path: root/include/linux/percpu-defs.h
2010-10-27percpu: Remove the multi-page alignment facilityIngo Molnar
[DECLARE|DEFINE]_PER_CPU_MULTIPAGE_ALIGNED never really worked because the head percpu section was only page aligned. Now that the last user is gone (32-bit IRQ stacks), remove the generic percpu facility. Cc: Brian Gerst <brgerst@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <1288158182-1753-1-git-send-email-brgerst@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-22Merge branch 'x86-irq-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-irq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, 32-bit: Align percpu area and irq stacks to THREAD_SIZE x86: Move alloc_desk_mask variables inside ifdef x86-32: Align IRQ stacks properly x86: Remove CONFIG_4KSTACKS x86: Always use irq stacks Fixed up trivial conflicts in include/linux/{irq.h, percpu-defs.h}
2010-10-20percpu: Introduce a read-mostly percpu APIShaohua Li
Add a new readmostly percpu section and API. This can be used to avoid dirtying data lines which are generally not written to, which is especially important for data which may be accessed by processors other than the one for which the percpu area belongs to. [ hpa: moved it *after* the page-aligned section, for obvious reasons. ] Signed-off-by: Shaohua Li <shaohua.li@intel.com> LKML-Reference: <1287544022.4571.7.camel@sli10-conroe.sh.intel.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-09-07x86, 32-bit: Align percpu area and irq stacks to THREAD_SIZEAlexander van Heukelum
The irq stacks, located in the percpu-area, need to be THREAD_SIZE aligned. Add the infrastucture to align percpu variables to larger-than-pagesize amounts within the percpu area, and use it to specify the alignment for the irq stacks. Also align the percpu area itself to THREAD_SIZE. This should make irq stacks work with 8K THREAD_SIZE. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Cc: Tejun Heo <tj@kernel.org> Cc: hch@lst.de LKML-Reference: <1283799222.15941.1393621887@webmail.messagingengine.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-03-03Rename .data[.percpu][.XXX] to .data[..percpu][..XXX].Denys Vlasenko
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-08percpu: remove compile warnings caused by __verify_pcpu_ptr()Tejun Heo
If percpu pointer is const, __verify_pcpu_ptr() triggers warnings like the following. drivers/net/loopback.c: In function 'loopback_get_stats': drivers/net/loopback.c:109: warning: initialization discards qualifiers from pointer target type Fix it by adding const to the verification target pointer used in __verify_pcpu_ptr(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>
2009-10-29percpu: make accessors check for percpu pointer in sparseTejun Heo
The previous patch made sparse warn about percpu variables being used directly without going through percpu accessors. This patch implements the other half - checking whether non percpu variable is passed into percpu accessors. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Al Viro <viro@zeniv.linux.org.uk>
2009-10-29percpu: add __percpu for sparse.Rusty Russell
We have to make __kernel "__attribute__((address_space(0)))" so we can cast to it. tj: * put_cpu_var() update. * Annotations added to dynamic allocator interface. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-10-29percpu: remove per_cpu__ prefix.Rusty Russell
Now that the return from alloc_percpu is compatible with the address of per-cpu vars, it makes sense to hand around the address of per-cpu variables. To make this sane, we remove the per_cpu__ prefix we used created to stop people accidentally using these vars directly. Now we have sparse, we can use that (next patch). tj: * Updated to convert stuff which were missed by or added after the original patch. * Kill per_cpu_var() macro. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
2009-10-29percpu: remove some sparse warningsTejun Heo
Make the following changes to remove some sparse warnings. * Make DEFINE_PER_CPU_SECTION() declare __pcpu_unique_* before defining it. * Annotate pcpu_extend_area_map() that it is entered with pcpu_lock held, releases it and then reacquires it. * Make percpu related macros use unique nested variable names. * While at it, add pcpu prefix to __size_call[_return]() macros as to-be-implemented sparse annotations will add percpu specific stuff to these macros. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au>
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-14Merge branch 'x86-percpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-percpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, percpu: Collect hot percpu variables into one cacheline x86, percpu: Fix DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() x86, percpu: Add 'percpu_read_stable()' interface for cacheable accesses
2009-09-04x86/i386: Put aligned stack-canary in percpu shared_aligned sectionJeremy Fitzhardinge
Pack aligned things together into a special section to minimize padding holes. Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Tejun Heo <tj@kernel.org> LKML-Reference: <4AA035C0.9070202@goop.org> [ queued up in tip:x86/asm because it depends on this commit: x86/i386: Make sure stack-protector segment base is cache aligned ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-04x86, percpu: Fix DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED()Tejun Heo
DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() put percpu variables in .page_aligned section without adding any alignment restrictions. Currently, this doesn't cause any problem because all users of the macros have explicit page alignment and page-sized but it's much safer to enforce page alignment from the macros. After all, it's what they claim to do. Add __aligned(PAGE_SIZE) to DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() and drop explicit alignment from it users. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-04Merge branch 'master' into for-nextTejun Heo
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix changes. As alpha in percpu tree uses 'weak' attribute instead of inline assembly, there's no need for __used attribute. Conflicts: arch/alpha/include/asm/percpu.h arch/mn10300/kernel/vmlinux.lds.S include/linux/percpu-defs.h
2009-06-30alpha: fix percpu build breakageTejun Heo
alpha percpu access requires custom SHIFT_PERCPU_PTR() definition for modules to work around addressing range limitation. This is done via generating inline assembly using C preprocessing which forces the assembler to generate external reference. This happens behind the compiler's back and makes the compiler think that static percpu variables in modules are unused. This used to be worked around by using __unused attribute for percpu variables which prevent the compiler from omitting the variable; however, recent declare/definition attribute unification change broke this as __used can't be used for declaration. Also, in the process, PER_CPU_ATTRIBUTES definition in alpha percpu.h got broken. This patch adds PER_CPU_DEF_ATTRIBUTES which is only used for definitions and make alpha use it to add __used for percpu variables in modules. This also fixes the PER_CPU_ATTRIBUTES double definition bug. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: maximilian attems <max@stro.at> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-29percpu: use __weak only in the definition of weak percpu variablesTejun Heo
__weak is necessary only for definition and might even not work in declaration. Drop it from declaration. This change was suggested by Ivan Kokshaysky. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
2009-06-24percpu: implement optional weak percpu definitionsTejun Heo
Some archs (alpha and s390) need to use weak definitions for percpu variables in modules so that the compiler generates external references for them. This patch implements weak percpu definitions which arch can enable by defining ARCH_NEEDS_WEAK_PER_CPU in arch percpu header file. This weak definition adds the following two restrictions on percpu variable definitions. 1. percpu symbols must be unique whether static or not 2. percpu variables can't be defined inside a function To ensure that these restrictions are observed in generic code, config option DEBUG_FORCE_WEAK_PER_CPU enables weak percpu definitions for all cases. This patch is inspired by Ivan Kokshaysky's alpha percpu patch. [ Impact: stricter rules for percpu variables, one more debug config option ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Howells <dhowells@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
2009-04-21PERCPU: Collect the DECLARE/DEFINE declarations togetherDavid Howells
Collect the DECLARE/DEFINE declarations together in linux/percpu-defs.h so that they're in one place, and give them descriptive comments, particularly the SHARED_ALIGNED variant. It would be nice to collect these in linux/percpu.h, but that's not possible without sorting out the severe #include recursion between the x86 arch headers and the general headers (and possibly other arches too). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
