path: root/include/linux/mv643xx_eth.h
2010-06-30mv643xx_eth: use sw csum for big packetsSaeed Bishara
Some controllers (KW, Dove) limits the TX IP/layer4 checksum offloading to a max size. Signed-off-by: Saeed Bishara <saeed@marvell.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-05mv643xx_eth: remove force_phy_addr fieldLennert Buytenhek
Currently, there are two different fields in the mv643xx_eth_platform_data struct that together describe the PHY address -- one field (phy_addr) has the address of the PHY, but if that address is zero, a second field (force_phy_addr) needs to be set to distinguish the actual address zero from a zero due to not having filled in the PHY address explicitly (which should mean 'use the default PHY address'). If we are a bit smarter about the encoding of the phy_addr field, we can avoid the need for a second field -- this patch does that. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-09-05mv643xx_eth: smi sharing is a per-unit property, not a per-port oneLennert Buytenhek
Which top-level unit's SMI interface to use should be a property of the top-level unit, not of the individual ports. This patch moves the ->shared_smi pointer from the per-port platform data to the global platform data. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-09-05mv643xx_eth: require contiguous receive and transmit queue numberingLennert Buytenhek
Simplify receive and transmit queue handling by requiring the set of queue numbers to be contiguous starting from zero. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
2008-06-12mv643xx_eth: allow multiple TX queuesLennert Buytenhek
As with the multiple RX queue support, allow the platform code to specify that the hardware we are running on supports multiple TX queues. This patch only uses the highest-numbered enabled queue to send packets to for now, this can be extended later to enable QoS and such. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Dale Farnsworth <dale@farnsworth.org>
2008-06-12mv643xx_eth: allow multiple RX queuesLennert Buytenhek
Allow the platform code to specify that we are running on hardware that is capable of supporting multiple RX queues. If this option is used, initialise all of the given RX queues instead of just RX queue zero. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Dale Farnsworth <dale@farnsworth.org>
2008-06-12mv643xx_eth: general cleanupLennert Buytenhek
General cleanup of the mv643xx_eth driver. Mainly fixes coding style / indentation issues, get rid of some useless 'volatile's, kill some more superfluous comments, and such. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Dale Farnsworth <dale@farnsworth.org>
2008-04-28mv643xx_eth: inter-mv643xx SMI port sharingLennert Buytenhek
There exist chips with up to four mv643xx_eth silicon blocks but only one external SMI (MII management) interface -- the SMI logic of the first block is shared by all the blocks. Handle this by allowing a per-port override of which mv643xx_eth_shared's SMI registers (and spinlock) to use. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
2008-04-28mv643xx_eth: shorten shared platform driver nameLennert Buytenhek
Change the MV643XX_ETH_SHARED_NAME platform driver name to something shorter than 19 characters, so that we can register multiple (otherwise we end up with sysfs conflicts since all instances will map to "mv643xx_eth_shared." as there is a 20-char sysfs file name limit.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
2008-04-28mv643xx_eth: configurable t_clkLennert Buytenhek
Make t_clk configurable via platform device data (with the current hardcoded value, 133 MHz, being the default), as it varies across different chip families. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
2008-04-28mv643xx_eth: mbus decode window supportLennert Buytenhek
Make it possible to pass mbus_dram_target_info to the mv643xx_eth driver via the platform data, and make the mv643xx_eth driver program the window registers based on this data if it is passed in. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Reviewed-by: Tzachi Perelstein <tzachi@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
2008-04-28mv643xx_eth: get rid of static variables, allow multiple instancesLennert Buytenhek
Move mv643xx_eth's static state (ethernet register block base address and MII management interface spinlock) into a struct hanging off the shared platform device. This is necessary to support chips that contain multiple mv643xx_eth silicon blocks. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
2007-10-30mv643xx_eth: Fix MV643XX_ETH offsets used by Pegasos 2Dale Farnsworth
In the mv643xx_eth driver, we now use offsets from the ethernet register block within the chip, but the pegasos 2 platform still needs offsets from the full chip's register base address. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-27fix breakage in pegasos_ethAl Viro
Fix fallout from commit b45d9147f1582333e180e1023624c003874b7312 ("mv643xx_eth: Remove unused register defines") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23mv643xx_eth: Split off mv643xx_eth platform device dataLennert Buytenhek
The mv643xx ethernet silicon block is also found in a couple of other Marvell chips. As a first step towards splitting off the mv643xx_eth bits from the rest of the mv643xx bits, this patch splits the mv643xx ethernet platform device data struct in linux/mv643xx.h off into linux/mv643xx_eth.h, and includes the latter from the former. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Tzachi Perelstein <tzachi@marvell.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
