path: root/include/linux/nl80211.h
2011-03-01cfg80211: add a field for the bitrate of the last rx data packet from a stationFelix Fietkau
Also fix a typo in the STATION_INFO_TX_BITRATE description Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-10nl80211: add/fix mesh docsJohannes Berg
Some mesh attribute/command docs are missing or have errors in the name so they don't match, fix all of them. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20nl80211: Export available antennasBruno Randolf
Export the information which antennas are available for configuration as TX or RX antennas via nl80211. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: Let userspace enable and configure vendor specific path selection.Javier Cardona
Userspace will now be allowed to toggle between the default path selection algorithm (HWMP, implemented in the kernel), and a vendor specific alternative. Also in the same patch, allow userspace to add information elements to mesh beacons. This is accordance with the Extensible Path Selection Framework specified in version 7.0 of the 802.11s draft. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-20mac80211: Rename mesh_params to mesh_config to prepare for mesh_setupJavier Cardona
Mesh parameters can be to setup a mesh or to configure it. This patch renames the ambiguous name mesh_params to mesh_config in preparation for mesh_setup. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-16nl80211: Add notification for dropped Deauth/DisassocJouni Malinen
Add a new notification to indicate that a received, unprotected Deauthentication or Disassociation frame was dropped due to management frame protection being in use. This notification is needed to allow user space (e.g., wpa_supplicant) to implement SA Query procedure to recover from association state mismatch between an AP and STA. This is needed to avoid getting stuck in non-working state when MFP (IEEE 802.11w) is used and a protected Deauthentication or Disassociation frame is dropped for any reason. After that, the station would silently discard any unprotected Deauthentication or Disassociation frame that could be indicating that the AP does not have association for the STA (when the Reason Code would be 6 or 7). IEEE Std 802.11w-2009, 11.13 describes this recovery mechanism. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-15nl80211: advertise maximum remain-on-channel durationJohannes Berg
With the upcoming hardware offload implementation, some devices will have a different maximum duration for the remain-on-channel command. Advertise the maximum duration in mac80211, and make mac80211 set it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-13cfg80211/nl80211: separate unicast/multicast default TX keysJohannes Berg
Allow userspace to specify that a given key is default only for unicast and/or multicast transmissions. Only WEP keys are for both, WPA/RSN keys set here are GTKs for multicast only. For more future flexibility, allow to specify all combiations. Wireless extensions can only set both so use nl80211; WEP keys (connect keys) must be set as default for both (but 802.1X WEP is still possible). Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-08cfg80211: Add new BSS attribute ht_opmodeHelmut Schaa
Add a new BSS attribute to allow hostapd to set the current HT opmode. Otherwise drivers won't be able to set up protection for HT rates in AP mode. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-07nl80211/mac80211: Report signal averageBruno Randolf
Extend nl80211 to report an exponential weighted moving average (EWMA) of the signal value. Since the signal value usually fluctuates between different packets, an average can be more useful than the value of the last packet. This uses the recently added generic EWMA library function. -- v2: fix ABI breakage and change factor to be a power of 2. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-06cfg80211/mac80211: add mesh join/leave commandsJohannes Berg
Instead of tying mesh activity to interface up, add join and leave commands for mesh. Since we must be backward compatible, let cfg80211 handle joining a mesh if a mesh ID was pre-configured when the device goes up. Note that this therefore must modify mac80211 as well since mac80211 needs to lose the logic to start the mesh on interface up. We now allow querying mesh parameters before the mesh is connected, which simply returns defaults. Setting them (internally renamed to "update") is only allowed while connected. Specify them with the new mesh join command instead where needed. In mac80211, beaconing must now also follow the mesh enabled/not enabled state, which is done by testing the mesh ID. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-06nl80211/mac80211: define and allow configuring mesh element TTLJavier Cardona
The TTL in path selection information elements is different from the mesh ttl used in mesh data frames. Version 7.03 of the 11s draft calls this ttl 'Element TTL'. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-29nl80211/cfg80211: extend mgmt-tx API for off-channelJohannes Berg
With p2p, it is sometimes necessary to transmit a frame (typically an action frame) on another channel than the current channel. Enable this through the CMD_FRAME API, and allow it to wait for a response. A new command allows that wait to be aborted. However, allow userspace to specify whether or not it wants to allow off-channel TX, it may actually want to use the same channel only. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24cfg80211: allow using CQM event to notify packet lossJohannes Berg
