path: root/include/linux/pm_wakeup.h
2011-03-15PM: Do not create wakeup sysfs files for devices that cannot wake upRafael J. Wysocki
Currently, wakeup sysfs attributes are created for all devices, regardless of whether or not they are wakeup-capable. This is excessive and complicates wakeup device identification from user space (i.e. to identify wakeup-capable devices user space has to read /sys/devices/.../power/wakeup for all devices and see if they are not empty). Fix this issue by avoiding to create wakeup sysfs files for devices that cannot wake up the system from sleep states (i.e. whose power.can_wakeup flags are unset during registration) and modify device_set_wakeup_capable() so that it adds (or removes) the relevant sysfs attributes if a device's wakeup capability status is changed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24PM: Make ACPI wakeup from S5 work again when CONFIG_PM_SLEEP is unsetRafael J. Wysocki
Commit 074037e (PM / Wakeup: Introduce wakeup source objects and event statistics (v3)) caused ACPI wakeup to only work if CONFIG_PM_SLEEP is set, but it also worked for CONFIG_PM_SLEEP unset before. This can be fixed by making device_set_wakeup_enable(), device_init_wakeup() and device_may_wakeup() work in the same way as before commit 074037e when CONFIG_PM_SLEEP is unset. Reported-and-tested-by: Justin Maggard <jmaggard10@gmail.com> Cc: stable@kernel.org Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM / Wakeup: Introduce wakeup source objects and event statistics (v3)Rafael J. Wysocki
Introduce struct wakeup_source for representing system wakeup sources within the kernel and for collecting statistics related to them. Make the recently introduced helper functions pm_wakeup_event(), pm_stay_awake() and pm_relax() use struct wakeup_source objects internally, so that wakeup statistics associated with wakeup devices can be collected and reported in a consistent way (the definition of pm_relax() is changed, which is harmless, because this function is not called directly by anyone yet). Introduce new wakeup-related sysfs device attributes in /sys/devices/.../power for reporting the device wakeup statistics. Change the global wakeup events counters event_count and events_in_progress into atomic variables, so that it is not necessary to acquire a global spinlock in pm_wakeup_event(), pm_stay_awake() and pm_relax(), which should allow us to avoid lock contention in these functions on SMP systems with many wakeup devices. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-19PM: describe kernel policy regarding wakeup defaults (v. 2)Alan Stern
This patch (as1381b) updates a comment describing the kernel's policy toward enabling wakeup by default. It also makes device_set_wakeup_capable() actually do something when CONFIG_PM isn't enabled. It's not clear this is necessary; however if it isn't then device_init_wakeup() and device_can_wakeup() should also be do-nothing routines. Furthermore, I don't expect this change to have any noticeable effect -- but if it does then clearly the old behavior was wrong. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM: pm_wakeup - switch to using boolDmitry Torokhov
Also change couple of stubs implemented as macros in !CONFIG_PM case in statinc inline functions to provide proper typechecking of arguments regardless of config. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2008-07-14PCI: include linux/pm_wakeup.h for device_set_wakeup_capableStephen Rothwell
drivers/pci/pci.c needs pm_wakeup.h since it uses device_set_wakup_capable(). The latter also needs to be stubbed out for !CONFIG_PM. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-07PCI ACPI: Rework PCI handling of wake-upRafael J. Wysocki
* Introduce function acpi_pm_device_sleep_wake() for enabling and disabling the system wake-up capability of devices that are power manageable by ACPI. * Introduce function acpi_bus_can_wakeup() allowing other (dependent) subsystems to check if ACPI is able to enable the system wake-up capability of given device. * Introduce callback .sleep_wake() in struct pci_platform_pm_ops and for the ACPI PCI 'driver' make it use acpi_pm_device_sleep_wake(). * Introduce callback .can_wakeup() in struct pci_platform_pm_ops and for the ACPI 'driver' make it use acpi_bus_can_wakeup(). * Move the PME# handlig code out of pci_enable_wake() and split it into two functions, pci_pme_capable() and pci_pme_active(), allowing the caller to check if given device is capable of generating PME# from given power state and to enable/disable the device's PME# functionality, respectively. * Modify pci_enable_wake() to use the new ACPI callbacks and the new PME#-related functions. * Drop the generic .platform_enable_wakeup() callback that is not used any more. * Introduce device_set_wakeup_capable() that will set the power.can_wakeup flag of given device. * Rework PCI device PM initialization so that, if given device is capable of generating wake-up events, either natively through the PME# mechanism, or with the help of the platform, its power.can_wakeup flag is set and its power.should_wakeup flag is unset as appropriate. * Make ACPI set the power.can_wakeup flag for devices found to be wake-up capable by it. * Make the ACPI wake-up code enable/disable GPEs for devices that have the wakeup.flags.prepared flag set (which means that their wake-up power has been enabled). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-19PM: Convert wakeup flag accessors to inline functionsAlan Stern
This patch (as1058) improves the wakeup macros in include/linux/pm.h. All but the trivial ones are converted to inline routines, which requires moving them to a separate header file since they depend on the definition of struct device. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
