[ Upstream commit f60e5990d9c1424af9dbca60a23ba2a1c7c1ce90 ]
We should not consult skb->sk for output decisions in xmit recursion
levels > 0 in the stack. Otherwise local socket settings could influence
the result of e.g. tunnel encapsulation process.
ipv6 does not conform with this in three places:
1) ip6_fragment: we do consult ipv6_npinfo for frag_size
2) sk_mc_loop in ipv6 uses skb->sk and checks if we should
loop the packet back to the local socket
3) ip6_skb_dst_mtu could query the settings from the user socket and
force a wrong MTU
Furthermore:
In sk_mc_loop we could potentially land in WARN_ON(1) if we use a
PF_PACKET socket ontop of an IPv6-backed vxlan device.
Reuse xmit_recursion as we are currently only interested in protecting
tunnel devices.
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 25175ba5c9bff9aaf0229df34bb5d54c81633ec3 ]
Currently netif_addr_lock_nested assumes that there can be only
a single nesting level between 2 devices. However, if we
have multiple devices of the same type stacked, this fails.
For example:
eth0 <-- vlan0.10 <-- vlan0.10.20
A more complicated configuration may stack more then one type of
device in different order.
Ex:
eth0 <-- vlan0.10 <-- macvlan0 <-- vlan1.10.20 <-- macvlan1
This patch adds an ndo_* function that allows each stackable
device to report its nesting level. If the device doesn't
provide this function default subclass of 1 is used.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 4085ebe8c31face855fd01ee40372cb4aab1df3a ]
Multiple devices in the kernel can be stacked/nested and they
need to know their nesting level for the purposes of lockdep.
This patch provides a generic function that determines a nesting
level of a particular device by its type (ex: vlan, macvlan, etc).
We only care about nesting of the same type of devices.
For example:
eth0 <- vlan0.10 <- macvlan0 <- vlan1.20
The nesting level of vlan1.20 would be 1, since there is another vlan
in the stack under it.
skb_network_protocol() already accounts for multiple vlan
headers that may be present in the skb. However, skb_mac_gso_segment()
doesn't know anything about it and assumes that skb->mac_len
is set correctly to skip all mac headers. That may not
always be the case. If we are simply forwarding the packet (via
bridge or macvtap), all vlan headers may not be accounted for.
A simple solution is to allow skb_network_protocol to return
the vlan depth it has calculated. This way skb_mac_gso_segment
will correctly skip all mac headers.
In order to allow users to invoke netdev_cap_txqueue, it needs to
be moved into netdevice.h header file. While at it, also add kernel
doc header to document the API.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Add a new argument for ndo_select_queue() callback that passes a
fallback handler. This gets invoked through netdev_pick_tx();
fallback handler is currently __netdev_pick_tx() as most drivers
invoke this function within their customized implementation in
case for skbs that don't need any special handling. This fallback
handler can then be replaced on other call-sites with different
queue selection methods (e.g. in packet sockets, pktgen etc).
This also has the nice side-effect that __netdev_pick_tx() is
then only invoked from netdev_pick_tx() and export of that
function to modules can be undone.
Suggested-by: David S. Miller <davem@davemloft.net>
Will be used by upcoming ipv4 forward path change that needs to
determine feature mask using skb->dst->dev instead of skb->dev.
No longer used API bond-specific can be removed now. This is now handled
in a generic way in rtnl_link_ops.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Add GRO handlers for protocols that do UDP encapsulation, with the intent of
being able to coalesce packets which encapsulate packets belonging to
the same TCP session.
For GRO purposes, the destination UDP port takes the role of the ether type
field in the ethernet header or the next protocol in the IP header.
The UDP GRO handler will only attempt to coalesce packets whose destination
port is registered to have gro handler.
Use a mark on the skb GRO CB data to disallow (flush) running the udp gro receive
code twice on a packet. This solves the problem of udp encapsulated packets whose
inner VM packet is udp and happen to carry a port which has registered offloads.
Signed-off-by: Shlomo Pongratz <shlomop@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
If link is IFF_SLAVE, extend link dev netlink attributes to include
slave attributes with new IFLA_SLAVE nest. Add netlink notification
(RTM_NEWLINK) when slave status changes from backup to active, or
visa-versa.
