path: root/include/linux/percpu_counter.h
2011-09-13locking, percpu_counter: Annotate ::lock as rawThomas Gleixner
The percpu_counter::lock can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-25percpu_counter: change return value and add commentsShaohua Li
The percpu_counter_*_positive() API in UP case doesn't check if return value is positive. Add comments to explain why we don't. Also if count < 0, returns 0 instead of 1 for *read_positive(). [akpm@linux-foundation.org: tweak comment] Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ext4: fix kernel oops if the journal superblock has a non-zero j_errnoTheodore Ts'o
Commit 84061e0 fixed an accounting bug only to introduce the possibility of a kernel OOPS if the journal has a non-zero j_errno field indicating that the file system had detected a fs inconsistency. After the journal replay, if the journal superblock indicates that the file system has an error, this indication is transfered to the file system and then ext4_commit_super() is called to write this to the disk. But since the percpu counters are now initialized after the journal replay, the call to ext4_commit_super() will cause a kernel oops since it needs to use the percpu counters the ext4 superblock structure. The fix is to skip setting the ext4 free block and free inode fields if the percpu counter has not been set. Thanks to Ken Sumrall for reporting and analyzing the root causes of this bug. Addresses-Google-Bug: #3054080 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-08-09tmpfs: add accurate compare function to percpu_counter libraryTim Chen
Add percpu_counter_compare that allows for a quick but accurate comparison of percpu_counter with a given value. A rough count is provided by the count field in percpu_counter structure, without accounting for the other values stored in individual cpu counters. The actual count is a sum of count and the cpu counters. However, count field is never different from the actual value by a factor of batch*num_online_cpu. We do not need to get actual count for comparison if count is different from the given value by this factor and allows for quick comparison without summing up all the per cpu counters. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: add __percpu sparse annotations to what's left percpu: add __percpu sparse annotations to fs percpu: add __percpu sparse annotations to core kernel subsystems local_t: Remove leftover local.h this_cpu: Remove pageset_notifier this_cpu: Page allocator conversion percpu, x86: Generic inc / dec percpu instructions local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c module: Use this_cpu_xx to dynamically allocate counters local_t: Remove cpu_local_xx macros percpu: refactor the code in pcpu_[de]populate_chunk() percpu: remove compile warnings caused by __verify_pcpu_ptr() percpu: make accessors check for percpu pointer in sparse percpu: add __percpu for sparse. percpu: make access macros universal percpu: remove per_cpu__ prefix.
2010-02-17percpu: add __percpu sparse annotations to core kernel subsystemsTejun Heo
Add __percpu sparse annotations to core subsystems. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-mm@kvack.org Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Biederman <ebiederm@xmission.com>
2010-02-08percpu_counter: Make __percpu_counter_add an inline function on UPAnton Blanchard
Even though batch isn't used on UP, we may want to pass one in to keep the SMP and UP code paths similar. Convert __percpu_counter_add to an inline function so we wont get variable unused warnings if we do. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: fix rcutorture bug rcu: eliminate synchronize_rcu_xxx macro rcu: make treercu safe for suspend and resume rcu: fix rcutree grace-period-latency bug on small systems futex: catch certain assymetric (get|put)_futex_key calls futex: make futex_(get|put)_key() calls symmetric locking, percpu counters: introduce separate lock classes swiotlb: clean up EXPORT_SYMBOL usage swiotlb: remove unnecessary declaration swiotlb: replace architecture-specific swiotlb.h with linux/swiotlb.h swiotlb: add support for systems with highmem swiotlb: store phys address in io_tlb_orig_addr array swiotlb: add hwdev to swiotlb_phys_to_bus() / swiotlb_sg_to_bus()
2009-01-06percpu_counter: FBC_BATCH should be a variableEric Dumazet
For NR_CPUS >= 16 values, FBC_BATCH is 2*NR_CPUS Considering more and more distros are using high NR_CPUS values, it makes sense to use a more sensible value for FBC_BATCH, and get rid of NR_CPUS. A sensible value is 2*num_online_cpus(), with a minimum value of 32 (This minimum value helps branch prediction in __percpu_counter_add()) We already have a hotcpu notifier, so we can adjust FBC_BATCH dynamically. We rename FBC_BATCH to percpu_counter_batch since its not a constant anymore. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29locking, percpu counters: introduce separate lock classesPeter Zijlstra
Impact: fix lockdep false positives Classify percpu_counter instances similar to regular lock objects -- that is, per instantiation site. The networking code has increased its use of percpu_counters, which leads to false positives if they are treated as a single class. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-10revert "percpu_counter: new function percpu_counter_sum_and_set"Andrew Morton
Revert commit e8ced39d5e8911c662d4d69a342b9d053eaaac4e Author: Mingming Cao <cmm@us.ibm.com> Date: Fri Jul 11 19:27:31 2008 -0400 percpu_counter: new function percpu_counter_sum_and_set As described in revert "percpu counter: clean up percpu_counter_sum_and_set()" the new percpu_counter_sum_and_set() is racy against updates to the cpu-local accumulators on other CPUs. Revert that change. This means that ext4 will be slow again. But correct. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10revert "percpu counter: clean up percpu_counter_sum_and_set()"Andrew Morton
