path: root/include/linux/ncp.h
2010-08-22header: fix broken headers for user spaceChangli Gao
__packed is only defined in kernel space, so we should use __attribute__((packed)) for the code shared between kernel and user space. Two __attribute() annotations are replaced with __attribute__() too. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-08[PATCH] Eliminate __attribute__ ((packed)) warnings for gcc-4.1Jan Blunck
Since version 4.1 the gcc is warning about ignored attributes. This patch is using the equivalent attribute on the struct instead of on each of the structure or union members. GCC Manual: "Specifying Attributes of Types packed This attribute, attached to struct or union type definition, specifies that each member of the structure or union is placed to minimize the memory required. When attached to an enum definition, it indicates that the smallest integral type should be used. Specifying this attribute for struct and union types is equivalent to specifying the packed attribute on each of the structure or union members." Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