Adds new ndo_get_slave op to net_device_ops to fill skb with IFLA_SLAVE
attributes. Currently only used by bonding driver, but could be
used by other aggregating devices with slaves.
Signed-off-by: Scott Feldman <sfeldma@cumulusnetworks.com>
Extend existing support for netdevice receive queue sysfs attributes to
permit a device-specific attribute group. Initial use case for this
support will be to allow the virtio-net device to export per-receive
queue mergeable receive buffer size.
Signed-off-by: Michael Dalton <mwdalton@google.com>
Currently, if a device changes its mtu, first the change happens (invloving
all the side effects), and after that the NETDEV_CHANGEMTU is sent so that
other devices can catch up with the new mtu. However, if they return
NOTIFY_BAD, then the change is reverted and error returned.
This is a really long and costy operation (sometimes). To fix this, add
NETDEV_PRECHANGEMTU notification which is called prior to any change
actually happening, and if any callee returns NOTIFY_BAD - the change is
aborted. This way we're skipping all the playing with apply/revert the mtu.
CC: "David S. Miller" <davem@davemloft.net>
CC: Jiri Pirko <jiri@resnulli.us>
CC: Eric Dumazet <edumazet@google.com>
CC: Nicolas Dichtel <nicolas.dichtel@6wind.com>
CC: Cong Wang <amwang@redhat.com>
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Currently, we don't rename the upper/lower_ifc symlinks in
/sys/class/net/*/ , which might result stale/duplicate links/names.
Fix this by adding netdev_adjacent_rename_links(dev, oldname) which renames
all the upper/lower interface's links to dev from the upper/lower_oldname
to the new name.
We don't need a rollback because only we control these symlinks and if we
fail to rename them - sysfs will anyway complain.
Reported-by: Ding Tianhong <dingtianhong@huawei.com>
CC: Ding Tianhong <dingtianhong@huawei.com>
Currently, the tx queue were selected implicitly in ndo_dfwd_start_xmit(). The
will cause several issues:
- NETIF_F_LLTX were removed for macvlan, so txq lock were done for macvlan
instead of lower device which misses the necessary txq synchronization for
lower device such as txq stopping or frozen required by dev watchdog or
control path.
- dev_hard_start_xmit() was called with NULL txq which bypasses the net device
watchdog.
- dev_hard_start_xmit() does not check txq everywhere which will lead a crash
when tso is disabled for lower device.
Fix this by explicitly introducing a new param for .ndo_select_queue() for just
selecting queues in the case of l2 forwarding offload. netdev_pick_tx() was also
extended to accept this parameter and dev_queue_xmit_accel() was used to do l2
forwarding transmission.
With this fixes, NETIF_F_LLTX could be preserved for macvlan and there's no need
to check txq against NULL in dev_hard_start_xmit(). Also there's no need to keep
a dedicated ndo_dfwd_start_xmit() and we can just reuse the code of
dev_queue_xmit() to do the transmission.
In the future, it was also required for macvtap l2 forwarding support since it
provides a necessary synchronization method.
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: e1000-devel@lists.sourceforge.net
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
This patch built on top of Commit 299603e8370a93dd5d8e8d800f0dff1ce2c53d36
("net-gro: Prepare GRO stack for the upcoming tunneling support") to add
the support of the standard GRE (RFC1701/RFC2784/RFC2890) to the GRO
stack. It also serves as an example for supporting other encapsulation
protocols in the GRO stack in the future.
The patch supports version 0 and all the flags (key, csum, seq#) but
will flush any pkt with the S (seq#) flag. This is because the S flag
is not support by GSO, and a GRO pkt may end up in the forwarding path,
thus requiring GSO support to break it up correctly.
Currently the "packet_offload" structure only contains L3 (ETH_P_IP/
ETH_P_IPV6) GRO offload support so the encapped pkts are limited to
IP pkts (i.e., w/o L2 hdr). But support for other protocol type can
be easily added, so is the support for GRE variations like NVGRE.
The patch also support csum offload. Specifically if the csum flag is on
and the h/w is capable of checksumming the payload (CHECKSUM_COMPLETE),
the code will take advantage of the csum computed by the h/w when
validating the GRE csum.
