path: root/include/linux/netfilter.h
2008-05-21netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__Patrick McHardy
Greg Steuck <greg@nest.cx> points out that some of the netfilter headers can't be used in userspace without including linux/types.h first. The headers include their own linux/types.h include statements, these are stripped by make headers-install because they are inside #ifdef __KERNEL__ however. Move them out to fix this. Reported and Tested by Greg Steuck. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[NETFILTER]: Add partial checksum validation helperPatrick McHardy
Move the UDP-Lite conntrack checksum validation to a generic helper similar to nf_checksum() and make it fall back to nf_checksum() in case the full packet is to be checksummed and hardware checksums are available. This is to be used by DCCP conntrack, which also needs to verify partial checksums. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: ip_tables: per-netns FILTER/MANGLE/RAW tables for realAlexey Dobriyan
Commit 9335f047fe61587ec82ff12fbb1220bcfdd32006 aka "[NETFILTER]: ip_tables: per-netns FILTER, MANGLE, RAW" added per-netns _view_ of iptables rules. They were shown to user, but ignored by filtering code. Now that it's possible to at least ping loopback, per-netns tables can affect filtering decisions. netns is taken in case of PRE_ROUTING, LOCAL_IN -- from in device, POST_ROUTING, LOCAL_OUT -- from out device, FORWARD -- from in device which should be equal to out device's netns. This code is relatively new, so BUG_ON was plugged. Wrappers were added to a) keep code the same from CONFIG_NET_NS=n users (overwhelming majority), b) consolidate code in one place -- similar changes will be done in ipv6 and arp netfilter code. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-03-25[NETFILTER]: Add nf_inet_addr_cmp()Patrick McHardy
2008-02-27[NETFILTER]: Fix NF_QUEUE_NR() parenthesisPatrick McHardy
Properly add parens around the macro argument. This is not needed by the kernel but the macro is exported to userspace, so it shouldn't make any assumptions. Also use NF_VERDICT_BITS instead of NF_VERDICT_QBTIS for the left-shift since thats whats logically correct. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-19[NETFILTER]: Use __u32 in struct nf_inet_addrPatrick McHardy
As reported by David Woodhouse <dwmw2@infradead.org>, using u_int32_t in struct nf_inet_addr breaks the busybox build. Fix by using __u32. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Extend nf_inet_addr with in{,6}_addrJan Engelhardt
Extend union nf_inet_addr with struct in_addr and in6_addr. Useful because a lot of in-kernel IPv4 and IPv6 functions use in_addr/in6_addr. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Use the ctl paths instead of hand-made analoguePavel Emelyanov
The conntracks subsystem has a similar infrastructure to maintain ctl_paths, but since we already have it on the generic level, I think it's OK to switch to using it. So, basically, this patch just replaces the ctl_table-s with ctl_path-s, nf_register_sysctl_table with register_sysctl_paths() and removes no longer needed code. After this the net/netfilter/nf_sysctl.c file contains the paths only. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce nf_inet_addressJan Engelhardt
A few netfilter modules provide their own union of IPv4 and IPv6 address storage. Will unify that in this patch series. (1/4): Rename union nf_conntrack_address to union nf_inet_addr and move it to x_tables.h. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_nat: properly use RCU for ip_nat_decode_sessionPatrick McHardy
We need to use rcu_assign_pointer/rcu_dereference to avoid races. Also remove an obsolete CONFIG_IP_NAT_NEEDED ifdef. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: constify nf_afinfoPatrick McHardy
2008-01-28[NETFILTER]: Kill function prototype for non-existing functionPatrick McHardy
2008-01-28[NETFILTER]: nf_log: move logging stuff to seperate headerPatrick McHardy
2008-01-28[NETFILTER]: nf_queue: move list_head/skb/id to struct nf_infoPatrick McHardy
Move common fields for queue management to struct nf_info and rename it to struct nf_queue_entry. The avoids one allocation/free per packet and simplifies the code a bit. Alternatively we could add some private room at the tail, but since all current users use identical structs this seems easier. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: move queueing related functions/struct to seperate headerPatrick McHardy
2008-01-28[NETFILTER]: nf_queue: remove unused data pointerPatrick McHardy
Remove the data pointer from struct nf_queue_handler. It has never been used and is useless for the only handler that really matters, nfnetlink_queue, since the handler is shared between all instances. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_queue: make queue_handler constPatrick McHardy
