Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Cc: <stable@kernel.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
This adds the PCI ID for the xHCI (USB 3.0) host controller in the Intel
Panther Point chipset. It will be used by both the EHCI and xHCI driver
in the following patches.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits)
PCI: Don't use dmi_name_in_vendors in quirk
PCI: remove unused AER functions
PCI/sysfs: move bus cpuaffinity to class dev_attrs
PCI: add rescan to /sys/.../pci_bus/.../
PCI: update bridge resources to get more big ranges when allocating space (again)
KVM: Use pci_store/load_saved_state() around VM device usage
PCI: Add interfaces to store and load the device saved state
PCI: Track the size of each saved capability data area
PCI/e1000e: Add and use pci_disable_link_state_locked()
x86/PCI: derive pcibios_last_bus from ACPI MCFG
PCI: add latency tolerance reporting enable/disable support
PCI: add OBFF enable/disable support
PCI: add ID-based ordering enable/disable support
PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot.
PCI: Set PCIE maxpayload for card during hotplug insertion
PCI/ACPI: Report _OSC control mask returned on failure to get control
x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs
PCI: handle positive error codes
PCI: check pci_vpd_pci22_wait() return
PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio
Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461
moved the intel SMBUS ID definitons to the i2c-i801.c driver.
The old IDE cmd64x checks the status of the CNTRL register to see if
the ports are enabled before probing them. pata_cmd64x doesn't do
this, which causes a HPMC on parisc when it tries to poke at the
secondary port because apparently the BAR isn't wired up (and a
non-responding piece of memory causes a HPMC).
Fix this by porting the CNTRL register port detection logic from IDE
cmd64x. In addition, following converns from Alan Cox, add a check to
see if a mobility electronics bridge is the immediate parent and forgo
the check if it is (prevents problems on hotplug controllers).
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
This patch adds the LPC Controller DeviceIDs for the Intel Panther Point PCH.
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Move the SMBus device ID definitions of recent devices from pci_ids.h
to the i2c-i801.c driver file. They don't have to be shared, as they
are clearly identified and only used in this driver. In the future,
such IDs will go to i2c-i801 directly. This will make adding support
for new devices much faster and easier, as it will avoid cross-
subsystem patch sets and merge conflicts.
Cc: Seth Heasley <seth.heasley@intel.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
With increasing number of PCI function ids, add the PCI function
id in the define name instead of its symbolic name in the BKDG
for more clarity. This renames function 4 define.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
LKML-Reference: <20110330183447.GA3668@aftab>
Signed-off-by: Denis Turischev <denis@compulab.co.il>
PCI: label: remove #include of ACPI header to avoid warnings
PCI: label: Fix compilation error when CONFIG_ACPI is unset
PCI: pre-allocate additional resources to devices only after successful allocation of essential resources.
