path: root/include/linux/page_cgroup.h
2012-07-31memcg: rename config variablesAndrew Morton
Sanity: CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM [mhocko@suse.cz: fix missed bits] Cc: Glauber Costa <glommer@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: remove PCG_FILE_MAPPEDKAMEZAWA Hiroyuki
With the new lock scheme for updating memcg's page stat, we don't need a flag PCG_FILE_MAPPED which was duplicated information of page_mapped(). [hughd@google.com: cosmetic fix] [hughd@google.com: add comment to MEM_CGROUP_CHARGE_TYPE_MAPPED case in __mem_cgroup_uncharge_common()] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Greg Thelen <gthelen@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: remove PCG_MOVE_LOCK flag from page_cgroupKAMEZAWA Hiroyuki
PCG_MOVE_LOCK is used for bit spinlock to avoid race between overwriting pc->mem_cgroup and page statistics accounting per memcg. This lock helps to avoid the race but the race is very rare because moving tasks between cgroup is not a usual job. So, it seems using 1bit per page is too costly. This patch changes this lock as per-memcg spinlock and removes PCG_MOVE_LOCK. If smaller lock is required, we'll be able to add some hashes but I'd like to start from this. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21memcg: remove PCG_CACHE page_cgroup flagKAMEZAWA Hiroyuki
We record 'the page is cache' with the PCG_CACHE bit in page_cgroup. Here, "CACHE" means anonymous user pages (and SwapCache). This doesn't include shmem. Considering callers, at charge/uncharge, the caller should know what the page is and we don't need to record it by using one bit per page. This patch removes PCG_CACHE bit and make callers of mem_cgroup_charge_statistics() to specify what the page is. About page migration: Mapping of the used page is not touched during migra tion (see page_remove_rmap) so we can rely on it and push the correct charge type down to __mem_cgroup_uncharge_common from end_migration for unused page. The force flag was misleading was abused for skipping the needless page_mapped() / PageCgroupMigration() check, as we know the unused page is no longer mapped and cleared the migration flag just a few lines up. But doing the checks is no biggie and it's not worth adding another flag just to skip them. [akpm@linux-foundation.org: checkpatch fixes] [hughd@google.com: fix PageAnon uncharging] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Ying Han <yinghan@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12memcg: simplify LRU handling by new ruleKAMEZAWA Hiroyuki
Now, at LRU handling, memory cgroup needs to do complicated works to see valid pc->mem_cgroup, which may be overwritten. This patch is for relaxing the protocol. This patch guarantees - when pc->mem_cgroup is overwritten, page must not be on LRU. By this, LRU routine can believe pc->mem_cgroup and don't need to check bits on pc->flags. This new rule may adds small overheads to swapin. But in most case, lru handling gets faster. After this patch, PCG_ACCT_LRU bit is obsolete and removed. [akpm@linux-foundation.org: remove unneeded VM_BUG_ON(), restore hannes's christmas tree] [akpm@linux-foundation.org: clean up code comment] [hughd@google.com: fix NULL mem_cgroup_try_charge] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Ying Han <yinghan@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12page_cgroup: add helper function to get swap_cgroupBob Liu
There are multiple places which need to get the swap_cgroup address, so add a helper function: static struct swap_cgroup *swap_cgroup_getsc(swp_entry_t ent, struct swap_cgroup_ctrl **ctrl); to simplify the code. Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: memcg: remove unused node/section info from pc->flagsJohannes Weiner
To find the page corresponding to a certain page_cgroup, the pc->flags encoded the node or section ID with the base array to compare the pc pointer to. Now that the per-memory cgroup LRU lists link page descriptors directly, there is no longer any code that knows the struct page_cgroup of a PFN but not the struct page. [hughd@google.com: remove unused node/section info from pc->flags fix] Signed-off-by: Johannes Weiner <jweiner@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Ying Han <yinghan@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: make per-memcg LRU lists exclusiveJohannes Weiner
