path: root/include/linux/of.h
2012-03-28Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull a few more things for powerpc by Benjamin Herrenschmidt: - Anton's did some recent improvements to EPOW event reporting on pSeries (power supply failures and such). The patches are self contained enough and replace really nasty code so I felt it should still go in - I did the vio driver registration change Greg requested, I don't see the point of leaving that til the next merge window - The remaining EEH changes I said were still pending to get rid of the EEH references from the generic struct device_node - A few more iSeries removal bits - A perf bug fix on 970 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/perf: Fix instruction address sampling on 970 and Power4 powerpc+sparc/vio: Modernize driver registration powerpc: Random little legacy iSeries removal tidy ups powerpc: Remove NO_IRQ_IGNORE powerpc/pseries: Cut down on enthusiastic use of defines in RAS code powerpc/pseries: Clean up ras_error_interrupt code powerpc/pseries: Remove RTAS_POWERMGM_EVENTS powerpc/pseries: Use rtas_get_sensor in RAS code powerpc/pseries: Parse and handle EPOW interrupts powerpc: Make function that parses RTAS error logs global powerpc/eeh: Retrieve PHB from global list powerpc/eeh: Remove eeh information from pci_dn powerpc/eeh: Remove eeh device from OF node
2012-03-28Merge tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More device tree support updates" from Olof Johansson: "This branch contains a number of updates for device tree support on several ARM platforms, in particular: * AT91 continues the device tree conversion adding support for a number of on-chip drivers and other functionality * ux500 adds probing of some of the core SoC blocks through device tree * Initial device tree support for ST SPEAr600 platforms * kirkwood continues the conversion to device-tree probing" Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and drivers/usb/gadget/at91_udc.c due to header file include cleanups. Also do an "evil merge" for the MACH_U8500 config option rename that the affected RMI4 touchscreen driver in staging. It's called MACH_MOP500 now, and it was missed during previous merges. * tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: SPEAr600: Add device-tree support to SPEAr600 boards ARM: ux500: Provide local timer support for Device Tree ARM: ux500: Enable PL022 SSP Controller in Device Tree ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree ARM: ux500: db8500: list most devices in the snowball device tree ARM: ux500: split dts file for snowball into generic part ARM: ux500: combine the board init functions for DT boot ARM: ux500: Initial Device Tree support for Snowball ARM: ux500: CONFIG: Enable Device Tree support for future endeavours ARM: kirkwood: use devicetree for rtc-mv ARM: kirkwood: rtc-mv devicetree bindings ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0 ARM: kirkwood: fdt: facilitate new boards during fdt migration ARM: kirkwood: fdt: absorb kirkwood_init() ARM: kirkwood: fdt: use mrvl ticker symbol ARM: orion: wdt: use resource vice direct access ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data. ARM: orion: spi: remove enable_clock_fix which is not used ...
2012-03-28powerpc/eeh: Remove eeh device from OF nodeGavin Shan
Originally, the PCI sensitive OF node is tracing the eeh device through struct device_node->edev. However, it was regarded as bad idea. The patch removes struct device_node->edev and uses PCI_DN to trace the corresponding eeh device according to BenH's comments. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-21Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull core device tree changes for Linux v3.4 from Grant Likely: "This branch contains a minor documentation addition, a utility function for parsing string properties needed by some of the new ARM platforms, disables dynamic DT code that isn't used anywhere but on a few PPC machines, and exports DT node compatible data to userspace via UEVENT properties. Nothing earth shattering here." * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6: of: Only compile OF_DYNAMIC on PowerPC pseries and iseries arm/dts: OMAP3: Add omap3evm and am335xevm support drivercore: Output common devicetree information in uevent of: Add of_property_match_string() to find index into a string list
2012-03-16Merge branch 'spear/dt' into next/dt2Arnd Bergmann
* spear/dt: ARM: SPEAr600: Add device-tree support to SPEAr600 boards (update to v3.3-rc7) Conflicts: arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-vexpress/Kconfig The conflicts are between the previous contents of the next/dt2 branch and upstream changes from v3.3-rc7. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-15of: introduce helper to manage booleanJean-Christophe PLAGNIOL-VILLARD
of_property_read_bool Search for a property in a device node. Returns true if the property exist false otherwise. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-09powerpc/eeh: Introduce EEH deviceGavin Shan