2008-01-28[NETFILTER]: nf_ct_h323: remove ipv6 module dependencyPatrick McHardy
nf_conntrack_h323 needs ip6_route_output for the call forwarding filter. Add a ->route function to nf_afinfo and use that to avoid pulling in the ipv6 module. Fix the #ifdef for the IPv6 code while I'm at it - the IPv6 support is only needed when IPv6 conntrack is enabled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Convert old checksum helper namesPatrick McHardy
Kill the defines again, convert to the new checksum helper names and remove the dependency of NET_ACT_NAT on NETFILTER. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Move netfilter checksum helpers to net/core/utils.cPatrick McHardy
This allows to get rid of the CONFIG_NETFILTER dependency of NET_ACT_NAT. This patch redefines the old names to keep the noise low, the next patch converts all users. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Do not copy skb in skb_make_writableHerbert Xu
Now that all callers of netfilter can guarantee that the skb is not shared, we no longer have to copy the skb in skb_make_writable. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-11[NETFILTER]: Fix/improve deadlock condition on module removal netfilterNeil Horman
So I've had a deadlock reported to me. I've found that the sequence of events goes like this: 1) process A (modprobe) runs to remove ip_tables.ko 2) process B (iptables-restore) runs and calls setsockopt on a netfilter socket, increasing the ip_tables socket_ops use count 3) process A acquires a file lock on the file ip_tables.ko, calls remove_module in the kernel, which in turn executes the ip_tables module cleanup routine, which calls nf_unregister_sockopt 4) nf_unregister_sockopt, seeing that the use count is non-zero, puts the calling process into uninterruptible sleep, expecting the process using the socket option code to wake it up when it exits the kernel 4) the user of the socket option code (process B) in do_ipt_get_ctl, calls ipt_find_table_lock, which in this case calls request_module to load ip_tables_nat.ko 5) request_module forks a copy of modprobe (process C) to load the module and blocks until modprobe exits. 6) Process C. forked by request_module process the dependencies of ip_tables_nat.ko, of which ip_tables.ko is one. 7) Process C attempts to lock the request module and all its dependencies, it blocks when it attempts to lock ip_tables.ko (which was previously locked in step 3) Theres not really any great permanent solution to this that I can see, but I've developed a two part solution that corrects the problem Part 1) Modifies the nf_sockopt registration code so that, instead of using a use counter internal to the nf_sockopt_ops structure, we instead use a pointer to the registering modules owner to do module reference counting when nf_sockopt calls a modules set/get routine. This prevents the deadlock by preventing set 4 from happening. Part 2) Enhances the modprobe utilty so that by default it preforms non-blocking remove operations (the same way rmmod does), and add an option to explicity request blocking operation. So if you select blocking operation in modprobe you can still cause the above deadlock, but only if you explicity try (and since root can do any old stupid thing it would like.... :) ). Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nfnetlink_queue: don't unregister handler of other subsystemYasuyuki Kozakai
The queue handlers registered by ip[6]_queue.ko at initialization should not be unregistered according to requests from userland program using nfnetlink_queue. If we allow that, there is no way to register the handlers of built-in ip[6]_queue again. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: kill destroy() in struct nf_conntrack for dietYasuyuki Kozakai
The destructor per conntrack is unnecessary, then this replaces it with system wide destructor. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: don't use nfct in skb if conntrack is disabledYasuyuki Kozakai
2007-02-12[NETFILTER]: nf_log: minor cleanupsPatrick McHardy
- rename nf_logging to nf_loggers since its an array of registered loggers - rename nf_log_unregister_logger() to nf_log_unregister() to make it symetrical to nf_log_register() and convert all users Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: nf_log: make nf_log_unregister_pf return voidPatrick McHardy
Since the only user of nf_log_unregister_pf (nfnetlink_log) doesn't check the return value, change it to void and bail out silently when a non-existant address family is supplied. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] fix fallout from header dependency trimmingAl Viro
OK, that seems to be enough to deal with the mess. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04netfilter.h needs rcuupdate.h for RCU locking functionsLinus Torvalds