Now that all code that operated on global per-zone LRU lists is converted to operate on per-memory cgroup LRU lists instead, there is no reason to keep the double-LRU scheme around any longer. The pc->lru member is removed and page->lru is linked directly to the per-memory cgroup LRU lists, which removes two pointers from a descriptor that exists for every page frame in the system. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Ying Han <yinghan@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: remove direct page_cgroup-to-page pointerJohannes Weiner
In struct page_cgroup, we have a full word for flags but only a few are reserved. Use the remaining upper bits to encode, depending on configuration, the node or the section, to enable page_cgroup-to-page lookups without a direct pointer. This saves a full word for every page in a system with memory cgroups enabled. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: fold __mem_cgroup_move_account into callerJohannes Weiner
It is one logical function, no need to have it split up. Also, get rid of some checks from the inner function that ensured the sanity of the outer function. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23memcg: change page_cgroup_zoneinfo signatureJohannes Weiner
Instead of passing a whole struct page_cgroup to this function, let it take only what it really needs from it: the struct mem_cgroup and the page. This has the advantage that reading pc->mem_cgroup is now done at the same place where the ordering rules for this pointer are enforced and explained. It is also in preparation for removing the pc->page backpointer. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-14Revert update for dirty_ratio for memcg.KAMEZAWA Hiroyuki
The flags added by commit db16d5ec1f87f17511599bc77857dd1662b5a22f has no user now. We believe we'll use it soon but considering patch reviewing, the change itself should be folded into incoming set of "dirty ratio for memcg" patches. So, it's better to drop this change from current mainline tree. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Greg Thelen <gthelen@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memcg: add lock to synchronize page accounting and migrationKAMEZAWA Hiroyuki
Introduce a new bit spin lock, PCG_MOVE_LOCK, to synchronize the page accounting and migration code. This reworks the locking scheme of _update_stat() and _move_account() by adding new lock bit PCG_MOVE_LOCK, which is always taken under IRQ disable. 1. If pages are being migrated from a memcg, then updates to that memcg page statistics are protected by grabbing PCG_MOVE_LOCK using move_lock_page_cgroup(). In an upcoming commit, memcg dirty page accounting will be updating memcg page accounting (specifically: num writeback pages) from IRQ context (softirq). Avoid a deadlocking nested spin lock attempt by disabling irq on the local processor when grabbing the PCG_MOVE_LOCK. 2. lock for update_page_stat is used only for avoiding race with move_account(). So, IRQ awareness of lock_page_cgroup() itself is not a problem. The problem is between mem_cgroup_update_page_stat() and mem_cgroup_move_account_page(). Trade-off: * Changing lock_page_cgroup() to always disable IRQ (or local_bh) has some impacts on performance and I think it's bad to disable IRQ when it's not necessary. * adding a new lock makes move_account() slower. Score is here. Performance Impact: moving a 8G anon process. Before: real 0m0.792s user 0m0.000s sys 0m0.780s After: real 0m0.854s user 0m0.000s sys 0m0.842s This score is bad but planned patches for optimization can reduce this impact. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Greg Thelen <gthelen@google.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Andrea Righi <arighi@develer.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memcg: add page_cgroup flags for dirty page trackingGreg Thelen
