path: root/include/linux/pci_hotplug.h
2010-02-22PCI: Make current and maximum bus speeds part of the PCI coreMatthew Wilcox
Move the max_bus_speed and cur_bus_speed into the pci_bus. Expose the values through the PCI slot driver instead of the hotplug slot driver. Update all the hotplug drivers to use the pci_bus instead of their own data structures. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Unify pcie_link_speed and pci_bus_speedMatthew Wilcox
These enums must not overlap anyway, since we only have a single pci_bus_speed_strings array. Use a single enum, and move it to pci.h. Add 'SPEED' to the pcie names to make it clear what they are. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-14PCI hotplug: acpiphp: use generic pci_configure_slot()Bjorn Helgaas
Use the generic pci_configure_slot() rather than the acpiphp-specific decode_hpp() and program_hpp(). Unlike the previous acpiphp-specific code, pci_configure_slot() programs PCIe settings when an _HPX method provides them, so acpiphp-managed PCIe devices can now be configured. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-14PCI hotplug: add pci_configure_slot()Bjorn Helgaas
This patch adds a new pci_configure_slot() function that programs the PCI bus characteristics for a newly-added device. This is based on code in pciehp_pci.c, but should be generic enough to be used by pciehp, shpchp, and acpiphp. The hotplug_params struct and the program_hpp_typeX() functions are based on the ACPI definitions, but they aren't really ACPI-specific, and there's no alternate implementation, so I don't see the need to abstract them yet. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-14PCI hotplug: clean up acpi_get_hp_params_from_firmware() interfaceBjorn Helgaas
This patch makes acpi_get_hp_params_from_firmware() take a pci_dev rather than a pci_bus and makes it return a standard int errno rather than acpi_status. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-14PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handleAlex Chiang
acpi_pci_detect_ejectable() goes through effort to convert its struct pci_bus arg to an acpi_handle, but every time we use this interface, we already have the handle available. So let's just use the handle instead of converting back and forth. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Tested-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI hotplug: add support for 5.0G link speedKenji Kaneshige
Add support for PCI-E 5.0 GT/s in max_bus_speed and cur_bus_speed. Reviewed-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-24Merge branches 'acerhdf', 'acpi-pci-bind', 'bjorn-pci-root', ↵Len Brown
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
2009-06-17ACPI: Introduce acpi_is_root_bridge()Alexander Chiang
Returns whether an ACPI CA node is a PCI root bridge or not. This API is generically useful, and shouldn't just be a hotplug function. The implementation becomes much simpler as well. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-16PCI hotplug: create symlink to hotplug driver moduleKenji Kaneshige
Create symbolic link to hotplug driver module in the PCI slot directory (/sys/bus/pci/slots/<SLOT#>). In the past, we need to load hotplug drivers one by one to identify the hotplug driver that handles the slot, and it was very inconvenient especially for trouble shooting. With this change, we can easily identify the hotplug driver. Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI: Remove untested Electromechanical Interlock (EMI) support in pciehp.Kenji Kaneshige
The EMI support in pciehp is obviously broken. It is implemented using struct hotplug_slot_attribute, but sysfs_ops for pci_slot_ktype is NOT for struct hotplug_slot_attribute, but for struct pci_slot_attribute. This bug had been there for a long time, maybe it was introduced when PCI slot framework was introduced. The reason why this bug didn't cause any problem is maybe the EMI support is not tested at all because of lack of test environment. As described above, the EMI support in pciehp seems not to be tested at all. So this patch removes EMI support from pciehp, instead of fixing the bug. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-07PCI hotplug: introduce functions for ACPI slot detectionKenji Kaneshige
Some ACPI related PCI hotplug code can be shared among PCI hotplug drivers. This patch introduces the following functions in drivers/pci/hotplug/acpi_pcihp.c to share the code, and changes acpiphp and pciehp to use them. - int acpi_pci_detect_ejectable(struct pci_bus *pbus) This checks if the specified PCI bus has ejectable slots. - int acpi_pci_check_ejectable(struct pci_bus *pbus, acpi_handle handle) This checks if the specified handle is ejectable ACPI PCI slot. The 'pbus' parameter is needed to check if 'handle' is PCI related ACPI object. This patch also introduces the following inline function in include/linux/pci-acpi.h, which is useful to get ACPI handle of the PCI bridge from struct pci_bus of the bridge's secondary bus. - static inline acpi_handle acpi_pci_get_bridge_handle(struct pci_bus *pbus) This returns ACPI handle of the PCI bridge which generates PCI bus specified by 'pbus'. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-12-31ACPI: remove private acpica headers from driver filesLin Ming
