path: root/include/linux/nfs_iostat.h
2012-02-16SUNRPC: add sending,pending queue and max slot to xprt statsAndy Adamson
With static RPC slots, the xprt backlog queue stats were useful in showing when the transport (TCP) was starved by lack of RPC slots. The new dynamic RPC slot code, commit d9ba131d8f58c0d2ff5029e7002ab43f913b36f9, always provides an RPC slot and so only uses the xprt backlog queue when the tcp_max_slot_table_entries value has been hit or when an allocation error occurs. All requests are now placed on the xprt sending or pending queue which need to be monitored for debugging. The max_slot stat shows the maximum number of dynamic RPC slots reached which is useful when debugging performance issues. Add the new fields at the end of the mountstats xprt stanza so that mountstats outputs the previous correct values and ignores the new fields. Bump NFS_IOSTATS_VERS. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: implement generic pnfs layer write switchAndy Adamson
Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: generic readAndy Adamson
Separate the rpc run portion of nfs_read_rpcsetup into a new function nfs_initiate_read that is called for normal NFS I/O. Add a pNFS read_pagelist function that is called instead of nfs_intitate_read for pNFS reads. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Fred Isaman <iisaman@citi.umich.edu> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-03NFS: Add some new I/O counters for FS-Cache doing things for NFSDavid Howells
Add some new NFS I/O counters for FS-Cache doing things for NFS. A new line is emitted into /proc/pid/mountstats if caching is enabled that looks like: fsc: <rok> <rfl> <wok> <wfl> <unc> Where <rok> is the number of pages read successfully from the cache, <rfl> is the number of failed page reads against the cache, <wok> is the number of successful page writes to the cache, <wfl> is the number of failed page writes to the cache, and <unc> is the number of NFS pages that have been disconnected from the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2008-07-09NFS: Move fs/nfs/iostat.h to include/linuxChuck Lever
The fs/nfs/iostat.h header has definitions that were designed to be exposed to user space. Move these definitions under include/linux so user space can use the definitions in applications that read /proc/self/mountstats. Also address a handful of coding style issues called out by checkpatch.pl in fs/nfs/iostat.h. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
