path: root/include/linux/netpoll.h
2014-03-29netpoll: Rename netpoll_rx_enable/disable to netpoll_poll_disable/enableEric W. Biederman
The netpoll_rx_enable and netpoll_rx_disable functions have always controlled polling the network drivers transmit and receive queues. Rename them to netpoll_poll_enable and netpoll_poll_disable to make their functionality clear. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-29netpoll: Remove gfp parameter from __netpoll_setupEric W. Biederman
The gfp parameter was added in: commit 47be03a28cc6c80e3aa2b3e8ed6d960ff0c5c0af Author: Amerigo Wang <amwang@redhat.com> Date: Fri Aug 10 01:24:37 2012 +0000 netpoll: use GFP_ATOMIC in slave_enable_netpoll() and __netpoll_setup() slave_enable_netpoll() and __netpoll_setup() may be called with read_lock() held, so should use GFP_ATOMIC to allocate memory. Eric suggested to pass gfp flags to __netpoll_setup(). Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> The reason for the gfp parameter was removed in: commit c4cdef9b7183159c23c7302aaf270d64c549f557 Author: dingtianhong <dingtianhong@huawei.com> Date: Tue Jul 23 15:25:27 2013 +0800 bonding: don't call slave_xxx_netpoll under spinlocks The slave_xxx_netpoll will call synchronize_rcu_bh(), so the function may schedule and sleep, it should't be called under spinlocks. bond_netpoll_setup() and bond_netpoll_cleanup() are always protected by rtnl lock, it is no need to take the read lock, as the slave list couldn't be changed outside rtnl lock. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net> Nothing else that calls __netpoll_setup or ndo_netpoll_setup requires a gfp paramter, so remove the gfp parameter from both of these functions making the code clearer. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-17netpoll: Remove dead packet receive code (CONFIG_NETPOLL_TRAP)Eric W. Biederman
The netpoll packet receive code only becomes active if the netpoll rx_skb_hook is implemented, and there is not a single implementation of the netpoll rx_skb_hook in the kernel. All of the out of tree implementations I have found all call netpoll_poll which was removed from the kernel in 2011, so this change should not add any additional breakage. There are problems with the netpoll packet receive code. __netpoll_rx does not call dev_kfree_skb_irq or dev_kfree_skb_any in hard irq context. netpoll_neigh_reply leaks every skb it receives. Reception of packets does not work successfully on stacked devices (aka bonding, team, bridge, and vlans). Given that the netpoll packet receive code is buggy, there are no out of tree users that will be merged soon, and the code has not been used for in tree for a decade let's just remove it. Reverting this commit can server as a starting point for anyone who wants to resurrect netpoll packet reception support. Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-17netpoll: Move all receive processing under CONFIG_NETPOLL_TRAPEric W. Biederman
Make rx_skb_hook, and rx in struct netpoll depend on CONFIG_NETPOLL_TRAP Make rx_lock, rx_np, and neigh_tx in struct netpoll_info depend on CONFIG_NETPOLL_TRAP Make the functions netpoll_rx_on, netpoll_rx, and netpoll_receive_skb no-ops when CONFIG_NETPOLL_TRAP is not set. Only build netpoll_neigh_reply, checksum_udp service_neigh_queue, pkt_is_ns, and __netpoll_rx when CONFIG_NETPOLL_TRAP is defined. Add helper functions netpoll_trap_setup, netpoll_trap_setup_info, netpoll_trap_cleanup, and netpoll_trap_cleanup_info that initialize and cleanup the struct netpoll and struct netpoll_info receive specific fields when CONFIG_NETPOLL_TRAP is enabled and do nothing otherwise. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-17netpoll: Move netpoll_trap under CONFIG_NETPOLL_TRAPEric W. Biederman
Now that we no longer need to receive packets to safely drain the network drivers receive queue move netpoll_trap and netpoll_set_trap under CONFIG_NETPOLL_TRAP Making netpoll_trap and netpoll_set_trap noop inline functions when CONFIG_NETPOLL_TRAP is not set. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-17netpoll: Don't drop all received packets.Eric W. Biederman
Change the strategy of netpoll from dropping all packets received during netpoll_poll_dev to calling napi poll with a budget of 0 (to avoid processing drivers rx queue), and to ignore packets received with netif_rx (those will safely be placed on the backlog queue). All of the netpoll supporting drivers have been reviewed to ensure either thay use netif_rx or that a budget of 0 is supported by their napi poll routine and that a budget of 0 will not process the drivers rx queues. Not dropping packets makes NETPOLL_RX_DROP unnecesary so it is removed. npinfo->rx_flags is removed as rx_flags with just the NETPOLL_RX_ENABLED flag becomes just a redundant mirror of list_empty(&npinfo->rx_np). Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-17netpoll: Add netpoll_rx_processingEric W. Biederman