This adds the ability for drivers to use CQM events to notify about packet loss for specific stations (which could be the AP for the managed mode case). Since the threshold might be determined by the driver (it isn't passed in right now) it will be passed out of the driver to userspace in the event. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24Revert "nl80211/mac80211: Report signal average"John W. Linville
This reverts commit 86107fd170bc379869250eb7e1bd393a3a70e8ae. This patch inadvertantly changed the userland ABI. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-18nl80211/mac80211: Report signal averageBruno Randolf
Extend nl80211 to report an exponential weighted moving average (EWMA) of the signal value. Since the signal value usually fluctuates between different packets, an average can be more useful than the value of the last packet. This uses the recently added generic EWMA library function. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16cfg80211: add support for setting the ad-hoc multicast rateFelix Fietkau
2010-11-16cfg80211: Add nl80211 antenna configurationBruno Randolf
Allow setting of TX and RX antennas configuration via nl80211. The antenna configuration is defined as a bitmap of allowed antennas to use. This API can be used to mask out antennas which are not attached or should not be used for other reasons like regulatory concerns or special setups. Separate bitmaps are used for RX and TX to allow configuring different antennas for receiving and transmitting. Each bitmap is 32 bit long, each bit representing one antenna, starting with antenna 1 at the first bit. If an antenna bit is set, this means the driver is allowed to use this antenna for RX or TX respectively; if the bit is not set the hardware is not allowed to use this antenna. Using bitmaps has the benefit of allowing for a flexible configuration interface which can support many different configurations and which can be used for 802.11n as well as non-802.11n devices. Instead of relying on some hardware specific assumptions, drivers can use this information to know which antennas are actually attached to the system and derive their capabilities based on that. 802.11n devices should enable or disable chains, based on which antennas are present (If all antennas belonging to a particular chain are disabled, the entire chain should be disabled). HT capabilities (like STBC, TX Beamforming, Antenna selection) should be calculated based on the available chains after applying the antenna masks. Should a 802.11n device have diversity antennas attached to one of their chains, diversity can be enabled or disabled based on the antenna information. Non-802.11n drivers can use the antenna masks to select RX and TX antennas and to enable or disable antenna diversity. While covering chainmasks for 802.11n and the standard "legacy" modes "fixed antenna 1", "fixed antenna 2" and "diversity" this API also allows more rare, but useful configurations as follows: 1) Send on antenna 1, receive on antenna 2 (or vice versa). This can be used to have a low gain antenna for TX in order to keep within the regulatory constraints and a high gain antenna for RX in order to receive weaker signals ("speak softly, but listen harder"). This can be useful for building long-shot outdoor links. Another usage of this setup is having a low-noise pre-amplifier on antenna 1 and a power amplifier on the other antenna. This way transmit noise is mostly kept out of the low noise receive channel. (This would be bitmaps: tx 1 rx 2). 2) Another similar setup is: Use RX diversity on both antennas, but always send on antenna 1. Again that would allow us to benefit from a higher gain RX antenna, while staying within the legal limits. (This would be: tx 0 rx 3). 3) And finally there can be special experimental setups in research and development even with pre 802.11n hardware where more than 2 antennas are available. It's good to keep the API simple, yet flexible. Signed-off-by: Bruno Randolf <br1@einfach.org> -- v7: Made bitmasks 32 bit wide and rebased to latest wireless-testing. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: fix disabling channels based on hintsLuis R. Rodriguez
After a module loads you will have loaded the world roaming regulatory domain or a custom regulatory domain. Further regulatory hints are welcomed and should be respected unless the regulatory hint is coming from a country IE as the IEEE spec allows for a country IE to be a subset of what is allowed by the local regulatory agencies. So disable all channels that do not fit a regulatory domain sent from a unless the hint is from a country IE and the country IE had no information about the band we are currently processing. This fixes a few regulatory issues, for example for drivers that depend on CRDA and had no 5 GHz freqencies allowed were not properly disabling 5 GHz at all, furthermore it also allows users to restrict devices further as was intended. If you recieve a country IE upon association we will also disable the channels that are not allowed if the country IE had at least one channel on the respective band we are procesing. This was the original intention behind this design but it was completely overlooked... Cc: David Quan <david.quan@atheros.com> Cc: Jouni Malinen <jouni.malinen@atheros.com> cc: Easwar Krishnan <easwar.krishnan@atheros.com> Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-11cfg80211: add channel utilization stats to the survey commandFelix Fietkau
Using these, user space can calculate a relative channel utilization with arbitrary intervals by regularly taking snapshots of the survey results. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06nl80211/mac80211: Add retry and failed transmission count to station infoBruno Randolf
