path: root/include/linux/proc_fs.h
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfdLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd: net: fix get_net_ns_by_fd for !CONFIG_NET_NS ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry. ns: Declare sys_setns in syscalls.h net: Allow setting the network namespace by fd ns proc: Add support for the ipc namespace ns proc: Add support for the uts namespace ns proc: Add support for the network namespace. ns: Introduce the setns syscall ns: proc files for namespace naming policy.
2011-05-25proc: make struct proc_maps_private truly privateStephen Wilson
Now that mm/mempolicy.c is no longer implementing /proc/pid/numa_maps there is no need to export struct proc_maps_private to the world. Move it to fs/proc/internal.h instead. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18procfs: add stub for proc_mkdir_mode()Randy Dunlap
Provide a stub for proc_mkdir_mode() when CONFIG_PROC_FS is not enabled, just like the stub for proc_mkdir(). Fixes this linux-next build error: drivers/net/wireless/airo.c:4504: error: implicit declaration of function 'proc_mkdir_mode' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10ns proc: Add support for the ipc namespaceEric W. Biederman
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-05-10ns proc: Add support for the uts namespaceEric W. Biederman
2011-05-10ns proc: Add support for the network namespace.Eric W. Biederman
Implementing file descriptors for the network namespace is simple and straight forward. Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-05-10ns: proc files for namespace naming policy.Eric W. Biederman
Create files under /proc/<pid>/ns/ to allow controlling the namespaces of a process. This addresses three specific problems that can make namespaces hard to work with. - Namespaces require a dedicated process to pin them in memory. - It is not possible to use a namespace unless you are the child of the original creator. - Namespaces don't have names that userspace can use to talk about them. The namespace files under /proc/<pid>/ns/ can be opened and the file descriptor can be used to talk about a specific namespace, and to keep the specified namespace alive. A namespace can be kept alive by either holding the file descriptor open or bind mounting the file someplace else. aka: mount --bind /proc/self/ns/net /some/filesystem/path mount --bind /proc/self/fd/<N> /some/filesystem/path This allows namespaces to be named with userspace policy. It requires additional support to make use of these filedescriptors and that will be comming in the following patches. Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-03-23proc: make struct proc_dir_entry::namelen unsigned intAlexey Dobriyan
1. namelen is declared "unsigned short" which hints for "maybe space savings". Indeed in 2.4 struct proc_dir_entry looked like: struct proc_dir_entry { unsigned short low_ino; unsigned short namelen; Now, low_ino is "unsigned int", all savings were gone for a long time. "struct proc_dir_entry" is not that countless to worry about it's size, anyway. 2. converting from unsigned short to int/unsigned int can only create problems, we better play it safe. Space is not really conserved, because of natural alignment for the next field. sizeof(struct proc_dir_entry) remains the same. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmemmap rangeKAMEZAWA Hiroyuki
Benjamin Herrenschmidt <benh@kernel.crashing.org> pointed out that vmemmap range is not included in KCORE_RAM, KCORE_VMALLOC .... This adds KCORE_VMEMMAP if SPARSEMEM_VMEMMAP is used. By this, vmemmap can be readable via /proc/kcore Because it's not vmalloc area, vread/vwrite cannot be used. But the range is static against the memory layout, this patch handles vmemmap area by the same scheme with physical memory. This patch assumes SPARSEMEM_VMEMMAP range is not in VMALLOC range. It's correct now. [akpm@linux-foundation.org: fix typo] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: use usual list for kclistKAMEZAWA Hiroyuki