Original EEH implementation depends on struct pci_dn heavily. However, EEH shouldn't depend on that actually because EEH needn't share much information with other PCI components. That's to say, EEH should have worked independently. The patch introduces struct eeh_dev so that EEH core components needn't be working based on struct pci_dn in future. Also, struct pci_dn, struct eeh_dev instances are created in dynamic fasion and the binding with EEH device, OF node, PCI device is implemented as well. The EEH devices are created after PHBs are detected and initialized, but PCI emunation hasn't started yet. Apart from that, PHB might be created dynamically through DLPAR component and the EEH devices should be creatd as well. Another case might be OF node is created dynamically by DR (Dynamic Reconfiguration), which has been defined by PAPR. For those OF nodes created by DR, EEH devices should be also created accordingly. The binding between EEH device and OF node is done while the EEH device is initially created. The binding between EEH device and PCI device should be done after PCI emunation is done. Besides, PCI hotplug also needs the binding so that the EEH devices could be traced from the newly coming PCI buses or PCI devices. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-21of: Only compile OF_DYNAMIC on PowerPC pseries and iseriesGrant Likely
Only two architectures use the OF node reference counting and reclaim bits. There is no need to compile it for the rest of the PowerPC platforms or for any of the other architectures. This patch makes iseries and pseries select CONFIG_OF_DYNAMIC, and makes it default to off for everything else. It is still safe to turn on CONFIG_OF_DYNAMIC on all architectures, it just isn't necessary. v2: Also select OF_DYNAMIC for PPC_CHROMA and MPC885ADS as reported by Michael Meuling Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Jimi Xenidis <jimix@pobox.com> (for PPC_CHROMA bug fix) Cc: Rob Herring <rob.herring@calxeda.com>
2012-02-15dt: add empty of_find_compatible_node functionShawn Guo
Add empty of_find_compatible_node function for !CONFIG_OF build. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-01-28of: Add of_property_match_string() to find index into a string listGrant Likely
Add a helper function for finding the index of a string in a string list property. This helper is useful for bindings that use a separate *-name property for attaching names to tuples in another property such as 'reg' or 'gpios'. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-01-07Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
devicetree/next changes queued for v3.3 merge window * tag 'devicetree-for-linus-20120104' of git://git.secretlab.ca/git/linux-2.6: ARM: prom.h: Fix build error by removing unneeded header file irq: check domain hwirq range for DT translate dt: add empty of_get_node/of_put_node functions of/pdt: fix section mismatch warning i2c-designware: add OF binding support dt/i2c: Enumerate some of the known trivial i2c devices dt: reform for_each_property to for_each_property_of_node ARM/of: allow *machine_desc.dt_compat to be const of/base: Take NULL string into account for property with multiple strings OF/device-tree: Add some entries to vendor-prefixes.txt Fix up trivial add-add conflicts in include/linux/of.h
2011-12-28dt: add empty of_get_node/of_put_node functionsRob Herring
Add empty of_get_node/of_put_node functions for !CONFIG_OF builds. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-12-27dt: reform for_each_property to for_each_property_of_nodeDong Aisheng
Make this macro easier to use(do not need to pass properties, a node is enough), also change to a more sensible name as for_each_child_of_node. Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2011-12-12of: create of_phandle_args to simplify return of phandle parsing dataGrant Likely
of_parse_phandle_with_args() needs to return quite a bit of data. Rather than making each datum a separate **out_ argument, this patch creates struct of_phandle_args to contain all the returned data and reworks the user of the function. This patch also enables of_parse_phandle_with_args() to return the device node pointer for the phandle node. This patch also ends up being fairly major surgery to of_parse_handle_with_args(). The existing structure didn't work well when extending to use of_phandle_args, and I discovered bugs during testing. I also took the opportunity to rename the function to be like the existing of_parse_phandle(). v2: - moved declaration of of_phandle_args to fix compile on non-DT builds - fixed incorrect index in example usage - fixed incorrect return code handling for empty entries Reviewed-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-04dt: add empty of_machine_is_compatibleStephen Warren
The patch adds an empty function for non-dt build, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. v3: New patch Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-11-03Merge branch 'for-grant' of git://sources.calxeda.com/kernel/linux into ↵Grant Likely
devicetree/merge
2011-11-01Merge branch 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits) ARM: OMAP: Warn if omap_ioremap is called before SoC detection ARM: OMAP: Move set_globals initialization to happen in init_early ARM: OMAP: Map SRAM later on with ioremap_exec() ARM: OMAP: Remove calls to SRAM allocations for framebuffer ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done ARM: OMAP1: Use generic map_io, init_early and init_irq arm/dts: OMAP3+: Add mpu, dsp and iva nodes arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver ARM: OMAP2+: l3-noc: Add support for device-tree ARM: OMAP2+: board-generic: Add i2c static init ARM: OMAP2+: board-generic: Add DT support to generic board arm/dts: Add support for OMAP3 Beagle board arm/dts: Add initial device tree support for OMAP3 SoC arm/dts: Add support for OMAP4 SDP board arm/dts: Add support for OMAP4 PandaBoard arm/dts: Add initial device tree support for OMAP4 SoC ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration of: Add helpers to get one string in multiple strings property ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures ... Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
