path: root/include/linux/of_device.h
2008-04-30Remove "#ifdef __KERNEL__" checks from unexported headersRobert P. J. Day
Remove the "#ifdef __KERNEL__" tests from unexported header files in linux/include whose entire contents are wrapped in that preprocessor test. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-17[POWERPC] Add of_find_matching_node() helper functionGrant Likely
Similar to of_find_compatible_node(), of_find_matching_node() and for_each_matching_node() allow you to iterate over the device tree looking for specific nodes, except that they take of_device_id tables instead of strings. This also moves of_match_node() from driver/of/device.c to driver/of/base.c to colocate it with the of_find_matching_node which depends on it. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Move of_device allocation into of_device.[ch]Joachim Fenkes
Extract generic of_device allocation code from of_platform_device_create() and move it into of_device.[ch], called of_device_alloc(). Also, there's now of_device_free() which puts the device node. This way, bus drivers that build on of_platform (like ibmebus will) can build upon this code instead of reinventing the wheel. Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-20Begin consolidation of of_device.hStephen Rothwell
This just moves the common stuff from the arch of_device.h files to linux/of_device.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net>