PCI: introduce reset_resource()
PCI: data structure agnostic free list function
PCI: refactor io size calculation code
PCI: do not create quirk I/O regions below PCIBIOS_MIN_IO for ICH
PCI hotplug: acpiphp: set current_state to D0 in register_slot
PCI: Export ACPI _DSM provided firmware instance number and string name to sysfs
PCI: add more checking to ICH region quirks
PCI: aer-inject: Override PCIe AER Mask Registers
PCI: fix tlan build when CONFIG_PCI is not enabled
PCI: remove quirk for pre-production systems
PCI: Avoid potential NULL pointer dereference in pci_scan_bridge
PCI/lpc: irq and pci_ids patch for Intel DH89xxCC DeviceIDs
PCI: sysfs: Fix failure path for addition of "vpd" attribute
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits)
[SCSI] scsi_dh_rdac: Add MD36xxf into device list
[SCSI] scsi_debug: add consecutive medium errors
[SCSI] libsas: fix ata list corruption issue
[SCSI] hpsa: export resettable host attribute
[SCSI] hpsa: move device attributes to avoid forward declarations
[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)
[SCSI] sd: Logical Block Provisioning update
[SCSI] Include protection operation in SCSI command trace
[SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try)
[SCSI] target: Fix volume size misreporting for volumes > 2TB
[SCSI] bnx2fc: Broadcom FCoE offload driver
[SCSI] fcoe: fix broken fcoe interface reset
[SCSI] fcoe: precedence bug in fcoe_filter_frames()
[SCSI] libfcoe: Remove stale fcoe-netdev entries
[SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h
[SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument
[SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs
[SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out"
[SCSI] libfc: Fixing a memory leak when destroying an interface
[SCSI] megaraid_sas: Version and Changelog update
Fix up trivial conflicts due to whitespace differences in
drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (38 commits)
amd64_edac: Fix decode_syndrome types
amd64_edac: Fix DCT argument type
amd64_edac: Fix ranges signedness
amd64_edac: Drop local variable
amd64_edac: Fix PCI config addressing types
amd64_edac: Fix DRAM base macros
amd64_edac: Fix node id signedness
amd64_edac: Drop redundant declarations
amd64_edac: Enable driver on F15h
amd64_edac: Adjust ECC symbol size to F15h
amd64_edac: Simplify scrubrate setting
PCI: Rename CPU PCI id define
amd64_edac: Improve DRAM address mapping
amd64_edac: Sanitize ->read_dram_ctl_register
amd64_edac: Adjust sys_addr to chip select conversion routine to F15h
amd64_edac: Beef up early exit reporting
amd64_edac: Revamp online spare handling
amd64_edac: Fix channel interleave removal
amd64_edac: Correct node interleaving removal
amd64_edac: Add support for interleaved region swapping
Fix up trivial conflict in include/linux/pci_ids.h due to
AMD_15H_NB_MISC being renamed as AMD_15H_NB_F3 next to the new
AMD_15H_NB_LINK entry.
With increasing number of PCI function ids, add the PCI function id
in the define name instead of its symbolic name in the BKDG for more
clarity.
Moved all PCI_DEVICE_ID_NX2_57712(E) definitions to pci_ids.h
Signed-off-by: Eddie Wai <eddie.wai@broadcom.com>
Acked-by: Michael Chan <mchan@broadcom.com>
Acked-by: Eilon Greenstein <eilong@broadcom.com>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
This patch adds the LPC Controller DeviceIDs for the Intel DH89xxCC PCH.
The code for capturing ranges of LPC Controller DeviceIDs has also been updated.
"Link Control" devices (NB function 4) will be used by L3 cache
partitioning on family 0x15.
Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: <andreas.herrmann3@amd.com>
LKML-Reference: <1295881543-572552-4-git-send-email-hans.rosenfeld@amd.com>
PCI/PM: Report wakeup events before resuming devices
PCI/PM: Use pm_wakeup_event() directly for reporting wakeup events
PCI: sysfs: Update ROM to include default owner write access
x86/PCI: make Broadcom CNB20LE driver EMBEDDED and EXPERIMENTAL
x86/PCI: don't use native Broadcom CNB20LE driver when ACPI is available
PCI/ACPI: Request _OSC control once for each root bridge (v3)
PCI: enable pci=bfsort by default on future Dell systems
PCI/PCIe: Clear Root PME Status bits early during system resume