This patchset is for /proc/kcore. With this, - many per-arch hooks are removed. - /proc/kcore will know really valid physical memory area. - /proc/kcore will be aware of memory hotplug. - /proc/kcore will be architecture independent i.e. if an arch supports CONFIG_MMU, it can use /proc/kcore. (if the arch uses usual memory layout.) This patch: /proc/kcore uses its own list handling codes. It's better to use generic list codes. No changes in logic. just clean up. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Move junk from proc_fs.h to fs/proc/internal.hAl Viro
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: remove fs/proc/proc_misc.cAlexey Dobriyan
Now that everything was moved to their more or less expected places, apply rm(1). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: move all /proc/kcore stuff to fs/proc/kcore.cAlexey Dobriyan
2008-10-07powerpc: Remove remains of /proc/ppc_htabGeert Uytterhoeven
commit 14cf11af6cf608eb8c23e989ddb17a715ddce109 ("powerpc: Merge enough to start building in arch/powerpc.") unwired /proc/ppc_htab, and commit 917f0af9e5a9ceecf9e72537fabb501254ba321d ("powerpc: Remove arch/ppc and include/asm-ppc") removed the rest of the /proc/ppc_htab support, but there are still a few references left. Kill them for good. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-26[PATCH] sanitize proc_sysctlAl Viro
* keep references to ctl_table_head and ctl_table in /proc/sys inodes * grab the former during operations, use the latter for access to entry if that succeeds * have ->d_compare() check if table should be seen for one who does lookup; that allows us to avoid flipping inodes - if we have the same name resolve to different things, we'll just keep several dentries and ->d_compare() will reject the wrong ones. * have ->lookup() and ->readdir() scan the table of our inode first, then walk all ctl_table_header and scan ->attached_by for those that are attached to our directory. * implement ->getattr(). * get rid of insane amounts of tree-walking * get rid of the need to know dentry in ->permission() and of the contortions induced by that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25proc: always do ->releaseAlexey Dobriyan
Current two-stage scheme of removing PDE emphasizes one bug in proc: open rmmod remove_proc_entry close ->release won't be called because ->proc_fops were cleared. In simple cases it's small memory leak. For every ->open, ->release has to be done. List of openers is introduced which is traversed at remove_proc_entry() if neeeded. Discussions with Al long ago (sigh). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25move proc_kmsg_operations to fs/proc/internal.hAdrian Bunk
This patch moves the extern of struct proc_kmsg_operations to fs/proc/internal.h and adds an #include "internal.h" to fs/proc/kmsg.c so that the latter sees the former. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22netns: make get_proc_net() staticAdrian Bunk
get_proc_net() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-12proc_fs.h: move struct mm_struct forward-declarationBen Nizette
Move the forward-declaration of struct mm_struct a little way up proc_fs.h. This fixes a bunch of "'struct mm_struct' declared inside parameter list" warnings with CONFIG_PROC_FS=n Signed-off-by: Ben Nizette <bn@niasdigital.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: introduce proc_create_data to setup de->dataDenis V. Lunev
This set of patches fixes an proc ->open'less usage due to ->proc_fops flip in the most part of the kernel code. The original OOPS is described in the commit 2d3a4e3666325a9709cc8ea2e88151394e8f20fc: Typical PDE creation code looks like: pde = create_proc_entry("foo", 0, NULL); if (pde) pde->proc_fops = &foo_proc_fops; Notice that PDE is first created, only then ->proc_fops is set up to final value. This is a problem because right after creation a) PDE is fully visible in /proc , and b) ->proc_fops are proc_file_operations which do not have ->open callback. So, it's possible to ->read without ->open (see one class of oopses below). The fix is new API called proc_create() which makes sure ->proc_fops are set up before gluing PDE to main tree. Typical new code looks like: pde = proc_create("foo", 0, NULL, &foo_proc_fops); if (!pde) return -ENOMEM; Fix most networking users for a start. In the long run, create_proc_entry() for regular files will go. In addition to this, proc_create_data is introduced to fix reading from proc without PDE->data. The race is basically the same as above. create_proc_entries is replaced in the entire kernel code as new method is also simply better. This patch: The problem is the same as for de->proc_fops. Right now PDE becomes visible without data set. So, the entry could be looked up without data. This, in most cases, will simply OOPS. proc_create_data call is created to address this issue. proc_create now becomes a wrapper around it. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Chris Mason <chris.mason@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Len Brown <lenb@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Osterlund <petero2@telia.com> Cc: Pierre Peiffer <peifferp@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Takashi Iwai <tiwai@suse.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove ->get_info infrastructureAlexey Dobriyan
Now that last dozen or so users of ->get_info were removed, ditch it too. Everyone sane shouldd have switched to seq_file interface long ago. P.S.: Co-existing 3 interfaces (->get_info/->read_proc/->proc_fops) for proc is long-standing crap, BTW, thus a) put ->read_proc/->write_proc/read_proc_entry() users on death row, b) new such users should be rejected, c) everyone is encouraged to convert his favourite ->read_proc user or I'll do it, lazy bastards. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root_driverAlexey Dobriyan
Use creation by full path: "driver/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root_fsAlexey Dobriyan
Use creation by full path instead: "fs/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29procfs task exe symlinkMatt Helsley
The kernel implements readlink of /proc/pid/exe by getting the file from the first executable VMA. Then the path to the file is reconstructed and reported as the result. Because of the VMA walk the code is slightly different on nommu systems. This patch avoids separate /proc/pid/exe code on nommu systems. Instead of walking the VMAs to find the first executable file-backed VMA we store a reference to the exec'd file in the mm_struct. That reference would prevent the filesystem holding the executable file from being unmounted even after unmapping the VMAs. So we track the number of VM_EXECUTABLE VMAs and drop the new reference when the last one is unmapped. This avoids pinning the mounted filesystem. [akpm@linux-foundation.org: improve comments] [yamamoto@valinux.co.jp: fix dup_mmap] Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com> Cc:"Eric W. Biederman" <ebiederm@xmission.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-07[NET]: Make /proc/net a symlink on /proc/self/net (v3)Pavel Emelyanov
Current /proc/net is done with so called "shadows", but current implementation is broken and has little chances to get fixed. The problem is that dentries subtree of /proc/net directory has fancy revalidation rules to make processes living in different net namespaces see different entries in /proc/net subtree, but currently, tasks see in the /proc/net subdir the contents of any other namespace, depending on who opened the file first. The proposed fix is to turn /proc/net into a symlink, which points to /proc/self/net, which in turn shows what previously was in /proc/net - the network-related info, from the net namespace the appropriate task lives in. # ls -l /proc/net lrwxrwxrwx 1 root root 8 Mar 5 15:17 /proc/net -> self/net In other words - this behaves like /proc/mounts, but unlike "mounts", "net" is not a file, but a directory. Changes from v2: * Fixed discrepancy of /proc/net nlink count and selinux labeling screwup pointed out by Stephen. To get the correct nlink count the ->getattr callback for /proc/net is overridden to read one from the net->proc_net entry. To make selinux still work the net->proc_net entry is initialized properly, i.e. with the "net" name and the proc_net parent. Selinux fixes are Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Changes from v1: * Fixed a task_struct leak in get_proc_task_net, pointed out by Paul. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14d_path: Make proc_get_link() use a struct path argumentJan Blunck