2011-10-31of: fix implicit use of errno.h in include/linux/of.hPaul Gortmaker
It shows up as a build failure on MIPS, as it is used in three of_property function stubs. include/linux/of.h:275: error: 'ENOSYS' undeclared (first use in this function) include/linux/of.h:282: error: 'ENOSYS' undeclared (first use in this function) include/linux/of.h:295: error: 'ENOSYS' undeclared (first use in this function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-29dt: add empty of_alias_get_id() for non-dt buildsNicolas Ferre
Add function of_alias_get_id() reporting -ENOSYS for non-dt builds, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-29of: include errno.hKalle Valo
When compiling ath6kl for beagleboard (omap2plus_defconfig plus CONFIG_ATH6KL, CONFIG_OF disable) with current linux-next compilation fails: include/linux/of.h:269: error: 'ENOSYS' undeclared (first use in this function) include/linux/of.h:276: error: 'ENOSYS' undeclared (first use in this function) include/linux/of.h:289: error: 'ENOSYS' undeclared (first use in this function) Fix this by including errno.h from of.h. Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-24dt: Add empty of_match_node() macroNicolas Ferre
Add an empty macro for of_match_node() that will save some '#ifdef CONFIG_OF' for non-dt builds. I have chosen to use a macro instead of a function to be able to avoid defining the first parameter. In fact, this "struct of_device_id *" first parameter is usualy not defined as well on non-dt builds. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-13dt: add empty dt helpers for non-dt buildRajendra Nayak
Add empty of_device_is_compatible() and of_parse_phandle() for non-dt builds to work. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-04dt: add helper to read 64-bit integersJamie Iles
Add a helper similar to of_property_read_u32() that handles 64-bit integers. v2/v3: constify device node and property name parameters. Cc: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-04of: Add helpers to get one string in multiple strings propertyBenoit Cousson
Add of_property_read_string_index and of_property_count_strings to retrieve one string inside a property that will contains severals strings. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-29OF: Add of_match_ptr() macroBen Dooks
Add a macro of_match_ptr() that allows the .of_match_table entry in the driver structures to be assigned without having an #ifdef xxx NULL for the case that OF is not enabled Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-09-22dt: add empty for_each_child_of_node, of_find_propertyStephen Warren
The patch adds a couple empty functions for non-dt build, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-09-22dt: add of_alias_scan and of_alias_get_idShawn Guo
The patch adds function of_alias_scan to populate a global lookup table with the properties of 'aliases' node and function of_alias_get_id for drivers to find alias id from the lookup table. v3: Split out automatic addition of aliases on id lookup so that it can be debated separately from the core functionality. v2: - Add of_chosen/of_aliases populating and of_alias_scan() invocation for OF_PROMTREE. - Add locking - rework parse loop Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-09dt: add empty of_get_property for non-dtStephen Warren
The patch adds empty function of_get_property for non-dt build, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. This also fixes the current Tegra compile problem in linux-next. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-04Revert "dt: add of_alias_scan and of_alias_get_id"Grant Likely
This reverts commit 750f463a749e28464151ad26938d11b07b1c43cb. of_alias_* still needs work to be generalized for 'promtree' dt platforms, and to no implicitly create entries for available ids. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-03dt: add of_alias_scan and of_alias_get_idShawn Guo
The patch adds function of_alias_scan to populate a global lookup table with the properties of 'aliases' node and function of_alias_get_id for drivers to find alias id from the lookup table. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> [grant.likely: add locking and rework parse loop] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-02of: constify property name parameters for helper functionsJamie Iles
The helper functions for reading u32 integers, u32 arrays and strings should have the property name as a const pointer. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08dt: add empty of_property_read_u32[_array] for non-dtShawn Guo
The patch adds empty functions of_property_read_u32 and of_property_read_u32_array for non-dt build, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> [grant.likely: Moved things around so only one new static inline is needed] [grant.likely: Added _string variant] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-06dt: add helper function to read u32 arraysRob Herring
Rework of_property_read_u32 to read an array of values. Then of_property_read_u32 becomes an inline with array size of 1. Also make struct device_node ptr const. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-03dt: add 'const' for of_property_read_string parameter **out_stringShawn Guo