This patchset provides the ability for each cgroup to have independent dirty page limits. Limiting dirty memory is like fixing the max amount of dirty (hard to reclaim) page cache used by a cgroup. So, in case of multiple cgroup writers, they will not be able to consume more than their designated share of dirty pages and will be forced to perform write-out if they cross that limit. The patches are based on a series proposed by Andrea Righi in Mar 2010. Overview: - Add page_cgroup flags to record when pages are dirty, in writeback, or nfs unstable. - Extend mem_cgroup to record the total number of pages in each of the interesting dirty states (dirty, writeback, unstable_nfs). - Add dirty parameters similar to the system-wide /proc/sys/vm/dirty_* limits to mem_cgroup. The mem_cgroup dirty parameters are accessible via cgroupfs control files. - Consider both system and per-memcg dirty limits in page writeback when deciding to queue background writeback or block for foreground writeback. Known shortcomings: - When a cgroup dirty limit is exceeded, then bdi writeback is employed to writeback dirty inodes. Bdi writeback considers inodes from any cgroup, not just inodes contributing dirty pages to the cgroup exceeding its limit. - When memory.use_hierarchy is set, then dirty limits are disabled. This is a implementation detail. An enhanced implementation is needed to check the chain of parents to ensure that no dirty limit is exceeded. Performance data: - A page fault microbenchmark workload was used to measure performance, which can be called in read or write mode: f = open(foo. $cpu) truncate(f, 4096) alarm(60) while (1) { p = mmap(f, 4096) if (write) *p = 1 else x = *p munmap(p) } - The workload was called for several points in the patch series in different modes: - s_read is a single threaded reader - s_write is a single threaded writer - p_read is a 16 thread reader, each operating on a different file - p_write is a 16 thread writer, each operating on a different file - Measurements were collected on a 16 core non-numa system using "perf stat --repeat 3". The -a option was used for parallel (p_*) runs. - All numbers are page fault rate (M/sec). Higher is better. - To compare the performance of a kernel without non-memcg compare the first and last rows, neither has memcg configured. The first row does not include any of these memcg patches. - To compare the performance of using memcg dirty limits, compare the baseline (2nd row titled "w/ memcg") with the the code and memcg enabled (2nd to last row titled "all patches"). root_cgroup child_cgroup s_read s_write p_read p_write s_read s_write p_read p_write mmotm w/o memcg 0.428 0.390 0.429 0.388 mmotm w/ memcg 0.411 0.378 0.391 0.362 0.412 0.377 0.385 0.363 all patches 0.384 0.360 0.370 0.348 0.381 0.363 0.368 0.347 all patches 0.431 0.402 0.427 0.395 w/o memcg This patch: Add additional flags to page_cgroup to track dirty pages within a mem_cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrea Righi <arighi@develer.com> Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-25memcg: fix false positive VM_BUG on non-SMPKirill A. Shutemov
Fix this: kernel BUG at mm/memcontrol.c:2155! invalid opcode: 0000 [#1] last sysfs file: Pid: 18, comm: sh Not tainted 2.6.37-rc3 #3 /Bochs EIP: 0060:[<c10731b2>] EFLAGS: 00000246 CPU: 0 EIP is at mem_cgroup_move_account+0xe2/0xf0 EAX: 00000004 EBX: c6f931d4 ECX: c681c300 EDX: c681c000 ESI: c681c300 EDI: ffffffea EBP: c681c000 ESP: c46f3e30 DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 Process sh (pid: 18, ti=c46f2000 task=c6826e60 task.ti=c46f2000) Stack: 00000155 c681c000 0805f000 c46ee180 c46f3e5c c7058820 c1074d37 00000000 08060000 c46db9a0 c46ec080 c7058820 0805f000 08060000 c46f3e98 c1074c50 c106c75e c46f3e98 c46ec080 08060000 0805ffff c46db9a0 c46f3e98 c46e0340 Call Trace: [<c1074d37>] ? mem_cgroup_move_charge_pte_range+0xe7/0x130 [<c1074c50>] ? mem_cgroup_move_charge_pte_range+0x0/0x130 [<c106c75e>] ? walk_page_range+0xee/0x1d0 [<c10725d6>] ? mem_cgroup_move_task+0x66/0x90 [<c1074c50>] ? mem_cgroup_move_charge_pte_range+0x0/0x130 [<c1072570>] ? mem_cgroup_move_task+0x0/0x90 [<c1042616>] ? cgroup_attach_task+0x136/0x200 [<c1042878>] ? cgroup_tasks_write+0x48/0xc0 [<c1041e9e>] ? cgroup_file_write+0xde/0x220 [<c101398d>] ? do_page_fault+0x17d/0x3f0 [<c108a79d>] ? alloc_fd+0x2d/0xd0 [<c1041dc0>] ? cgroup_file_write+0x0/0x220 [<c1077ba2>] ? vfs_write+0x92/0xc0 [<c1077c81>] ? sys_write+0x41/0x70 [<c1140e3d>] ? syscall_call+0x7/0xb Code: 03 00 74 09 8b 44 24 04 e8 1c f1 ff ff 89 73 04 8d 86 b0 00 00 00 b9 01 00 00 00 89 da 31 ff e8 65 f5 ff ff e9 4d ff ff ff 0f 0b <0f> 0b 0f 0b 0f 0b 90 8d b4 26 00 00 00 00 83 ec 10 8b 0d f4 e3 EIP: [<c10731b2>] mem_cgroup_move_account+0xe2/0xf0 SS:ESP 0068:c46f3e30 ---[ end trace 7daa1582159b6532 ]--- lock_page_cgroup and unlock_page_cgroup are implemented using bit_spinlock. bit_spinlock doesn't touch the bit if we are on non-SMP machine, so we can't use the bit to check whether the lock was taken. Let's introduce is_page_cgroup_locked based on bit_spin_is_locked instead of PageCgroupLocked to fix it. [akpm@linux-foundation.org: s/is_page_cgroup_locked/page_is_cgroup_locked/] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: fix mis-accounting of file mapped racy with migrationakpm@linux-foundation.org