Note that commit 60769a5dcd8755715c7143b4571d5c44f01796f1 "ipv4: gre:
add GRO capability" already introduces GRO capability to IPv4 GRE
tunnels, using the gro_cells infrastructure. But GRO is done after
GRE hdr has been removed (i.e., decapped). The following patch applies
GRO when pkts first come in (before hitting the GRE tunnel code). There
is some performance advantage for applying GRO as early as possible.
Also this approach is transparent to other subsystem like Open vSwitch
where GRE decap is handled outside of the IP stack hence making it
harder for the gro_cells stuff to apply. On the other hand, some NICs
are still not capable of hashing on the inner hdr of a GRE pkt (RSS).
In that case the GRO processing of pkts from the same remote host will
all happen on the same CPU and the performance may be suboptimal.
I'm including some rough preliminary performance numbers below. Note
that the performance will be highly dependent on traffic load, mix as
usual. Moreover it also depends on NIC offload features hence the
following is by no means a comprehesive study. Local testing and tuning
will be needed to decide the best setting.
All tests spawned 50 copies of netperf TCP_STREAM and ran for 30 secs.
(super_netperf 50 -H 192.168.1.18 -l 30)
An IP GRE tunnel with only the key flag on (e.g., ip tunnel add gre1
mode gre local 10.246.17.18 remote 10.246.17.17 ttl 255 key 123)
is configured.
The GRO support for pkts AFTER decap are controlled through the device
feature of the GRE device (e.g., ethtool -K gre1 gro on/off).
1.1 ethtool -K gre1 gro off; ethtool -K eth0 gro off
thruput: 9.16Gbps
CPU utilization: 19%
1.2 ethtool -K gre1 gro on; ethtool -K eth0 gro off
thruput: 5.9Gbps
CPU utilization: 15%
1.3 ethtool -K gre1 gro off; ethtool -K eth0 gro on
thruput: 9.26Gbps
CPU utilization: 12-13%
1.4 ethtool -K gre1 gro on; ethtool -K eth0 gro on
thruput: 9.26Gbps
CPU utilization: 10%
The following tests were performed on a different NIC that is capable of
csum offload. I.e., the h/w is capable of computing IP payload csum
(CHECKSUM_COMPLETE).
2.1 ethtool -K gre1 gro on (hence will use gro_cells)
2.1.1 ethtool -K eth0 gro off; csum offload disabled
thruput: 8.53Gbps
CPU utilization: 9%
2.1.2 ethtool -K eth0 gro off; csum offload enabled
thruput: 8.97Gbps
CPU utilization: 7-8%
2.1.3 ethtool -K eth0 gro on; csum offload disabled
thruput: 8.83Gbps
CPU utilization: 5-6%
2.1.4 ethtool -K eth0 gro on; csum offload enabled
thruput: 8.98Gbps
CPU utilization: 5%
2.2 ethtool -K gre1 gro off
2.2.1 ethtool -K eth0 gro off; csum offload disabled
thruput: 5.93Gbps
CPU utilization: 9%
2.2.2 ethtool -K eth0 gro off; csum offload enabled
thruput: 5.62Gbps
CPU utilization: 8%
2.2.3 ethtool -K eth0 gro on; csum offload disabled
thruput: 7.69Gbps
CPU utilization: 8%
2.2.4 ethtool -K eth0 gro on; csum offload enabled
thruput: 8.96Gbps
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c
net/ipv6/ip6_tunnel.c
net/ipv6/ip6_vti.c
ipv6 tunnel statistic bug fixes conflicting with consolidation into
generic sw per-cpu net stats.
qlogic conflict between queue counting bug fix and the addition
of multiple MAC address support.
Pablo Neira Ayuso says:
netfilter/IPVS updates for net-next
The following patchset contains Netfilter updates for your net-next tree,
they are:
* Add full port randomization support. Some crazy researchers found a way
to reconstruct the secure ephemeral ports that are allocated in random mode
by sending off-path bursts of UDP packets to overrun the socket buffer of
the DNS resolver to trigger retransmissions, then if the timing for the
DNS resolution done by a client is larger than usual, then they conclude
that the port that received the burst of UDP packets is the one that was
opened. It seems a bit aggressive method to me but it seems to work for
them. As a result, Daniel Borkmann and Hannes Frederic Sowa came up with a
new NAT mode to fully randomize ports using prandom.