proc_get_link() is always called with a dentry and a vfsmount from a struct path. Make proc_get_link() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: fix ->open'less usage due to ->proc_fops flipAlexey Dobriyan
Typical PDE creation code looks like: pde = create_proc_entry("foo", 0, NULL); if (pde) pde->proc_fops = &foo_proc_fops; Notice that PDE is first created, only then ->proc_fops is set up to final value. This is a problem because right after creation a) PDE is fully visible in /proc , and b) ->proc_fops are proc_file_operations which do not have ->open callback. So, it's possible to ->read without ->open (see one class of oopses below). The fix is new API called proc_create() which makes sure ->proc_fops are set up before gluing PDE to main tree. Typical new code looks like: pde = proc_create("foo", 0, NULL, &foo_proc_fops); if (!pde) return -ENOMEM; Fix most networking users for a start. In the long run, create_proc_entry() for regular files will go. BUG: unable to handle kernel NULL pointer dereference at virtual address 00000024 printing eip: c1188c1b *pdpt = 000000002929e001 *pde = 0000000000000000 Oops: 0002 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/block/sda/sda1/dev Modules linked in: foo af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 24679, comm: cat Not tainted (2.6.24-rc3-mm1 #2) EIP: 0060:[<c1188c1b>] EFLAGS: 00210002 CPU: 0 EIP is at mutex_lock_nested+0x75/0x25d EAX: 000006fe EBX: fffffffb ECX: 00001000 EDX: e9340570 ESI: 00000020 EDI: 00200246 EBP: e9340570 ESP: e8ea1ef8 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 24679, ti=E8EA1000 task=E9340570 task.ti=E8EA1000) Stack: 00000000 c106f7ce e8ee05b4 00000000 00000001 458003d0 f6fb6f20 fffffffb 00000000 c106f7aa 00001000 c106f7ce 08ae9000 f6db53f0 00000020 00200246 00000000 00000002 00000000 00200246 00200246 e8ee05a0 fffffffb e8ee0550 Call Trace: [<c106f7ce>] seq_read+0x24/0x28a [<c106f7aa>] seq_read+0x0/0x28a [<c106f7ce>] seq_read+0x24/0x28a [<c106f7aa>] seq_read+0x0/0x28a [<c10818b8>] proc_reg_read+0x60/0x73 [<c1081858>] proc_reg_read+0x0/0x73 [<c105a34f>] vfs_read+0x6c/0x8b [<c105a6f3>] sys_read+0x3c/0x63 [<c10025f2>] sysenter_past_esp+0x5f/0xa5 [<c10697a7>] destroy_inode+0x24/0x33 ======================= INFO: lockdep is turned off. Code: 75 21 68 e1 1a 19 c1 68 87 00 00 00 68 b8 e8 1f c1 68 25 73 1f c1 e8 84 06 e9 ff e8 52 b8 e7 ff 83 c4 10 9c 5f fa e8 28 89 ea ff <f0> fe 4e 04 79 0a f3 90 80 7e 04 00 7e f8 eb f0 39 76 34 74 33 EIP: [<c1188c1b>] mutex_lock_nested+0x75/0x25d SS:ESP 0068:e8ea1ef8 [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: seqfile convert proc_pid_status to properly handle pid namespacesEric W. Biederman
Currently we possibly lookup the pid in the wrong pid namespace. So seq_file convert proc_pid_status which ensures the proper pid namespaces is passed in. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: s390 build fix] [akpm@linux-foundation.org: fix task_name() output] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: implement proc_single_file_operationsEric W. Biederman
Currently many /proc/pid files use a crufty precursor to the current seq_file api, and they don't have direct access to the pid_namespace or the pid of for which they are displaying data. So implement proc_single_file_operations to make the seq_file routines easy to use, and to give access to the full state of the pid of we are displaying data for. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: move clear_refs code to task_mmu.cMatt Mackall
This puts all the clear_refs code where it belongs and probably lets things compile on MMU-less systems as well. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[ATM]: Oops reading net/atm/arpDenis V. Lunev
cat /proc/net/atm/arp causes the NULL pointer dereference in the get_proc_net+0xc/0x3a. This happens as proc_get_net believes that the parent proc dir entry contains struct net. Fix this assumption for "net/atm" case. The problem is introduced by the commit c0097b07abf5f92ab135d024dd41bd2aada1512f from Eric W. Biederman/Daniel Lezcano. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-05proc: fix proc_dir_entry refcountingAlexey Dobriyan
