path: root/include/linux/nls.h
2009-06-15NLS: update handling of UnicodeAlan Stern
This patch (as1239) updates the kernel's treatment of Unicode. The character-set conversion routines are well behind the current state of the Unicode specification: They don't recognize the existence of code points beyond plane 0 or of surrogate pairs in the UTF-16 encoding. The old wchar_t 16-bit type is retained because it's still used in lots of places. This shouldn't cause any new problems; if a conversion now results in an invalid 16-bit code then before it must have yielded an undefined code. Difficult-to-read names like "utf_mbstowcs" are replaced with more transparent names like "utf8s_to_utf16s" and the ordering of the parameters is rationalized (buffer lengths come immediate after the pointers they refer to, and the inputs precede the outputs). Fortunately the low-level conversion routines are used in only a few places; the interfaces to the higher-level uni2char and char2uni methods have been left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-30nls: add a nls_nullsize inlineJeff Layton
It's possible for character sets to require a multi-byte null string terminator. Add a helper function that determines the size of the null terminator at runtime. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-17add consts where appropriate in fs/nls/*Denys Vlasenko
Add const modifiers to a few struct nls_table's member pointers in include/linux/nls.h and adds a lot of const's in fs/nls/*.c files. Resulting changes as visible by size: text data bss dec hex filename 113612 481216 2368 597196 91ccc nls.org/built-in.o 593548 3296 288 597132 91c8c nls/built-in.o Apparently compiler managed to optimize code a bit better because of const-ness. No other changes are made. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