PCI: pci-stub: ignore zero-length id parameters
x86/PCI: irq and pci_ids patch for Intel Patsburg
PCI: Skip id checking if no id is passed
PCI: fix __pci_device_probe kernel-doc warning
PCI: make pci_restore_state return void
PCI: Disable ASPM if BIOS asks us to
PCI: Add mask bit definition for MSI-X table
PCI: MSI: Move MSI-X entry definition to pci_regs.h
Fix up trivial conflicts in drivers/net/{skge.c,sky2.c} that had in the
meantime been converted to not use legacy PCI power management, and thus
no longer use pci_restore_state() at all (and that caused trivial
conflicts with the "make pci_restore_state return void" patch)
Signed-off-by: Aries Lee <arieslee@jmicron.com>
Cc: Alex Dubov <oakad@yahoo.com>
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix Moorestown VRTC fixmap placement
x86/gpio: Implement x86 gpio_to_irq convert function
x86, UV: Fix APICID shift for Westmere processors
x86: Use PCI method for enabling AMD extended config space before MSR method
x86: tsc: Prevent delayed init if initial tsc calibration failed
x86, lapic-timer: Increase the max_delta to 31 bits
x86: Fix sparse non-ANSI function warnings in smpboot.c
x86, numa: Fix CONFIG_DEBUG_PER_CPU_MAPS without NUMA emulation
x86, AMD, PCI: Add AMD northbridge PCI device id for CPU families 12h and 14h
x86, numa: Fix cpu to node mapping for sparse node ids
x86, numa: Fake node-to-cpumask for NUMA emulation
x86, numa: Fake apicid and pxm mappings for NUMA emulation
x86, numa: Avoid compiling NUMA emulation functions without CONFIG_NUMA_EMU
x86, numa: Reduce minimum fake node size to 32M
Fix up trivial conflict in arch/x86/kernel/apic/x2apic_uv_x.c
JMicron 388 SD/MMC combo controller supports the 1.8V low-voltage for
SD, but MMC doesn't work with the low-voltage, resulting in an error
at probing.
This patch adds the support for multiple voltage mask per device type,
so that SD works with 1.8V while MMC forces 3.3V. Here new ocr_avail_*
fields for each device are introduced, so that the actual OCR mask is
switched dynamically.
Also, the restriction of low-voltage in core/sd.c is removed when the
bit is allowed explicitly via ocr_avail_sd mask.
This patch was rewritten from scratch based on Aries' original code.
Reviewed-by: Chris Ball <cjb@laptop.org>
This patch disables the broken ADMA on selected O2Micro devices.
Signed-off-by: Jennifer Li <Jennifer.li@o2micro.com>
This patch adds the PCI northbridge device id for AMD CPU
families 12h and 14h. Both families have implemented the same
PCI northbridge device.
There are some future use cases that use this PCI device and
we would like to clarify its naming.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: xen-devel@lists.xensource.com <xen-devel@lists.xensource.com>
Cc: Keir Fraser <keir@xen.org>
Cc: Jan Beulich <JBeulich@novell.com>
LKML-Reference: <20110106165107.GL4739@erda.amd.com>
This patch adds an additional LPC Controller DeviceID for the Intel
Patsburg PCH.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits)
af_unix: limit recursion level
pch_gbe driver: The wrong of initializer entry
pch_gbe dreiver: chang author
ucc_geth: fix ucc halt problem in half duplex mode
inet: Fix __inet_inherit_port() to correctly increment bsockets and num_owners
ehea: Add some info messages and fix an issue
hso: fix disable_net
NET: wan/x25_asy, move lapb_unregister to x25_asy_close_tty
cxgb4vf: fix setting unicast/multicast addresses ...
net, ppp: Report correct error code if unit allocation failed
DECnet: don't leak uninitialized stack byte
au1000_eth: fix invalid address accessing the MAC enable register
dccp: fix error in updating the GAR
tcp: restrict net.ipv4.tcp_adv_win_scale (#20312)
netns: Don't leak others' openreq-s in proc
Net: ceph: Makefile: Remove unnessary code
vhost/net: fix rcu check usage
econet: fix CVE-2010-3848
econet: fix CVE-2010-3850
econet: disallow NULL remote addr for sendmsg(), fixes CVE-2010-3849
Add new vendor for Broadcom 4318.
Signed-off-by: Daniel Klaffenbach <danielklaffenbach@gmail.com>
Cc: Stable <stable@kernel.org>
SDHC2 is newly added in C0 stepping of Langwell. Without the Moorestown
specific quirk, the default pci_probe will be called and crash the kernel.