* Add a new classifier to x_tables based on the socket net_cls set via
cgroups. These includes two patches to prepare the field as requested by
Zefan Li. Also from Daniel Borkmann.
* Use prandom instead of get_random_bytes in several locations of the
netfilter code, from Florian Westphal.
* Allow to use the CTA_MARK_MASK in ctnetlink when mangling the conntrack
mark, also from Florian Westphal.
* Fix compilation warning due to unused variable in IPVS, from Geert
Uytterhoeven.
* Add support for UID/GID via nfnetlink_queue, from Valentina Giusti.
* Add IPComp extension to x_tables, from Fan Du.
They are same, so unify them as one, pcpu_sw_netstats.
Define pcpu_sw_netstat in netdevice.h, remove pcpu_tstats
from if_tunnel and remove br_cpu_netstats from br_private.h
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
While we're at it and introduced CGROUP_NET_CLASSID, lets also make
NETPRIO_CGROUP more consistent with the rest of cgroups and rename it
into CONFIG_CGROUP_NET_PRIO so that for networking, we now have
CONFIG_CGROUP_NET_{PRIO,CLASSID}. This not only makes the CONFIG
option consistent among networking cgroups, but also among cgroups
CONFIG conventions in general as the vast majority has a prefix of
CONFIG_CGROUP_<SUBSYS>.
Cc: Zefan Li <lizefan@huawei.com>
Cc: cgroups@vger.kernel.org
Acked-by: Li Zefan <lizefan@huawei.com>
VM to VM GSO traffic is broken if it goes through VXLAN or GRE
tunnel and the physical NIC on the host supports hardware VXLAN/GRE
GSO offload (e.g. bnx2x and next-gen mlx4).
Two issues -
(VXLAN) VM traffic has SKB_GSO_DODGY and SKB_GSO_UDP_TUNNEL with
SKB_GSO_TCP/UDP set depending on the inner protocol. GSO header
integrity check fails in udp4_ufo_fragment if inner protocol is
TCP. Also gso_segs is calculated incorrectly using skb->len that
includes tunnel header. Fix: robust check should only be applied
to the inner packet.
(VXLAN & GRE) Once GSO header integrity check passes, NULL segs
is returned and the original skb is sent to hardware. However the
tunnel header is already pulled. Fix: tunnel header needs to be
restored so that hardware can perform GSO properly on the original
packet.
Signed-off-by: Wei-Chun Chao <weichunc@plumgrid.com>
The following functions are not used outside of net/core/dev.c
and should be declared static.
call_netdevice_notifiers_info
__dev_remove_offload
netdev_has_any_upper_dev
__netdev_adjacent_dev_remove
__netdev_adjacent_dev_link_lists
__netdev_adjacent_dev_unlink_lists
__netdev_adjacent_dev_link_neighbour
__netdev_adjacent_dev_unlink_neighbour
And the following are never used and should be deleted
netdev_lower_dev_get_private_rcu
__netdev_find_adj_rcu
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
drivers/net/ethernet/intel/i40e/i40e_main.c
drivers/net/macvtap.c
Both minor merge hassles, simple overlapping changes.
These function to manipulate multiple addresses are not used anywhere
in current net-next tree. Some out of tree code maybe using these but
too bad; they should submit their code upstream..
Also, make __hw_addr_flush local since only used by dev_addr_lists.c
The bond_first_slave_rcu() will be used to instead of bond_first_slave()
in rcu_read_lock().
According to the Jay Vosburgh's suggestion, the struct netdev_adjacent
should hide from users who wanted to use it directly. so I package a
new function to get the first slave of the bond.
Suggested-by: Nikolay Aleksandrov <nikolay@redhat.com>
Suggested-by: Jay Vosburgh <fubar@us.ibm.com>
Suggested-by: Veaceslav Falico <vfalico@redhat.com>
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
neigh_priv_len is defined as u8. With all debug enabled struct
ipoib_neigh has 200 bytes. The largest part is sk_buff_head with 96
bytes and here the spinlock with 72 bytes.
The size value still fits in this u8 leaving some room for more.
On -RT struct ipoib_neigh put on weight and has 392 bytes. The main
reason is sk_buff_head with 288 and the fatty here is spinlock with 192
bytes. This does no longer fit into into neigh_priv_len and gcc
complains.