FILE_MAPPED per memcg of migrated file cache is not properly updated, because our hook in page_add_file_rmap() can't know to which memcg FILE_MAPPED should be counted. Basically, this patch is for fixing the bug but includes some big changes to fix up other messes. Now, at migrating mapped file, events happen in following sequence. 1. allocate a new page. 2. get memcg of an old page. 3. charge ageinst a new page before migration. But at this point, no changes to new page's page_cgroup, no commit for the charge. (IOW, PCG_USED bit is not set.) 4. page migration replaces radix-tree, old-page and new-page. 5. page migration remaps the new page if the old page was mapped. 6. Here, the new page is unlocked. 7. memcg commits the charge for newpage, Mark the new page's page_cgroup as PCG_USED. Because "commit" happens after page-remap, we can count FILE_MAPPED at "5", because we should avoid to trust page_cgroup->mem_cgroup. if PCG_USED bit is unset. (Note: memcg's LRU removal code does that but LRU-isolation logic is used for helping it. When we overwrite page_cgroup->mem_cgroup, page_cgroup is not on LRU or page_cgroup->mem_cgroup is NULL.) We can lose file_mapped accounting information at 5 because FILE_MAPPED is updated only when mapcount changes 0->1. So we should catch it. BTW, historically, above implemntation comes from migration-failure of anonymous page. Because we charge both of old page and new page with mapcount=0, we can't catch - the page is really freed before remap. - migration fails but it's freed before remap or .....corner cases. New migration sequence with memcg is: 1. allocate a new page. 2. mark PageCgroupMigration to the old page. 3. charge against a new page onto the old page's memcg. (here, new page's pc is marked as PageCgroupUsed.) 4. page migration replaces radix-tree, page table, etc... 5. At remapping, new page's page_cgroup is now makrked as "USED" We can catch 0->1 event and FILE_MAPPED will be properly updated. And we can catch SWAPOUT event after unlock this and freeing this page by unmap() can be caught. 7. Clear PageCgroupMigration of the old page. So, FILE_MAPPED will be correctly updated. Then, for what MIGRATION flag is ? Without it, at migration failure, we may have to charge old page again because it may be fully unmapped. "charge" means that we have to dive into memory reclaim or something complated. So, it's better to avoid charge it again. Before this patch, __commit_charge() was working for both of the old/new page and fixed up all. But this technique has some racy condtion around FILE_MAPPED and SWAPOUT etc... Now, the kernel use MIGRATION flag and don't uncharge old page until the end of migration. I hope this change will make memcg's page migration much simpler. This page migration has caused several troubles. Worth to add a flag for simplification. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07memcg: fix race in file_mapped accountingKAMEZAWA Hiroyuki
Presently, memcg's FILE_MAPPED accounting has following race with move_account (happens at rmdir()). increment page->mapcount (rmap.c) mem_cgroup_update_file_mapped() move_account() lock_page_cgroup() check page_mapped() if page_mapped(page)>1 { FILE_MAPPED -1 from old memcg FILE_MAPPED +1 to old memcg } ..... overwrite pc->mem_cgroup unlock_page_cgroup() lock_page_cgroup() FILE_MAPPED + 1 to pc->mem_cgroup unlock_page_cgroup() Then, old memcg (-1 file mapped) new memcg (+2 file mapped) This happens because move_account see page_mapped() which is not guarded by lock_page_cgroup(). This patch adds FILE_MAPPED flag to page_cgroup and move account information based on it. Now, all checks are synchronous with lock_page_cgroup(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@in.ibm.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Andrea Righi <arighi@develer.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12memcg: move charges of anonymous swapDaisuke Nishimura