Creating PDEs with refcount 0 and "deleted" flag has problems (see below). Switch to usual scheme: * PDE is created with refcount 1 * every de_get does +1 * every de_put() and remove_proc_entry() do -1 * once refcount reaches 0, PDE is freed. This elegantly fixes at least two following races (both observed) without introducing new locks, without abusing old locks, without spreading lock_kernel(): 1) PDE leak remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_read(&de->count) == 0) if (atomic_dec_and_test(&de->count)) if (de->deleted) /* also not taken! */ free_proc_entry(de); else de->deleted = 1; [refcount=0, deleted=1] 2) use after free remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_dec_and_test(&de->count)) if (atomic_read(&de->count) == 0) free_proc_entry(de); /* boom! */ if (de->deleted) free_proc_entry(de); BUG: unable to handle kernel paging request at virtual address 6b6b6b6b printing eip: c10acdda *pdpt = 00000000338f8001 *pde = 0000000000000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 23161, comm: cat Not tainted (2.6.24-rc2-8c0863403f109a43d7000b4646da4818220d501f #4) EIP: 0060:[<c10acdda>] EFLAGS: 00210097 CPU: 1 EIP is at strnlen+0x6/0x18 EAX: 6b6b6b6b EBX: 6b6b6b6b ECX: 6b6b6b6b EDX: fffffffe ESI: c128fa3b EDI: f380bf34 EBP: ffffffff ESP: f380be44 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 23161, ti=f380b000 task=f38f2570 task.ti=f380b000) Stack: c10ac4f0 00000278 c12ce000 f43cd2a8 00000163 00000000 7da86067 00000400 c128fa20 00896b18 f38325a8 c128fe20 ffffffff 00000000 c11f291e 00000400 f75be300 c128fa20 f769c9a0 c10ac779 f380bf34 f7bfee70 c1018e6b f380bf34 Call Trace: [<c10ac4f0>] vsnprintf+0x2ad/0x49b [<c10ac779>] vscnprintf+0x14/0x1f [<c1018e6b>] vprintk+0xc5/0x2f9 [<c10379f1>] handle_fasteoi_irq+0x0/0xab [<c1004f44>] do_IRQ+0x9f/0xb7 [<c117db3b>] preempt_schedule_irq+0x3f/0x5b [<c100264e>] need_resched+0x1f/0x21 [<c10190ba>] printk+0x1b/0x1f [<c107c8ad>] de_put+0x3d/0x50 [<c107c8f8>] proc_delete_inode+0x38/0x41 [<c107c8c0>] proc_delete_inode+0x0/0x41 [<c1066298>] generic_delete_inode+0x5e/0xc6 [<c1065aa9>] iput+0x60/0x62 [<c1063c8e>] d_kill+0x2d/0x46 [<c1063fa9>] dput+0xdc/0xe4 [<c10571a1>] __fput+0xb0/0xcd [<c1054e49>] filp_close+0x48/0x4f [<c1055ee9>] sys_close+0x67/0xa5 [<c10026b6>] sysenter_past_esp+0x5f/0x85 ======================= Code: c9 74 0c f2 ae 74 05 bf 01 00 00 00 4f 89 fa 5f 89 d0 c3 85 c9 57 89 c7 89 d0 74 05 f2 ae 75 01 4f 89 f8 5f c3 89 c1 89 c8 eb 06 <80> 38 00 74 07 40 4a 83 fa ff 75 f4 29 c8 c3 90 90 90 57 83 c9 EIP: [<c10acdda>] strnlen+0x6/0x18 SS:ESP 0068:f380be44 Also, remove broken usage of ->deleted from reiserfs: if sget() succeeds, module is already pinned and remove_proc_entry() can't happen => nobody can mark PDE deleted. Dummy proc root in netns code is not marked with refcount 1. AFAICS, we never get it, it's just for proper /proc/net removal. I double checked CLONE_NETNS continues to work. Patch survives many hours of modprobe/rmmod/cat loops without new bugs which can be attributed to refcounting. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-02[NETNS]: Fix /proc/net breakageEric W. Biederman
Well I clearly goofed when I added the initial network namespace support for /proc/net. Currently things work but there are odd details visible to user space, even when we have a single network namespace. Since we do not cache proc_dir_entry dentries at the moment we can just modify ->lookup to return a different directory inode depending on the network namespace of the process looking at /proc/net, replacing the current technique of using a magic and fragile follow_link method. To accomplish that this patch: - introduces a shadow_proc method to allow different dentries to be returned from proc_lookup. - Removes the old /proc/net follow_link magic - Fixes a weakness in our not caching of proc generic dentries. As shadow_proc uses a task struct to decided which dentry to return we can go back later and fix the proc generic caching without modifying any code that uses the shadow_proc method. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-07[NET]: Kill proc_net_create()David S. Miller