This patch changes neigh_priv_len from being 8bit to 16bit. Since the
following element (dev_id) is 16bit followed by a spinlock which is
aligned, the struct remains with a total size of 3200 (allmodconfig) /
2048 (with as much debug off as possible) bytes on x86-64.
On x86-32 the struct is 1856 (allmodconfig) / 1216 (with as much debug
off as possible) bytes long. The numbers were gained with and without
the patch to prove that this change does not increase the size of the
struct.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
This patch modifies the GRO stack to avoid the use of "network_header"
and associated macros like ip_hdr() and ipv6_hdr() in order to allow
an arbitary number of IP hdrs (v4 or v6) to be used in the
encapsulation chain. This lays the foundation for various IP
tunneling support (IP-in-IP, GRE, VXLAN, SIT,...) to be added later.
With this patch, the GRO stack traversing now is mostly based on
skb_gro_offset rather than special hdr offsets saved in skb (e.g.,
skb->network_header). As a result all but the top layer (i.e., the
the transport layer) must have hdrs of the same length in order for
a pkt to be considered for aggregation. Therefore when adding a new
encap layer (e.g., for tunneling), one must check and skip flows
(e.g., by setting NAPI_GRO_CB(p)->same_flow to 0) that have a
different hdr length.
Note that unlike the network header, the transport header can and
will continue to be set by the GRO code since there will be at
most one "transport layer" in the encap chain.
Suggested-by: Eric Dumazet <edumazet@google.com>
TIPC is currently using the field 'af_packet_priv' in struct net_device
as a handle to find the bearer instance associated to the given network
device. But, by doing so it is blocking other networking cleanups, such
as the one discussed here:
http://patchwork.ozlabs.org/patch/178044/
This commit removes this usage from TIPC. Instead, we introduce a new
field, 'tipc_ptr', to the net_device structure, to serve this purpose.
When TIPC bearer is enabled, the bearer object is associated to
'tipc_ptr'. When a TIPC packet arrives in the recv_msg() upcall
from a networking device, the bearer object can now be obtained from
'tipc_ptr'. When a bearer is disabled, the bearer object is detached
from its underlying network device by setting 'tipc_ptr' to NULL.
Additionally, an RCU lock is used to protect the new pointer.
Henceforth, the existing tipc_net_lock is used in write mode to
serialize write accesses to this pointer, while the new RCU lock is
applied on the read side to ensure that the pointer is 100% valid
within its wrapped area for all readers.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Cc: Patrick McHardy <kaber@trash.net>
Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
Some network drivers use dev_kfree_skb_any() and dev_kfree_skb_irq()
helpers to free skbs, both for dropped packets and TX completed ones.
We need to separate the two causes to get better diagnostics
given by dropwatch or "perf record -e skb:kfree_skb"
This patch provides two new helpers, dev_consume_skb_any() and
dev_consume_skb_irq() to be used for consumed skbs.
__dev_kfree_skb_irq() is slightly optimized to remove one
atomic_dec_and_test() in fast path, and use this_cpu_{r|w} accessors.
Pull trivial tree updates from Jiri Kosina:
"Usual earth-shaking, news-breaking, rocket science pile from
trivial.git"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
doc: usb: Fix typo in Documentation/usb/gadget_configs.txt
doc: add missing files to timers/00-INDEX
timekeeping: Fix some trivial typos in comments
mm: Fix some trivial typos in comments
irq: Fix some trivial typos in comments
NUMA: fix typos in Kconfig help text
mm: update 00-INDEX
doc: Documentation/DMA-attributes.txt fix typo
DRM: comment: `halve' -> `half'
Docs: Kconfig: `devlopers' -> `developers'
doc: typo on word accounting in kprobes.c in mutliple architectures
treewide: fix "usefull" typo
treewide: fix "distingush" typo
mm/Kconfig: Grammar s/an/a/
kexec: Typo s/the/then/
Documentation/kvm: Update cpuid documentation for steal time and pv eoi
treewide: Fix common typo in "identify"
__page_to_pfn: Fix typo in comment
Correct some typos for word frequency
clk: fixed-factor: Fix a trivial typo
Pull networking updates from David Miller:
1) The addition of nftables. No longer will we need protocol aware
firewall filtering modules, it can all live in userspace.
