The inputted table is never modified, so should be considered const.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Greg Steuck <greg@nest.cx> points out that some of the netfilter
headers can't be used in userspace without including linux/types.h
first. The headers include their own linux/types.h include statements,
these are stripped by make headers-install because they are inside
#ifdef __KERNEL__ however. Move them out to fix this.
Reported and Tested by Greg Steuck.
Typical table module registers xt_table structure (i.e. packet_filter)
and link it to list during it. We can't use one template for it because
corresponding list_head will become corrupted. We also can't unregister
with template because it wasn't changed at all and thus doesn't know in
which list it is.
So, we duplicate template at the very first step of table registration.
Table modules will save it for use during unregistration time and actual
filtering.
Do it at once to not screw bisection.
P.S.: renaming i.e. packet_filter => __packet_filter is temporary until
full netnsization of table modules is done.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Use compat types and compat iterators when dealing with compat entries for
clarity. This doesn't actually make a difference for ip_tables, but is
needed for ip6_tables and arp_tables.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
check_compat_entry_size_and_hooks iterates over the matches and calls
compat_check_calc_match, which loads the match and calculates the
compat offsets, but unlike the non-compat version, doesn't call
->checkentry yet. On error however it calls cleanup_matches, which in
turn calls ->destroy, which can result in crashes if the destroy
function (validly) expects to only get called after the checkentry
function.
Add a compat_release_match function that only drops the module reference
on error and rename compat_check_calc_match to compat_find_calc_match to
reflect the fact that it doesn't call the checkentry function.
Reported by Jan Engelhardt <jengelh@linux01.gwdg.de>
Signed-off-by: Dmitry Mishin <dim@openvz.org>
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
function
structure names
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Use the x_tables functions directly to make it better visible which
parts are shared between ip_tables and ip6_tables.
With the introduction of x_tables we accidentally broke compatibility
by defining IPT_TABLE_MAXNAMELEN to XT_FUNCTION_MAXNAMELEN instead of
XT_TABLE_MAXNAMELEN, which is two bytes larger.
On most architectures it doesn't really matter since we don't have
any tables with names that long in the kernel and the structure
layout didn't change because of alignment requirements of following
members. On CRIS however (and other architectures that don't align
data) this changed the structure layout and thus broke compatibility
with old iptables binaries.
Changing it back will break compatibility with binaries compiled
against recent kernels again, but since the breakage has only been
there for three releases this seems like the better choice.
Spotted by Jonas Berlin <xkr47@outerspace.dyndns.org>.
66 and 67 for getsockopt on IPv6 socket is doubly used for IPv6 Advanced
API and ip6tables. This moves numbers for ip6tables to 68 and 69.
This also kills XT_SO_* because {ip,ip6,arp}_tables doesn't have so much
common numbers now.
The old userland tools keep to behave as ever, because old kernel always
calls functions of IPv6 Advanced API for their numbers.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
This patch extends current iptables compatibility layer in order to get
32bit iptables to work on 64bit kernel. Current layer is insufficient due
to alignment checks both in kernel and user space tools.
Patch is for current net-2.6.17 with addition of move of ipt_entry_{match|
target} definitions to xt_entry_{match|target}.
Acked-off-by: Kirill Korotaev <dev@openvz.org>
This patch moves {ip,ip6,arp}t_entry_{match,target} definitions to
x_tables.h. This move simplifies code and future compatibility fixes.
Set the family field in xt_[matches|targets] registered.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
Originally written by Henrik Nordstrom <hno@marasystems.com>, taken
from netfilter patch-o-matic and added ip6_tables support.
infrastructure for it.
Let it rip!
