Add of_pci_dma_configure() to allow updating the DMA configuration of the
PCI device using the configuration from DT of the parent of the root bridge
device. Use the newly added APIs pci_get/put_host_bridge_device() for
implementing this.
[bhelgaas: fold in fix for host bridges with no parent OF device]
Tested-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> (AMD Seattle)
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Rob Herring <robh+dt@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
CC: Joerg Roedel <joro@8bytes.org>
CC: Grant Likely <grant.likely@linaro.org>
CC: Russell King <linux@arm.linux.org.uk>
CC: Arnd Bergmann <arnd@arndb.de>
"msi_chip" isn't very descriptive, so rename it to "msi_controller". That
tells a little more about what it does and is already used in device tree
bindings.
No functional change.
[bhelgaas: changelog, change *only* the struct name so it's reviewable]
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Provide a function to parse the PCI DT ranges that can be used to create a
pci_host_bridge structure together with its associated bus.
Signed-off-by: Liviu Dudau <Liviu.Dudau@arm.com>
[make io_base parameter optional]
Signed-off-by: Robert Richter <rrichter@cavium.com>
CC: Rob Herring <robh+dt@kernel.org>
CC: Catalin Marinas <catalin.marinas@arm.com>
Add pci_get_new_domain_nr() to allocate a new domain number and
of_get_pci_domain_nr() to retrieve the PCI domain number of a given device
from DT. Host bridge drivers or architecture-specific code can choose to
implement their PCI domain number policy using these two functions.
Using of_get_pci_domain_nr() guarantees a stable PCI domain number on every
boot provided that all host bridge controllers are assigned a number in the
device tree using "linux,pci-domain" property. Mixing use of
pci_get_new_domain_nr() and of_get_pci_domain_nr() is not recommended as it
can lead to potentially conflicting domain numbers being assigned to root
buses behind different host bridges.
The pci-rcar driver is enabled for compile tests, and this has
now shown that the driver cannot build without CONFIG_OF,
following the inclusion of f8f2fe7355fb "PCI: rcar: Use new OF
interrupt mapping when possible":
drivers/built-in.o: In function `rcar_pci_map_irq':
:(.text+0x1cc7c): undefined reference to `of_irq_parse_and_map_pci'
pci/host/pcie-rcar.c: In function 'pci_dma_range_parser_init':
pci/host/pcie-rcar.c:875:2: error: implicit declaration of function 'of_n_addr_cells' [-Werror=implicit-function-declaration]
As pointed out by Ben Dooks and Geert Uytterhoeven, this is actually
supposed to build fine, which we can achieve if we make the
declaration of of_irq_parse_and_map_pci conditional on CONFIG_OF
and provide an empty inline function otherwise, as we do for
a lot of other of interfaces.
This lets us build the rcar_pci driver again without CONFIG_OF
for build testing. All platforms using this driver select OF,
so this doesn't change anything for the users.
Cc: devicetree@vger.kernel.org
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Lucas Stach <l.stach@pengutronix.de>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Magnus Damm <damm@opensource.se>
Cc: Ben Dooks <ben.dooks@codethink.co.uk>
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
[robh: drop wrappers for of_n_addr_cells and of_n_size_cells which are
low-level functions that should not be used for !OF]
Signed-off-by: Rob Herring <robh@kernel.org>
Several architectures open code effectively the same code block for
finding and mapping PCI irqs. This patch consolidates it down to a
single function.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Michal Simek <monstr@monstr.eu>
struct of_irq and struct of_phandle_args are exactly the same structure.
This patch makes the kernel use of_phandle_args everywhere. This in
itself isn't a big deal, but it makes some follow-on patches simpler.
The OF irq handling code has been overloading the term 'map' to refer to
both parsing the data in the device tree and mapping it to the internal
linux irq system. This is probably because the device tree does have the
concept of an 'interrupt-map' function for translating interrupt
references from one node to another, but 'map' is still confusing when
the primary purpose of some of the functions are to parse the DT data.
This patch renames all the of_irq_map_* functions to of_irq_parse_*
which makes it clear that there is a difference between the parsing
phase and the mapping phase. Kernel code can make use of just the
parsing or just the mapping support as needed by the subsystem.
The patch was generated mechanically with a handful of sed commands.
This commit adds a very basic registry of msi_chip structures, so that
an IRQ controller driver can register an msi_chip, and a PCIe host
controller can find it, based on a 'struct device_node'.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This function can be used to parse a bus-range property as specified by
device nodes representing PCI bridges.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
This function can be used to parse the device and function number from a
standard 5-cell PCI resource. PCI_SLOT() and PCI_FUNC() can be used on
the returned value obtain the device and function numbers respectively.
On MIPS we want to call of_irq_map_pci from inside
arch/mips/include/asm/pci.h:extern int pcibios_map_irq(
const struct pci_dev *dev, u8 slot, u8 pin);
For this to work we need to change several functions to const usage.
Signed-off-by: John Crispin <blogic@openwrt.org>
Cc: devicetree-discuss@lists.ozlabs.org
Cc: linux-mips@linux-mips.org
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Patchwork: https://patchwork.linux-mips.org/patch/3710/
powerpc has two different ways of matching PCI devices to their
corresponding OF node (if any) for historical reasons. The ppc64 one
does a scan looking for matching bus/dev/fn, while the ppc32 one does a
scan looking only for matching dev/fn on each level in order to be
agnostic to busses being renumbered (which Linux does on some
platforms).
This removes both and instead moves the matching code to the PCI core
itself. It's the most logical place to do it: when a pci_dev is created,
we know the parent and thus can do a single level scan for the matching
device_node (if any).
The benefit is that all archs now get the matching for free. There's one
hook the arch might want to provide to match a PHB bus to its device
node. A default weak implementation is provided that looks for the
parent device device node, but it's not entirely reliable on powerpc for
various reasons so powerpc provides its own.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
There is a tiny difference between PPC32 and PPC64. Microblaze uses the
PPC32 variant.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
[grant.likely@secretlab.ca: Added comment to #endif, moved documentation
block to function implementation, fixed for non ppc and microblaze
compiles]