Add a helper netpoll_rx_processing that reports when netpoll has receive side processing to perform. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-25netpoll: fix rx_hook() interface by passing the skbAntonio Quartulli
Right now skb->data is passed to rx_hook() even if the skb has not been linearised and without giving rx_hook() a way to linearise it. Change the rx_hook() interface and make it accept the skb and the offset to the UDP payload as arguments. rx_hook() is also renamed to rx_skb_hook() to ensure that out of the tree users notice the API change. In this way any rx_skb_hook() implementation can perform all the needed operations to properly (and safely) access the skb data. Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27netpoll: remove return value from netpoll_rx_disable()dingtianhong
The netpoll_rx_disable() will always return 0, it is no use and looks wordy, so remove the unnecessary code and get rid of it in _dev_open and _dev_close. Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01netpoll: convert mutex into a semaphoreNeil Horman
Bart Van Assche recently reported a warning to me: <IRQ> [<ffffffff8103d79f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8103d7fa>] warn_slowpath_null+0x1a/0x20 [<ffffffff814761dd>] mutex_trylock+0x16d/0x180 [<ffffffff813968c9>] netpoll_poll_dev+0x49/0xc30 [<ffffffff8136a2d2>] ? __alloc_skb+0x82/0x2a0 [<ffffffff81397715>] netpoll_send_skb_on_dev+0x265/0x410 [<ffffffff81397c5a>] netpoll_send_udp+0x28a/0x3a0 [<ffffffffa0541843>] ? write_msg+0x53/0x110 [netconsole] [<ffffffffa05418bf>] write_msg+0xcf/0x110 [netconsole] [<ffffffff8103eba1>] call_console_drivers.constprop.17+0xa1/0x1c0 [<ffffffff8103fb76>] console_unlock+0x2d6/0x450 [<ffffffff8104011e>] vprintk_emit+0x1ee/0x510 [<ffffffff8146f9f6>] printk+0x4d/0x4f [<ffffffffa0004f1d>] scsi_print_command+0x7d/0xe0 [scsi_mod] This resulted from my commit ca99ca14c which introduced a mutex_trylock operation in a path that could execute in interrupt context. When mutex debugging is enabled, the above warns the user when we are in fact exectuting in interrupt context interrupt context. After some discussion, It seems that a semaphore is the proper mechanism to use here. While mutexes are defined to be unusable in interrupt context, no such condition exists for semaphores (save for the fact that the non blocking api calls, like up and down_trylock must be used when in irq context). Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Bart Van Assche <bvanassche@acm.org> CC: Bart Van Assche <bvanassche@acm.org> CC: David Miller <davem@davemloft.net> CC: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-11netpoll: Fix __netpoll_rcu_free so that it can hold the rtnl lockNeil Horman
__netpoll_rcu_free is used to free netpoll structures when the rtnl_lock is already held. The mechanism is used to asynchronously call __netpoll_cleanup outside of the holding of the rtnl_lock, so as to avoid deadlock. Unfortunately, __netpoll_cleanup modifies pointers (dev->np), which means the rtnl_lock must be held while calling it. Further, it cannot be held, because rcu callbacks may be issued in softirq contexts, which cannot sleep. Fix this by converting the rcu callback to a work queue that is guaranteed to get scheduled in process context, so that we can hold the rtnl properly while calling __netpoll_cleanup Tested successfully by myself. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: "David S. Miller" <davem@davemloft.net> CC: Cong Wang <amwang@redhat.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-06netpoll: protect napi_poll and poll_controller during dev_[open|close]Neil Horman
Ivan Vercera was recently backporting commit 9c13cb8bb477a83b9a3c9e5a5478a4e21294a760 to a RHEL kernel, and I noticed that, while this patch protects the tg3 driver from having its ndo_poll_controller routine called during device initalization, it does nothing for the driver during shutdown. I.e. it would be entirely possible to have the ndo_poll_controller method (or subsequently the ndo_poll) routine called for a driver in the netpoll path on CPU A while in parallel on CPU B, the ndo_close or ndo_open routine could be called. Given that the two latter routines tend to initizlize and free many data structures that the former two rely on, the result can easily be data corruption or various other crashes. Furthermore, it seems that this is potentially a problem with all net drivers that support netpoll, and so this should ideally be fixed in a common path. As Ben H Pointed out to me, we can't preform dev_open/dev_close in atomic context, so I've come up with this solution. We can use a mutex to sleep in open/close paths and just do a mutex_trylock in the napi poll path and abandon the poll attempt if we're locked, as we'll just retry the poll on the next send anyway. I've tested this here by flooding netconsole with messages on a system whos nic driver I modfied to periodically return NETDEV_TX_BUSY, so that the netpoll tx workqueue would be forced to send frames and poll the device. While this was going on I rapidly ifdown/up'ed the interface and watched for any problems. I've not found any. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Ivan Vecera <ivecera@redhat.com> CC: "David S. Miller" <davem@davemloft.net> CC: Ben Hutchings <bhutchings@solarflare.com> CC: Francois Romieu <romieu@fr.zoreil.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-08netpoll: prepare for ipv6Cong Wang