External driver files should not include any private acpica headers. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22PCI: Hotplug core: remove 'name'Alex Chiang
Now that the PCI core manages the 'name' for each individual hotplug driver, and all drivers (except rpaphp) have been converted to use hotplug_slot_name(), there is no need for the PCI hotplug core to drag around its own copy of name either. Cc: kristen.c.accardi@intel.com Cc: matthew@wil.cx Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-22PCI, PCI Hotplug: introduce slot_name helpersAlex Chiang
In preparation for cleaning up the various hotplug drivers such that they don't have to manage their own 'name' parameters anymore, we provide the following convenience functions: pci_slot_name() hotplug_slot_name() These helpers will be used by individual hotplug drivers. Cc: kristen.c.accardi@intel.com Cc: matthew@wil.cx Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-22PCI Hotplug core: add 'name' param pci_hp_register interfaceAlex Chiang
Update pci_hp_register() to take a const char *name parameter. The motivation for this is to clean up the individual hotplug drivers so that each one does not have to manage its own name. The PCI core should be the place where we manage the name. We update the interface and all callsites first, in a "no functional change" manner, and clean up the drivers later. Cc: kristen.c.accardi@intel.com Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10PCI: introduce pci_slotAlex Chiang
Currently, /sys/bus/pci/slots/ only exposes hotplug attributes when a hotplug driver is loaded, but PCI slots have attributes such as address, speed, width, etc. that are not related to hotplug at all. Introduce pci_slot as the primary data structure and kobject model. Hotplug attributes described in hotplug_slot become a secondary structure associated with the pci_slot. This patch only creates the infrastructure that allows the separation of PCI slot attributes and hotplug attributes. In this patch, the PCI hotplug core remains the only user of this infrastructure, and thus, /sys/bus/pci/slots/ will still only become populated when a hotplug driver is loaded. A later patch in this series will add a second user of this new infrastructure and demonstrate splitting the task of exposing pci_slot attributes from hotplug_slot attributes. - Make pci_slot the primary sysfs entity. hotplug_slot becomes a subsidiary structure. o pci_create_slot() creates and registers a slot with the PCI core o pci_slot_add_hotplug() gives it hotplug capability - Change the prototype of pci_hp_register() to take the bus and slot number (on parent bus) as parameters. - Remove all the ->get_address methods since this functionality is now handled by pci_slot directly. [achiang@hp.com: rpaphp-correctly-pci_hp_register-for-empty-pci-slots] Tested-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: make headers_check happy] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: fix typo in #include] Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Cc: Greg KH <greg@kroah.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Len Brown <lenb@kernel.org> Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10shpchp: check firmware before taking controlKenji Kaneshige
Fix the following problems of shpchp driver about getting hotplug control from firmware. - The shpchp driver must not control the hotplug controller if it fails to get control from the firmware. But current shpchp controls the hotplug controller regardless the result, because it doesn't check the return value of get_hp_hw_control_from_firmware(). - Current shpchp driver doesn't support _OSC. The pciehp driver already have the code for evaluating _OSC and OSHP and shpchp and pciehp can share it. So this patch move that code from pciehp to acpi_pcihp.c. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-01-24kset: convert pci hotplug to use kset_create_and_addGreg Kroah-Hartman
This also renames pci_hotplug_slots_subsys to pcis_hotplug_slots_kset catch all current users with a build error instead of a build warning which can easily be missed. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18PCI Hotplug: move pci_hotplug.h to include/linux/Greg Kroah-Hartman
This makes it possible to build pci hotplug drivers outside of the main kernel tree, and Sam keeps telling me to move local header files to their proper places... Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
