path: root/include/linux/pci_ids.h
2007-09-11PCI: irq and pci_ids patch for Intel TolapaiJason Gaston
This patch adds the Intel Tolapai LPC and SMBus Controller DID's. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-10[libata, IDE] add new VIA bridge to VIA PATA driversJoseph Chan
Signed-off-by: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31i2c-piix4: Fix SB700 PCI device IDShane Huang
We find that SB700 and SB800 use the same SMBus device ID as SB600, which is 0x4385, instead of the already submitted 0x4395. Besides removing the wrong SB700 device ID, add SB800 support to kernel, by renaming the PCI_DEVICE_ID_ATI_IXP600_SMBUS into PCI_DEVICE_ID_ATI_SBX00_SMBUS. Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-25Merge branch 'agp-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp: balance ioremap checks agp: Add device id for P4M900 to via-agp module efficeon-agp leaks 'struct agp_bridge_data' in error paths of agp_efficeon_probe()
2007-08-25agp: Add device id for P4M900 to via-agp moduleXavier Bachelot
Signed-off-by: Dave Airlie <airlied@linux.ie>
2007-08-22PCI: disable MSI on RX790Tejun Heo
RX790 can't do MSI like its predecessors. Disable MSI on RX790. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22PCI: disable MSI on RD580Tejun Heo
RD580 can't do MSI like its predecessors. Disable MSI on RD580. Signed-off-by: Tejun Heo <teheo@suse.de> CC: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22PCI: disable MSI on RS690Tejun Heo
RS690 can't do MSI like its predecessors. Disable MSI on RS690. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Henry Su <henry.su@amd.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-21[POWERPC] Fix PCI Device ID for MPC8544/8533 processorsKumar Gala
The initial user manuals for MPC8544/8533 had some issues with properly documenting the device IDs for MPC8544/8533. These processors are almost identical and both show up on the reference boards. Fix up the quirks for PCIe support to handle MPC8533/E. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-31DDB5477: remove driver bits of supportYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: drivers/mmc/core/: make 3 functions static mmc: add missing printk levels mmc: remove redundant debug information from sdhci and wbsd mmc: proper debugging output in core mmc: be more verbose about card insertions/removal mmc: Don't hold lock when releasing an added card mmc: add a might_sleep() to mmc_claim_host() mmc: update kerneldoc mmc: update header file paths sdhci: add support to ENE-CB714 mmc: check error bits before command completion
2007-07-26sdhci: add support to ENE-CB714Leandro Dorileo
Added its pci_id and implemented a quirk for it because this controller needs to reset cmd and data when setting ios. Signed-off-by: Leandro Dorileo <dorileo@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-24Merge branch 'for_paulus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc * 'for_paulus' of master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc: (25 commits) [POWERPC] 85xx: Added needed MPC85xx PCI device IDs [POWERPC] Add Freescale PCI VENDOR ID and 8641 device IDs [POWERPC] 85xxCDS: MPC8548 DTS cleanup. [POWERPC] 85xxCDS: Misc 8548 PCI Corrections. [POWERPC] 85xxCDS: Delay 8259 cascade hookup. [POWERPC] 85xxCDS: Make sure restart resets the PCI bus. [POWERPC] 85xxCDS: Allow 8259 cascade to share an MPIC interrupt line. [POWERPC] FSL: Add support for PCI-X controllers [POWERPC] Make sure virtual P2P bridge registers are setup on PCIe PHB [POWERPC] Provide ability to setup P2P bridge registers from struct resource [POWERPC] Add basic PCI/PCI Express support for 8544DS board [POWERPC] Make endianess of cfg_addr for indirect pci ops runtime [POWERPC] Removed setup_indirect_pci_nomap [POWERPC] 85xx: Add quirk to ignore bogus FPGA on CDS [POWERPC] 85xx: Added 8568 PCIe support [POWERPC] Fixup resources on pci_bus for PCIe PHB when no device is connected [POWERPC] Add basic PCI node for mpc8568mds board [POWERPC] Use Freescale pci/pcie common code for 85xx boards [POWERPC] Update PCI nodes in the 83xx/85xx boards device tree [POWERPC] Add 8548 CDS PCI express controller node and PCI-X device node ...