This patch is another core part of this move-charge-at-task-migration feature. It enables moving charges of anonymous swaps. To move the charge of swap, we need to exchange swap_cgroup's record. In current implementation, swap_cgroup's record is protected by: - page lock: if the entry is on swap cache. - swap_lock: if the entry is not on swap cache. This works well in usual swap-in/out activity. But this behavior make the feature of moving swap charge check many conditions to exchange swap_cgroup's record safely. So I changed modification of swap_cgroup's recored(swap_cgroup_record()) to use xchg, and define a new function to cmpxchg swap_cgroup's record. This patch also enables moving charge of non pte_present but not uncharged swap caches, which can be exist on swap-out path, by getting the target pages via find_get_page() as do_mincore() does. [kosaki.motohiro@jp.fujitsu.com: fix ia64 build] [akpm@linux-foundation.org: fix typos] Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16memcg: cleanup mem_cgroup_move_parent()Daisuke Nishimura
mem_cgroup_move_parent() calls try_charge first and cancel_charge on failure. IMHO, charge/uncharge(especially charge) is high cost operation, so we should avoid it as far as possible. This patch tries to delay try_charge in mem_cgroup_move_parent() by re-ordering checks it does. And this patch renames mem_cgroup_move_account() to __mem_cgroup_move_account(), changes the return value of __mem_cgroup_move_account() from int to void, and adds a new wrapper(mem_cgroup_move_account()), which checks whether a @pc is valid for moving account and calls __mem_cgroup_move_account(). This patch removes the last caller of trylock_page_cgroup(), so removes its definition too. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24memcg: remove the overhead associated with the root cgroupBalbir Singh
Change the memory cgroup to remove the overhead associated with accounting all pages in the root cgroup. As a side-effect, we can no longer set a memory hard limit in the root cgroup. A new flag to track whether the page has been accounted or not has been added as well. Flags are now set atomically for page_cgroup, pcg_default_flags is now obsolete and removed. [akpm@linux-foundation.org: fix a few documentation glitches] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-20includecheck fix: include/linux, page_cgroup.hJaswinder Singh Rajput
fix the following 'make includecheck' warning: include/linux/page_cgroup.h: linux/swap.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com>
2009-06-12memcg: fix page_cgroup fatal error in FLATMEMKAMEZAWA Hiroyuki
Now, SLAB is configured in very early stage and it can be used in init routine now. But replacing alloc_bootmem() in FLAT/DISCONTIGMEM's page_cgroup() initialization breaks the allocation, now. (Works well in SPARSEMEM case...it supports MEMORY_HOTPLUG and size of page_cgroup is in reasonable size (< 1 << MAX_ORDER.) This patch revive FLATMEM+memory cgroup by using alloc_bootmem. In future, We stop to support FLATMEM (if no users) or rewrite codes for flatmem completely.But this will adds more messy codes and overheads. Reported-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-04-02cgroups: use css id in swap cgroup for saving memory v5KAMEZAWA Hiroyuki
Try to use CSS ID for records in swap_cgroup. By this, on 64bit machine, size of swap_cgroup goes down to 2 bytes from 8bytes. This means, when 2GB of swap is equipped, (assume the page size is 4096bytes) From size of swap_cgroup = 2G/4k * 8 = 4Mbytes. To size of swap_cgroup = 2G/4k * 2 = 1Mbytes. Reduction is large. Of course, there are trade-offs. This CSS ID will add overhead to swap-in/swap-out/swap-free. But in general, - swap is a resource which the user tend to avoid use. - If swap is never used, swap_cgroup area is not used. - Reading traditional manuals, size of swap should be proportional to size of memory. Memory size of machine is increasing now. I think reducing size of swap_cgroup makes sense. Note: - ID->CSS lookup routine has no locks, it's under RCU-Read-Side. - memcg can be obsolete at rmdir() but not freed while refcnt from swap_cgroup is available. Changelog v4->v5: - reworked on to memcg-charge-swapcache-to-proper-memcg.patch Changlog ->v4: - fixed not configured case. - deleted unnecessary comments. - fixed NULL pointer bug. - fixed message in dmesg. [nishimura@mxp.nes.nec.co.jp: css_tryget can be called twice in !PageCgroupUsed case] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: synchronized LRUKAMEZAWA Hiroyuki
