This explains the allowed upper protocol numbers. IP6T_F_NOPROTO was
introduced to use 0 as Hop-by-Hop option header, not wildcard. But that
seemed to be forgotten. 0 has been used as wildcard since 2002-08-23.
Signed-off-by: Yasuyuki Kozakai <yasuyuki@netfilter.org>
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
Move ip6t_standard/ip6t_error_target/ip6t_error definitions to ip6_tables.h
instead of defining them in each table individually.
structure names
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Use the x_tables functions directly to make it better visible which
parts are shared between ip_tables and ip6_tables.
66 and 67 for getsockopt on IPv6 socket is doubly used for IPv6 Advanced
API and ip6tables. This moves numbers for ip6tables to 68 and 69.
This also kills XT_SO_* because {ip,ip6,arp}_tables doesn't have so much
common numbers now.
The old userland tools keep to behave as ever, because old kernel always
calls functions of IPv6 Advanced API for their numbers.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
This patch moves {ip,ip6,arp}t_entry_{match,target} definitions to
x_tables.h. This move simplifies code and future compatibility fixes.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
Acked-off-by: Kirill Korotaev <dev@openvz.org>
Set the family field in xt_[matches|targets] registered.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
The original ipv6_find_hdr() finds the specified header in IPv6 packets.
This makes it possible to get transport header so that we can kill similar
loop in ip6_match_packet().
Like ip_tables already has it for some time, this adds support for
having multiple revisions for each match/target. We steal one byte from
the name in order to accomodate a 8 bit version number.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Some IPv6 matches have very similar loops to find IPv6 extension header
and we can unify them. This patch introduces ipv6_find_hdr() to do it.
I just checked that it can find the target headers in the packet which has
dst,hbh,rt,frag,ah,esp headers.
Originally written by Henrik Nordstrom <hno@marasystems.com>, taken
from netfilter patch-o-matic and added ip6_tables support.
infrastructure for it.
Let it rip!