There are no more users. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19pid namespaces: initialize the namespace's proc_mntPavel Emelyanov
The namespace's proc_mnt must be kern_mount-ed to make this pointer always valid, independently of whether the user space mounted the proc or not. This solves raced in proc_flush_task, etc. with the proc_mnt switching from NULL to not-NULL. The initialization is done after the init's pid is created and hashed to make proc_get_sb() finr it and get for root inode. Sice the namespace holds the vfsmnt, vfsmnt holds the superblock and the superblock holds the namespace we must explicitly break this circle to destroy all the stuff. This is done after the init of the namespace dies. Running a few steps forward - when init exits it will kill all its children, so no proc_mnt will be needed after its death. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: make proc have multiple superblocks - one for each namespacePavel Emelyanov
Each pid namespace have to be visible through its own proc mount. Thus we need to have per-namespace proc trees with their own superblocks. We cannot easily show different pid namespace via one global proc tree, since each pid refers to different tasks in different namespaces. E.g. pid 1 refers to the init task in the initial namespace and to some other task when seeing from another namespace. Moreover - pid, exisintg in one namespace may not exist in the other. This approach has one move advantage is that the tasks from the init namespace can see what tasks live in another namespace by reading entries from another proc tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: prepare proc_flust_task() to flush entries from multiple ↵Pavel Emelyanov
proc trees The first part is trivial - we just make the proc_flush_task() to operate on arbitrary vfsmount with arbitrary ids and pass the pid and global proc_mnt to it. The other change is more tricky: I moved the proc_flush_task() call in release_task() higher to address the following problem. When flushing task from many proc trees we need to know the set of ids (not just one pid) to find the dentries' names to flush. Thus we need to pass the task's pid to proc_flush_task() as struct pid is the only object that can provide all the pid numbers. But after __exit_signal() task has detached all his pids and this information is lost. This creates a tiny gap for proc_pid_lookup() to bring some dentries back to tree and keep them in hash (since pids are still alive before __exit_signal()) till the next shrink, but since proc_flush_task() does not provide a 100% guarantee that the dentries will be flushed, this is OK to do so. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Fix race when opening a proc file while a network namespace is exiting.Eric W. Biederman
The problem: proc_net files remember which network namespace the are against but do not remember hold a reference count (as that would pin the network namespace). So we currently have a small window where the reference count on a network namespace may be incremented when opening a /proc file when it has already gone to zero. To fix this introduce maybe_get_net and get_proc_net. maybe_get_net increments the network namespace reference count only if it is greater then zero, ensuring we don't increment a reference count after it has gone to zero. get_proc_net handles all of the magic to go from a proc inode to the network namespace instance and call maybe_get_net on it. PROC_NET the old accessor is removed so that we don't get confused and use the wrong helper function. Then I fix up the callers to use get_proc_net and handle the case case where get_proc_net returns NULL. In that case I return -ENXIO because effectively the network namespace has already gone away so the files we are trying to access don't exist anymore. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-11Remove unused struct proc_dir_entry::setAlexey Dobriyan
After /proc/sys rewrite it was left unused. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Fix rmmod/read/write races in /proc entriesAlexey Dobriyan