This information is already available in mac80211, we just need to export it via cfg80211 and nl80211. Signed-off-by: Bruno Randolf <br1@einfach.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06cfg80211/mac80211: allow per-station GTKsJohannes Berg
This adds API to allow adding per-station GTKs, updates mac80211 to support it, and also allows drivers to remove a key from hwaccel again when this may be necessary due to multiple GTKs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05nl80211: fix remain-on-channel documentationJohannes Berg
The documentation for NL80211_CMD_REMAIN_ON_CHANNEL isn't accurate, an interface index is required by the command. Update it accordingly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05cfg80211: patches to allow setting the WDS peerBill Jordan
Added a nl interface to set the peer bssid of a WDS interface. Signed-off-by: Bill Jordan <bjordan@rajant.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05nl80211: allow drivers to indicate whether the survey data channel is in useFelix Fietkau
Some user space applications only want to display survey data for the operating channel, however there is no API to get that yet. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-16cfg80211/nl80211: introduce p2p device typesJohannes Berg
This adds P2P-STA and P2P-GO as device types so we can distinguish between those and normal STA or AP (respectively) type interfaces. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-27cfg80211: allow changing port control protocolJohannes Berg
Some vendor specified mechanisms for 802.1X-style functionality use a different protocol than EAP (even if EAP is vendor-extensible). Allow setting the ethertype for the protocol when a driver has support for this. The default if unspecified is EAP, of course. Note: This is suitable only for station mode, not for AP implementation. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-24nl80211: some documentation fixesJohannes Berg
The nl80211 documentation is currently never generated, so problems have accumulated. Fix most of the trivial ones. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-24cfg80211/mac80211: extensible frame processingJohannes Berg
Allow userspace to register for more than just action frames by giving the frame subtype, and make it possible to use this in various modes as well. With some tweaks and some added functionality this will, in the future, also be usable in AP mode and be able to replace the cooked monitor interface currently used in that case. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-24nl80211: Add option to adjust transmit powerJuuso Oikarinen
This patch adds transmit power setting type and transmit power level attributes to NL80211_CMD_SET_WIPHY in order to facilitate adjusting of the transmit power level of the device. The added attributes allow selection of automatic, limited or fixed transmit power level, with the level definable in signed mBm format. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-24cfg80211/mac80211: Update set_tx_power to use mBm instead of dBm unitsJuuso Oikarinen
In preparation for a TX power setting interface in the nl80211, change the .set_tx_power function to use mBm units instead of dBm for greater accuracy and smaller power levels. Also, already in advance move the tx_power_setting enumeration to nl80211. This change affects the .tx_set_power function prototype. As a result, the corresponding changes are needed to modules using it. These are mac80211, iwmc3200wifi and rndis_wlan. Cc: Samuel Ortiz <samuel.ortiz@intel.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Acked-by: Samuel Ortiz <samuel.ortiz@intel.com> Acked-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-02wireless: fix several minor description typosWalter Goldens
Signed-off-by: Walter Goldens <goldenstranger@yahoo.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-07cfg80211/mac80211: better channel handlingJohannes Berg
Currently (all tested with hwsim) you can do stupid things like setting up an AP on a certain channel, then adding another virtual interface and making that associate on another channel -- this will make the beaconing to move channel but obviously without the necessary IEs data update. In order to improve this situation, first make the configuration APIs (cfg80211 and nl80211) aware of multi-channel operation -- we'll eventually need that in the future anyway. There's one userland API change and one API addition. The API change is that now SET_WIPHY must be called with virtual interface index rather than only wiphy index in order to take effect for that interface -- luckily all current users (hostapd) do that. For monitor interfaces, the old setting is preserved, but monitors are always slaved to other devices anyway so no guarantees. The second userland API change is the introduction of a per virtual interface SET_CHANNEL command, that hostapd should use going forward to make it easier to understand what's going on (it can automatically detect a kernel with this command). Other than mac80211, no existing cfg80211 drivers are affected by this change because they only allow a single virtual interface. mac80211, however, now needs to be aware that the channel settings are per interface now, and needs to disallow (for now) real multi-channel operation, which is another important part of this patch. One of the immediate benefits is that you can now start hostapd to operate on a hardware that already has a connection on another virtual interface, as long as you specify the same channel. Note that two things are left unhandled (this is an improvement -- not a complete fix): * different HT/no-HT modes currently you could start an HT AP and then connect to a non-HT network on the same channel which would configure the hardware for no HT; that can be fixed fairly easily * CSA An AP we're connected to on a virtual interface might indicate switching channels, and in that case we would follow it, regardless of how many other interfaces are operating; this requires more effort to fix but is pretty rare after all Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-27cfg80211: add ap isolation supportFelix Fietkau