2007-07-24forcedeth: new device ids in pci_ids.hAyaz Abdulla
This patch contains new device ids for MCP73 chipset. Signed-Off-By: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24[POWERPC] 85xx: Added needed MPC85xx PCI device IDsKumar Gala
Added the MPC85xx PCI device IDs that we need for the quirks we have. Also, fixed the MPC8567E, MPC8567 device IDs which had the wrong value. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-24[POWERPC] Add Freescale PCI VENDOR ID and 8641 device IDsJon Loeliger
Also add 8641/8641D device IDs as well. All of which already exist or have been submitted to The Linux PCI ID Repository at: http://pci-ids.ucw.cz/ CC-to: pci-ids@ucw.cz Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-22Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits) [SCSI] libsas: make ATA functions selectable by a config option [SCSI] bsg: unexport sg v3 helper functions [SCSI] bsg: fix bsg_unregister_queue [SCSI] bsg: make class backlinks [SCSI] 3w-9xxx: add support for 9690SA [SCSI] bsg: fix bsg_register_queue error path [SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275. [SCSI] libsas: fix scr_read/write users and update the libata documentation [SCSI] mpt fusion: update Kconfig help [SCSI] scsi_transport_sas: add destructor for bsg [SCSI] iscsi_tcp: buggered kmalloc() [SCSI] qla2xxx: Update version number to 8.02.00-k2. [SCSI] qla2xxx: Add ISP25XX support. [SCSI] qla2xxx: Use pci_try_set_mwi(). [SCSI] qla2xxx: Use PCI-X/PCI-Express read control interfaces. [SCSI] qla2xxx: Re-factor isp_operations to static structures. [SCSI] qla2xxx: Validate mid-layer 'underflow' during check-condition handling. [SCSI] qla2xxx: Correct setting of 'current' and 'supported' speeds during FDMI registration. [SCSI] qla2xxx: Generalize iIDMA support. [SCSI] qla2xxx: Generalize FW-Interface-2 support. ...
2007-07-21ACPI: thinkpad-acpi: store ThinkPad model informationHenrique de Moraes Holschuh
Keep note of ThinkPad model, BIOS and EC firmware information, and log it on startup. Makes for far more readable code in places, too. This patch also adds Lenovo's PCI ID to the pci ids table. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-19include/linux/pci_id.h: add amd northbridge definesDouglas Thompson
pci_ids.h needs two of the AMD NB device-ids namely, Addressmap and the Memory Controller devices This patch adds those to the pci_id.h include file Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: new inte 30x0 MC driverJason Uhlenkott
Here's a driver for the Intel 3000 and 3010 memory controllers, relative to today's Sourceforge code drop. This has only had light testing (I've yet to actually see it handle a memory error) but it detects my hardware correctly. Signed-off-by: Jason Uhlenkott <juhlenko@akamai.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18[SCSI] add PCI_VENDOR_ID macro for Brocade in pci_ids.hPrakash, Sathya
Adds PCI_VENDOR_ID_BROCADE macro in include/linux/pci_ids.h file. This macro is used in MPT Fusion FC drivers to support Brocade branded FC controllers signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-13Merge branch 'ioat-md-accel-for-linus' of ↵Linus Torvalds
git://lost.foo-projects.org/~dwillia2/git/iop * 'ioat-md-accel-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: (28 commits) ioatdma: add the unisys "i/oat" pci vendor/device id ARM: Add drivers/dma to arch/arm/Kconfig iop3xx: surface the iop3xx DMA and AAU units to the iop-adma driver iop13xx: surface the iop13xx adma units to the iop-adma driver dmaengine: driver for the iop32x, iop33x, and iop13xx raid engines md: remove raid5 compute_block and compute_parity5 md: handle_stripe5 - request io processing in raid5_run_ops md: handle_stripe5 - add request/completion logic for async expand ops md: handle_stripe5 - add request/completion logic for async read ops md: handle_stripe5 - add request/completion logic for async check ops md: handle_stripe5 - add request/completion logic for async compute ops md: handle_stripe5 - add request/completion logic for async write ops md: common infrastructure for running operations with raid5_run_ops md: raid5_run_ops - run stripe operations outside sh->lock raid5: replace custom debug PRINTKs with standard pr_debug raid5: refactor handle_stripe5 and handle_stripe6 (v3) async_tx: add the async_tx api xor: make 'xor_blocks' a library routine for use with async_tx dmaengine: make clients responsible for managing channels dmaengine: refactor dmaengine around dma_async_tx_descriptor ...
2007-07-13ioatdma: add the unisys "i/oat" pci vendor/device idDan Williams
Cc: John Magolan <john.magolan@unisys.com> Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2007-07-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (34 commits) PCI: Only build PCI syscalls on architectures that want them PCI: limit pci_get_bus_and_slot to domain 0 PCI: hotplug: acpiphp: avoid acpiphp "cannot get bridge info" PCI hotplug failure PCI: hotplug: acpiphp: remove hot plug parameter write to PCI host bridge PCI: hotplug: acpiphp: fix slot poweroff problem on systems without _PS3 PCI: hotplug: pciehp: wait for 1 second after power off slot PCI: pci_set_power_state(): check for PM capabilities earlier PCI: cpci_hotplug: Convert to use the kthread API PCI: add pci_try_set_mwi PCI: pcie: remove SPIN_LOCK_UNLOCKED PCI: ROUND_UP macro cleanup in drivers/pci PCI: remove pci_dac_dma_... APIs PCI: pci-x-pci-express-read-control-interfaces cleanups PCI: Fix typo in include/linux/pci.h PCI: pci_ids, remove double or more empty lines PCI: pci_ids, add atheros and 3com_2 vendors PCI: pci_ids, reorder some entries PCI: i386: traps, change VENDOR to DEVICE PCI: ATM: lanai, change VENDOR to DEVICE PCI: Change all drivers to use pci_device->revision ...