This patch adjusts some struct and functions, to prepare for supporting IPv6. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: convert several functions to boolAmerigo Wang
These functions are just boolean, let them return bool instead of int. Cc: David Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: take rcu_read_lock_bh() in netpoll_send_skb_on_dev()Amerigo Wang
This patch fixes several problems in the call path of netpoll_send_skb_on_dev(): 1. Disable IRQ's before calling netpoll_send_skb_on_dev(). 2. All the callees of netpoll_send_skb_on_dev() should use rcu_dereference_bh() to dereference ->npinfo. 3. Rename arp_reply() to netpoll_arp_reply(), the former is too generic. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: use netpoll_rx_on() in netpoll_rx()Amerigo Wang
The logic of the code is same, just call netpoll_rx_on(). Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: take rcu_read_lock_bh() in netpoll_rx()Amerigo Wang
In __netpoll_rx(), it dereferences ->npinfo without rcu_dereference_bh(), this patch fixes it by using the 'npinfo' passed from netpoll_rx() where it is already dereferenced with rcu_dereference_bh(). Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: make __netpoll_cleanup non-blockAmerigo Wang
Like the previous patch, slave_disable_netpoll() and __netpoll_cleanup() may be called with read_lock() held too, so we should make them non-block, by moving the cleanup and kfree() to call_rcu_bh() callbacks. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14netpoll: use GFP_ATOMIC in slave_enable_netpoll() and __netpoll_setup()Amerigo Wang
2012-07-17netpoll: move np->dev and np->dev_name init into __netpoll_setup()Jiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-03netpoll: Remove unused EXPORT_SYMBOLs of netpoll_poll and netpoll_poll_devJoe Perches
Unused symbols waste space. Commit 0e34e93177fb "(netpoll: add generic support for bridge and bonding devices)" added the symbol more than a year ago with the promise of "future use". Because it is so far unused, remove it for now. It can be easily readded if or when it actually needs to be used. cc: WANG Cong <amwang@redhat.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18bonding: Fix bonding drivers improper modification of netpoll structureNeil Horman
The bonding driver currently modifies the netpoll structure in its xmit path while sending frames from netpoll. This is racy, as other cpus can access the netpoll structure in parallel. Since the bonding driver points np->dev to a slave device, other cpus can inadvertently attempt to send data directly to slave devices, leading to improper locking with the bonding master, lost frames, and deadlocks. This patch fixes that up. This patch also removes the real_dev pointer from the netpoll structure as that data is really only used by bonding in the poll_controller, and we can emulate its behavior by check each slave for IS_UP. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-17netpoll: Disable IRQ around RCU dereference in netpoll_rxHerbert Xu
We cannot use rcu_dereference_bh safely in netpoll_rx as we may be called with IRQs disabled. We could however simply disable IRQs as that too causes BH to be disabled and is safe in either case. Thanks to John Linville for discovering this bug and providing a patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10net: make netpoll_rx return bool for !CONFIG_NETPOLLJohn W. Linville
"netpoll: Use 'bool' for netpoll_rx() return type." missed the case when CONFIG_NETPOLL is disabled. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15netpoll: Use correct primitives for RCU dereferencingHerbert Xu
Now that RCU debugging checks for matching rcu_dereference calls and rcu_read_lock, we need to use the correct primitives or face nasty warnings. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15netpoll: Add netpoll_tx_runningHerbert Xu
This patch adds the helper netpoll_tx_running for use within ndo_start_xmit. It returns non-zero if ndo_start_xmit is being invoked by netpoll, and zero otherwise. This is currently implemented by simply looking at the hardirq count. This is because for all non-netpoll uses of ndo_start_xmit, IRQs must be enabled while netpoll always disables IRQs before calling ndo_start_xmit. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15netpoll: Allow netpoll_setup/cleanup recursionHerbert Xu