This is used to configure APs to not bridge traffic between connected stations. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-07cfg80211: Add local-state-change-only auth/deauth/disassocJouni Malinen
cfg80211 is quite strict on allowing authentication and association commands only in certain states. In order to meet these requirements, user space applications may need to clear authentication or association state in some cases. Currently, this can be done with deauth/disassoc command, but that ends up sending out Deauthentication or Disassociation frame unnecessarily. Add a new nl80211 attribute to allow this sending of the frame be skipped, but with all other deauth/disassoc operations being completed. Similar state change is also needed for IEEE 802.11r FT protocol in the FT-over-DS case which does not use Authentication frame exchange in a transition to another BSS. For this to work with cfg80211, an authentication entry needs to be created for the target BSS without sending out an Authentication frame. The nl80211 authentication command can be used for this purpose, too, with the new attribute to indicate that the command is only for changing local state. This enables wpa_supplicant to complete FT-over-DS transition successfully. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-24cfg80211: Improve connection quality maintenance docs in nl80211.hJuuso Oikarinen
In nl80211.h, be a little more elaborate in the docs for the definitions NL80211_ATTR_CQM_RSSI_THOLD and NL80211_ATTR_CQM_RSSI_HYST. Reported-by: Luis R. Rodriguez <mcgrof@gmail.com> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-24cfg80211: Add connection quality monitoring support to nl80211Juuso Oikarinen
Add support for basic configuration of a connection quality monitoring to the nl80211 interface, and basic support for notifying about triggered monitoring events. Via this interface a user-space connection manager may configure and receive pre-warning events of deteriorating WLAN connection quality, and start preparing for roaming in advance, before the connection is already lost. An example usage of such a trigger is starting scanning for nearby AP's in an attempt to find one with better connection quality, and associate to it before the connection characteristics of the existing connection become too bad or the association is even lost, leading in a prolonged delay in connectivity. The interface currently supports only RSSI, but it could be later extended to include other parameters, such as signal-to-noise ratio, if need for that arises. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-19nl80211: add power save commandsKalle Valo
The most needed command from nl80211, which Wireless Extensions had, is support for power save mode. Add a simple command to make it possible to enable and disable power save via nl80211. I was also planning about extending the interface, for example adding the timeout value, but after thinking more about this I decided not to do it. Basically there were three reasons: Firstly, the parameters for power save are very much hardware dependent. Trying to find a unified interface which would work with all hardware, and still make sense to users, will be very difficult. Secondly, IEEE 802.11 power save implementation in Linux is still in state of flux. We have a long way to still to go and there is no way to predict what kind of implementation we will have after few years. And because we need to support nl80211 interface a long time, practically forever, adding now parameters to nl80211 might create maintenance problems later on. Third issue are the users. Power save parameters are mostly used for debugging, so debugfs is better, more flexible, interface for this. For example, wpa_supplicant currently doesn't configure anything related to power save mode. It's better to strive that kernel can automatically optimise the power save parameters, like with help of pm qos network and other traffic parameters. Later on, when we have better understanding of power save, we can extend this command with more features, if there's a need for that. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-15cfg80211/mac80211: allow registering for and sending action framesJouni Malinen
This implements a new command to register for action frames that userspace wants to handle instead of the in-kernel rejection. It is then responsible for rejecting ones that it decided not to handle. There is no unregistration, but the socket can be closed for that. Frames that are not registered for will not be forwarded to userspace and will be rejected by the kernel, the cfg80211 API helps implementing that. Additionally, this patch adds a new command that allows doing action frame transmission from userspace. It can be used either to exchange action frames on the current operational channel (e.g., with the AP with which we are currently associated) or to exchange off-channel Public Action frames with the remain-on-channel command. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12cfg80211: Store IEs from both Beacon and Probe Response framesJouni Malinen