The existing dt codes usually call of_get_property to get a string property and save it as a 'const char *'. The patch adds'const' for of_property_read_string parameter **out_string to make the converting of existing code a little easier. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-30dt: add helper functions to read u32 and string property valuesThomas Abraham
Add helper functions to retrieve unsigned integer and string property values from properties of a device node. These helper functions can be used to lookup a property in a device node, perform error checking and read the property value. [grant.likely@secretlab.ca: Proposal and initial implementation] Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> [grant.likely: some word smithing and be more defensive validating the string] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-02-28dt: Typo fix.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-23rtc: cmos: Add OF bindingsSebastian Andrzej Siewior
This allows to load the OF driver based informations from the device tree. Systems without BIOS may need to perform some initialization. PowerPC creates a PNP device from the OF information and performs this kind of initialization in their private PCI quirk. This looks more generic. This patch also avoids registering the platform RTC driver on X86 if we have a device tree blob. Otherwise we would setup the device based on the hardcoded information in arch/x86 rather than the device tree based one. [ tglx: Changed "int of_have_populated_dt()" to bool as recommended by Grant ] Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org Cc: rtc-linux@googlegroups.com Cc: Alessandro Zummo <a.zummo@towertech.it> LKML-Reference: <1298405266-1624-12-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-21driver-core: remove conditionals around devicetree pointersGrant Likely
Having conditional around the of_match_table and the of_node pointers turns out to make driver code use ugly #ifdef blocks. Drop the conditionals and remove the #ifdef blocks from the affected drivers. Also tidy up minor whitespace issues within the same hunks. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-30of: Provide default of_node_to_nid() implementation.Grant Likely
of_node_to_nid() is only relevant in a few architectures. Don't force everyone to implement it anyway. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-14of/sparc: move is_root_node() to of.hAndres Salomon
Rename is_root_node() to of_node_is_root() and make it available for all archs to use, as it's not PROM-specific. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-03-18of: Fix comparison of "compatible" propertiesGrant Likely
Commit 7c7b60cb87547b1664a4385c187f029bf514a737 "of: put default string compare and #a/s-cell values into common header" Breaks various things on powerpc due to using strncasecmp instead of strcasecmp for comparing against "compatible" strings. This causes things like the 4xx PCI code to fail miserably due to the partial matches in code like this: for_each_compatible_node(np, NULL, "ibm,plb-pcix") ppc4xx_probe_pcix_bridge(np); for_each_compatible_node(np, NULL, "ibm,plb-pci") ppc4xx_probe_pci_bridge(np); It's not quite right to do partial name match. Entries in a compatible list are meant to be matched whole. If a device is compatible with both "foo" and "foo1", then the device should have both strings in its "compatible" property. This patch reverts powerpc and microblaze us to use strcasecmp. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> (for patch description) Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Michal Simek <michal.simek@petalogix.com>
2010-02-14of/sparc: Remove sparc-local declaration of allnodes and devtree_lockGrant Likely
Both allnodes and devtree_lock are defined in common code. The extern declaration should be in the common header too so that the compiler can type check. allnodes is already in of.h, but devtree_lock should be declared there too. This patch removes the SPARC declarations and uses decls in of.h instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: David S. Miller <davem@davemloft.net>
2010-02-14of: move definition of of_chosen into common code.Grant Likely
Rather than defining of_chosen in each arch, it can be defined for all in driver/of/base.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-14of: put default string compare and #a/s-cell values into common headerGrant Likely
Most architectures don't need to change these. Put them into common code to eliminate some duplication Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-14of: protect linux/of.h with CONFIG_OFJeremy Kerr
For platforms that have CONFIG_OF optional, we need to make the contents of linux/of.h conditional on CONFIG_OF. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-14of: Remove old and misplaced function declarationsGrant Likely
The following functions don't exist: finish_device_tree() print_properties() prom_n_intr_cells() prom_get_irq_senses() The following functions are in drivers/of/base.c, so the declaration belongs in of.h instead of of_fdt.h of_machine_is_compatible() prom_add_property() prom_remove_property() prom_update_property() Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-09of: use __be32 for cell value accessorsJeremy Kerr
Currently, we're using u32 for cell values, and hence assuming host-endian device trees. As we'd like to support little-endian platforms, use a __be32 for cell values, and convert in the cell accessors. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
