path: root/include/linux/omapfb.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-09-10ARM: OMAP1: move lcd pdata out of arch/arm/*Igor Grinberg
omap1 lcd platform data resides inside plat/board.h while it should be inside include/linux/... Move the omap1 lcd platform data to include/linux/omapfb.h. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAP1: pass LCD config with omapfb_set_lcd_config()Tomi Valkeinen
LCD config for old omapfb driver is passed with OMAP_TAG_LCD from board files or from the bootloader. In an effort to remove OMAP_TAG_LCD, this patch adds omapfb_set_lcd_config() function that the board files can call to set the LCD config. This has the drawback that configuration can no longer come from the bootloader. Of the boards supported by the kernel, this should only affect N770 which depends on the data from the bootloader. This patch adds an LCD config for N770 to its board files, but that is most probably broken. Fixing this would need information about the HW setup in N770 boards. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAPFB: remove omapfb_set_platform_data()Tomi Valkeinen
omapfb_set_platform_data() is no longer used, so remove it. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-23OMAPFB: Move old omapfb private structs to a private include fileTomi Valkeinen
include/linux/omapfb.h contains structs that are used only by the omapfb driver. Move the structs into drivers/video/omap/omapfb.h. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-02-23OMAPFB: remove mem info from platform_dataTomi Valkeinen
omapfb driver used platform_data to get fb memory areas and formats defined by the board file. This patch removes omapfb's (both old and new omapfb) use of the memory data in platform_data, because: - No board uses them currently - It's not board file's job to define things like amount of default framebuffer memory. These should come from the bootloader via command line parameters. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-02-23OMAPFB: remove early mem alloc from old omapfbTomi Valkeinen
arch/arm/plat-omap/fb.c contains code to alloc omapfb buffers at early boot time according to information given from the bootloader or board file. This code isn't currently used by any board, and is anyway something that the newer vram.c could handle. So remove the alloc code and in later patches make old omapfb driver use vram.c. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2012-02-23OAMPFB: remove unused omapfb_set_ctrl_platform_data()Tomi Valkeinen
omapfb_set_ctrl_platform_data() is no longer used, so it can be removed. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2010-08-08Merge branch 'for-linus' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: (64 commits) OMAP: DSS2: OMAPFB: add support for FBIO_WAITFORVSYNC OMAP: DSS2: Replace strncmp() with sysfs_streq() in overlay_manager_store() OMAP: DSS2: Fix error path in omap_dsi_update() OMAP: DSS2: TDO35S: fix video signaling OMAP: DSS2: OMAPFB: Fix invalid bpp for PAL and NTSC modes OMAP: DSS2: OMAPFB: Fix probe error path OMAP3EVM: Replace vdvi regulator supply with vdds_dsi OMAP: DSS2: Remove extra return statement OMAP: DSS2: adjust YUV overlay width to be even OMAP: DSS2: OMAPFB: Fix sysfs mirror input check OMAP: DSS2: OMAPFB: Remove redundant color register range check OMAP: DSS2: OMAPFB: Remove redundant rotate range check OMAP: DSS2: OMAPFB: Check fb2display() return value OMAP: DSS2: Taal: Optimize enable_te, rotate, mirror when value unchanged OMAP: DSS2: DSI: detect unsupported update requests OMAP: DSS2: DSI: increase FIFO low threshold OMAP: DSS2: DSI: Add error IRQ mask for DSI complexIO OMAP: DSS2: DSI: Remove BTA after set_max_rx_packet_size OMAP: DSS2: change manual update scaling setup OMAP: DSS2: DSI: use BTA to end the frame transfer ...
2010-08-03OMAP: DSS2: OMAPFB: Add support for switching memory regionsVille Syrjälä
Separate the memory region from the framebuffer device a little bit. It's now possible to select the memory region used by the framebuffer device using the new mem_idx parameter of omapfb_plane_info. If the mem_idx is specified it will be interpreted as an index into the memory regions array, if it's not specified the framebuffer's index is used instead. So by default each framebuffer keeps using it's own memory region which preserves backwards compatibility. This allows cloning the same memory region to several overlays and yet each overlay can be controlled independently since they can be associated with separate framebuffer devices. Signed-off-by: Ville Syrjälä <ville.syrjala@nokia.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2010-07-27ARM: OMAP: Convert OMAPFB and VRAM SDRAM reservation to LMBRussell King
2010-02-15OMAP: DSS2: OMAPFB: implement OMAPFB_GET_DISPLAY_INFOTomi Valkeinen
Previously the only place to get the size of the display was from the DSS's sysfs interface, making, for example, configuring overlays and doing updates on manual displays more difficult. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2009-12-09OMAP: DSS2: omapfb driverTomi Valkeinen
2009-12-09OMAP: OMAPFB: split omapfb.hTomi Valkeinen
Split arch/arm/plat-omap/include/mach/omapfb.h into two files: include/linux/omapfb.h - ioctls etc for userspace and some kernel stuff for board files drivers/video/omap/omapfb.h - for omapfb internal use This cleans up omapfb.h and also makes it easier for the upcoming new DSS driver to co-exist with the old driver. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com>