Store information elements from Beacon and Probe Response frames in separate buffers to allow both sets to be made available through nl80211. This allows user space applications to get access to IEs from Beacon frames even if we have received Probe Response frames from the BSS. Previously, the IEs from Probe Response frames would have overridden the IEs from Beacon frames. This feature is of somewhat limited use since most protocols include the same (or extended) information in Probe Response frames. However, there are couple of exceptions where the IEs from Beacon frames could be of some use: TIM IE is only included in Beacon frames (and it would be needed to figure out the DTIM period used in the BSS) and at least some implementations of Wireless Provisioning Services seem to include the full IE only in Beacon frames). The new BSS attribute for scan results is added to allow both the IE sets to be delivered. This is done in a way that maintains the previously used behavior for applications that are not aware of the new NL80211_BSS_BEACON_IES attribute. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12nl80211: New command for setting TX rate mask for rate controlJouni Malinen
Add a new NL80211_CMD_SET_TX_BITRATE_MASK command and related attributes to provide support for setting TX rate mask for rate control. This uses the existing cfg80211 set_bitrate_mask operation that was previously used only with WEXT compat code (SIOCSIWRATE). The nl80211 command allows more generic configuration of allowed rates as a mask instead of fixed/max rate. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12nl80211: Add new WIPHY attribute COVERAGE_CLASSLukáš Turek
The new attribute NL80211_ATTR_WIPHY_COVERAGE_CLASS sets IEEE 802.11 Coverage Class, which depends on maximum distance of nodes in a wireless network. It's required for long distance links (more than a few hundred meters). The attribute is now ignored by two non-mac80211 drivers, rndis and iwmc3200wifi, together with WIPHY_PARAM_RETRY_SHORT and WIPHY_PARAM_RETRY_LONG. If it turns out to be a problem, we could split set_wiphy_params callback or add new capability bits. Signed-off-by: Lukas Turek <8an@praha12.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: add remain-on-channel commandJouni Malinen
Add new commands for requesting the driver to remain awake on a specified channel for the specified amount of time (and another command to cancel such an operation). This can be used to implement userspace-controlled off-channel operations, like Public Action frame exchange on another channel than the operation channel. The off-channel operation should behave similarly to scan, i.e. the local station (if associated) moves into power save mode to request the AP to buffer frames for it and then moves to the other channel to allow the off-channel operation to be completed. The duration parameter can be used to request enough time to receive a response from the target station. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-28nl80211: PMKSA caching supportSamuel Ortiz
This is an interface to set, delete and flush PMKIDs through nl80211. Main users would be fullmac devices which firmwares are capable of generating the RSN IEs for the re-association requests, e.g. iwmc3200wifi. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13cfg80211: return channel noise via survey APIHolger Schurig
This patch implements the NL80211_CMD_GET_SURVEY command and an get_survey() ops that a driver can implement. The goal of this command is to allow a drivers to report channel survey data (e.g. channel noise, channel occupation). For now, only the mechanism to report back channel noise has been implemented. In future, there will either be a survey-trigger command --- or the existing scan-trigger command will be enhanced. This will allow user-space to request survey for arbitrary channels. Note: any driver that cannot report channel noise should not report any value at all, e.g. made-up -92 dBm. Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: add nl80211/cfg80211 handling of the new mesh root mode option.Rui Paulo
Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: replace "destination" with "target" to follow the specRui Paulo
Resulting object files have the same MD5 as before. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11nl80211: add a parameter for using 4-address frames on virtual interfacesFelix Fietkau
2009-10-07nl80211: report age of scan resultsHolger Schurig
Linux keeps scan results up to 15 seconds. This can be a problem for fast moving clients: they get back stale data. But if the kernel reports the age of the BSS items, then user-space can simply weed out old entries by itself. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14nl80211: add generation number to all dumpsJohannes Berg
In order for userspace to be able to figure out whether it obtained a consistent snapshot of data or not when using netlink dumps, we need to have a generation number in each dump message that indicates whether the list has changed or not -- its value is arbitrary. This patch adds such a number to all dumps, this needs some mac80211 involvement to keep track of a generation number to start with when adding/removing mesh paths or stations. The wiphy and netdev lists can be fully handled within cfg80211, of course, but generation numbers need to be stored there as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