This patch adds the functions __netpoll_setup/__netpoll_cleanup which is designed to be called recursively through ndo_netpoll_seutp. They must be called with RTNL held, and the caller must initialise np->dev and ensure that it has a valid reference count. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15netpoll: Fix RCU usageHerbert Xu
The use of RCU in netpoll is incorrect in a number of places: 1) The initial setting is lacking a write barrier. 2) The synchronize_rcu is in the wrong place. 3) Read barriers are missing. 4) Some places are even missing rcu_read_lock. 5) npinfo is zeroed after freeing. This patch fixes those issues. As most users are in BH context, this also converts the RCU usage to the BH variant. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06netpoll: Use 'bool' for netpoll_rx() return type.David S. Miller
2010-05-06netpoll: add generic support for bridge and bonding devicesWANG Cong
This whole patchset is for adding netpoll support to bridge and bonding devices. I already tested it for bridge, bonding, bridge over bonding, and bonding over bridge. It looks fine now. To make bridge and bonding support netpoll, we need to adjust some netpoll generic code. This patch does the following things: 1) introduce two new priv_flags for struct net_device: IFF_IN_NETPOLL which identifies we are processing a netpoll; IFF_DISABLE_NETPOLL is used to disable netpoll support for a device at run-time; 2) introduce one new method for netdev_ops: ->ndo_netpoll_cleanup() is used to clean up netpoll when a device is removed. 3) introduce netpoll_poll_dev() which takes a struct net_device * parameter; export netpoll_send_skb() and netpoll_poll_dev() which will be used later; 4) hide a pointer to struct netpoll in struct netpoll_info, ditto. 5) introduce ->real_dev for struct netpoll. 6) introduce a new status NETDEV_BONDING_DESLAE, which is used to disable netconsole before releasing a slave, to avoid deadlocks. Cc: David Miller <davem@davemloft.net> Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13netpoll: allow execution of multiple rx_hooks per interfaceDaniel Borkmann
Signed-off-by: Daniel Borkmann <danborkmann@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28netpoll: store local and remote ip in net-endianHarvey Harrison
Allows for the removal of byteswapping in some places and the removal of HIPQUAD (replaced by %pI4). Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16GRO: Move netpoll checks to correct locationHerbert Xu
As my netpoll fix for net doesn't really work for net-next, we need this update to move the checks into the right place. As it stands we may pass freed skbs to netpoll_receive_skb. This patch also introduces a netpoll_rx_on function to avoid GRO completely if we're invoked through netpoll. This might seem paranoid but as netpoll may have an external receive hook it's better to be safe than sorry. I don't think we need this for 2.6.29 though since there's nothing immediately broken by it. This patch also moves the GRO_* return values to netdevice.h since VLAN needs them too (I tried to avoid this originally but alas this seems to be the easiest way out). This fixes a bug in VLAN where it continued to use the old return value 2 instead of the correct GRO_DROP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15net: Add Generic Receive Offload infrastructureHerbert Xu
This patch adds the top-level GRO (Generic Receive Offload) infrastructure. This is pretty similar to LRO except that this is protocol-independent. Instead of holding packets in an lro_mgr structure, they're now held in napi_struct. For drivers that intend to use this, they can set the NETIF_F_GRO bit and call napi_gro_receive instead of netif_receive_skb or just call netif_rx. The latter will call napi_receive_skb automatically. When napi_gro_receive is used, the driver must either call napi_complete/napi_rx_complete, or call napi_gro_flush in softirq context if the driver uses the primitives __napi_complete/__napi_rx_complete. Protocols will set the gro_receive and gro_complete function pointers in order to participate in this scheme. In addition to the packet, gro_receive will get a list of currently held packets. Each packet in the list has a same_flow field which is non-zero if it is a potential match for the new packet. For each packet that may match, they also have a flush field which is non-zero if the held packet must not be merged with the new packet. Once gro_receive has determined that the new skb matches a held packet, the held packet may be processed immediately if the new skb cannot be merged with it. In this case gro_receive should return the pointer to the existing skb in gro_list. Otherwise the new skb should be merged into the existing packet