2007-07-12i2c-piix4: Add support for the ATI SB700Henry Su
Add the SMBus device ID for ATI SB700. Signed-off-by: Henry Su <Henry.su@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-11PCI: pci_ids, remove double or more empty linesJiri Slaby
pci_ids, remove two or more empty lines Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: pci_ids, add atheros and 3com_2 vendorsJiri Slaby
pci_ids, add atheros and 3com_2 vendors Atheros is wifi vendor. 3com_2 (0xa727) is an vendor id for one card with ath chip. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: pci_ids, reorder some entriesJiri Slaby
pci_ids, reorder some entries Some lines are not vendor sorted, reorder it to comply with the rest of document. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: i386: traps, change VENDOR to DEVICEJiri Slaby
traps, change VENDOR to DEVICE Change macro for SGI lithium (arch/i386/mach-visws/traps.c) device from VENDOR to DEVICE, because it's a device id. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: ATM: lanai, change VENDOR to DEVICEJiri Slaby
lanai, change VENDOR to DEVICE There were 2 bad named macros in pci_ids (LANAI 2 and IHB). Rename it to DEVICE, because it's device id. Also make some cleanpu in pci_device_id table (use PCI_VDEVICE). Cc: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-09sdhci: add ene controller idMilko Krachounov
ENE has a very weird design where an SDHCI device (0805) is presented on the PCI bus, but that device is non-functional, and the real device is hidden as a more generic device. Signed-off-by: Milko Krachounov <milko@3mhz.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-07-08sis5513: adding PCI-IDUwe Koziolek
The SiS966 has one additional PCI-ID 1180. If the chipset is using this PCI-ID, the primary channel is connected to the first PATA-port. The secondary channel is connected to SATA-ports in IDE emulation mode. The legacy IO-ports are used. The including of the PCI-ID into pata_sis is not sufficient, because the legacy driver in drivers/ide is initialized before pata_sis. Signed-off-by: Uwe Koziolek <uwe.koziolek@gmx.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-06-08Add the PATA controller device ID to pci_ids.h for MCP73/MCP77.Peer Chen
Add the PATA controller device ID to pci_ids.h for MCP73/MCP77. Signed-off-by: Peer Chen <peerchen@gmail.com> Cc: Alan Cox <alan@redhat.com>, Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-06-01pci_ids: update patch for Intel ICH9MJason Gaston
This patch updates the Intel ICH9M LPC Controller DID's, due to a specification change. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Cc: <stable@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-31PCI: quirk disable MSI on via vt3351Jay Cliburn
The Via VT3351 APIC does not play well with MSI and unleashes a flood of APIC errors when MSI is used to deliver interrupts. The problem was recently exposed when the atl1 network device driver, which enables MSI by default, stimulated APIC errors on an Asus M2V mainboard, which employs the Via VT3351. See http://bugzilla.kernel.org/show_bug.cgi?id=8472 for additional details on this bug. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-31PCI: disable MSI by default on systems with Serverworks HT1000 chipsAndy Gospodarek
I've been seeing lots of messages like these: eth0: No interrupt was generated using MSI, switching to INTx mode. Please report this failure to the PCI maintainer and include system chipset information. On several systems that use the following Severworks HT1000 (also sometimes labeled as a Broadcom chipset as well) bridge chips. It doesn't appear MSI works well (if at all) on these systems. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-24add the IDE device ID for ATI SB700Henry Su
Add the IDE device ID to atiixp_pci_tbl struct in atiixp.c for ATI SB700. From: Henry Su <henry.su@amd.com> Signed-off-by: Luugi Marsan <luugi.marsan@amd.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-17icom: add new sub-device-id to support new adapterwendy xiong
This patch add new sub-device-id to support new adapter and changed the interrupt irq number for unsigned char to unsigned int. [akpm@osdl.org: fix whitespace in device table] Signed-off by: Wendy Xiong <wendyx@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-13[AGPGART] Fix wrong ID in via-agp.cGabriel Mansi
there is a wrong id in drivers/char/agp/via-agp.c #define PCI_DEVICE_ID_VIA_CX700 0x8324 It must be 0x0324 Notice that PCI_DEVICE_ID_VIA_CX700 is also used in drivers/i2c/busses/i2c-viapro.c and drivers/ide/pci/via82cxxx.c So, I think that constant must be renamed to avoid conflicting. I attached a proposed patch. Signed-off-by: Dave Jones <davej@redhat.com>
