path: root/include/linux/nfs.h
2014-05-29pnfs: support multiple verfs per direct reqWeston Andros Adamson
Support direct requests that span multiple pnfs data servers by comparing nfs_pgio_header->verf to a cached verf in pnfs_commit_bucket. Continue to use dreq->verf if the MDS is used / non-pNFS. Signed-off-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-01-31SUNRPC: handle RPC client pipefs dentries by network namespace aware routinesStanislav Kinsbursky
v2: 1) "Over-put" of PipeFS mount point fixed. Fix is ugly, but allows to bisect the patch set. And it will be removed later in the series. This patch makes RPC clients PipeFs dentries allocations in it's owner network namespace context. RPC client pipefs dentries creation logic has been changed: 1) Pipefs dentries creation by sb was moved to separated function, which will be used for handling PipeFS mount notification. 2) Initial value of RPC client PipeFS dir dentry is set no NULL now. RPC client pipefs dentries cleanup logic has been changed: 1) Cleanup is done now in separated rpc_remove_pipedir() function, which takes care about pipefs superblock locking. Also this patch removes slashes from cb_program.pipe_dir_name and from NFS_PIPE_DIRNAME to make rpc_d_lookup_sb() work. This doesn't affect vfs_path_lookup() results in nfs4blocklayout_init() since this slash is cutted off anyway in link_path_walk(). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-31pnfsblock: add device operationsJim Rees
Signed-off-by: Jim Rees <rees@umich.edu> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> [upcall bugfixes] Signed-off-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Clean up MNT program definitionsChuck Lever
Clean up: Relocate MNT program procedure number definitions to the only file that uses them. Relocate the version number definitions, which are shared, to nfs.h. Remove duplicate program number definitions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-03nfsd41: define nfs41 error codesMarc Eshel
Define all error code present in http://tools.ietf.org/html/draft-ietf-nfsv4-minorversion1-29. Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: clean up error code definitions] [nfsd41: change NFSERR_REPLAY_ME] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2006-04-25Don't include private headers from user-visible parts of include/linux/nfs*.hDavid Woodhouse
