed some very old leftovers.
Use these only if you know that you already hold mtd_table_mutex
Move MANUFACTURER_MACRONIX and MANUFACTURER_SST definitions to the
include/linux/mtd/cfi.h header file and rename them to CFI_MFR_MACRONIX and
CFI_MFR_SST.
All references in drivers/mtd/chips/cfi_cmdset_0002.c are updated to reflect
this.
Add nand lock / unlock routines. At least 'micron' parts
support this.
Signed-off-by: Vimal Singh <vimalsingh@ti.com>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
In the inline function cfi_build_cmd_addr, the cast of cmd_ofs to an
uint8_t produces a sparse warning of the type:
warning: cast truncates bits from constant value (2aa becomes aa)
Quiet the warning by masking cmd_ofs with 0xff and remove the cast.
This patch extends the sh_flctl driver with support
for 16-bit bus configuration using SEL_16BIT and
support for multiplexed pins using SHBUSSEL.
Signed-off-by: Magnus Damm <damm@opensource.se>
Acked-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
This patch contains a few changes for the sh_flctl driver:
- not sh7723-only driver - get rid of kconfig dependency
- use dev_err() instead of printk()
- use __devinit and __devexit for probe()/remove()
- fix probe() return values
(Commit 7cb777a3d71f9d1f7eb149c7a504d21f24219ae8 (mtd: add ARM pismo support)
intended to add this, but seems only to have patched the Makefile without
touching Kconfig or providing any code...)
The following patch adds support for PISMO modules found on ARM Ltd
development platforms. These are MTD modules, and can have a
selection of SRAM, flash or DOC devices as described by an on-board
I2C EEPROM.
We support SRAM and NOR flash devices only by registering appropriate
conventional MTD platform devices as children of the 'pismo' device.
* git://git.infradead.org/mtd-2.6: (90 commits)
jffs2: Fix long-standing bug with symlink garbage collection.
mtd: OneNAND: Fix test of unsigned in onenand_otp_walk()
mtd: cfi_cmdset_0002, fix lock imbalance
Revert "mtd: move mxcnd_remove to .exit.text"
mtd: m25p80: add support for Macronix MX25L4005A
kmsg_dump: fix build for CONFIG_PRINTK=n
mtd: nandsim: add support for 4KiB pages
mtd: mtdoops: refactor as a kmsg_dumper
mtd: mtdoops: make record size configurable
mtd: mtdoops: limit the maximum mtd partition size
mtd: mtdoops: keep track of used/unused pages in an array
mtd: mtdoops: several minor cleanups
core: Add kernel message dumper to call on oopses and panics
mtd: pxa3xx_nand: Fix PIO data transfer
mtd: nand: fix multi-chip suspend problem
mtd: add support for switching old SST chips into QRY mode
mtd: fix M29W800D dev_id and uaddr
mtd: don't use PF_MEMALLOC
mtd: Add bad block table overrides to Davinci NAND driver
Fixed up conflicts (mostly trivial) in
drivers/mtd/devices/m25p80.c
drivers/mtd/maps/pcmciamtd.c
drivers/mtd/nand/pxa3xx_nand.c
kernel/printk.c
This patch moves the MANUFACTURER_ST and MANUFACTURER_INTEL to the
include/linux/mtd/cfi.h header file and renames them to CFI_MFR_ST and
CFI_MFR_INTEL. CFI_MFR_ST was already present there.
All references in drivers/mtd/chips/cfi_cmdset_0001.c are updated to reflect
this.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Add NAND_SCAN_SILENT_NODEV to chip->options to the user-worrying messages
'No NAND device found!!!'. This message often worries users (was three
exclamation marks really necessary?) and especially in systems such as the
Simtec Osiris where there may be optional NAND devices which are not
known until probe time.
Revised version of the original NAND_PROBE_SPECULATIVE patch after comments
by Artem Bityutskiy about adding a whole new call.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
Signed-off-by: Simtec Linux Team <linux@simtec.co.uk>
Add support for multiblock erase command. OneNANDs (excluding Flex-OneNAND)
are capable of simultaneous erase of up to 64 eraseblocks which is much faster.
This changes the erase requests for regions covering multiple eraseblocks
to be performed using multiblock erase.
Signed-off-by: Mika Korhonen <ext-mika.2.korhonen@nokia.com>
Reviewed-by: Adrian Hunter <adrian.hunter@nokia.com>
Add __nand_calculate_ecc() which does not take struct mtd_info.
The built-in 256/512 software ECC calculation and correction tester
will use it.
Acked-by: Vimal Singh <vimalsingh@ti.com>