At the core of nftables is a, for lack of a better term, virtual
machine that executes byte codes to inspect packet or metadata
(arriving interface index, etc.) and make verdict decisions.
Besides support for loading packet contents and comparing them, the
interpreter supports lookups in various datastructures as
fundamental operations. For example sets are supports, and
therefore one could create a set of whitelist IP address entries
which have ACCEPT verdicts attached to them, and use the appropriate
byte codes to do such lookups.
Since the interpreted code is composed in userspace, userspace can
do things like optimize things before giving it to the kernel.
Another major improvement is the capability of atomically updating
portions of the ruleset. In the existing netfilter implementation,
one has to update the entire rule set in order to make a change and
this is very expensive.
Userspace tools exist to create nftables rules using existing
netfilter rule sets, but both kernel implementations will need to
co-exist for quite some time as we transition from the old to the
new stuff.
Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have
worked so hard on this.
2) Daniel Borkmann and Hannes Frederic Sowa made several improvements
to our pseudo-random number generator, mostly used for things like
UDP port randomization and netfitler, amongst other things.
In particular the taus88 generater is updated to taus113, and test
cases are added.
3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet
and Yang Yingliang.
4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin
Sujir.
5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet,
Neal Cardwell, and Yuchung Cheng.
6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary
control message data, much like other socket option attributes.
From Francesco Fusco.
7) Allow applications to specify a cap on the rate computed
automatically by the kernel for pacing flows, via a new
SO_MAX_PACING_RATE socket option. From Eric Dumazet.
8) Make the initial autotuned send buffer sizing in TCP more closely
reflect actual needs, from Eric Dumazet.
9) Currently early socket demux only happens for TCP sockets, but we
can do it for connected UDP sockets too. Implementation from Shawn
Bohrer.
10) Refactor inet socket demux with the goal of improving hash demux
performance for listening sockets. With the main goals being able
to use RCU lookups on even request sockets, and eliminating the
listening lock contention. From Eric Dumazet.
11) The bonding layer has many demuxes in it's fast path, and an RCU
conversion was started back in 3.11, several changes here extend the
RCU usage to even more locations. From Ding Tianhong and Wang
Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav
Falico.
12) Allow stackability of segmentation offloads to, in particular, allow
segmentation offloading over tunnels. From Eric Dumazet.
13) Significantly improve the handling of secret keys we input into the
various hash functions in the inet hashtables, TCP fast open, as
well as syncookies. From Hannes Frederic Sowa. The key fundamental
operation is "net_get_random_once()" which uses static keys.
Hannes even extended this to ipv4/ipv6 fragmentation handling and
our generic flow dissector.
14) The generic driver layer takes care now to set the driver data to
NULL on device removal, so it's no longer necessary for drivers to
explicitly set it to NULL any more. Many drivers have been cleaned
up in this way, from Jingoo Han.
15) Add a BPF based packet scheduler classifier, from Daniel Borkmann.
16) Improve CRC32 interfaces and generic SKB checksum iterators so that
SCTP's checksumming can more cleanly be handled. Also from Daniel
Borkmann.
17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces
using the interface MTU value. This helps avoid PMTU attacks,
particularly on DNS servers. From Hannes Frederic Sowa.
18) Use generic XPS for transmit queue steering rather than internal
(re-)implementation in virtio-net. From Jason Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
random32: add test cases for taus113 implementation
random32: upgrade taus88 generator to taus113 from errata paper
random32: move rnd_state to linux/random.h
random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized
random32: add periodic reseeding
random32: fix off-by-one in seeding requirement
PHY: Add RTL8201CP phy_driver to realtek
xtsonic: add missing platform_set_drvdata() in xtsonic_probe()
macmace: add missing platform_set_drvdata() in mace_probe()
ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe()
ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh
vlan: Implement vlan_dev_get_egress_qos_mask as an inline.
ixgbe: add warning when max_vfs is out of range.