Revert commit 1f7c14c62ce63805f9574664a6c6de3633d4a354 Author: Mingming Cao <cmm@us.ibm.com> Date: Thu Oct 9 12:50:59 2008 -0400 percpu counter: clean up percpu_counter_sum_and_set() Before this patch we had the following: percpu_counter_sum(): return the percpu_counter's value percpu_counter_sum_and_set(): return the percpu_counter's value, copying that value into the central value and zeroing the per-cpu counters before returning. After this patch, percpu_counter_sum_and_set() has gone, and percpu_counter_sum() gets the old percpu_counter_sum_and_set() functionality. Problem is, as Eric points out, the old percpu_counter_sum_and_set() functionality was racy and wrong. It zeroes out counters on "other" cpus, without holding any locks which will prevent races agaist updates from those other CPUS. This patch reverts 1f7c14c62ce63805f9574664a6c6de3633d4a354. This means that percpu_counter_sum_and_set() still has the race, but percpu_counter_sum() does not. Note that this is not a simple revert - ext4 has since started using percpu_counter_sum() for its dirty_blocks counter as well. Note that this revert patch changes percpu_counter_sum() semantics. Before the patch, a call to percpu_counter_sum() will bring the counter's central counter mostly up-to-date, so a following percpu_counter_read() will return a close value. After this patch, a call to percpu_counter_sum() will leave the counter's central accumulator unaltered, so a subsequent call to percpu_counter_read() can now return a significantly inaccurate result. If there is any code in the tree which was introduced after e8ced39d5e8911c662d4d69a342b9d053eaaac4e was merged, and which depends upon the new percpu_counter_sum() semantics, that code will break. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-09percpu counter: clean up percpu_counter_sum_and_set()Mingming Cao
percpu_counter_sum_and_set() and percpu_counter_sum() is the same except the former updates the global counter after accounting. Since we are taking the fbc->lock to calculate the precise value of the counter in percpu_counter_sum() anyway, it should simply set fbc->count too, as the percpu_counter_sum_and_set() does. This patch merges these two interfaces into one. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-07-11percpu_counter: new function percpu_counter_sum_and_setMingming Cao
Delayed allocation need to check free blocks at every write time. percpu_counter_read_positive() is not quit accurate. delayed allocation need a more accurate accounting, but using percpu_counter_sum_positive() is frequently is quite expensive. This patch added a new function to update center counter when sum per-cpu counter, to increase the accurate rate for next percpu_counter_read() and require less calling expensive percpu_counter_sum(). Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-10-17lib: percpu_counter_init_irqPeter Zijlstra
provide a way to tell lockdep about percpu_counters that are supposed to be used from irq safe contexts. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_init error handlingPeter Zijlstra
alloc_percpu can fail, propagate that error. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_count_sum()Peter Zijlstra
Provide an accurate version of percpu_counter_read. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_sum_positivePeter Zijlstra
s/percpu_counter_sum/&_positive/ Because its consitent with percpu_counter_read* Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_setPeter Zijlstra
Provide a method to set a percpu counter to a specified value. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: make percpu_counter_add take s64Peter Zijlstra
percpu_counter is a s64 counter, make _add consitent. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter variable batchPeter Zijlstra
Because the current batch setup has an quadric error bound on the counter, allow for an alternative setup. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_subPeter Zijlstra
Hugh spotted that some code does: percpu_counter_add(&counter, -unsignedlong) which, when the amount argument is of type s32, sort-of works thanks to two's-complement. However when we'd change the type to s64 this breaks on 32bit machines, because the promotion rules zero extend the unsigned number. Provide percpu_counter_sub() to hide the s64 cast. That is: percpu_counter_sub(&counter, foo) is equal to: percpu_counter_add(&counter, -(s64)foo); Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_addPeter Zijlstra
s/percpu_counter_mod/percpu_counter_add/ Because its a better name, _mod implies modulo. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16percpu_counters(): use cpu notifiersAndrew Morton
per-cpu counters presently must iterate over all possible CPUs in the exhaustive percpu_counter_sum(). But it can be much better to only iterate over the presently-online CPUs. To do this, we must arrange for an offlined CPU's count to be spilled into the counter's central count. We can do this for all percpu_counters in the machine by linking them into a single global list and walking that list at CPU_DEAD time. (I hope. Might have race windows in which the percpu_counter_sum() count is inaccurate?) Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-23[PATCH] percpu counter data type changes to suppport more than 2**31 ext3 ↵Mingming Cao
free blocks counter The percpu counter data type are changed in this set of patches to support more users like ext3 who need more than 32 bit to store the free blocks total in the filesystem. - Generic perpcu counters data type changes. The size of the global counter and local counter were explictly specified using s64 and s32. The global counter is changed from long to s64, while the local counter is changed from long to s32, so we could avoid doing 64 bit update in most cases. - Users of the percpu counters are updated to make use of the new percpu_counter_init() routine now taking an additional parameter to allow users to pass the initial value of the global counter. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-08[PATCH] percpu_counter_sum()Andrew Morton
Implement percpu_counter_sum(). This is a more accurate but slower version of percpu_counter_read_positive(). We need this for Alex's speedup-ext3_statfs patch and for the nr_file accounting fix. Otherwise these things would be too inaccurate on large CPU counts. Cc: Ravikiran G Thirumalai <kiran@scalex86.org> Cc: Alex Tomas <alex@clusterfs.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