This was exposed by Al's recent header file dependency reduction patches.. Cc: Al Viro <viro@ftp.linux.org.uk> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[NETFILTER]: Add NAT support for nf_conntrackJozsef Kadlecsik
Add NAT support for nf_conntrack. Joint work of Jozsef Kadlecsik, Yasuyuki Kozakai, Martin Josefsson and myself. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack: automatic sysctl registation for conntrack protocolsPatrick McHardy
Add helper functions for sysctl registration with optional instantiating of common path elements (like net/netfilter) and use it for support for automatic registation of conntrack protocol sysctls. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NET]: netfilter checksum annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate __skb_checksum_complete() and friends.Al Viro
2006-09-22[NETFILTER]: Get rid of HW checksum invalidationPatrick McHardy
Update hardware checksums incrementally to avoid breaking GSO. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-09[NETFILTER]: Add address family specific checksum helpersPatrick McHardy
Add checksum operation which takes care of verifying the checksum and dealing with HW checksum errors and avoids multiple checksum operations by setting ip_summed to CHECKSUM_UNNECESSARY after successful verification. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Introduce infrastructure for address family specific operationsPatrick McHardy
Change the queue rerouter intrastructure to a generic usable infrastructure for address family specific operations as a base for some cleanups. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Add helper functions for mass hook registration/unregistrationPatrick McHardy
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[NETFILTER]: Don't invoke okfn in CONFIG_NETFILTER=n variant of nf_hook()Patrick McHardy
nf_hook() is supposed to call the netfilter hook and return control of the packet back to the caller in case it may pass, the okfn is only used for queueing. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[XFRM]: Fix SNAT-related crash in xfrm4_output_finishPatrick McHardy
When a packet matching an IPsec policy is SNATed so it doesn't match any policy anymore it looses its xfrm bundle, which makes xfrm4_output_finish crash because of a NULL pointer dereference. This patch directs these packets to the original output path instead. Since the packets have already passed the POST_ROUTING hook, but need to start at the beginning of the original output path which includes another POST_ROUTING invocation, a flag is added to the IPCB to indicate that the packet was rerouted and doesn't need to pass the POST_ROUTING hook again. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[NETFILTER]: Add dummy nf_hook{_thresh}() when NETFILTER is disabled.David S. Miller
2006-01-07[NETFILTER]: Handle NAT in IPsec policy checksPatrick McHardy
Handle NAT of decapsulated IPsec packets by reconstructing the struct flowi of the original packet from the conntrack information for IPsec policy checks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[XFRM]: Netfilter IPsec output hooksPatrick McHardy
Call netfilter hooks before IPsec transforms. Packets visit the FORWARD/LOCAL_OUT and POST_ROUTING hook before the first encapsulation and the LOCAL_OUT and POST_ROUTING hook before each following tunnel mode transform. Patch from Herbert Xu <herbert@gondor.apana.org.au>: Move the loop from dst_output into xfrm4_output/xfrm6_output since they're the only ones who need to it. xfrm{4,6}_output_one() processes the first SA all subsequent transport mode SAs and is called in a loop that calls the netfilter hooks between each two calls. In order to avoid the tail call issue, I've added the inline function nf_hook which is nf_hook_slow plus the empty list check. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Fix gcc-3.4.x warning about iplicit operator precedenceHarald Welte
Fix gcc-3.4.x warning about iplicit operator precedence in NF_QUEUE_NR() Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Fix NF_QUEUE_NR() macroHarald Welte
I obviously wanted to use bitwise-or, not logical or. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: check nf_log function call argumentsHarald Welte
Check whether pf is too large in order to prevent array overflow. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: add /proc/net/netfilter interface to nf_queueHarald Welte
This patch adds a /proc/net/netfilter/nf_queue file, similar to the recently-added /proc/net/netfilter/nf_log. It indicates which queue handler is registered to which protocol family. This is useful since there are now multiple queue handlers in the treee (ip[6]_queue, nfnetlink_queue). Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
