path: root/include/linux/nl802154.h
2014-10-25ieee802154: mac802154: remove FSF addressAlexander Aring
This patch removes the FSF address in files which belongs to ieee802154 and mac802154. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Cc: Alan Ott <alan@signal11.us> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-05-16ieee802154: add netlink interfaces for llsecPhoebe Buckheister
This patch adds user-visible interfaces for the llsec infrastructure. For the added methods, the only major difference between all add/remove implementation lies in how the specific object is parsed, and for dump requests, how objects are written into netlink messages. To save on boilerplate code, table dumps are routed through a helper function that handles netlink dump state, leaving the actual dumping code to care only about iterating over the table to be dumped and filling netlink messages. For add/remove methods, the boilerplate required to work is not quite as large, but still enough to also move into a local helper. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-01mac802154: make csma/cca parameters per-wpanPhoebe Buckheister
Commit 9b2777d6089bcd (ieee802154: add TX power control to wpan_phy) and following erroneously added CSMA and CCA parameters for 802.15.4 devices as PHY parameters, while they are actually MAC parameters and can differ for any two WPAN instances. Since it is now sensible to have multiple WPAN devices with differing CSMA/CCA parameters, make these parameters MAC parameters instead. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17ieee802154: add netlink APIs for smartMAC configurationPhoebe Buckheister
Introduce new netlink attributes for SET_PHY_ATTRS: * CSMA minimal backoff exponent * CSMA maximal backoff exponent * CSMA retry limit * frame retransmission limit The CSMA attributes shall correspond to minBE, maxBE and maxCSMABackoffs of 802.15.4, respectively. The frame retransmission shall correspond to maxFrameRetries of 802.15.4, unless given as -1: then the old behaviour of the stack shall apply. For RF2xy, the old behaviour is to not do channel sensing at all and simply send *right now*, which is not intended behaviour for most applications and actually prohibited for some channel/page combinations. For all values except frame retransmission limit, the defaults of 802.15.4 apply. Frame retransmission limits are set to -1 to indicate backward-compatible behaviour. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17ieee802154: add support for setting CCA energy detection levelsPhoebe Buckheister
Since three of the four clear channel assesment modes make use of energy detection, provide an API to set the energy detection threshold. Driver support for this is available in at86rf230 for the RF212 chips. Since for these chips the minimal energy detection threshold depends on page and channel used, add a field to struct at86rf230_local that stores the minimal threshold. Actual ED thresholds are configured as offsets from this value. For RF212, setting the ED threshold will not work before a channel/page has been set due to the dependency of energy detection in the chip and the actual channel/page selected. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17ieee802154: add support for CCA mode in wpan physPhoebe Buckheister
The standard describes four modes of clear channel assesment: "energy above threshold", "carrier found", and the logical and/or of these two. Support for CCA mode setting is included in the at86rf230 driver, predicated for RF212 chips. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17ieee802154: add support for listen-before-talk in wpan_phyPhoebe Buckheister
Listen-before-talk is an alternative to CSMA in uncoordinated networks and prescribed by european regulations if one wants to have a device with radio duty cycles above 10% (or less in some bands). Add a phy property to enable/disable LBT in the phy, including support in the at86rf230 driver for RF212 chips. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17ieee802154: add TX power control to wpan_phyPhoebe Buckheister
Replace the current u8 transmit_power in wpan_phy with s8 transmit_power. The u8 field contained the actual tx power and a tolerance field, which no physical radio every used. Adjust sysfs entries to keep compatibility with userspace, give tolerances of +-1dB statically there. This patch only adds support for this in the at86rf230 driver and the RF212 chip. Configuration calculation for RF212 is also somewhat basic, but does the job - the RF212 datasheet gives a large table with suggested values for combinations of TX power and page/channel, if this does not work well, we might have to copy the whole table. Signed-off-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26mac802154: add wpan device-class supportalex.bluesman.smirnov@gmail.com
Every real 802.15.4 transceiver, which works with software MAC layer, can be classified as a wpan device in this stack. So the wpan device implementation provides missing link in datapath between the device drivers and the Linux network queue. According to the IEEE 802.15.4 standard each packet can be one of the following types: - beacon - MAC layer command - ACK - data This patch adds support for the data packet-type only, but this is enough to perform data transmission and receiving over radio. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16mac802154: monitor device supportalex.bluesman.smirnov@gmail.com
Support for monitor device intended to capture all the network activity. This interface could be used by networks sniffers and is already supported by WireShark. That's a good test point to check that basic MAC support works. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16ieee802154: interface type to be addedalex.bluesman.smirnov@gmail.com
This stack implementation distinguishes several types of slave interfaces. Another parameter to 'add_iface_' function is added to clarify the interface type is going to be registered. Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06ieee802154: add support for creation/removal of logic interfacesDmitry Eremin-Solenikov
Add support for two more NL802154 commands: ADD_IFACE and DEL_IFACE, thus allowing creation and removal of logic WPAN interfaces on the top of wpan-phy. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-11-06ieee802154: add LIST_PHY command supportDmitry Eremin-Solenikov
Add nl802154 command to get information about PHY's present in the system. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-19ieee802154: add support for channel pages from IEEE 802.15.4-2006Dmitry Eremin-Solenikov
IEEE 802.15.4-2006 adds new concept: channel pages, which can contain several channels. Add support for channel pages in the API and in the fakehard driver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-12nl802154: add support for dumping WPAN interface informationDmitry Baryshkov
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12nl802154: make ieee802154_policy constantDmitry Baryshkov
2009-06-09net: add NL802154 interface for configuration of 802.15.4 devicesSergey Lapin
Add a netlink interface for configuration of IEEE 802.15.4 device. Also this interface specifies events notification sent by devices towards higher layers. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