This patch unblocks the crash problem on C0 by using the same probing
function as HC1, which limits the number of slots to one.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Add support for the Intel Patsburg PCH SMBus Controller.
x86: allocate space within a region top-down
x86: update iomem_resource end based on CPU physical address capabilities
x86/PCI: allocate space from the end of a region, not the beginning
PCI: allocate bus resources from the top down
resources: support allocating space within a region from the top down
resources: handle overflow when aligning start of available area
resources: ensure callback doesn't allocate outside available space
resources: factor out resource_clip() to simplify find_resource()
resources: add a default alignf to simplify find_resource()
x86/PCI: MMCONFIG: fix region end calculation
PCI: Add support for polling PME state on suspended legacy PCI devices
PCI: Export some PCI PM functionality
PCI: fix message typo
PCI: log vendor/device ID always
PCI: update Intel chipset names and defines
PCI: use new ccflags variable in Makefile
PCI: add PCI_MSIX_TABLE/PBA defines
PCI: add PCI vendor id for STmicroelectronics
x86/PCI: irq and pci_ids patch for Intel Patsburg DeviceIDs
PCI: OLPC: Only enable PCI configuration type override on XO-1
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits)
mmc: add new sdhci-pxa driver for Marvell SoCs
mmc: make number of mmcblk minors configurable
mmc_spi: Recover from CRC errors for r/w operation over SPI.
mmc: sdhci-pltfm: add -pltfm driver for imx35/51
mmc: sdhci-of-esdhc: factor out common stuff
mmc: sdhci_pltfm: pass more data on custom init call
mmc: sdhci: introduce get_ro private write-protect hook
mmc: sdhci-pltfm: move .h file into appropriate subdir
mmc: sdhci-pltfm: Add structure for host-specific data
mmc: fix cb710 kconfig dependency warning
mmc: cb710: remove debugging printk (info duplicated from mmc-core)
mmc: cb710: clear irq handler on init() error path
mmc: cb710: remove unnecessary msleep()
mmc: cb710: implement get_cd() callback
mmc: cb710: partially demystify clock selection
mmc: add a file to debugfs for changing host clock at runtime
mmc: sdhci: allow for eMMC 74 clock generation by controller
mmc: sdhci: highspeed: check for mmc as well as sd cards
mmc: sdhci: Add Moorestown device support
mmc: sdhci: Intel Medfield support
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits)
sh: i2c-sh7760: Replase from ctrl_* to __raw_*
sh: clkfwk: Shuffle around to match the intc split up.
sh: clkfwk: modify for_each_frequency end condition
sh: fix clk_get() error handling
sh: clkfwk: Fix fault in frequency iterator.
sh: clkfwk: Add a helper for rate rounding by divisor ranges.
sh: clkfwk: Abstract rate rounding helper.
sh: clkfwk: support clock remapping.
sh: pci: Convert to upper/lower_32_bits() helpers.
sh: mach-sdk7786: Add support for the FPGA SRAM.
sh: Provide a generic SRAM pool for tiny memories.
sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786.
sh: pci: Support slot 4 routing on SDK7786.
sh: Fix up PMB locking.
sh: mach-sdk7786: Add support for fpga gpios.
sh: use pr_fmt for clock framework, too.
sh: remove name and id from struct clk
sh: free-without-alloc fix for sh_mobile_lcdcfb
sh: perf: Set up perf_max_events.
sh: perf: Support SH-X3 hardware counters.
Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/edac
* 'devel' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/edac: (25 commits)
i7300_edac: Properly initialize per-csrow memory size
V4L/DVB: i7300_edac: better initialize page counts
MAINTAINERS: Add maintainer for i7300-edac driver
i7300-edac: CodingStyle cleanup
i7300_edac: Improve comments
i7300_edac: Cleanup: reorganize the file contents
i7300_edac: Properly detect channel on CE errors
i7300_edac: enrich FBD error info for corrected errors
i7300_edac: enrich FBD error info for fatal errors
i7300_edac: pre-allocate a buffer used to prepare err messages
i7300_edac: Fix MTR x4/x8 detection logic
i7300_edac: Make the debug messages coherent with the others
i7300_edac: Cleanup: remove get_error_info logic
i7300_edac: Add a code to cleanup error registers
i7300_edac: Add support for reporting FBD errors
i7300_edac: Properly detect the type of error correction
i7300_edac: Detect if the device is on single mode
i7300_edac: Adds detection for enhanced scrub mode on x8
i7300_edac: Clear the error bit after reading
i7300_edac: Add error detection code for global errors
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
Basic support for the Intel Medfield devices
Give them their own quirks as we will need to update this later.
Signed-off-by: Xiaochen Shen <xiaochen.shen@intel.com>
* 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-block: (95 commits)
cciss: fix PCI IDs for new Smart Array controllers
drbd: add race-breaker to drbd_go_diskless
drbd: use dynamic_dev_dbg to optionally log uuid changes
dynamic_debug.h: Fix dynamic_dev_dbg() macro if CONFIG_DYNAMIC_DEBUG not set
drbd: cleanup: change "<= 0" to "== 0"
drbd: relax the grace period of the md_sync timer again
drbd: add some more explicit drbd_md_sync
drbd: drop wrong debug asserts, fix recently introduced race
drbd: cleanup useless leftover warn/error printk's
drbd: add explicit drbd_md_sync to drbd_resync_finished
drbd: Do not log an ASSERT for P_OV_REQUEST packets while C_CONNECTED
drbd: fix for possible deadlock on IO error during resync
drbd: fix unlikely access after free and list corruption
drbd: fix for spurious fullsync (uuids rotated too fast)
drbd: allow for explicit resync-finished notifications
drbd: preparation commit, using full state in receive_state()
drbd: drbd_send_ack_dp must not rely on header information
drbd: Fix regression in recv_bm_rle_bits (compressed bitmap)
drbd: Fixed a stupid copy and paste error
drbd: Allow larger values for c-fill-target.
Fix up trivial conflict in drivers/block/ataflop.c due to BKL removal
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (71 commits)
powerpc/44x: Update ppc44x_defconfig
powerpc/watchdog: Make default timeout for Book-E watchdog a Kconfig option
fsl_rio: Add comments for sRIO registers.
powerpc/fsl-booke: Add e55xx (64-bit) smp defconfig
powerpc/fsl-booke: Add p5020 DS board support
powerpc/fsl-booke64: Use TLB CAMs to cover linear mapping on FSL 64-bit chips
powerpc/fsl-booke: Add support for FSL Arch v1.0 MMU in setup_page_sizes
powerpc/fsl-booke: Add support for FSL 64-bit e5500 core
powerpc/85xx: add cache-sram support
powerpc/85xx: add ngPIXIS FPGA device tree node to the P1022DS board
powerpc: Fix compile error with paca code on ppc64e
powerpc/fsl-booke: Add p3041 DS board support
oprofile/fsl emb: Don't set MSR[PMM] until after clearing the interrupt.
