path: root/include/linux/personality.h
2011-08-25Add a personality to report 2.6.x version numbersAndi Kleen
I ran into a couple of programs which broke with the new Linux 3.0 version. Some of those were binary only. I tried to use LD_PRELOAD to work around it, but it was quite difficult and in one case impossible because of a mix of 32bit and 64bit executables. For example, all kind of management software from HP doesnt work, unless we pretend to run a 2.6 kernel. $ uname -a Linux svivoipvnx001 3.0.0-08107-g97cd98f #1062 SMP Fri Aug 12 18:11:45 CEST 2011 i686 i686 i386 GNU/Linux $ hpacucli ctrl all show Error: No controllers detected. $ rpm -qf /usr/sbin/hpacucli hpacucli-8.75-12.0 Another notable case is that Python now reports "linux3" from sys.platform(); which in turn can break things that were checking sys.platform() == "linux2": https://bugzilla.mozilla.org/show_bug.cgi?id=664564 It seems pretty clear to me though it's a bug in the apps that are using '==' instead of .startswith(), but this allows us to unbreak broken programs. This patch adds a UNAME26 personality that makes the kernel report a 2.6.40+x version number instead. The x is the x in 3.x. I know this is somewhat ugly, but I didn't find a better workaround, and compatibility to existing programs is important. Some programs also read /proc/sys/kernel/osrelease. This can be worked around in user space with mount --bind (and a mount namespace) To use: wget ftp://ftp.kernel.org/pub/linux/kernel/people/ak/uname26/uname26.c gcc -o uname26 uname26.c ./uname26 program Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04sys_personality: change sys_personality() to accept "unsigned int" instead ↵Oleg Nesterov
of u_long task_struct->pesonality is "unsigned int", but sys_personality() paths use "unsigned long pesonality". This means that every assignment or comparison is not right. In particular, if this argument does not fit into "unsigned int" __set_personality() changes the caller's personality and then sys_personality() returns -EINVAL. Turn this argument into "unsigned int" and avoid overflows. Obviously, this is the user-visible change, we just ignore the upper bits. But this can't break the sane application. There is another thing which can confuse the poorly written applications. User-space thinks that this syscall returns int, not long. This means that the returned value can be negative and look like the error code. But note that libc won't be confused and thus errno won't be set, and with this patch the user-space can never get -1 unless sys_personality() really fails. And, most importantly, the negative RET != -1 is only possible if that app previously called personality(RET). Pointed-out-by: Wenming Zhang <wezhang@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12personality: fix PER_CLEAR_ON_SETIDJulien Tinnes
We have found that the current PER_CLEAR_ON_SETID mask on Linux doesn't include neither ADDR_COMPAT_LAYOUT, nor MMAP_PAGE_ZERO. The current mask is READ_IMPLIES_EXEC|ADDR_NO_RANDOMIZE. We believe it is important to add MMAP_PAGE_ZERO, because by using this personality it is possible to have the first page mapped inside a process running as setuid root. This could be used in those scenarios: - Exploiting a NULL pointer dereference issue in a setuid root binary - Bypassing the mmap_min_addr restrictions of the Linux kernel: by running a setuid binary that would drop privileges before giving us control back (for instance by loading a user-supplied library), we could get the first page mapped in a process we control. By further using mremap and mprotect on this mapping, we can then completely bypass the mmap_min_addr restrictions. Less importantly, we believe ADDR_COMPAT_LAYOUT should also be added since on x86 32bits it will in practice disable most of the address space layout randomization (only the stack will remain randomized). Signed-off-by: Julien Tinnes <jt@cr0.org> Signed-off-by: Tavis Ormandy <taviso@sdf.lonestar.org> Cc: stable@kernel.org Acked-by: Christoph Hellwig <hch@infradead.org> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Eugene Teo <eugene@redhat.com> [ Shortened lines and fixed whitespace as per Christophs' suggestion ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Remove the macro get_personalityWANG Cong
Remove the macro get_personality, use ->personality instead. Cc: Christoph Hellwig <hch@infradead.org Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-13[PATCH] Fix missing parens in set_personality()Russell King
If you call set_personality() with an expression such as: set_personality(foo ? PERS_FOO1 : PERS_FOO2); then this evaluates to: ((current->personality == foo ? PERS_FOO1 : PERS_FOO2) ? ... which is obviously not the intended result. Add the missing parents to ensure this gets evaluated as expected: ((current->personality == (foo ? PERS_FOO1 : PERS_FOO2)) ? ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] Make <linux/personality.h> userspace proofRalf Baechle
<linux/personality.h> contains the constants for personality(2) but also some defintions that are useless or even harmful in userspace such as the personality() macro. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