igb: Update link modes display in ethtool
netfilter: push reasm skb through instead of original frag skbs
ip6_output: fragment outgoing reassembled skb properly
MAINTAINERS: mv643xx_eth: take over maintainership from Lennart
net_sched: tbf: support of 64bit rates
ixgbe: deleting dfwd stations out of order can cause null ptr deref
ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS
Add a operations structure that allows a network interface to export
the fact that it supports package forwarding in hardware between
physical interfaces and other mac layer devices assigned to it (such
as macvlans). This operaions structure can be used by virtual mac
devices to bypass software switching so that forwarding can be done
in hardware more efficiently.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Andy Gospodarek <andy@greyhouse.net>
There is a bug in cpsw_probe() where we do:
ndev->irq = platform_get_irq(pdev, 0);
if (ndev->irq < 0) {
The problem is that "ndev->irq" is unsigned so the error handling
doesn't work. I have changed it to a regular int.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core / sysfs patches from Greg KH:
"Here's the big driver core / sysfs update for 3.13-rc1.
There's lots of dev_groups updates for different subsystems, as they
all get slowly migrated over to the safe versions of the attribute
groups (removing userspace races with the creation of the sysfs
files.) Also in here are some kobject updates, devres expansions, and
the first round of Tejun's sysfs reworking to enable it to be used by
other subsystems as a backend for an in-kernel filesystem.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (83 commits)
sysfs: rename sysfs_assoc_lock and explain what it's about
sysfs: use generic_file_llseek() for sysfs_file_operations
sysfs: return correct error code on unimplemented mmap()
mdio_bus: convert bus code to use dev_groups
device: Make dev_WARN/dev_WARN_ONCE print device as well as driver name
sysfs: separate out dup filename warning into a separate function
sysfs: move sysfs_hash_and_remove() to fs/sysfs/dir.c
sysfs: remove unused sysfs_get_dentry() prototype
sysfs: honor bin_attr.attr.ignore_lockdep
sysfs: merge sysfs_elem_bin_attr into sysfs_elem_attr
devres: restore zeroing behavior of devres_alloc()
sysfs: fix sysfs_write_file for bin file
input: gameport: convert bus code to use dev_groups
input: serio: remove bus usage of dev_attrs
input: serio: use DEVICE_ATTR_RO()
i2o: convert bus code to use dev_groups
memstick: convert bus code to use dev_groups
tifm: convert bus code to use dev_groups
virtio: convert bus code to use dev_groups
ipack: convert bus code to use dev_groups
Joby Poriyath provided a xen-netback patch to reduce the size of
xenvif structure as some netdev allocation could fail under
memory pressure/fragmentation.
This patch is handling the problem at the core level, allowing
any netdev structures to use vmalloc() if kmalloc() failed.
As vmalloc() adds overhead on a critical network path, add __GFP_REPEAT
to kzalloc() flags to do this fallback only when really needed.
Reported-by: Joby Poriyath <joby.poriyath@citrix.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
napi_disable uses an msleep() call to wait for outstanding napi work to be
finished after setting the disable bit. It does not always sleep incase there
was no outstanding work. This resulted in a rare bug in ixgbe_down operation
where a napi_disable call took place inside of a local_bh_disable()d context.
In order to enable easier detection of future sleep while atomic BUGs, this
patch adds a might_sleep() call, so that every use of napi_disable during
atomic context will be visible.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com>
Cc: Alexander Duyck <alexander.duyck@intel.com>
Cc: Hyong-Youb Kim <hykim@myri.com>
Cc: Amir Vadai <amirv@mellanox.com>
Cc: Dmitry Kravkov <dmitry@broadcom.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
Macro definitions should not normally end with a semi-colon, as this
makes it dangerous to use them an if...else statement. Happily this
has not happened yet.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Correct common misspelling of "identify" as "indentify" throughout
the kernel
Signed-off-by: Maxime Jayat <maxime@artisandeveloppeur.fr>
include/linux/netdevice.h
net/core/sock.c
Trivial merge issues.
Removal of "extern" for functions declaration in netdevice.h
at the same time "const" was added to an argument.
Two parallel line additions in net/core/sock.c
Separate the unreg_list and the close_list in dev_close_many preventing
dev_close_many from permuting the unreg_list. The permutations of the
unreg_list have resulted in cases where the loopback device is accessed
it has been freed in code such as dst_ifdown. Resulting in subtle memory
corruption.