and NULL should be returned, unless the new skb makes it impossible for any further merges to be made (e.g., FIN packet) where the merged skb should be returned. Whenever the skb is merged into an existing entry, the gro_receive function should set NAPI_GRO_CB(skb)->same_flow. Note that if an skb merely matches an existing entry but can't be merged with it, then this shouldn't be set. If gro_receive finds it pointless to hold the new skb for future merging, it should set NAPI_GRO_CB(skb)->flush. Held packets will be flushed by napi_gro_flush which is called by napi_complete and napi_rx_complete. Currently held packets are stored in a singly liked list just like LRO. The list is limited to a maximum of 8 entries. In future, this may be expanded to use a hash table to allow more flows to be held for merging. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[NETPOLL]: Revert two bogus cleanups that broke netconsole.David S. Miller
Based upon a report by Andrew Morton and code analysis done by Jarek Poplawski. This reverts 33f807ba0d9259e7c75c7a2ce8bd2787e5b540c7 ("[NETPOLL]: Kill NETPOLL_RX_DROP, set but never tested.") and c7b6ea24b43afb5749cb704e143df19d70e23dea ("[NETPOLL]: Don't need rx_flags."). The rx_flags did get tested for zero vs. non-zero and therefore we do need those tests and that code which sets NETPOLL_RX_DROP et al. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETPOLL]: Don't need rx_flags.Stephen Hemminger
The rx_flags variable is redundant. Turning rx on/off is done via setting the rx_np pointer. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETPOLL]: no need to store local_macStephen Hemminger
The local_mac is managed by the network device, no need to keep a spare copy and all the management problems that could cause. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] netconsole: Support dynamic reconfiguration using configfsSatyam Sharma
Based upon initial work by Keiichi Kii <k-keiichi@bx.jp.nec.com>. This patch introduces support for dynamic reconfiguration (adding, removing and/or modifying parameters of netconsole targets at runtime) using a userspace interface exported via configfs. Documentation is also updated accordingly. Issues and brief design overview: (1) Kernel-initiated creation / destruction of kernel objects is not possible with configfs -- the lifetimes of the "config items" is managed exclusively from userspace. But netconsole must support boot/module params too, and these are parsed in kernel and hence netpolls must be setup from the kernel. Joel Becker suggested to separately manage the lifetimes of the two kinds of netconsole_target objects -- those created via configfs mkdir(2) from userspace and those specified from the boot/module option string. This adds complexity and some redundancy here and also means that boot/module param-created targets are not exposed through the configfs namespace (and hence cannot be updated / destroyed dynamically). However, this saves us from locking / refcounting complexities that would need to be introduced in configfs to support kernel-initiated item creation / destroy there. (2) In configfs, item creation takes place in the call chain of the mkdir(2) syscall in the driver subsystem. If we used an ioctl(2) to create / destroy objects from userspace, the special userspace program is able to fill out the structure to be passed into the ioctl and hence specify attributes such as local interface that are required at the time we set up the netpoll. For configfs, this information is not available at the time of mkdir(2). So, we keep all newly-created targets (via configfs) disabled by default. The user is expected to set various attributes appropriately (including the local network interface if required) and then write(2) "1" to the "enabled" attribute. Thus, netpoll_setup() is then called on the set parameters in the context of _this_ write(2) on the "enabled" attribute itself. This design enables the user to reconfigure existing netconsole targets at runtime to be attached to newly-come-up interfaces that may not have existed when netconsole was loaded or when the targets were actually created. All this effectively enables us to get rid of custom ioctls. (3) Ultra-paranoid configfs attribute show() and store() operations, with sanity and input range checking, using only safe string primitives, and compliant with the recommendations in Documentation/filesystems/sysfs.txt. (4) A new function netpoll_print_options() is created in the netpoll API, that just prints out the configured parameters for a netpoll structure. netpoll_parse_options() is modified to use that and it is also exported to be used from netconsole. Signed-off-by: Satyam Sharma <satyam@infradead.org> Acked-by: Keiichi Kii <k-keiichi@bx.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-05WorkQueue: Fix up arch-specific work items where possibleDavid Howells
