path: root/include/linux/netfilter_ipv6/ip6_tables.h
2008-01-31[NETFILTER]: ip6_tables: netns preparationAlexey Dobriyan
* Propagate netns from userspace down to xt_find_table_lock() * Register ip6 tables in netns (modules still use init_net) Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: x_tables: return new table from {arp,ip,ip6}t_register_table()Alexey Dobriyan
Typical table module registers xt_table structure (i.e. packet_filter) and link it to list during it. We can't use one template for it because corresponding list_head will become corrupted. We also can't unregister with template because it wasn't changed at all and thus doesn't know in which list it is. So, we duplicate template at the very first step of table registration. Table modules will save it for use during unregistration time and actual filtering. Do it at once to not screw bisection. P.S.: renaming i.e. packet_filter => __packet_filter is temporary until full netnsization of table modules is done. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: ip6_tables: use XT_ALIGNPatrick McHardy
2008-01-28[NETFILTER]: ip6_tables: add compat supportPatrick McHardy
2008-01-28[NETFILTER]: {ip,ip6,arp}_tables: consolidate iterator macrosPatrick McHardy
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: ip6_tables: fix explanation of valid upper protocol numberYasuyuki Kozakai
This explains the allowed upper protocol numbers. IP6T_F_NOPROTO was introduced to use 0 as Hop-by-Hop option header, not wildcard. But that seemed to be forgotten. 0 has been used as wildcard since 2002-08-23. Signed-off-by: Yasuyuki Kozakai <yasuyuki@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[NETFILTER]: Clean up table initializationPatrick McHardy
- move arp_tables initial table structure definitions to arp_tables.h similar to ip_tables and ip6_tables - use C99 initializers - use initializer macros where possible Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETFILTER]: ip6_tables: remove redundant structure definitionsPatrick McHardy
Move ip6t_standard/ip6t_error_target/ip6t_error definitions to ip6_tables.h instead of defining them in each table individually. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETFILTER]: {ip,ip6}_tables: use struct xt_table instead of redefined ↵Jan Engelhardt
structure names Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETFILTER]: {ip,ip6}_tables: remove x_tables wrapper functionsJan Engelhardt
Use the x_tables functions directly to make it better visible which parts are shared between ip_tables and ip6_tables. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-15[NETFILTER]: ip6_tables: fixed conflicted optname for getsockoptYasuyuki Kozakai
66 and 67 for getsockopt on IPv6 socket is doubly used for IPv6 Advanced API and ip6tables. This moves numbers for ip6tables to 68 and 69. This also kills XT_SO_* because {ip,ip6,arp}_tables doesn't have so much common numbers now. The old userland tools keep to behave as ever, because old kernel always calls functions of IPv6 Advanced API for their numbers. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: x_tables: remove unused argument to target functionsPatrick McHardy
2006-03-22[NETFILTER]: futher {ip,ip6,arp}_tables unificationDmitry Mishin
This patch moves {ip,ip6,arp}t_entry_{match,target} definitions to x_tables.h. This move simplifies code and future compatibility fixes. Signed-off-by: Dmitry Mishin <dim@openvz.org> Acked-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[NETFILTER]: x_tables: set the protocol family in x_tables targets/matchesPablo Neira Ayuso
Set the family field in xt_[matches|targets] registered. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[NETFILTER] x_tables: Abstraction layer for {ip,ip6,arp}_tablesHarald Welte
This monster-patch tries to do the best job for unifying the data structures and backend interfaces for the three evil clones ip_tables, ip6_tables and arp_tables. In an ideal world we would never have allowed this kind of copy+paste programming... but well, our world isn't (yet?) ideal. o introduce a new x_tables module o {ip,arp,ip6}_tables depend on this x_tables module o registration functions for tables, matches and targets are only wrappers around x_tables provided functions o all matches/targets that are used from ip_tables and ip6_tables are now implemented as xt_FOOBAR.c files and provide module aliases to ipt_FOOBAR and ip6t_FOOBAR o header files for xt_matches are in include/linux/netfilter/, include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers around the xt_FOOBAR.h headers Based on this patchset we're going to further unify the code, gradually getting rid of all the layer 3 specific assumptions. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Export ip6_masked_addrcmp, don't pass IPv6 addresses on stackPatrick McHardy
2006-01-05[NETFILTER]: make ipv6_find_hdr() find transport protocol headerPatrick McHardy
The original ipv6_find_hdr() finds the specified header in IPv6 packets. This makes it possible to get transport header so that we can kill similar loop in ip6_match_packet(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-31[NETFILTER]: Add "revision" support to arp_tables and ip6_tablesHarald Welte
Like ip_tables already has it for some time, this adds support for having multiple revisions for each match/target. We steal one byte from the name in order to accomodate a 8 bit version number. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-19[NETFILTER] ip6tables: remove duplicate codeYasuyuki Kozakai
Some IPv6 matches have very similar loops to find IPv6 extension header and we can unify them. This patch introduces ipv6_find_hdr() to do it. I just checked that it can find the target headers in the packet which has dst,hbh,rt,frag,ah,esp headers. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Add goto targetPatrick McHardy
Originally written by Henrik Nordstrom <hno@marasystems.com>, taken from netfilter patch-o-matic and added ip6_tables support. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