A big patch for changing memcg's LRU semantics. Now, - page_cgroup is linked to mem_cgroup's its own LRU (per zone). - LRU of page_cgroup is not synchronous with global LRU. - page and page_cgroup is one-to-one and statically allocated. - To find page_cgroup is on what LRU, you have to check pc->mem_cgroup as - lru = page_cgroup_zoneinfo(pc, nid_of_pc, zid_of_pc); - SwapCache is handled. And, when we handle LRU list of page_cgroup, we do following. pc = lookup_page_cgroup(page); lock_page_cgroup(pc); .....................(1) mz = page_cgroup_zoneinfo(pc); spin_lock(&mz->lru_lock); .....add to LRU spin_unlock(&mz->lru_lock); unlock_page_cgroup(pc); But (1) is spin_lock and we have to be afraid of dead-lock with zone->lru_lock. So, trylock() is used at (1), now. Without (1), we can't trust "mz" is correct. This is a trial to remove this dirty nesting of locks. This patch changes mz->lru_lock to be zone->lru_lock. Then, above sequence will be written as spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU mem_cgroup_add/remove/etc_lru() { pc = lookup_page_cgroup(page); mz = page_cgroup_zoneinfo(pc); if (PageCgroupUsed(pc)) { ....add to LRU } spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU This is much simpler. (*) We're safe even if we don't take lock_page_cgroup(pc). Because.. 1. When pc->mem_cgroup can be modified. - at charge. - at account_move(). 2. at charge the PCG_USED bit is not set before pc->mem_cgroup is fixed. 3. at account_move() the page is isolated and not on LRU. Pros. - easy for maintenance. - memcg can make use of laziness of pagevec. - we don't have to duplicated LRU/Active/Unevictable bit in page_cgroup. - LRU status of memcg will be synchronized with global LRU's one. - # of locks are reduced. - account_move() is simplified very much. Cons. - may increase cost of LRU rotation. (no impact if memcg is not configured.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: swap cgroup for remembering usageKAMEZAWA Hiroyuki
For accounting swap, we need a record per swap entry, at least. This patch adds following function. - swap_cgroup_swapon() .... called from swapon - swap_cgroup_swapoff() ... called at the end of swapoff. - swap_cgroup_record() .... record information of swap entry. - swap_cgroup_lookup() .... lookup information of swap entry. This patch just implements "how to record information". No actual method for limit the usage of swap. These routine uses flat table to record and lookup. "wise" lookup system like radix-tree requires requires memory allocation at new records but swap-out is usually called under memory shortage (or memcg hits limit.) So, I used static allocation. (maybe dynamic allocation is not very hard but it adds additional memory allocation in memory shortage path.) Note1: In this, we use pointer to record information and this means 8bytes per swap entry. I think we can reduce this when we create "id of cgroup" in the range of 0-65535 or 0-255. Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Hugh Dickins <hugh@veritas.com> Reported-by: Balbir Singh <balbir@linux.vnet.ibm.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30meminit section warningsAl Viro
2008-10-23memcg: fix page_cgroup allocationKAMEZAWA Hiroyuki
page_cgroup_init() is called from mem_cgroup_init(). But at this point, we cannot call alloc_bootmem(). (and this caused panic at boot.) This patch moves page_cgroup_init() to init/main.c. Time table is following: == parse_args(). # we can trust mem_cgroup_subsys.disabled bit after this. .... cgroup_init_early() # "early" init of cgroup. .... setup_arch() # memmap is allocated. ... page_cgroup_init(); mem_init(); # we cannot call alloc_bootmem after this. .... cgroup_init() # mem_cgroup is initialized. == Before page_cgroup_init(), mem_map must be initialized. So, I added page_cgroup_init() to init/main.c directly. (*) maybe this is not very clean but - cgroup_init_early() is too early - in cgroup_init(), we have to use vmalloc instead of alloc_bootmem(). use of vmalloc area in x86-32 is important and we should avoid very large vmalloc() in x86-32. So, we want to use alloc_bootmem() and added page_cgroup_init() directly to init/main.c [akpm@linux-foundation.org: remove unneeded/bad mem_cgroup_subsys declaration] [akpm@linux-foundation.org: fix build] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