Fix up arch-specific work items where possible to use the new work_struct and delayed_work structs. Three places that enqueue bits of their stack and then return have been marked with #error as this is not permitted. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-02netpoll header cleanupStephen Hemminger
As Steve left netpoll beast, hopefully not to return soon. He noticed that the header was messy. He straightened it up and polished it a little, then waved goodbye. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-12-02netpoll queue cleanupStephen Hemminger
The beast had a long and not very happy history. At one point, a friend (netdump) had asked that he open up a little. Well, the friend was long gone now, and the beast had this dangling piece hanging (netpoll_queue). It wasn't hard to stitch the netpoll_queue back in where it belonged and make everything tidy. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-12-02netpoll retry cleanupStephen Hemminger
The netpoll beast was still not happy. If the beast got clogged pipes, it tended to stare blankly off in space for a long time. The problem couldn't be completely fixed because the beast talked with irq's disabled. But it could be made less painful and shorter. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-12-02netpoll per device txqStephen Hemminger
When the netpoll beast got really busy, it tended to clog things, so it stored them for later. But the beast was putting all it's skb's in one basket. This was bad because maybe some pipes were clogged and others were not. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-12-02netpoll info leakStephen Hemminger
After looking harder, Steve noticed that the netpoll beast leaked a little every time it shutdown for a nap. Not a big leak, but a nuisance kind of thing. He took out his refcount duct tape and patched the leak. It was overkill since there was already other locking in that area, but it looked clean and wouldn't attract fleas. Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-06-26[NET] netpoll: break recursive loop in netpoll rx pathNeil Horman
The netpoll system currently has a rx to tx path via: netpoll_rx __netpoll_rx arp_reply netpoll_send_skb dev->hard_start_tx This rx->tx loop places network drivers at risk of inadvertently causing a deadlock or BUG halt by recursively trying to acquire a spinlock that is used in both their rx and tx paths (this problem was origionally reported to me in the 3c59x driver, which shares a spinlock between the boomerang_interrupt and boomerang_start_xmit routines). This patch breaks this loop, by queueing arp frames, so that they can be responded to after all receive operations have been completed. Tested by myself and the reported with successful results. Specifically it was tested with netdump. Heres the BZ with details: https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=194055 Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-12[NETPOLL]: wrong return for null netpoll_poll_lock()Ben Dooks
When netpoll is not being used, the macro that defines the removed routing netpoll_poll_lock defines the return as zero, but the real routine returns a `void *` Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-11[NETPOLL]: fix initialization/NAPI raceMatt Mackall
This fixes a race during initialization with the NAPI softirq processing by using an RCU approach. This race was discovered when refill_skbs() was added to the setup code. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-11[NETPOLL]: add retry timeoutMatt Mackall
Add limited retry logic to netpoll_send_skb Each time we attempt to send, decrement our per-device retry counter. On every successful send, we reset the counter. We delay 50us between attempts with up to 20000 retries for a total of 1 second. After we've exhausted our retries, subsequent failed attempts will try only once until reset by success. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[NETPOLL]: allow multiple netpoll_clients to register against one interfaceJeff Moyer
This patch provides support for registering multiple netpoll clients to the same network device. Only one of these clients may register an rx_hook, however. In practice, this restriction has not been problematic. It is worth mentioning, though, that the current design can be easily extended to allow for the registration of multiple rx_hooks. The basic idea of the patch is that the rx_np pointer in the netpoll_info structure points to the struct netpoll that has rx_hook filled in. Aside from this one case, there is no need for a pointer from the struct net_device to an individual struct netpoll. A lock is introduced to protect the setting and clearing of the np_rx pointer. The pointer will only be cleared upon netpoll client module removal, and the lock should be uncontested. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