Fix following races: =========================================== 1. Write via ->write_proc sleeps in copy_from_user(). Module disappears meanwhile. Or, more generically, system call done on /proc file, method supplied by module is called, module dissapeares meanwhile. pde = create_proc_entry() if (!pde) return -ENOMEM; pde->write_proc = ... open write copy_from_user pde = create_proc_entry(); if (!pde) { remove_proc_entry(); return -ENOMEM; /* module unloaded */ } *boom* ========================================== 2. bogo-revoke aka proc_kill_inodes() remove_proc_entry vfs_read proc_kill_inodes [check ->f_op validness] [check ->f_op->read validness] [verify_area, security permissions checks] ->f_op = NULL; if (file->f_op->read) /* ->f_op dereference, boom */ NOTE, NOTE, NOTE: file_operations are proxied for regular files only. Let's see how this scheme behaves, then extend if needed for directories. Directories creators in /proc only set ->owner for them, so proxying for directories may be unneeded. NOTE, NOTE, NOTE: methods being proxied are ->llseek, ->read, ->write, ->poll, ->unlocked_ioctl, ->ioctl, ->compat_ioctl, ->open, ->release. If your in-tree module uses something else, yell on me. Full audit pending. [akpm@linux-foundation.org: build fix] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between proc_get_inode() and remove_proc_entry()Alexey Dobriyan
proc_lookup remove_proc_entry =========== ================= lock_kernel(); spin_lock(&proc_subdir_lock); [find PDE with refcount 0] spin_unlock(&proc_subdir_lock); spin_lock(&proc_subdir_lock); [find PDE with refcount 0] [check refcount and free PDE] spin_unlock(&proc_subdir_lock); proc_get_inode: de_get(de); /* boom */ Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07smaps: add clear_refs file to clear referenceDavid Rientjes
Adds /proc/pid/clear_refs. When any non-zero number is written to this file, pte_mkold() and ClearPageReferenced() is called for each pte and its corresponding page, respectively, in that task's VMAs. This file is only writable by the user who owns the task. It is now possible to measure _approximately_ how much memory a task is using by clearing the reference bits with echo 1 > /proc/pid/clear_refs and checking the reference count for each VMA from the /proc/pid/smaps output at a measured time interval. For example, to observe the approximate change in memory footprint for a task, write a script that clears the references (echo 1 > /proc/pid/clear_refs), sleeps, and then greps for Pgs_Referenced and extracts the size in kB. Add the sizes for each VMA together for the total referenced footprint. Moments later, repeat the process and observe the difference. For example, using an efficient Mozilla: accumulated time referenced memory ---------------- ----------------- 0 s 408 kB 1 s 408 kB 2 s 556 kB 3 s 1028 kB 4 s 872 kB 5 s 1956 kB 6 s 416 kB 7 s 1560 kB 8 s 2336 kB 9 s 1044 kB 10 s 416 kB This is a valuable tool to get an approximate measurement of the memory footprint for a task. Cc: Hugh Dickins <hugh@veritas.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> [akpm@linux-foundation.org: build fixes] [mpm@selenic.com: rename for_each_pmd] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: reimplement the sysctl proc supportEric W. Biederman
With this change the sysctl inodes can be cached and nothing needs to be done when removing a sysctl table. For a cost of 2K code we will save about 4K of static tables (when we remove de from ctl_table) and 70K in proc_dir_entries that we will not allocate, or about half that on a 32bit arch. The speed feels about the same, even though we can now cache the sysctl dentries :( We get the core advantage that we don't need to have a 1 to 1 mapping between ctl table entries and proc files. Making it possible to have /proc/sys vary depending on the namespace you are in. The currently merged namespaces don't have an issue here but the network namespace under /proc/sys/net needs to have different directories depending on which network adapters are visible. By simply being a cache different directories being visible depending on who you are is trivial to implement. [akpm@osdl.org: fix uninitialised var] [akpm@osdl.org: fix ARM build] [bunk@stusta.de: make things static] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
