path: root/include/linux/of_fdt.h
2011-12-27ARM/of: allow *machine_desc.dt_compat to be constUwe Kleine-König
This allows dt_compat to point to a constant list of compatible strings. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2011-08-04Revert "dt: add of_alias_scan and of_alias_get_id"Grant Likely
This reverts commit 750f463a749e28464151ad26938d11b07b1c43cb. of_alias_* still needs work to be generalized for 'promtree' dt platforms, and to no implicitly create entries for available ids. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-03dt: add of_alias_scan and of_alias_get_idShawn Guo
The patch adds function of_alias_scan to populate a global lookup table with the properties of 'aliases' node and function of_alias_get_id for drivers to find alias id from the lookup table. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> [grant.likely: add locking and rework parse loop] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-15dt/flattree: Return virtual address from early_init_dt_alloc_memory_arch()Grant Likely
The physical address is never used by the device tree code when allocating memory for unflattening. Change the architecture's alloc hook to return the virutal address instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-08of/flattree: forward declare struct device_node in of_fdt.hGrant Likely
This patch forward declares struct device_node to fix a compile error when of_fdt.h is included, but of.h is not. Alternately, including linux/of.h could have been added to of_fdt.h, but that pulls in a lot of unnecessary declarations when only working with the flattened form. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-01of/flattree: Add of_flat_dt_match() helper functionGrant Likely
This patch adds of_flat_dt_match() which tests a node for compatibility with a list of values and converts the relevant powerpc platform code to use it. This approach simplifies the board support code a bit. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
2010-12-29of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_treeStephen Neuendorffer
unflatten_device_tree has two dependencies on things that happen during boot time. Firstly, it references the initial device tree directly. Secondly, it allocates memory using the early boot allocator. This patch factors out these dependencies and uses the new __unflatten_device_tree function to implement a driver-visible fdt_unflatten_tree function, which can be used to unflatten a blob after boot time. V2: - remove extra __va() call - make dt_alloc functions return void *. This doesn't fix the general strangeness in this code that constantly casts back and forth between unsigned long and __be32 * Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Add non-boottime device tree functionsStephen Neuendorffer
In preparation for providing run-time handling of device trees, factor out some of the basic functions so that they take an arbitrary blob, rather than relying on the single boot-time tree. V2: - functions have of_fdt_* names - removed find_flat_dt_string - blob argument is first Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-21of/flattree: Eliminate need to provide early_init_dt_scan_chosen_archGrant Likely
This patch refactors the early init parsing of the chosen node so that architectures aren't forced to provide an empty implementation of early_init_dt_scan_chosen_arch. Instead, if an architecture wants to do something different, it can either use a wrapper function around early_init_dt_scan_chosen(), or it can replace it altogether. This patch was written in preparation to adding device tree support to both x86 ad MIPS. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: David Daney <ddaney@caviumnetworks.com>
2010-04-28of/flattree: Make unflatten_device_tree() safe to call from any archGrant Likely
This patch makes unflatten_device_tree() safe to call from any arch setup code with the following changes: - Make sure initial_boot_params actually points to a device tree blob before unflattening - Make sure the initial_boot_params->magic field is correct - If CONFIG_OF_FLATTREE is not set, then make unflatten_device_tree() an empty static inline function. This patch also adds some additional debug output to the top of unflatten_device_tree(). Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28of/flattree: make of_fdt.h safe to unconditionally include.Grant Likely
If CONFIG_OF_FLATTREE is not set, then don't process the body of linux/of_fdt.h Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-14of/flattree: Don't assume HAVE_LMBJeremy Kerr
We don't always have lmb available, so make arches provide an early_init_dt_alloc_memory_arch() to handle the allocation of memory in the fdt code. When we don't have lmb.h included, we need asm/page.h for __va. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-14of: Remove old and misplaced function declarationsGrant Likely
The following functions don't exist: finish_device_tree() print_properties() prom_n_intr_cells() prom_get_irq_senses() The following functions are in drivers/of/base.c, so the declaration belongs in of.h instead of of_fdt.h of_machine_is_compatible() prom_add_property() prom_remove_property() prom_update_property() Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-09of/flattree: endian-convert members of boot_param_headerJeremy Kerr
The boot_param_header has big-endian fields, so change the types to __be32, and perform endian conversion when we access them. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-09of: use __be32 for cell value accessorsJeremy Kerr
Currently, we're using u32 for cell values, and hence assuming host-endian device trees. As we'd like to support little-endian platforms, use a __be32 for cell values, and convert in the cell accessors. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-09of/flattree: use callback to setup initrd from /chosenJeremy Kerr
At present, the fdt code sets the kernel-wide initrd_start and initrd_end variables when parsing /chosen. On ARM, we only set these once the bootmem has been reserved. This change adds an arch hook to setup the initrd from the device tree: void early_init_dt_setup_initrd_arch(unsigned long start, unsigned long end); The arch-specific code can then setup the initrd however it likes. Compiled on powerpc, with CONFIG_BLK_DEV_INITRD=y and =n. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-02-09of/flattree: merge early_init_dt_scan_memory() common codeGrant Likely
Merge common code between PowerPC and Microblaze architectures. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2009-12-10of/flattree: merge early_init_dt_scan_chosen()Grant Likely
Merge common code between PowerPC and Microblaze. This patch splits the arch-specific stuff out into a new function, early_init_dt_scan_chosen_arch(). Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-10of/flattree: merge dt_mem_next_cellGrant Likely
Merge common code between PowerPC and Microblaze Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-10of/flattree: Merge earlyinit_dt_scan_root()Grant Likely
2009-12-10of/flattree: Merge early_init_dt_check_for_initrd()Grant Likely
Merge common code between PowerPC and Microblaze Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-23of/flattree: Merge unflatten_device_treeGrant Likely
Merge common code between PowerPC and MicroBlaze Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Michal Simek <monstr@monstr.eu>
2009-11-23of/flattree: Merge unflatten_dt_nodeGrant Likely
2009-11-23of/flattree: remove __init annotations from the header fileGrant Likely
__init annotation belongs in the .c file, not the header. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Michal Simek <monstr@monstr.eu>
2009-11-23of/flattree: merge find_flat_dt_string and initial_boot_paramsGrant Likely
Merge common code between Microblaze and PowerPC. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Michal Simek <monstr@monstr.eu>
2009-10-15of: merge other miscellaneous prototypesGrant Likely
Merge common prototypes used by Microblaze and PowerPC Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
2009-10-15of: merge of_*_flat_dt*() functionsGrant Likely
Merge common flattened device tree code between Microblaze and PowerPC Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
2009-10-15of: merge struct boot_param_header from Microblaze and PowerPCGrant Likely
Merge common code for working with Flattened Device Tree data structure Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
2009-10-15of: add common header for flattened device tree representationGrant Likely
Add a common header file for working with the flattened device tree data structure and merge the shared data tags used by Microblaze and PowerPC Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