This is the second bug from sharing the storage between the close_list
and the unreg_list. The issues that crop up with sharing are
apparently too subtle to show up in normal testing or usage, so let's
forget about being clever and use two separate lists.
v2: Make all callers pass in a close_list to dev_close_many
virtio wants to pass in cpumask_of(cpu), make parameter
const to avoid build warnings.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
git://repo.or.cz/linux-2.6/trivial-mods
More extern removals from Joe Perches.
Minor conflict with the dev_notify_flags changes which added a new
argument to __dev_notify_flags().
This patch only prepares the next one, there is no functional change.
Now, __dev_notify_flags() can also be used to notify flags changes via
rtnetlink.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
sysfs ns (namespace) implementation became more convoluted than
necessary while trying to hide ns information from visible interface.
The relatively recent attr ns support is a good example.
* attr ns tag is determined by sysfs_ops->namespace() callback while
dir tag is determined by kobj_type->namespace(). The placement is
arbitrary.
* Instead of performing operations with explicit ns tag, the namespace
callback is routed through sysfs_attr_ns(), sysfs_ops->namespace(),
class_attr_namespace(), class_attr->namespace(). It's not simpler
in any sense. The only thing this convolution does is traversing
the whole stack backwards.
The namespace callbacks are unncessary because the operations involved
are inherently synchronous. The information can be provided in in
straight-forward top-down direction and reversing that direction is
unnecessary and against basic design principles.
This backward interface is unnecessarily convoluted and hinders
properly separating out sysfs from driver model / kobject for proper
layering. This patch updates attr ns support such that
* sysfs_ops->namespace() and class_attr->namespace() are dropped.
* sysfs_{create|remove}_file_ns(), which take explicit @ns param, are
added and sysfs_{create|remove}_file() are now simple wrappers
around the ns aware functions.
* ns handling is dropped from sysfs_chmod_file(). Nobody uses it at
this point. sysfs_chmod_file_ns() can be added later if necessary.
* Explicit @ns is propagated through class_{create|remove}_file_ns()
and netdev_class_{create|remove}_file_ns().
* driver/net/bonding which is currently the only user of attr
namespace is updated to use netdev_class_{create|remove}_file_ns()
with @bh->net as the ns tag instead of using the namespace callback.
This patch should be an equivalent conversion without any functional
difference. It makes the code easier to follow, reduces lines of code
a bit and helps proper separation and layering.
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Kay Sievers <kay@vrfy.org>
It will be useful to get first/last element.
CC: Alexander Duyck <alexander.h.duyck@intel.com>
Add a possibility to iterate through netdev_adjacent's private, currently
only for lower neighbours.
Add both RCU and RTNL/other locking variants of iterators, and make the
non-rcu variant to be safe from removal.
Currently, even though we can access any linked device, we can't attach
anything to it, which is vital to properly manage them.
To fix this, add a new void *private to netdev_adjacent and functions
setting/getting it (per link), so that we can save, per example, bonding's
slave structures there, per slave device.
netdev_master_upper_dev_link_private(dev, upper_dev, private) links dev to
upper dev and populates the neighbour link only with private.
netdev_lower_dev_get_private{,_rcu}() returns the private, if found.
Currently, we distinguish neighbours (first-level linked devices) from
non-neighbours by the neighbour bool in the netdev_adjacent. This could be
quite time-consuming in case we would like to traverse *only* through
neighbours - cause we'd have to traverse through all devices and check for
this flag, and in a (quite common) scenario where we have lots of vlans on
top of bridge, which is on top of a bond - the bonding would have to go
through all those vlans to get its upper neighbour linked devices.
This situation is really unpleasant, cause there are already a lot of cases
when a device with slaves needs to go through them in hot path.
To fix this, introduce a new upper/lower device lists structure -
adj_list, which contains only the neighbours. It works always in
pair with the all_adj_list structure (renamed from upper/lower_dev_list),
i.e. both of them contain the same links, only that all_adj_list contains
also non-neighbour device links. It's really a small change visible,
currently, only for __netdev_adjacent_dev_insert/remove(), and doesn't
change the main linked logic at all.
Also, add some comments a fix a name collision in
netdev_for_each_upper_dev_rcu() and rework the naming by the following
rules:
netdev_(all_)(upper|lower)_*
If "all_" is present, then we work with the whole list of upper/lower
devices, otherwise - only with direct neighbours. Uninline functions - to
get better stack traces.