powerpc/fsl-booke: Add PCI device ids for P2040/P3041/P5010/P5020 QoirQ chips
powerpc/mpc8xxx_gpio: Add support for 'qoriq-gpio' controllers
powerpc/fsl_booke: Add support to boot from core other than 0
powerpc/p1022: Add probing for individual DMA channels
powerpc/fsl_soc: Search all global-utilities nodes for rstccr
powerpc: Fix invalid page flags in create TLB CAM path for PTE_64BIT
powerpc/mpc83xx: Support for MPC8308 P1M board
Fix up conflict with the generic irq_work changes in arch/powerpc/kernel/time.c
* 'x86-amd-nb-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, amd_nb: Enable GART support for AMD family 0x15 CPUs
x86, amd: Use compute unit information to determine thread siblings
x86, amd: Extract compute unit information for AMD CPUs
x86, amd: Add support for CPUID topology extension of AMD CPUs
x86, nmi: Support NMI watchdog on newer AMD CPU families
x86, mtrr: Assume SYS_CFG[Tom2ForceMemTypeWB] exists on all future AMD CPUs
x86, k8: Rename k8.[ch] to amd_nb.[ch] and CONFIG_K8_NB to CONFIG_AMD_NB
x86, k8-gart: Decouple handling of garts and northbridges
x86, cacheinfo: Fix dependency of AMD L3 CID
x86, kvm: add new AMD SVM feature bits
x86, cpu: Fix allowed CPUID bits for KVM guests
x86, cpu: Update AMD CPUID feature bits
x86, cpu: Fix renamed, not-yet-shipping AMD CPUID feature bit
x86, AMD: Remove needless CPU family check (for L3 cache info)
x86, tsc: Remove CPU frequency calibration on AMD
cciss: fix PCI IDs for new controllers
This patch fixes the botched up PCI IDs of new controllers. Please consider
this patch for inclusion.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
This patch updates the defines for Intel devices in
include/linux/pci_ids.h, referenced in arch/x86/pci/irq.c and
drivers/i2c/busses/i2c-i801.c, reflecting approved legal branding, and
using fuller code-names for products under development.
Signed-off-by: Anders Wallin <anders.wallin@windriver.com>
This patch adds the LPC Controller DeviceIDs for the Intel Patsburg PCH.
MCP55 northbridge
A long time ago I worked on a RHEL5 bug in which kdump hung during boot
on a set of systems. The systems hung because they never received timer
interrupts during calibrate_delay. These systems also all had Opteron
processors on a hypertransport bus, bridged to a pci bus via an Nvidia
MCP55 northbridge chip. After much wrangling I managed to learn from
Nvidia that they have an undocumented register in some versions of that
chip which control how legacy interrupts are send to the cpu complex
when the ioapic isn't active. Nvidia defaults this register to only
send legacy interrupts to the BSP, so if kdump happens to boot on an AP,
we never get timer interrupts and boom. I had initially used this quirk
as a workaround, with my intent being to move apic initalization to an
earlier point in the boot process, so the setting of the register would
be irrelevant. Given the work involved in doing that however, the
fragile nature of the apic initalization code, and the fact that, over
the 2 years since we found this bug, the MCP55 is the only chip which
seems to have this issue, I've figure at this point its likely safer to
just carry the quirk around. By setting the referenced bits in this
hidden register, interrupts will be broadcast to all cpus when the
ioapic isn't active on the above described systems.
Acked-by: Simon Horman <horms@verge.net.au>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
drivers/net/pcmcia/pcnet_cs.c
net/caif/caif_socket.c
AMD CPU family 0x15 still supports GART for compatibility reasons.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
LKML-Reference: <20100930124316.GG20545@loge.amd.com>
This patch adds a workaround for an IOMMU BIOS problem to
the AMD IOMMU driver. The result of the bug is that the
IOMMU does not execute commands anymore when the system
comes out of the S3 state resulting in system failure. The
bug in the BIOS is that is does not restore certain hardware
specific registers correctly. This workaround reads out the
contents of these registers at boot time and restores them
on resume from S3. The workaround is limited to the specific
IOMMU chipset where this problem occurs.
Cc: stable@kernel.org
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Previously these IDs were only used by one driver, so there was not much
need for having them generically defined. Now that this will no longer
hold true, move them over.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
net/mac80211/main.c
This is needed for proper PCI-E support on P1021 SoCs.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
This is patch 1/6 which contains linux driver source for
Brocade's BR1010/BR1020 10Gb CEE capable ethernet adapter.
Signed-off-by: Debashis Dutt <ddutt@brocade.com>
Signed-off-by: Rasesh Mody <rmody@brocade.com>