2007-05-11Add the combined mode for ATI SB700Henry Su
Besides those modes in ATI SB600 SATA controller, ATI SB700 supports one more mode:the combined mode. The combined mode is a Legacy IDE mode used for compatibility with some old OS without AHCI driver, but now it is not necessary for Linux since the kernel has supported AHCI. Signed-off-by: Luugi Marsan <luugi.marsan@amd.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (49 commits) [SCTP]: Set assoc_id correctly during INIT collision. [SCTP]: Re-order SCTP initializations to avoid race with sctp_rcv() [SCTP]: Fix the SO_REUSEADDR handling to be similar to TCP. [SCTP]: Verify all destination ports in sctp_connectx. [XFRM] SPD info TLV aggregation [XFRM] SAD info TLV aggregationx [AF_RXRPC]: Sort out MTU handling. [AF_IUCV/IUCV] : Add missing section annotations [AF_IUCV]: Implementation of a skb backlog queue [NETLINK]: Remove bogus BUG_ON [IPV6]: Some cleanups in include/net/ipv6.h [TCP]: zero out rx_opt in tcp_disconnect() [BNX2]: Fix TSO problem with small MSS. [NET]: Rework dev_base via list_head (v3) [TCP] Highspeed: Limited slow-start is nowadays in tcp_slow_start [BNX2]: Update version and reldate. [BNX2]: Print bus information for PCIE devices. [BNX2]: Add 1-shot MSI handler for 5709. [BNX2]: Restructure PHY event handling. [BNX2]: Add indirect spinlock. ...
2007-05-03[BNX2]: Add support for 5709 Serdes.Michael Chan
Add PCI ID and code to support the 5709 Serdes PHY. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-01i2c-nforce2: Add support for the MCP61 and MCP65Jean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans-Frieder Vogt <hfvogt@gmx.net>
2007-04-29Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (107 commits) smc911x: fix compilation breakage wjen debug is on [netdrvr] eexpress: minor corrections add NAPI support to sb1250-mac.c ixgb: ROUND_UP macro cleanup in drivers/net/ixgb e1000: ROUND_UP macro cleanup in drivers/net/e1000 Generic HDLC sparse annotations e100: Optionally use I/O mode only to access register space e100: allow bad MAC address when running with invalid eeprom csum ehea: fix for dlpar support ehea: fix for sysfs entries 3C509: Remove unnecessary include of <linux/pm_legacy.h> NetXen: Fix for vmalloc issues NetXen: Fixes for Power PC architecture NetXen: Port swap feature for multi port cards NetXen: Removal of redundant macros NetXen: Multi PCI support for Quad cards NetXen: Removal of redundant argument passing NetXen: Use multiple PCI functions [netdrvr e100] experiment with doing RX in a similar manner to eepro100 [PATCH] ieee80211: add missing global needed by IEEE80211_DEBUG_XXXX ...
2007-04-28ahci.c: remove non-existing SB600 raid id (re-send)Conke Hu
SB600 RAID and SB600 SATA is the same controller and share the same PCI ID 0x4380. There is no such PCI ID 0x4381. Signed-off-by: Conke Hu <conke.hu@gmail.com> --------- Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28tc35815 driver update (take 2)Atsushi Nemoto
Current tc35815 driver is very obsolete and less maintained for a long time. Replace it with a new driver based on one from CELF patch archive. Major advantages of CELF version (version 1.23, for kernel 2.6.10) are: * Independent of JMR3927. (Actually independent of MIPS, but AFAIK the chip is used only on MIPS platforms) * TX4938 support. * 64-bit proof. * Asynchronous and on-demand auto negotiation. * High performance on non-coherent architecture. * ethtool support. * Many bugfixes and cleanups. And improvoments since version 1.23 are: * TX4939 support. * NETPOLL support. * NAPI support. (disabled by default) * Reduce memcpy on receiving. * PM support. * Many cleanups and bugfixes. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-17atl1: add L1 device id to pci_ids, then use itChris Snook
Add device id for the Attansic L1 chip to pci_ids.h, then use it. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-13i2c-piix4: Add support for the ATI SB600Jean Delvare
Add support for the ATI SB600 SMBus controller. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-11[PATCH] serial: support for new boardMatthias Fuchs
Add support for the CPCI-ASIO4 quad port CompactPCI UART board from electronic system design gmbh. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Perle multimodem card (PCI-RAS) detectionThomas Hoehn
Get the Perle quad-modem PCI card (PCI-RAS4) detected by serial driver. It may also get the PCI-RAS8 running, but can't guarantee as I didn't had one for testing. Signed-off-by: Thomas Hoehn <thomas.hoehn@avocent.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
